【玄铁杯第三届RISC-V应用创新大赛】GPIOD库驱动LED灯
这篇测试下开发板使用GPIOD库驱动GPIO,使用LED指示灯显示GPIO状态。
一、安装部署GPIO库
按照官网的教程,安装部署GPIOD库
sudo apt install wget
wget https://git.kernel.org/pub/scm/libs/libgpiod/libgpiod.git/snapshot/libgpiod-2.0.tar.gz
tar zxvf libgpiod-2.0.tar.gz
cd libgpiod-2.0
sudo apt-get install build-essential pkg-config m4 automake autoconf libtool autoconf-archive
sudo apt install gcc g++
export CC=gcc
export CXX=g++
#部署库的相关文件到项目文件夹:--prefix后面的路径要换成自己项目所在的路径,方便后续操作
./autogen.sh --enable-tools=yes --prefix=/home/sipeed/mylib_local
make
sudo make install
二、硬件部分
2.1、底板原理图GPIO部分
2.2、官方文档GPIO部分
官网文档和原理图上的标号不一致,官网提示以文档的标注为准。
2.3、接口转接
使用设计的转接板 https://bbs.eeworld.com.cn/thread-1259074-1-1.html
三、测试代码
gpio.c
//#gpio.c
#include<stdio.h>
#include<unistd.h>
#include<gpiod.h>
#define PIN_IO1_3 3
#define PIN_IO1_4 4
#define PIN_IO1_5 5
#define PIN_IO1_6 6
int main()
struct gpiod_chip *gchip;
struct gpiod_line_info *glinein, *glineout;
struct gpiod_line_settings *gline_settings_in, *gline_settings_out;
struct gpiod_line_config *gline_config_in, *gline_config_out;
struct gpiod_request_config *gline_request_config_in, *gline_request_config_out;
struct gpiod_line_request *gline_request_in, *gline_request_out;
int offset_in[1] = {PIN_IO1_5};
int offset_out[3] = {PIN_IO1_3, PIN_IO1_4, PIN_IO1_6};
int value;
if ((gchip=gpiod_chip_open("/dev/gpiochip1")) == NULL)
perror("gpiod_chip_open");
return 1;
gline_settings_in = gpiod_line_settings_new();
if ((value=gpiod_line_settings_set_direction(gline_settings_in, GPIOD_LINE_DIRECTION_INPUT)) != 0)
perror("gpiod_line_settings_set_direction");
gline_config_in = gpiod_line_config_new();
value=gpiod_line_config_add_line_settings(gline_config_in, offset_in, 1, gline_settings_in);
gline_request_config_in = gpiod_request_config_new();
gline_request_in = gpiod_chip_request_lines(gchip, gline_request_config_in, gline_config_in);
gline_settings_out = gpiod_line_settings_new();
if (gpiod_line_settings_set_direction(gline_settings_out, GPIOD_LINE_DIRECTION_OUTPUT) != 0)
gline_config_out = gpiod_line_config_new();
gpiod_line_config_add_line_settings(gline_config_out, offset_out, 3, gline_settings_out);
gline_request_config_out = gpiod_request_config_new();
gline_request_out = gpiod_chip_request_lines(gchip, gline_request_config_out, gline_config_out);
value=gpiod_line_request_set_value(gline_request_out, PIN_IO1_3, 0);
value=gpiod_line_request_set_value(gline_request_out, PIN_IO1_4, 1);
value=gpiod_line_request_set_value(gline_request_out, PIN_IO1_6, 0);
//printf("IO1-3 = 1, IO1-4 = 0\n");
sleep(1);
for (int i = 0; i < 10; i++) {
value=gpiod_line_request_get_value(gline_request_in, PIN_IO1_5);
printf("IO1-5 = %d\n", value);
value=gpiod_line_request_set_value(gline_request_out, PIN_IO1_3, 1);
value=gpiod_line_request_set_value(gline_request_out, PIN_IO1_4, 0);
value=gpiod_line_request_set_value(gline_request_out, PIN_IO1_6, 1);
sleep(1);
sleep(1);
gpiod_chip_close(gchip);
return 0;
四、编译运行
4.1、编译代码
编译之前运行下面命令
export LD_LIBRARY_PATH=/home/sipeed/mylib_local/lib:$LD_LIBRARY_PATH
export PATH=/home/sipeed/mylib_local/bin:$PATH
sudo chmod o+rw /dev/gpiochip4
sudo chmod o+rw /dev/spidev2.0
执行编译命令
gcc -I/home/sipeed/mylib_local/include -L/home/sipeed/mylib_local/lib -o gpio gpio.c -lgpiod
运行程序
./gpio
4.2、程序运行
运行视频如下:
gpiod
