1244|2
452
【STM32F723 Discovery Kit】运行chibios系统 [复制链接]
看到网上有个chibios系统,支持STM32开发板,发现没有支持STM32F723这个型号,下面移植到这款开发板上运行。
一、chibios系统下载
下载地址:http://www.chibios.org/dokuwiki/doku.php
chibios有几种产品分类,我这里下开发工具chibistudio软件
使用windows环境,下载相应的版本
软件使用手册:https://www.playembedded.org/blog/category/articles/chibios/how-tos/
下载的软件包使用7Z软件解压到C盘
点击快捷方式,直接运行软件
复制已有的STM32开发板,创建STM32F723板
二、程序
2.1、修改硬件端口
修改LED灯,按键输入端口
修改调试串口端口
其他端口未调试,没有修改。
2.2、main.c
#include "ch.h"
#include "hal.h"
#include "rt_test_root.h"
#include "oslib_test_root.h"
 * This is a periodic thread that does absolutely nothing except flashing
 * a LED.
static THD_WORKING_AREA(waThread1, 128);
static THD_FUNCTION(Thread1, arg) {
  (void)arg;
  chRegSetThreadName("blinker");
  while (true) {
    palSetLine(LINE_LED5);
    chThdSleepMilliseconds(100);
    palClearLine(LINE_LED5);
    palSetLine(LINE_LED6);
    palClearLine(LINE_LED6);
 * Application entry point.
int main(void) {
   * System initializations.
   * - HAL initialization, this also initializes the configured device drivers
   *   and performs the board-specific initializations.
   * - Kernel initialization, the main() function becomes a thread and the
   *   RTOS is active.
  halInit();
  chSysInit();
   * ARD_D13 is programmed as output (board LED).
  palSetLineMode(LINE_LED6, PAL_MODE_OUTPUT_PUSHPULL);
   * Activates the serial driver 1 using the driver default configuration.
  sdStart(&SD6, NULL);
   * Creates the example thread.
  chThdCreateStatic(waThread1, sizeof(waThread1), NORMALPRIO+1, Thread1, NULL);
   * Normal main() thread activity, in this demo it does nothing except
   * sleeping in a loop and check the button state.
  while (true) {
    if (palReadLine(LINE_BUTTON_USER)) {
      test_execute((BaseSequentialStream *)&SD6, &rt_test_suite);
      test_execute((BaseSequentialStream *)&SD6, &oslib_test_suite);
    chThdSleepMilliseconds(500);
三、程序运行
将编译生成的ch.hex文件下载到开发板运行
按下B1按键,串口输出,运行视频如下:
chibios
此帖出自stm32/stm8论坛
chibios系统能支持STM32开发板,最后楼主感觉测试的如何   详情 回复 发表于 2023-9-27 07:23
6931
此帖出自stm32/stm8论坛
觉得编译环境不是很好用 ,资料有点少,其它驱动还没有试过,再测试测试。  详情 回复 发表于 2023-9-27 08:48
452
Jacktang 发表于 2023-9-27 07:23 chibios系统能支持STM32开发板,最后楼主感觉测试的如何
此帖出自stm32/stm8论坛
