1069|2
【瑞萨RA4E1评估板】输入捕获中断的使用-按键捕获 [复制链接]
前段时间忙成狗了,公司新的板子到了,调的飞起,现在调的差不多了开始补测评
下面是在上几篇的基础上
新建输入捕获中断
中断配置如下
io配置如下
代码实现
#include "hal_data.h"
#include <stdio.h>
#include <string.h>
#include <stdarg.h>
#include "common_data.h"
FSP_CPP_HEADER
void R_BSP_WarmStart(bsp_warm_start_event_t event);
FSP_CPP_FOOTER
int cmd_get_char(char *ch);
void LedBlink(uint16_t call_period);
void myprintf(const void *format, ...);
char cmd;
volatile bool switch1 = false;
#define DELAY_TIME (5)
 * main() is generated by the RA Configuration editor and is used to generate threads if an RTOS is used.  This function
 * is called by main() when no RTOS is used.
void hal_entry(void)
    /* TODO: add your own code here */
    fsp_err_t err = FSP_SUCCESS;
#if BSP_TZ_SECURE_BUILD
    /* Enter non-secure code */
    R_BSP_NonSecureEnter();
#endif
    /* Open the transfer instance with initial configuration. */
    err = R_SCI_UART_Open(&g_uart0_ctrl, &g_uart0_cfg);
    err = R_ICU_ExternalIrqOpen(&g_external_irq0_ctrl, &g_external_irq0_cfg);
    err = R_ICU_ExternalIrqEnable(&g_external_irq0_ctrl);
    //err = R_ICU_ExternalIrqClose(&g_external_irq0_ctrl);
    assert(FSP_SUCCESS == err);
    for (;;)
        if (switch1)
            myprintf("switch\r\n");
            switch1 = false;
            LedBlink(1000);
        // LedBlink(DELAY_TIME);
        R_BSP_SoftwareDelay(DELAY_TIME, BSP_DELAY_UNITS_MILLISECONDS);
 * @brief 灯闪烁
 * @param call_period 调用周期
#define LEN_OPEN_TIME (1000)
#define LEN_CLOSE_TIME (2000)
    static uint16_t sys_time = 0;
    sys_time += call_period;
    if (sys_time >= LEN_CLOSE_TIME)
        sys_time = 0;
        R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_07, BSP_IO_LEVEL_HIGH);
        R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_08, BSP_IO_LEVEL_LOW);
    else if (sys_time >= LEN_OPEN_TIME)
        R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_07, BSP_IO_LEVEL_LOW);
        R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_08, BSP_IO_LEVEL_HIGH);
 * This function is called at various points during the startup process.  This implementation uses the event that is
 * called right before main() to set up the pins.
 * @param[in]  event    Where at in the start up process the code is currently at
    if (BSP_WARM_START_RESET == event)
#if BSP_FEATURE_FLASH_LP_VERSION != 0
        /* Enable reading from data flash. */
        R_FACI_LP->DFLCTL = 1U;
        /* Would normally have to wait tDSTOP(6us) for data flash recovery. Placing the enable here, before clock and
         * C runtime initialization, should negate the need for a delay since the initialization will typically take more than 6us. */
#endif
    if (BSP_WARM_START_POST_C == event)
        /* C runtime environment and system clocks are setup. */
        /* Configure pins. */
        R_IOPORT_Open(&g_ioport_ctrl, g_ioport.p_cfg);
FSP_CPP_HEADER
BSP_CMSE_NONSECURE_ENTRY void template_nonsecure_callable();
/* Trustzone Secure Projects require at least one nonsecure callable function in order to build (Remove this if it is not required to build). */
FSP_CPP_FOOTER
#endif
#define RING_LEN (255)
char rx_buff[RING_LEN] = {0};
volatile int twrite = 0;
int tread = 0;
 * @brief 串口数据回调函数
 * @param p_args
void xcmd_callback(uart_callback_args_t *p_args)
    if (p_args->event == UART_EVENT_RX_CHAR)
        rx_buff[twrite] = (char)(p_args->data);
        twrite++;
        if (twrite >= RING_LEN)
            twrite = 0;
 * @brief 从循环buf中获取一个字节
 * @param ch 输出的字节
 * @return int 0:未读到数据,1:读到数据
    if (tread != twrite)
        *ch = rx_buff[tread];
        tread++;
        if(tread >= RING_LEN)
            tread = 0;
        return 1;
    return 0;
#define CMD_LEN_MAX (1024)
char buff[CMD_LEN_MAX];
 * @brief 打印数据
 * @param format 格式
 * @param ...
    int len = 0;
    va_list list;
    va_start(list, format);
    len = vsnprintf(buff, CMD_LEN_MAX, format, list);
    va_end(list);
    if (len > 0)
        R_SCI_UART_Write(&g_uart0_ctrl, (const uint8_t* const) buff, (uint32_t)len);
 * @brief 按键回调函数
 * @param p_args
void switchCallBack(external_irq_callback_args_t *p_args)
    if(1 == p_args->channel) // 中断通道为1
        switch1 = true;
程序思路就是
接收中断->置个标志->主循环中不断访问这个标志,然后交替闪灯
    err = R_ICU_ExternalIrqOpen(&g_external_irq0_ctrl, &g_external_irq0_cfg);     err = R_ICU_ExternalIrqEnable(&g_external_irq0_ctrl);   void switchCallBack(external_irq_callback_args_t *p_args) {     if(1 == p_args->channel) // 中断通道为1     {         switch1 = true;     } } 核心的代码是这几行吧,RA的清中断标志,不知道是在哪里搞好的。     详情 回复 发表于 2023-8-8 07:46
6815
测试的思路比较清晰,值得学学习
6998
        switch1 = true;
