857|0
国产芯片车载视频转换方案LT9211C-LVDS/MIPI/TTL转 LVDS/MIPI/TTL,兼容性超强 [复制链接]
描述
  1. Lontium LT9211C是一种高性能转换器,可以在MIPI DSI/CSI-2/双端口LVDS和TTL之间相互转换,除了24位TTL到同步和DE的24位TTL,并且不推荐在2端口10位LVDS和同步和DE的24位TTL之间进行转换。LT9211C对输入的MIPI/LVDS/TTL视频数据进行反序列化,解码数据包,并将格式化的视频数据流在AP和移动显示面板或摄像机之间转换为MIPI/LVDS/TTL发射机输出。
LT9211C可作为2端口MIPI/LVDS中继器,支持最大14dB输入均衡和可编程预强调,以提高性能。
LT9211C也可以用作MIPI/LVDS的分割器和分割器。对于MIPI中继器,Muxer和Splitter,我们也支持CSI RAW格式的连续时钟。
除TTL输入和输出外,VCCIO可以为1.8V,当TTL输入时,VCCIO电压必须大于TTL输入高压电平,TTL输出电压电平即为VCCIO。
LT9211C采用先进的CMOS工艺制造,采用7.5x7.5mm QFN64封装。该包符合RoHS标准,并指定在-40°C至+85°C范围内运行。
2. 特性
•双端口LVDS发射器•MIPI发射机•TTL输出•MIPI接收器
•双端口LVDS接收器•TTL输入•杂项
3.应用程序
•移动系统
•蜂窝手机•数码相机•数码摄像机
•平板电脑、笔记本电脑
•汽车显示和摄像系统
  1. Description
The Lontium LT9211C is a high performance convertor which interconvertible between MIPI DSI/CSI-2/Dual-Port LVDS and TTL except for 24bit TTL to 24bit TTL with both SYNC and DE, and the conversion between 2-port 10-bit LVDS and 24bit TTL with both SYNC and DE is not recommended. The LT9211C deserializes input MIPI/LVDS/TTL video data, decodes packets, and converts the formatted video data stream to MIPI/LVDS/TTL transmitter output between AP and mobile display panel or camera.
The LT9211C can be used as 2-Port MIPI/LVDS Repeater which support maximum 14dB input equalization and programmable pre-emphasis to improve performance.
The LT9211C can also be used as MIPI/LVDS Muxer and Splitter. For MIPI Repeater, Muxer and Splitter, we also support CSI RAW format with continuous clock.
Except TTL input and output, the VCCIO could be 1.8V, when TTL input, the VCCIO voltage must be greater than the TTL input high voltage level, and the TTL output voltage level is the VCCIO.
The LT9211C is fabricated in advanced CMOS process and implemented in 7.5x7.5mm QFN64 package. This package is RoHS compliant and specified to operate from -40°C to +85°C.
2. Features
• Dual-Port LVDS Transimitter
• MIPI Transmitter
• TTL Output
• MIPI Receiver
• Dual-Port LVDS Receiver
• TTL Intput
• Miscellaneous
3. Applications
• Mobile systems
• Cellular handsets
• Digital still cameras
• Digital  video cameras
• Tablet PC, Notebook PC
