1157|2
【RTT&英飞凌PSoC6评估板(带触摸)】8,管脚模拟驱动LCD [复制链接]
今天想点个屏,本来想用SPI驱动来这,但是从能不能驱动行了方面考量,我还是选择了模拟管脚驱动。因为我的屏还有一些零碎的东东,不是纯SPI所能办得到地。
我的管脚分配在屏后边印的我只好整里出管脚的对应关系:
      CS  ------------ P5.7
      DC-------------  P0.5
     RES------------  P0.2
    MOS------------  P0.3
    CLK-------------  P0.4
    BLK-------------  P5.6
另外的电源地,接开发板的3.3V电源和GND
以下是程序:
lcd.h:
#ifndef __LCD_INIT_H
#define __LCD_INIT_H
#include <rtthread.h>
#include <rtdevice.h>
#include "drv_gpio.h"
#define USE_HORIZONTAL 1  //设置横屏或者竖屏显示 0或1为竖屏 2或3为横屏
#if USE_HORIZONTAL==0||USE_HORIZONTAL==1
#define LCD_W 128
#define LCD_H 160
#else
#define LCD_W 160
#define LCD_H 128
#endif
#define u8  unsigned char
#define u16 unsigned int
#define LCD_CS     GET_PIN(5, 7)//SCLK
#define LCD_SDA     GET_PIN(0, 3)//MOSI
#define LCD_RES     GET_PIN(0, 2)//RES
#define LCD_DC     GET_PIN(0, 5)//DC
#define LCD_CLK     GET_PIN(0, 4)
#define LCD_BLK    GET_PIN(5, 6)
//sbit LCD_BLK=P0^4; //BLK
//sbit LCD_CS =P0^6; //CS1
//-----------------LCD端口定义----------------
#define LCD_SCLK_Clr() rt_pin_write(LCD_CLK, PIN_LOW)
#define LCD_SCLK_Set() rt_pin_write(LCD_CLK, PIN_HIGH)
#define LCD_MOSI_Clr() rt_pin_write(LCD_SDA, PIN_LOW)
#define LCD_MOSI_Set() rt_pin_write(LCD_SDA, PIN_HIGH)
#define LCD_RES_Clr() rt_pin_write(LCD_RES, PIN_LOW)//RES
#define LCD_RES_Set() rt_pin_write(LCD_RES, PIN_HIGH)
#define LCD_DC_Clr() rt_pin_write(LCD_DC, PIN_LOW)//DC
#define LCD_DC_Set() rt_pin_write(LCD_DC, PIN_HIGH)
#define LCD_BLK_Clr()  rt_pin_write(LCD_BLK, PIN_LOW)//BLK
#define LCD_BLK_Set()  rt_pin_write(LCD_BLK, PIN_HIGH)
#define LCD_CS_Clr()  rt_pin_write(LCD_CS, PIN_LOW)//CS1
#define LCD_CS_Set()  rt_pin_write(LCD_CS, PIN_HIGH)
void delay_ms(unsigned int ms);//不准确延时函数
void LCD_GPIO_Init(void);//初始化GPIO
void LCD_Writ_Bus(u8 dat);//模拟SPI时序
void LCD_WR_DATA8(u8 dat);//写入一个字节
void LCD_WR_DATA(u16 dat);//写入两个字节
void LCD_WR_REG(u8 dat);//写入一个指令
void LCD_Address_Set(u16 x1,u16 y1,u16 x2,u16 y2);//设置坐标函数
void LCD_Init(void);//LCD初始化
#endif
lcd.c
include "lcd.h"
#include "lcd_init.h"
#include "lcdfont.h"
#include "delay.h"
      oˉêyËμÃ÷£oÔúÖ¸¶¨Çøóòìî3äÑÕé«
      èë¿úêy¾Y£oxsta,ysta   Æeê¼×ø±ê
                xend,yend   ÖÕÖ1×ø±ê
								color       òaìî3äμÄÑÕé«
      ·μ»ØÖμ£o  ÎT
void LCD_Fill(u16 xsta,u16 ysta,u16 xend,u16 yend,u16 color)
	u16 i,j;
	LCD_Address_Set(xsta,ysta,xend-1,yend-1);//éèÖÃÏÔê¾·¶Î§
	for(i=ysta;i<yend;i++)
		for(j=xsta;j<xend;j++)
			LCD_WR_DATA(color);
      oˉêyËμÃ÷£oÔúÖ¸¶¨Î»Öû-μã
      èë¿úêy¾Y£ox,y »-μã×ø±ê
                color μãμÄÑÕé«
      ·μ»ØÖμ£o  ÎT
void LCD_DrawPoint(u16 x,u16 y,u16 color)
	LCD_Address_Set(x,y,x,y);//éèÖÃ1a±êλÖà
	LCD_WR_DATA(color);
      oˉêyËμÃ÷£o»-Ïß
      èë¿úêy¾Y£ox1,y1   Æeê¼×ø±ê
                x2,y2   ÖÕÖ1×ø±ê
                color   ÏßμÄÑÕé«
      ·μ»ØÖμ£o  ÎT
void LCD_DrawLine(u16 x1,u16 y1,u16 x2,u16 y2,u16 color)
	u16 t;
	int xerr=0,yerr=0,delta_x,delta_y,distance;
	int incx,incy,uRow,uCol;
	delta_x=x2-x1; //¼ÆËã×ø±êÔöá¿
	delta_y=y2-y1;
	uRow=x1;//»-ÏßÆeμã×ø±ê
	uCol=y1;
	if(delta_x>0)incx=1; //éèÖÃμ¥2½·½Ïò
	else if (delta_x==0)incx=0;//′1Ö±Ïß
	else {incx=-1;delta_x=-delta_x;}
	if(delta_y>0)incy=1;
	else if (delta_y==0)incy=0;//ˮƽÏß
	else {incy=-1;delta_y=-delta_y;}
	if(delta_x>delta_y)distance=delta_x; //Ñ¡è¡»ù±¾Ôöá¿×ø±êÖá
	else distance=delta_y;
	for(t=0;t<distance+1;t++)
		LCD_DrawPoint(uRow,uCol,color);//»-μã
		xerr+=delta_x;
		yerr+=delta_y;
		if(xerr>distance)
			xerr-=distance;
			uRow+=incx;
		if(yerr>distance)
			yerr-=distance;
			uCol+=incy;
      oˉêyËμÃ÷£o»-¾ØDÎ
                x2,y2   ÖÕÖ1×ø±ê
                color   ¾ØDÎμÄÑÕé«
      ·μ»ØÖμ£o  ÎT
void LCD_DrawRectangle(u16 x1, u16 y1, u16 x2, u16 y2,u16 color)
	LCD_DrawLine(x1,y1,x2,y1,color);
	LCD_DrawLine(x1,y1,x1,y2,color);
	LCD_DrawLine(x1,y2,x2,y2,color);
	LCD_DrawLine(x2,y1,x2,y2,color);
      oˉêyËμÃ÷£o»-Ô2
      èë¿úêy¾Y£ox0,y0   Ô2DÄ×ø±ê
                r       °ë¾¶
                color   Ô2μÄÑÕé«
      ·μ»ØÖμ£o  ÎT
void Draw_Circle(u16 x0,u16 y0,u8 r,u16 color)
	int a,b;
	a=0;b=r;
	while(a<=b)
		LCD_DrawPoint(x0-b,y0-a,color);             //3
		LCD_DrawPoint(x0+b,y0-a,color);             //0
		LCD_DrawPoint(x0-a,y0+b,color);             //1
		LCD_DrawPoint(x0-a,y0-b,color);             //2
		LCD_DrawPoint(x0+b,y0+a,color);             //4
		LCD_DrawPoint(x0+a,y0-b,color);             //5
		LCD_DrawPoint(x0+a,y0+b,color);             //6
		LCD_DrawPoint(x0-b,y0+a,color);             //7
		a++;
		if((a*a+b*b)>(r*r))//ÅD¶Ïòa»-μÄμãêÇ·ñ1yÔ¶
			b--;
      oˉêyËμÃ÷£oÏÔê¾oo×Ö′®
      èë¿úêy¾Y£ox,yÏÔê¾×ø±ê
                *s òaÏÔê¾μÄoo×Ö′®
                fc ×ÖμÄÑÕé«
                bc ×Öμı3¾°é«
                sizey ×ÖoÅ ¿éÑ¡ 16 24 32
                mode:  0·Çμt¼óÄ£ê½  1μt¼óÄ£ê½
      ·μ»ØÖμ£o  ÎT
void LCD_ShowChinese(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
	while(*s!=0)
		if(sizey==12) LCD_ShowChinese12x12(x,y,s,fc,bc,sizey,mode);
		else if(sizey==16) LCD_ShowChinese16x16(x,y,s,fc,bc,sizey,mode);
		else if(sizey==24) LCD_ShowChinese24x24(x,y,s,fc,bc,sizey,mode);
		else if(sizey==32) LCD_ShowChinese32x32(x,y,s,fc,bc,sizey,mode);
		else return;
		s+=2;
		x+=sizey;
      oˉêyËμÃ÷£oÏÔê¾μ¥¸ö12x12oo×Ö
                *s òaÏÔê¾μÄoo×Ö
                fc ×ÖμÄÑÕé«
                bc ×Öμı3¾°é«
                sizey ×ÖoÅ
      ·μ»ØÖμ£o  ÎT
void LCD_ShowChinese12x12(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
	u8 i,j,m=0;
	u16 k;
	u16 HZnum;//oo×ÖêyÄ¿
	u16 TypefaceNum;//ò»¸ö×Ö·ûËùÕ¼×Ö½ú′óD¡
	u16 x0=x;
	TypefaceNum=(sizey/8+((sizey%8)?1:0))*sizey;
	HZnum=sizeof(tfont12)/sizeof(typFNT_GB12);	//í3¼Æoo×ÖêyÄ¿
	for(k=0;k<HZnum;k++)
		if((tfont12[k].Index[0]==*(s))&&(tfont12[k].Index[1]==*(s+1)))
			LCD_Address_Set(x,y,x+sizey-1,y+sizey-1);
			for(i=0;i<TypefaceNum;i++)
				for(j=0;j<8;j++)
					if(!mode)//·Çμt¼ó·½ê½
						if(tfont12[k].Msk[i]&(0x01<<j))LCD_WR_DATA(fc);
						else LCD_WR_DATA(bc);
						m++;
						if(m%sizey==0)
							m=0;
							break;
					else//μt¼ó·½ê½
						if(tfont12[k].Msk[i]&(0x01<<j))	LCD_DrawPoint(x,y,fc);//»-ò»¸öμã
						x++;
						if((x-x0)==sizey)
							x=x0;
							y++;
							break;
		continue;  //2éÕò콶Ôó|μãÕó×Ö¿aᢼ′íË3ö£¬·àÖ1¶à¸öoo×ÖÖظ′è¡Ä£′øà′ó°Ïì
      oˉêyËμÃ÷£oÏÔê¾μ¥¸ö16x16oo×Ö
                *s òaÏÔê¾μÄoo×Ö
                fc ×ÖμÄÑÕé«
                bc ×Öμı3¾°é«
                sizey ×ÖoÅ
      ·μ»ØÖμ£o  ÎT
void LCD_ShowChinese16x16(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
	u8 i,j,m=0;
	u16 k;
	u16 x0=x;
	HZnum=sizeof(tfont16)/sizeof(typFNT_GB16);	//í3¼Æoo×ÖêyÄ¿
		if ((tfont16[k].Index[0]==*(s))&&(tfont16[k].Index[1]==*(s+1)))
				for(j=0;j<8;j++)
						if(tfont16[k].Msk[i]&(0x01<<j))LCD_WR_DATA(fc);
						m++;
						if(m%sizey==0)
							m=0;
							break;
					else//μt¼ó·½ê½
						if(tfont16[k].Msk[i]&(0x01<<j))	LCD_DrawPoint(x,y,fc);//»-ò»¸öμã
						x++;
						if((x-x0)==sizey)
							x=x0;
							y++;
							break;
      oˉêyËμÃ÷£oÏÔê¾μ¥¸ö24x24oo×Ö
                *s òaÏÔê¾μÄoo×Ö
                fc ×ÖμÄÑÕé«
                bc ×Öμı3¾°é«
                sizey ×ÖoÅ
      ·μ»ØÖμ£o  ÎT
void LCD_ShowChinese24x24(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
	u8 i,j,m=0;
	u16 k;
	u16 x0=x;
	HZnum=sizeof(tfont24)/sizeof(typFNT_GB24);	//í3¼Æoo×ÖêyÄ¿
		if ((tfont24[k].Index[0]==*(s))&&(tfont24[k].Index[1]==*(s+1)))
				for(j=0;j<8;j++)
						if(tfont24[k].Msk[i]&(0x01<<j))LCD_WR_DATA(fc);
						m++;
						if(m%sizey==0)
							m=0;
							break;
					else//μt¼ó·½ê½
						if(tfont24[k].Msk[i]&(0x01<<j))	LCD_DrawPoint(x,y,fc);//»-ò»¸öμã
						x++;
						if((x-x0)==sizey)
							x=x0;
							y++;
							break;
      oˉêyËμÃ÷£oÏÔê¾μ¥¸ö32x32oo×Ö
                *s òaÏÔê¾μÄoo×Ö
                fc ×ÖμÄÑÕé«
                bc ×Öμı3¾°é«
                sizey ×ÖoÅ
      ·μ»ØÖμ£o  ÎT
void LCD_ShowChinese32x32(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
	u8 i,j,m=0;
	u16 k;
	u16 x0=x;
	HZnum=sizeof(tfont32)/sizeof(typFNT_GB32);	//í3¼Æoo×ÖêyÄ¿
		if ((tfont32[k].Index[0]==*(s))&&(tfont32[k].Index[1]==*(s+1)))
				for(j=0;j<8;j++)
						if(tfont32[k].Msk[i]&(0x01<<j))LCD_WR_DATA(fc);
						m++;
						if(m%sizey==0)
							m=0;
							break;
					else//μt¼ó·½ê½
						if(tfont32[k].Msk[i]&(0x01<<j))	LCD_DrawPoint(x,y,fc);//»-ò»¸öμã
						x++;
						if((x-x0)==sizey)
							x=x0;
							y++;
							break;
      oˉêyËμÃ÷£oÏÔê¾μ¥¸ö×Ö·û
                num òaÏÔê¾μÄ×Ö·û
                fc ×ÖμÄÑÕé«
                bc ×Öμı3¾°é«
                sizey ×ÖoÅ
      ·μ»ØÖμ£o  ÎT
void LCD_ShowChar(u16 x,u16 y,u8 num,u16 fc,u16 bc,u8 sizey,u8 mode)
	u8 temp,sizex,t,m=0;
	u16 i,TypefaceNum;//ò»¸ö×Ö·ûËùÕ¼×Ö½ú′óD¡
	u16 x0=x;
	sizex=sizey/2;
	TypefaceNum=(sizex/8+((sizex%8)?1:0))*sizey;
	num=num-' ';    //μÃμ½Æ«òÆoóμÄÖμ
	LCD_Address_Set(x,y,x+sizex-1,y+sizey-1);  //éèÖÃ1a±êλÖà
		if(sizey==12)temp=ascii_1206[num][i];		       //μ÷óÃ6x12×Öìå
		else if(sizey==16)temp=ascii_1608[num][i];		 //μ÷óÃ8x16×Öìå
		else if(sizey==24)temp=ascii_2412[num][i];		 //μ÷óÃ12x24×Öìå
		else if(sizey==32)temp=ascii_3216[num][i];		 //μ÷óÃ16x32×Öìå
		else return;
		for(t=0;t<8;t++)
			if(!mode)//·Çμt¼óÄ£ê½
				if(temp&(0x01<<t))LCD_WR_DATA(fc);
				m++;
				if(m%sizex==0)
					m=0;
					break;
			else//μt¼óÄ£ê½
				if(temp&(0x01<<t))LCD_DrawPoint(x,y,fc);//»-ò»¸öμã
				x++;
				if((x-x0)==sizex)
					x=x0;
					y++;
					break;
      oˉêyËμÃ÷£oÏÔê¾×Ö·û′®
                *p òaÏÔê¾μÄ×Ö·û′®
                fc ×ÖμÄÑÕé«
                bc ×Öμı3¾°é«
                sizey ×ÖoÅ
      ·μ»ØÖμ£o  ÎT
void LCD_ShowString(u16 x,u16 y,const u8 *p,u16 fc,u16 bc,u8 sizey,u8 mode)
	while(*p!='\0')
		LCD_ShowChar(x,y,*p,fc,bc,sizey,mode);
		x+=sizey/2;
		p++;
      oˉêyËμÃ÷£oÏÔê¾êy×Ö
      èë¿úêy¾Y£omμ×êy£¬nÖ¸êy
      ·μ»ØÖμ£o  ÎT
u32 mypow(u8 m,u8 n)
	u32 result=1;
	while(n--)result*=m;
	return result;
      oˉêyËμÃ÷£oÏÔê¾Õûêy±äá¿
                num òaÏÔê¾Õûêy±äá¿
                len òaÏÔê¾μÄλêy
                fc ×ÖμÄÑÕé«
                bc ×Öμı3¾°é«
                sizey ×ÖoÅ
      ·μ»ØÖμ£o  ÎT
void LCD_ShowIntNum(u16 x,u16 y,u16 num,u8 len,u16 fc,u16 bc,u8 sizey)
	u8 t,temp;
	u8 enshow=0;
	u8 sizex=sizey/2;
	for(t=0;t<len;t++)
		temp=(num/mypow(10,len-t-1))%10;
		if(enshow==0&&t<(len-1))
			if(temp==0)
				LCD_ShowChar(x+t*sizex,y,' ',fc,bc,sizey,0);
				continue;
			}else enshow=1;
	 	LCD_ShowChar(x+t*sizex,y,temp+48,fc,bc,sizey,0);
      oˉêyËμÃ÷£oÏÔê¾á½Î»D¡êy±äá¿
                num òaÏÔê¾D¡êy±äá¿
                len òaÏÔê¾μÄλêy
                fc ×ÖμÄÑÕé«
                bc ×Öμı3¾°é«
                sizey ×ÖoÅ
      ·μ»ØÖμ£o  ÎT
void LCD_ShowFloatNum1(u16 x,u16 y,float num,u8 len,u16 fc,u16 bc,u8 sizey)
	u8 t,temp,sizex;
	u16 num1;
	sizex=sizey/2;
	num1=num*100;
	for(t=0;t<len;t++)
		temp=(num1/mypow(10,len-t-1))%10;
		if(t==(len-2))
			LCD_ShowChar(x+(len-2)*sizex,y,'.',fc,bc,sizey,0);
			t++;
			len+=1;
      oˉêyËμÃ÷£oÏÔê¾í¼Æ¬
      èë¿úêy¾Y£ox,yÆeμã×ø±ê
                length í¼Æ¬3¤¶è
                width  í¼Æ¬¿í¶è
                pic[]  í¼Æ¬êy×é
      ·μ»ØÖμ£o  ÎT
void LCD_ShowPicture(u16 x,u16 y,u16 length,u16 width,const u8 pic[])
	u16 i,j;
	u32 k=0;
	LCD_Address_Set(x,y,x+length-1,y+width-1);
	for(i=0;i<length;i++)
		for(j=0;j<width;j++)
			LCD_WR_DATA8(pic[k*2]);
			LCD_WR_DATA8(pic[k*2+1]);
			k++;
main.c
#include "lcd.h"
#define RED              0xF800
#define LED_PIN     GET_PIN(0, 0)
    u16 i,j;
    LCD_Address_Set(xsta,ysta,xend-1,yend-1);//设置显示范围
            LCD_WR_DATA(color);
int main(void)
    LCD_Init();
    delay_ms(100);
    LCD_Fill(0,0,128,160,RED);
    delay_ms(100);
    rt_pin_mode(LED_PIN, PIN_MODE_OUTPUT);
    for (;;)
        rt_pin_write(LED_PIN, PIN_HIGH);
        rt_thread_mdelay(500);
        rt_pin_write(LED_PIN, PIN_LOW);
运行结果:
楼主辛苦!   详情 回复 发表于 2023-7-9 13:17
点赞 关注(1)
6107
楼主辛苦!
版主吉祥  详情 回复 发表于 2023-7-9 18:41
版主吉祥
