2184|0
64
关于PROCESS中的SIGNAL [复制链接]
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY light IS
        PORT
                clk,reset,sensor                : IN        STD_LOGIC;
                green_1,green_2,red_1,red_2,yellow_1,yellow_2        : OUT        STD_LOGIC
END ENTITY light;
ARCHITECTURE a OF light IS
        TYPE state IS (s0,s1,s2);
        SIGNAL current_state:state;
        SIGNAL next_state:state;
        SIGNAL c0,c1,c2:STD_LOGIC_VECTOR (1 DOWNTO 0);
        SIGNAL from:state;
BEGIN
currents:PROCESS (current_state)
BEGIN
        IF reset='1' THEN
           next_state<=s0;
        ELSE
           CASE current_state IS
                  WHEN s0 =>
                    green_1<='1';green_2<='0';red_1<='0';red_2<='1';yellow_1<='0';yellow_2<='0';
                        IF c0="11" AND sensor='1' THEN
                            next_state<=s1;
                            from<=s0; -----------------------------------------------------
                        ELSE next_state<=s0;
                        END IF;
                  WHEN s1 =>
                    green_1<='0';green_2<='0';red_1<='0';red_2<='0';yellow_1<='1';yellow_2<='1';
                        IF c1="01" THEN
                           IF sensor='1' AND from=s0 THEN
                              next_state<=s2;
                                   END IF;
                        ELSE next_state<=s1;
                        END IF;
                  WHEN s2 =>
                    green_1<='0';green_2<='1';red_1<='1';red_2<='0';yellow_1<='0';yellow_2<='0';
                        IF c2="11" THEN
                           next_state<=s1;
                           from<=s2;
                        ELSE next_state<=s2;
                        END IF;
                     END CASE;
                END IF;
END PROCESS currents;
PROCESS (clk)
BEGIN
IF clk'event AND clk='1' THEN
   current_state<=next_state;
END IF;
END PROCESS;
count:PROCESS (clk)
BEGIN
IF reset='1' THEN
    c0<="00";
    c1<="00";
    c2<="00";
ELSE
        WHEN s0 =>
                c0<=c0+1;
        WHEN s1 =>
                IF c1="01" THEN
                   c1<="00";
                ELSE c1<=c1+1;
                END IF;
        WHEN s2 =>
                c2<=c2+1;
END CASE;
END IF;
END IF;
END PROCESS count;
END a;
----------------这里,我把STATE中的一种放在from中,可是等到下一个上升沿这个值就不见了,这是为什么?
