1104|2
7044
【CW32L052测评】 纯手工移植rt-thread nano [复制链接]
  1. 准备cw32l083 printf的工程包一个。
  2. 准备RTthread nano工程源码。(可以复制一份mdk下的源码)也可以去官网下载一份:
  1.  在官方的固件库下面新建RT_Thread文件夹,用于存放rtt的源码:
  1. 拷贝源码下的 include、libcpu、src到RT_Threa文件夹下面
5. libcpu文件夹只保留arm/cortexm0这个文件夹,其他的都删除,包括riscv文件夹。
6. 打开example的下面的UART_Printf工程:
 7.  在分组中新建rtt/src分组,把RT_Thread/src下面的文件全部添加进来
8、新建rtt/libcpu把\RT_Thread\libcpu\arm\cortex-m0下面的cpuport.c\context_rvds.S添回进来。
9、添加头文件路径  \RT_Thread\include到工程中:
10、在user下面新建board.c,并把他加入到user组里面:内容如下:
 * Copyright (c) 2006-2019, RT-Thread Development Team
 * SPDX-License-Identifier: Apache-2.0
 * Change Logs:
 * Date           Author       Notes
 * 2021-05-24                  the first version
#include <rthw.h>
#include <rtthread.h>
#include "main.h"
#if defined(RT_USING_USER_MAIN) && defined(RT_USING_HEAP)
 * Please modify RT_HEAP_SIZE if you enable RT_USING_HEAP
 * the RT_HEAP_SIZE max value = (sram size - ZI size), 1024 means 1024 bytes
#define RT_HEAP_SIZE (2*1024)
static rt_uint8_t rt_heap[RT_HEAP_SIZE];
RT_WEAK void *rt_heap_begin_get(void)
    return rt_heap;
RT_WEAK void *rt_heap_end_get(void)
    return rt_heap + RT_HEAP_SIZE;
#endif
void rt_os_tick_callback(void)
    rt_interrupt_enter();
    rt_tick_increase();
    rt_interrupt_leave();
void SysTick_Handler(void)
	rt_os_tick_callback();
 * This function will initial your board.
void rt_hw_board_init(void)
	SysTick_Config(SystemCoreClock/1000);
//#error "TODO 1: OS Tick Configuration."
     * TODO 1: OS Tick Configuration
     * Enable the hardware timer and call the rt_os_tick_callback function
     * periodically with the frequency RT_TICK_PER_SECOND.
    /* Call components board initial (use INIT_BOARD_EXPORT()) */
#ifdef RT_USING_COMPONENTS_INIT
    rt_components_board_init();
#endif
    rt_system_heap_init(rt_heap_begin_get(), rt_heap_end_get());
#endif
#ifdef RT_USING_CONSOLE
static int uart_init(void)
#error "TODO 2: Enable the hardware uart and config baudrate."
    return 0;
INIT_BOARD_EXPORT(uart_init);
void rt_hw_console_output(const char *str)
#error "TODO 3: Output the string 'str' through the uart."
#endif
11. 新建在user文件夹下新建rtconfig.h,内容如下:
/* RT-Thread config file */
#ifndef __RTTHREAD_CFG_H__
#define __RTTHREAD_CFG_H__
// <<< Use Configuration Wizard in Context Menu >>>
// <h>Basic Configuration
// <o>Maximal level of thread priority <8-256>
//  <i>Default: 32
#define RT_THREAD_PRIORITY_MAX  32
// <o>OS tick per second
//  <i>Default: 1000   (1ms)
#define RT_TICK_PER_SECOND  1000
// <o>Alignment size for CPU architecture data access
//  <i>Default: 4
#define RT_ALIGN_SIZE   4
// <o>the max length of object name<2-16>
//  <i>Default: 8
#define RT_NAME_MAX    8
// <c1>Using RT-Thread components initialization
//  <i>Using RT-Thread components initialization
#define RT_USING_COMPONENTS_INIT
// </c>
#define RT_USING_USER_MAIN
// <o>the stack size of main thread<1-4086>
//  <i>Default: 512
#define RT_MAIN_THREAD_STACK_SIZE     256
// </h>
// <h>Debug Configuration
// <c1>enable kernel debug configuration
//  <i>Default: enable kernel debug configuration
//#define RT_DEBUG
// </c>
// <o>enable components initialization debug configuration<0-1>
//  <i>Default: 0
#define RT_DEBUG_INIT 0
// <c1>thread stack over flow detect
//  <i> Diable Thread stack over flow detect
//#define RT_USING_OVERFLOW_CHECK
// </c>
// </h>
// <h>Hook Configuration
// <c1>using hook
//  <i>using hook
//#define RT_USING_HOOK
// </c>
// <c1>using idle hook
//  <i>using idle hook
//#define RT_USING_IDLE_HOOK
// </c>
// </h>
// <e>Software timers Configuration
// <i> Enables user timers
#define RT_USING_TIMER_SOFT         0
#if RT_USING_TIMER_SOFT == 0
    #undef RT_USING_TIMER_SOFT
#endif
// <o>The priority level of timer thread <0-31>
//  <i>Default: 4
#define RT_TIMER_THREAD_PRIO        4
// <o>The stack size of timer thread <0-8192>
//  <i>Default: 512
#define RT_TIMER_THREAD_STACK_SIZE  512
// </e>
// <h>IPC(Inter-process communication) Configuration
// <c1>Using Semaphore
//  <i>Using Semaphore
#define RT_USING_SEMAPHORE
// </c>
// <c1>Using Mutex
//  <i>Using Mutex
//#define RT_USING_MUTEX
// </c>
// <c1>Using Event
//  <i>Using Event
//#define RT_USING_EVENT
// </c>
// <c1>Using MailBox
//  <i>Using MailBox
#define RT_USING_MAILBOX
// </c>
// <c1>Using Message Queue
//  <i>Using Message Queue
//#define RT_USING_MESSAGEQUEUE
// </c>
// </h>
// <h>Memory Management Configuration
// <c1>Memory Pool Management
//  <i>Memory Pool Management
//#define RT_USING_MEMPOOL
// </c>
// <c1>Dynamic Heap Management(Algorithm: small memory )
//  <i>Dynamic Heap Management
//#define RT_USING_HEAP
//#define RT_USING_SMALL_MEM
// </c>
// <c1>using tiny size of memory
//  <i>using tiny size of memory
//#define RT_USING_TINY_SIZE
// </c>
// </h>
// <h>Console Configuration
// <c1>Using console
//  <i>Using console
//#define RT_USING_CONSOLE
// </c>
// <o>the buffer size of console <1-1024>
//  <i>the buffer size of console
//  <i>Default: 128  (128Byte)
#define RT_CONSOLEBUF_SIZE          256
// </h>
// <h>FinSH Configuration
// <c1>include finsh config
//  <i>Select this choice if you using FinSH
//#include "finsh_config.h"
// </c>
// </h>
// <h>Device Configuration
// <c1>using device framework
//  <i>using device framework
//#define RT_USING_DEVICE
// </c>
// </h>
// <<< end of configuration section >>>
#endif
12、屏蔽interrupts_cw32050.c中的HardFault_Handler以及PendSV_Handler函数。
编译结果为无错误无警告:
  13、编写main中的测试函数如下:
struct rt_thread thread1;
struct rt_thread thread2;
char thread1_stack[512];
char thread2_stack[512];
void led_init(void)
	  GPIO_InitTypeDef GPIO_InitStruct = {0};
    RCC_HSI_Enable(RCC_HSIOSC_DIV6);
    __RCC_GPIOC_CLK_ENABLE();
		__RCC_GPIOA_CLK_ENABLE();
    GPIO_InitStruct.IT = GPIO_IT_NONE;
    GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
    GPIO_InitStruct.Pins = GPIO_PIN_10;
    GPIO_Init(CW_GPIOC, &GPIO_InitStruct);
		GPIO_InitStruct.Pins = GPIO_PIN_15;
		GPIO_Init(CW_GPIOA, &GPIO_InitStruct);
void thread1_entry(void*param)
	while (1)
	//printf("thread1 is runningrn\r\n");
		GPIO_TogglePin(CW_GPIOC, GPIO_PIN_10);
		rt_thread_mdelay(1000);
void thread2_entry(void*param)
while (1)
	GPIO_TogglePin(CW_GPIOA, GPIO_PIN_15);
	rt_thread_mdelay(500);
void thread1_init(void)
	rt_err_t fd=rt_thread_init(&thread1,"thread1",&thread1_entry,0,&thread1_stack[0],sizeof(thread1_stack),10,10);
	if(fd < 0)
	printf("thread2 init is fail \r\n");
	rt_thread_startup(&thread1);
void thread2_init(void)
	rt_err_t fd=rt_thread_init(&thread2,"thread2",&thread2_entry,0,&thread2_stack[0],sizeof(thread2_stack),10,10);
	if(fd < 0)
	rt_thread_startup(&thread2);
int32_t main(void)
    //配置RCC
    RCC_Configuration();
    //配置GPIO
    GPIO_Configuration();
    //配置UART
    UART_Configuration();
		led_init();
    printf("\r\nCW32L052 UART Printf Example\r\n");
		thread1_init();
		thread2_init();
    while(1)
下载后测试效果为LED1与LED2按0.5秒与1秒的闪灯,两个任务成功运行:
rtt
你这确实是纯手工移植,不是从Keil中导入的。   详情 回复 发表于 2023-7-20 18:36
7244
手工移植,更能体验到移植的原理,就是board.c跟rtconfig没有做特别的介绍,少了一些什么。  详情 回复 发表于 2023-7-20 21:54
7044
wangerxian 发表于 2023-7-20 18:36 你这确实是纯手工移植,不是从Keil中导入的。
