1480|3
441
【MSPM0L1306 LaunchPad】按键输入测试 [复制链接]
这篇测试下开发板按键输入,通过LED1和LED2绿色指示灯,来指示按键输入变化。
一、硬件电路
开发板上的两个按键分别使用了PA14和PA18端口。
按键的硬件电路图部分如下;
二、程序
2.1、key.c
#include "key/key.h"
#include "led/led.h"
void key_init(void)
	DL_GPIO_initDigitalInputFeatures(GPIO_SWITCHES_USER_SWITCH_2_IOMUX,
		 DL_GPIO_INVERSION_DISABLE, DL_GPIO_RESISTOR_PULL_UP,
		 DL_GPIO_HYSTERESIS_DISABLE, DL_GPIO_WAKEUP_DISABLE);
	DL_GPIO_initDigitalInputFeatures(GPIO_SWITCHES_USER_SWITCH_1_IOMUX,
		 DL_GPIO_INVERSION_DISABLE, DL_GPIO_RESISTOR_NONE,
uint8_t key_scan(uint8_t mode)
	static uint8_t key_up = 1;
	static uint8_t sw1_sta=0;
	static uint8_t sw2_sta=1;
	uint8_t keyval = 0;
	if(DL_GPIO_readPins(GPIO_SWITCHES_PORT, GPIO_SWITCHES_USER_SWITCH_1_PIN))
		sw1_sta=1;
	else
		sw1_sta=0;
	if(!DL_GPIO_readPins(GPIO_SWITCHES_PORT, GPIO_SWITCHES_USER_SWITCH_2_PIN))
		sw2_sta=1;
	else
		sw2_sta=0;
	if (mode) key_up = 1;
	if (key_up && ((sw2_sta == 1)||(sw1_sta == 1)))
			delay_cycles(32000*10);
			key_up = 0;
			if (sw1_sta == 1) keyval = SW1_PRES;
			if (sw2_sta == 1) keyval = SW2_PRES;
	else if ((sw1_sta==0) && (sw2_sta==0))
			key_up = 1;
	return keyval;
void key_test(void)
	uint8_t key;
	key = key_scan(0);
	if (key)
			switch (key)
					case SW1_PRES:
							led1_r_tog();
							break;
					case SW2_PRES:
							led2_g_tog();
							break;
2.2、key.h
#ifndef __KEY_H
#define __KEY_H
#include <ti/driverlib/driverlib.h>
#define GPIO_SWITCHES_PORT                                               (GPIOA)
#define GPIO_SWITCHES_USER_SWITCH_1_PIN                         (DL_GPIO_PIN_18)
#define GPIO_SWITCHES_USER_SWITCH_1_IOMUX                        (IOMUX_PINCM19)
#define GPIO_SWITCHES_USER_SWITCH_2_PIN                         (DL_GPIO_PIN_14)
#define GPIO_SWITCHES_USER_SWITCH_2_IOMUX                        (IOMUX_PINCM15)
#define SW1_PRES    1
#define SW2_PRES    2
void key_init(void);
uint8_t key_scan(uint8_t mode);
void key_test(void);
#endif
2.3、main.c
#include "ti_msp_dl_config.h"
#include "systick/systick.h"
#include "uart/uart.h"
int main(void)
	SYSCFG_DL_init();
	init_systick();
	init_led();
	init_uart(115200);
	key_init();
	printf("mspm0l1306 board test! \r\n");
	while (1)
		key_test();
三、运行结果
下载程序后,复位开发板运行
key
此帖出自MSPM0 MCU论坛
我试了一下按键,好象连击好严重,消抖有什么好方法。   详情 回复 发表于 2023-10-13 22:01
6998
展示了两个按键的输入,与GPIO的应用,很好!
此帖出自MSPM0 MCU论坛
6502
没直接把外部中断在这里一快测了啊
此帖出自MSPM0 MCU论坛
在爱好的道路上不断前进,在生活的迷雾中播撒光引
6998
此帖出自MSPM0 MCU论坛
