789|1
7096
【CW32L052评测】串口驱动 [复制链接]
  1. 新建bsp文件夹,在其下面新建uart文件夹,下面新建uart.c/uart.h
  2. 工程中新建BSP/uart分组,添加uart.c到工程下面:
  3. 添加文件的头文件引用:
  4. 串口k通信的UARTIO选择PF04、PF05 UART1来进行通信。从用户手册查到端口复用为AF!:
  5. 建立uart1初始化代码如下:
    void uart1_init(void)
    uint32_t PCLK_Freq;
    GPIO_InitTypeDef GPIO_InitStructure = {0};
    UART_InitTypeDef UART_InitStructure = {0};
    /* 开始 PF端口时钟 */
    __RCC_GPIOF_CLK_ENABLE();
    /* 使用UART1 时钟 */
    __RCC_UART1_CLK_ENABLE();
    /* 复用GPIOF04-05 */
    PF04_AFx_UART1TXD();
    PF05_AFx_UART1RXD();
    /* 初始化TX IO */
    GPIO_InitStructure.Pins = GPIO_PIN_4;
    GPIO_InitStructure.Mode = GPIO_MODE_OUTPUT_PP;
    GPIO_Init(CW_GPIOF, &GPIO_InitStructure);
    /* 初始化RX IO */
    GPIO_InitStructure.Pins = GPIO_PIN_5;
    GPIO_InitStructure.Mode = GPIO_MODE_INPUT_PULLUP;
    PCLK_Freq = SystemCoreClock >> pow2_table[CW_SYSCTRL->CR0_f.HCLKPRS];
    PCLK_Freq >>= pow2_table[CW_SYSCTRL->CR0_f.PCLKPRS];
    UART_InitStructure.UART_BaudRate = 115200;
    UART_InitStructure.UART_Over = UART_Over_16;
    UART_InitStructure.UART_Source = UART_Source_PCLK;
    UART_InitStructure.UART_UclkFreq = PCLK_Freq;
    UART_InitStructure.UART_StartBit = UART_StartBit_FE;
    UART_InitStructure.UART_StopBits = UART_StopBits_1;
    UART_InitStructure.UART_Parity = UART_Parity_No;
    UART_InitStructure.UART_HardwareFlowControl = UART_HardwareFlowControl_None;
    UART_InitStructure.UART_Mode = UART_Mode_Rx | UART_Mode_Tx;
    UART_Init(CW_UART1, &UART_InitStructure);
    /* 使能 UART中断 */
    NVIC_SetPriority(UART1_IRQn, 0);
    NVIC_EnableIRQ(UART1_IRQn);
    UART_ITConfig(CW_UART1, UART_IT_RC, ENABLE);
  6. 主程序先初始化uart1,然后加入发送函数,测试是否初始化成功:
  7. 打开串口助手,下载后成功的获取到串口输出的信息:
致此串口驱动成功!
这个CW32L052串口驱动,从用户手册查到端口复用为AF!这个是技术点   详情 回复 发表于 2023-7-16 22:14
1708
