3440|2
ExFreePool产生蓝屏 [复制链接]
大致代码如下:
一个链表结构,
  1. typedef struct _P
  2. {
  3.         ULONG Addr;
  4.         int ID;
  5.         UCHAR N[16];
  6.         struct _P *link;
  7. }P, *PP;
复制代码
驱动中全局变量:
  1. PP head = NULL;
  2. PP pi = NULL;
复制代码
在DispatchIoctl函数中,处理IOCTL时,
  1. case IOCTL_TEST:
  2. {
  3.   PP q;
  4.   ...
  5.   if(head == NULL)
  6.   {
  7.     head = (PP)ExAllocatePool(NonPagedPool,sizeof(PP));
  8.     if(head == NULL)
  9.         status = STATUS_INSUFFICIENT_RESOURCES;
  10.     head->Addr = 0x0;
  11.   }
  12.   if(head->Addr == 0x0)
  13.   {
  14.     head->Addr = 1;
  15.     pi = head;
  16.   }
  17.   status = A();
  18.   if(!NT_SUCCESS(status))
  19.     break;
  20.   if(head == NULL)
  21.   {
  22.     status = STATUS_SUCCESS;
  23.     break;
  24.   }
  25.   for(pi = head; pi; pi = pi->link)
  26.   {
  27.     ...          //填充P结构的其他域
  28.     ...   //拷贝结果到buffer中
  29.   }
  30.   //free the link list
  31.   pi = head;
  32.   q = pi->link;
  33.   while(q != NULL)
  34.   {
  35.     ExFreePool(pi);                ------------------> 使用Windbg单步到此处,继续执行变产生蓝屏,BAD_POOL_HEADER, Parameter 1为0x20
  36.     pi = q;
  37.     q = pi->link;
  38.   }
  39.   ExFreePool(pi);
  40.
  41.   status = STATUS_SUCCESS;
  42.   break;
  43. }
复制代码
其中函数A大概如下,
  1. NTSTATUS A()
  2. {
  3.   ...
  4.   status = RecordInfo(object);
  5.   ...
  6. }
复制代码
函数RecordInfo如下:
  1. NTSTATUS RecordInfo(ULONG ob)
  2. {
  3.         PP r;
  4.         NTSTATUS status;
  5.         r = (PP)ExAllocatePool(NonPagedPool,sizeof(PP));
  6.         if(r == NULL)
  7.                 status = STATUS_INSUFFICIENT_RESOURCES;
  8.         pi->link = r;
  9.         r->Addr = ob;
  10.         r->link = NULL;
  11.         pi = r;
  12.         status = STATUS_SUCCESS;
  13.         return status;
  14. }
复制代码
请问该怎么解决这个问题?
狂晕哦…… 结贴  详情 回复 发表于 2008-3-12 15:24
79
ExAllocatePool的sizeof(PP)改为sizeof(P)。
38
狂晕哦……
结贴
