552|1
【得捷电子Follow me第2期】5,显示天气 [复制链接]
显示天气,首先是连接WIFI然后从天气网站获取JOSON码,再然后是解析JOSON码,再以后是显示。
需要注意的是,显示时那个字体,应用:
而我用
显示:NameEorror:font not defined
程序如下:
  • ## 连接wifi --------------------------------------------------------------------------------------
  • import os
  • import wifi
  • for network in wifi.radio.start_scanning_networks():
  • print("\t%s\t\tRSSI: %d\tChannel: %d" % (str(network.ssid, "utf-8"),
  • network.rssi, network.channel))
  • wifi.radio.stop_scanning_networks()
  • print(f"Connecting to {os.getenv('WIFI_SSID')}")
  • wifi.radio.connect('TPLINK555', '12345678')
  • print(f"Connected to {os.getenv('WIFI_SSID')}")
  • print(f"My IP address: {wifi.radio.ipv4_address}")
  • ## END连接wifi --------------------------------------------------------------------------------------
  • ## 访问网络 --------------------------------------------------------------------------------------
  • import ssl
  • import socketpool
  • import adafruit_requests
  • # 请求获取JSON
  • JSON_TIME_URL = "http://t.weather.sojson.com/api/weather/city/101070601"
  • pool = socketpool.SocketPool(wifi.radio)
  • requests = adafruit_requests.Session(pool, ssl.create_default_context())
  • ## END访问网络 --------------------------------------------------------------------------------------
  • ## 读取解析Json ---------------------------------------------------------------------------------------
  • print(f"Fetching and parsing json from {JSON_TIME_URL}")
  • response = requests.get(JSON_TIME_URL)
  • print("-" * 40)
  • ## print(f"Time: {response.json()['sysTime2']}")
  • print("-" * 40)
  • print(response.json())
  • weather = response.json()
  • cityInfo = weather['cityInfo']
  • city_weather = weather['data']
  • forecast = city_weather['forecast']
  • dis_str = ""+cityInfo['parent']+' '+cityInfo['city'] +' '+weather['time'][:11] + forecast[0]['week']
  • dis_str += '\n 空气质量:'+city_weather['quality'] +" " +forecast[0]['type']
  • dis_str += "\n 最"+forecast[0]['high']+' 最'+forecast[0]['low']
  • dis_str += "\n 湿度: "+city_weather['shidu']+' pm2.5:'+str(city_weather['pm25']) +' pm10:'+str(city_weather['pm10'])
  • dis_str += "\n 注意!! "+forecast[0]['notice']
  • ## END读取解析Json ---------------------------------------------------------------------------------------
  • ## 显示天气信息 ---------------------------------------------------
  • import board
  • import displayio
  • from adafruit_display_text import label, wrap_text_to_lines
  • from adafruit_bitmap_font import bitmap_font
  • display = board.DISPLAY
  • board.DISPLAY.brightness = 0.9
  • board.DISPLAY.rotation = 0
  • font = bitmap_font.load_font("wenquanyi_10pt.pcf")
  • ## 字体颜色
  • color = 0x9499CA
  • text_group = displayio.Group()
  • text_area = label.Label(font, text=dis_str, color=color)
  • text_area.x = 0
  • text_area.y = 10
  • text_area.line_spacing = 0.8
  • text_area.scale = 1
  • text_group.append(text_area)
  • display.show(text_group)
  • ## END显示天气信息 ---------------------------------------------------
  • while True:
  • pass
运行效果:
看来显示时那个字体可能更是重点了,,,   详情 回复 发表于 2023-10-4 10:13
7024
看来显示时那个字体可能更是重点了,,,
有奖直播 | AI之眼——安森美图像传感器 报名中
直播主题:AI之眼——安森美图像传感器
报名观看直播、直播间提问、填写问卷均有机会获得精美礼品!
