657|2
115
任务5:通过网络控制WS2812B| 【调色板控彩灯】 [复制链接]
#准备工作
硬件
  • ESP32-S3 TFT Feather开发板一块
##HTTP Web Server
#代码分析
##库
  • 通过Web Server控制WS2812B需要导入adafruit_httpserver的lib文件
  1. from time import monotonic
  2. import board
  3. import microcontroller
  4. import neopixel
  5. import socketpool
  6. import wifi
  7. from adafruit_httpserver import Server, Request, Response, Websocket, GET
##Server
  • 创建套接字,Http Server以及neopixel
  1. pool = socketpool.SocketPool(wifi.radio)
  2. server = Server(pool, debug=True)
  3. pixel = neopixel.NeoPixel(board.NEOPIXEL, 1)
  4. websocket: Websocket = None
  5. next_message_time = monotonic()
HTML
  • 在http GET请求,返回html页面,其中重点部分是颜色拾取器,进行颜色的选择,然后用于设定LED的颜色。
  1. HTML_TEMPLATE = """
  2. <html lang="en">
  3. <head>
  4. <title>Websocket Client</title>
  5. </head>
  6. <body>
  7. <p>CPU temperature: <strong>-</strong>°C</p>
  8. <p>NeoPixel Color: <input type="color"></p>
  9. <script>
  10. const cpuTemp = document.querySelector('strong');
  11. const colorPicker = document.querySelector('input[type="color"]');
  12. let ws = new WebSocket('ws://' + location.host + '/connect-websocket');
  13. ws.onopen = () => console.log('WebSocket connection opened');
  14. ws.onclose = () => console.log('WebSocket connection closed');
  15. ws.onmessage = event => cpuTemp.textContent = event.data;
  16. ws.onerror = error => cpuTemp.textContent = error;
  17. colorPicker.oninput = debounce(() => ws.send(colorPicker.value), 200);
  18. function debounce(callback, delay = 1000) {
  19. let timeout
  20. return (...args) => {
  21. clearTimeout(timeout)
  22. timeout = setTimeout(() => {
  23. callback(...args)
  24. }, delay)
  25. }
  26. }
  27. </script>
  28. </body>
  29. </html>
  30. """
##响应
  • 针对HTTP页面响应,处理浏览器下发的操作。
  1. @server.route("/client", GET)
  2. def client(request: Request):
  3. return Response(request, HTML_TEMPLATE, content_type="text/html")
  4. @server.route("/connect-websocket", GET)
  5. def connect_client(request: Request):
  6. global websocket # pylint: disable=global-statement
  7. if websocket is not None:
  8. websocket.close() # Close any existing connection
  9. websocket = Websocket(request)
  10. return websocket
  11. server.start(str(wifi.radio.ipv4_address))
  12. while True:
  13. server.poll()
  14. # Check for incoming messages from client
  15. if websocket is not None:
  16. if (data := websocket.receive(True)) is not None:
  17. r, g, b = int(data[1:3], 16), int(data[3:5], 16), int(data[5:7], 16)
  18. pixel.fill((r, g, b))
  19. # Send a message every second
  20. if websocket is not None and next_message_time < monotonic():
  21. cpu_temp = round(microcontroller.cpu.temperature, 2)
  22. websocket.send_message(str(cpu_temp))
  23. next_message_time = monotonic() + 1
##综合源码
webserver_led_rgb.py
(2.68 KB, 下载次数: 1)
#调试
#演示
  • 根据调试log窗口可知,ESP32连接WiFi路由器获得192.168.0.100的IP,然后将连入相同路由的手机浏览器输入“192.168.0.100/client”,此时,浏览器将出现html页面,分别包含CPU的温度以及LED的颜色可配置,点击颜色设置,即可调色板载Neopixel的RGB LED灯。
    播放器加载失败: 未检测到Flash Player,请到安装
    webserver_ledrgb
调试板控彩灯 [attach]733213[/attach]     详情 回复 发表于 2023-9-17 20:53
6909
调试板控彩灯
“广普” 4这样的啦!。。。哈哈  详情 回复 发表于 2023-9-18 08:34
115
“广普” 4这样的啦!。。。哈哈
直播时间:3月12日(周三)上午10:00
直播奖励:多功能榨汁机、蓝牙音箱、手机支架
