5176|14
63
NANDFLASH ECC校验出错~奇怪了~ [复制链接]
BSP中的FMD.CPP驱动怎么不一样呢?同样的ReadBlock(DWORD dwBlock, LPBYTE pbBlock, PSectorInfo pSectorInfoTable)当LPBYTE pbBlock不为空时,ECC校验就错了~~是不是驱动问题啊~~~
BOOL FMD_ReadSector(SECTOR_ADDR startSectorAddr, LPBYTE pSectorBuff, PSectorInfo pSectorInfoBuff, DWORD dwNumSectors)
    ULONG SectorAddr = (ULONG)startSectorAddr;
        ULONG MECC;
    if (!pSectorBuff && !pSectorInfoBuff)
        return(FALSE);
    BOOL bLastMode = SetKMode(TRUE);
    NF_nFCE_L();                        // Select the flash chip.
    NF_WAITRB();                                    // Wait for flash to complete command.
    NF_CMD(CMD_RESET);                                // Send reset command.
    while (dwNumSectors--)
        ULONG blockPage = (((SectorAddr / NAND_PAGE_CNT) * NAND_PAGE_CNT) | (SectorAddr % NAND_PAGE_CNT));
                if (!pSectorBuff)
            NF_CMD(CMD_READ2);                                    // Send read confirm command.
            NF_WAITRB();                                        // Wait for command to complete.
            NF_ADDR(0);                                            // Column = 0.
            NF_ADDR(blockPage         & 0xff);                    // Page address.
            NF_ADDR((blockPage >>  8) & 0xff);
                        if (NEED_EXT_ADDR)
                    NF_ADDR((blockPage >> 16) & 0xff);
            RdPageInfo((PBYTE)pSectorInfoBuff);                    // Read page/sector information.
            pSectorInfoBuff++;
                else
            NF_CMD(CMD_READ);                                    // Send read command.
                        if (NEED_EXT_ADDR)
            //  Handle unaligned buffer pointer
                       NF_RSTECC();
                NF_MECC_UnLock();
            if( ((DWORD) pSectorBuff) & 0x3)
                RdPage512Unalign (pSectorBuff);
            else
                RdPage512(pSectorBuff);                        // Read page/sector data.
                NF_MECC_Lock();
                        if (pSectorInfoBuff)
                pSectorInfoBuff ++;
                        else
                BYTE TempInfo[8];
                                RdPageInfo(TempInfo);                                           // Read page/sector information.
                        MECC  = NF_RDDATA() << 0;
                        MECC |= NF_RDDATA() << 8;
                        MECC |= NF_RDDATA() << 16;
                        MECC |= NF_RDDATA() << 24;
                        NF_WRMECCD0( ((MECC&0xff00)<<8)|(MECC&0xff) );
                         NF_WRMECCD1( ((MECC&0xff000000)>>8)|((MECC&0xff0000)>>16) );
                         if (NF_RDESTST0 & 0x3)
                            RETAILMSG(1,(TEXT("ecc error %x %x \r\n"),NF_RDMECC0(),MECC));
                            NF_nFCE_H();                            // Deselect the flash chip.
                            SetKMode (bLastMode);
                                 return FALSE;
                pSectorBuff += NAND_PAGE_SIZE;
        ++SectorAddr;
    return(TRUE);
S6dAvmT2sRr 顶啊顶啊 doS8WKKPmkO TnLWt8tfry7 顶起来!  详情 回复 发表于 2010-4-22 14:19
NFESTAT0 0x4E000024 NAND flash ECC status for I/O[7:0]
NFESTAT1 0x4E000028 NAND flash ECC status for I/O[15:8]
NF_RDESTST0 这个与0x3与 肯定非0啊~
87
ECC.....唉,痛苦啊!
引用 1 楼 lightsoure 的回复:
NF_RDESTST0这个参数干什么的?它的低两位有什么说法没有?
如果它的低两位是0的话,if (NF_RDESTST0 & 0x3)就不会成立的。
79
------pbBlock不为空就要读数据了,读数据就要ECC了
58
#define NF_WRMECCD0(data)                        {s2440NAND->NFMECCD0 = (data);}
#define NF_WRMECCD1(data)                        {s2440NAND->NFMECCD1 = (data);}
#define NF_WRSECCD(data)                        {s2440NAND->NFSECCD = (data);}
#define NF_RDESTST0                                (s2440NAND->NFESTAT0)
#define NF_RDESTST1                                (s2440NAND->NFESTAT1)
NF_RDESTST0这个是ECC状态位  我的NAND是64M 的小页  这里是16位校验
我这里是读NAND的时候 ECC校验。。。出错了~因为我在写NAND的时候没有用到ECC校验
所以我想用这个方法来解决:就在仅仅做这个读NAND的时候不ECC校验,怎么做呢?我先读出NF_RDESTST0 这个值,如果是这个值 我就不做ECC校验。。当读出的NF_RDESTST0不是我定义的设定好的值,就做ECC校验,这样以后别人读NAND的时候还是可以用ECC校验的
我想要确认的是NF_RDESTST0这个值 应该会根据我WRITE NAND的不同变化的吧~如果是那么我想上面方法是可以的。
NAND读写还是要做校验的,否则读出来的数据可能是错的,影响程序的执行。
引用 6 楼 veabol 的回复:
恩,理解,所以我想就仅仅做这1个读的时候,不做ECC可以吗?我加个判断~判断下是不是我不做ECC校验的读。。这个应该可以的吧
譬如说 我可以根据:Spare:ff ff ff ff 00 00 00 00 ff ff ff f0 00 00 00 00
这个值来定 要不要ECC
解决
2种方法:
1,在写NAND的时候FMD_WriteSector进行ECC检验,这样读的时候再写时候根据得到的数据检验就过了
2,先读出要读的NF_RDESTST0的值,加个判断。。。。。。。。不过这样觉得不妥。。呵呵
选了前者
78
引用 9 楼 lightsoure 的回复:
写的时候截获然后先保存到RAM中?读的时候不从NAND中读出来?
98
你这个是什么nand呀?
81
引用 10 楼 veabol 的回复:
我这个是1208 NAND 64M  小页
我的理解是ECC校验会对512字节产生校验码,然后在写的时候,把他存在每个PAGE外带的16字节的setor spare中去,然后再读NAND的时候,先把512字节数据读出来,
                pSectorInfoBuff ++;
                        else
                BYTE TempInfo[8];
然后经过处理,
这个值NF_RDESTST0(ECC校验状态位低8位)与0X3比较  判断
Spare:ff ff ff ff 00 00 00 00 ff ff ff f0 00 00 00 00  这个就是我用工具烧录NAND数据后,从NAND PAGE中读到的信息
S6dAvmT2sRr
顶啊顶啊
doS8WKKPmkO
TnLWt8tfry7
顶起来!
