【STM32WBA52CG】+5 THREADX使用
【NUCLEO-WBA52CG】+1开箱贴
【STM32WBA52CG】+2 STM32WBA Web Bluetooth试玩
【STM32WBA52CG】+3 STM32WBA 外设应用一 按键和点灯
【STM32WBA52CG】+4 外设应用二 串口使用之后继续
据说THREADX很不错,而且STM32免费使用,就拿STM32WBA52CG实验一下。
下载STM32Cube_FW_WBA_V1.1.0解压,例子在..\STM32Cube_FW_WBA_V1.1.0\Projects\NUCLEO-WBA52CG\Applications\ThreadX\Tx_Thread_MsgQueue
,用MDK打开。
项目如下所示,main.c负责硬件的初始化和ThreadX的初始化,MX_ThreadX_Init调用app_threadx.c的 MX_ThreadX_Init (里面调用tx_kernel_enter())。
接着程序会运行App_ThreadX_Init(VOID *memory_ptr)函数。
这里可以创建 任务和消息:
发送任务1入口函数中处理按键1和按键 2并发送消息到消息队列1:
发送任务2入口函数中处理按键3并发送消息到消息队列2:
接收任务接收到消息 并启动 相应的led闪烁
主要代码如下:
UINT App_ThreadX_Init(VOID *memory_ptr)
UINT ret = TX_SUCCESS;
TX_BYTE_POOL *byte_pool = (TX_BYTE_POOL*)memory_ptr;
CHAR *pointer;
/* Allocate the stack for Message Queue Sender Thread One */
if (tx_byte_allocate(byte_pool, (VOID**) &pointer, TX_APP_STACK_SIZE, TX_NO_WAIT) !=
TX_SUCCESS){ return TX_POOL_ERROR;}
/* Create Message Queue Sender Thread One. */
if (tx_thread_create(&tx_app_thread, "Message Queue Sender Thread One",
MsgSenderThreadOne_Entry, 0, pointer,TX_APP_STACK_SIZE, TX_APP_THREAD_PRIO,
TX_APP_THREAD_PREEMPTION_THRESHOLD,TX_APP_THREAD_TIME_SLICE, TX_APP_THREAD_AUTO_START) !=
TX_SUCCESS){ return TX_THREAD_ERROR;}
/* Allocate the stack for Message Queue One. */
if (tx_byte_allocate(byte_pool, (VOID **) &pointer, TX_APP_MSG_QUEUE_FULL_SIZE * sizeof(ULONG),
TX_NO_WAIT) != TX_SUCCESS){ return TX_POOL_ERROR;}
/* Create Message Queue One. */
if (tx_queue_create(&tx_app_msg_queue,"Message Queue One", TX_APP_SINGLE_MSG_SIZE,pointer,
TX_APP_MSG_QUEUE_FULL_SIZE * sizeof(ULONG)) != TX_SUCCESS){return TX_QUEUE_ERROR; }
/* USER CODE BEGIN App_ThreadX_Init */
/* Allocate the stack for MsgSenderThreadTwo. */
if (tx_byte_allocate(byte_pool, (VOID **) &pointer, TX_APP_STACK_SIZE, TX_NO_WAIT) !=
TX_SUCCESS){ ret = TX_POOL_ERROR;}
/* Create MsgSenderThreadTwo. */
if (tx_thread_create(&MsgSenderThreadTwo, "Message Queue Sender Thread Two",
MsgSenderThreadTwo_Entry, 0, pointer, TX_APP_STACK_SIZE,TX_APP_THREAD_PRIO,
TX_APP_THREAD_PREEMPTION_THRESHOLD,TX_NO_TIME_SLICE, TX_AUTO_START) != TX_SUCCESS)
{ ret = TX_THREAD_ERROR;}
/* Allocate the stack for MsgReceiverThread. */
TX_SUCCESS){ ret = TX_POOL_ERROR; }
/* Create MsgReceiverThread. */
if (tx_thread_create(&MsgReceiverThread, "Message Queue Receiver Thread",
MsgReceiverThread_Entry, 0, pointer, TX_APP_STACK_SIZE,
RECEIVER_THREAD_PRIO, RECEIVER_THREAD_PREEMPTION_THRESHOLD,
TX_NO_TIME_SLICE, TX_AUTO_START) != TX_SUCCESS){ ret = TX_THREAD_ERROR;}
/* Allocate the MsgQueueTwo. */
if (tx_byte_allocate(byte_pool, (VOID **) &pointer, TX_APP_MSG_QUEUE_FULL_SIZE *sizeof(ULONG),
TX_NO_WAIT) != TX_SUCCESS){ ret = TX_POOL_ERROR; }
/* Create the MsgQueueTwo shared by MsgSenderThreadTwo and MsgReceiverThread. */
if (tx_queue_create(&MsgQueueTwo, "Message Queue Two", TX_1_ULONG, pointer,
TX_APP_MSG_QUEUE_FULL_SIZE *sizeof(ULONG)) != TX_SUCCESS){ ret = TX_QUEUE_ERROR;}
/* USER CODE END App_ThreadX_Init */
return ret;
void MsgSenderThreadOne_Entry(ULONG thread_input)
/* USER CODE BEGIN MsgSenderThreadOne_Entry */
ULONG Msg = TOGGLE_LED;
ULONG Msg2 = TOGGLE_LED2;
(void) thread_input;
/* Infinite loop */
while(1)
HAL_GPIO_TogglePin(LED1_GPIO_Port, LED1_Pin);
GPIO_PinState B1Status = HAL_GPIO_ReadPin(B1_GPIO_Port, B1_Pin);
if(B1Status ==GPIO_PIN_RESET)
/* Send message to MsgQueueOne. */
if (tx_queue_send(&tx_app_msg_queue, &Msg, TX_WAIT_FOREVER) != TX_SUCCESS)
Error_Handler();
GPIO_PinState B2Status = HAL_GPIO_ReadPin(B2_GPIO_Port, B2_Pin);
if(B2Status ==GPIO_PIN_RESET)
if (tx_queue_send(&tx_app_msg_queue, &Msg2, TX_WAIT_FOREVER) != TX_SUCCESS)
Error_Handler();
/* Sleep for 200ms */
tx_thread_sleep(20);
/* USER CODE END MsgSenderThreadOne_Entry */
void MsgSenderThreadTwo_Entry(ULONG thread_input)
/* Infinite loop */
while(1)
GPIO_PinState B3Status = HAL_GPIO_ReadPin(B3_GPIO_Port, B3_Pin);
if(B3Status ==GPIO_PIN_RESET)
/* Send message to MsgQueueTwo. */
if (tx_queue_send(&MsgQueueTwo, &Msg, TX_WAIT_FOREVER) != TX_SUCCESS)
Error_Handler();
/* Sleep for 500s */
void MsgReceiverThread_Entry(ULONG thread_input)
ULONG RMsg = 0;
UINT status = 0 ;
/* Infinite loop */
while (1)
/* Determine whether a message MsgQueueOne or MsgQueueTwo is available */
status = tx_queue_receive(&tx_app_msg_queue, &RMsg, TX_NO_WAIT);
if (status == TX_SUCCESS)
/* Check Message value */
if (RMsg == TOGGLE_LED)
HAL_GPIO_TogglePin(LED2_GPIO_Port, LED2_Pin);
else
if (RMsg == TOGGLE_LED2)
HAL_GPIO_TogglePin(LED3_GPIO_Port, LED3_Pin);
else
Error_Handler();
else
status = tx_queue_receive(&MsgQueueTwo, &RMsg, TX_NO_WAIT);
if ( status == TX_SUCCESS)
if (RMsg != TOGGLE_LED)
Error_Handler();
else
实验结果:
谢谢
