【得捷电子Follow me第1期】任务2:驱动外设-BEEP
外设驱动部分任务涉及到三个,LED昨天完成了,本帖子想法搞定BEEP蜂鸣器
我的蜂鸣器连接到扩展板左下角D20口,根据模块手册,控制引脚是接到了pico W模块的GPIO20口
模块手册也上传上来:
方法一:用GPIO+延时方式完成驱动任务:
# 在这里写上你的代码 :-)
# BEEP using PWM Example
from machine import Pin
from time import sleep
# 蜂鸣器管脚定义GPIO20
IO_buzzer = 20
# 设置蜂鸣器GPIO口为输出模式
buzzer = Pin(IO_buzzer, Pin.OUT)
# 死循环
while True:
# 设置低电平,关闭蜂鸣器
buzzer.value(0)
# 延时
sleep(0.8)
# 设置高电平,打开蜂鸣器
buzzer.value(1)
# 延时
sleep(0.2)
实际效果见下面视频:
30c9de70ce632507ebd1bb600fdb67e3
方式二:用PWM方式实现midi音乐
加载方式参考我发的加载包的帖子
共两个文件内容如下:
buzzer_music.py
Micropython (Raspberry Pi Pico)
Plays music written on onlinesequencer.net through a passive piezo buzzer.
Uses fast arpeggios with a single buzzer to simulate polyphony
Also supports multiple buzzers at once for real polyphony
https://github.com/james1236/buzzer_music
from machine import Pin, PWM
from math import ceil
tones = {
'C0':16,
'C#0':17,
'D0':18,
'D#0':19,
'E0':21,
'F0':22,
'F#0':23,
'G0':24,
'G#0':26,
'A0':28,
'A#0':29,
'B0':31,
'C1':33,
'C#1':35,
'D1':37,
'D#1':39,
'E1':41,
'F1':44,
'F#1':46,
'G1':49,
'G#1':52,
'A1':55,
'A#1':58,
'B1':62,
'C2':65,
'C#2':69,
'D2':73,
'D#2':78,
'E2':82,
'F2':87,
'F#2':92,
'G2':98,
'G#2':104,
'A2':110,
'A#2':117,
'B2':123,
'C3':131,
'C#3':139,
'D3':147,
'D#3':156,
'E3':165,
'F3':175,
'F#3':185,
'G3':196,
'G#3':208,
'A3':220,
'A#3':233,
'B3':247,
'C4':262,
'C#4':277,
'D4':294,
'D#4':311,
'E4':330,
'F4':349,
'F#4':370,
'G4':392,
'G#4':415,
'A4':440,
'A#4':466,
'B4':494,
'C5':523,
'C#5':554,
'D5':587,
'D#5':622,
'E5':659,
'F5':698,
'F#5':740,
'G5':784,
'G#5':831,
'A5':880,
'A#5':932,
'B5':988,
'C6':1047,
'C#6':1109,
'D6':1175,
'D#6':1245,
'E6':1319,
'F6':1397,
'F#6':1480,
'G6':1568,
'G#6':1661,
'A6':1760,
'A#6':1865,
'B6':1976,
'C7':2093,
'C#7':2217,
'D7':2349,
'D#7':2489,
'E7':2637,
'F7':2794,
'F#7':2960,
'G7':3136,
'G#7':3322,
'A7':3520,
'A#7':3729,
'B7':3951,
'C8':4186,
'C#8':4435,
'D8':4699,
'D#8':4978,
'E8':5274,
'F8':5588,
'F#8':5920,
'G8':6272,
'G#8':6645,
'A8':7040,
'A#8':7459,
'B8':7902,
'C9':8372,
'C#9':8870,
'D9':9397,
'D#9':9956,
'E9':10548,
'F9':11175,
'F#9':11840,
'G9':12544,
'G#9':13290,
'A9':14080,
'A#9':14917,
'B9':15804
#Time, Note, Duration, Instrument (onlinesequencer.net schematic format)
#0 D4 8 0;0 D5 8 0;0 G4 8 0;8 C5 2 0;10 B4 2 0;12 G4 2 0;14 F4 1 0;15 G4 17 0;16 D4 8 0;24 C4 8 0
class music:
def __init__(self, songString='0 D4 8 0', looping=True, tempo=3, duty=2512, pin=None, pins=[Pin(0)]):
self.tempo = tempo
self.song = songString
self.looping = looping
self.duty = duty
self.stopped = False
self.timer = -1
self.beat = -1
self.arpnote = 0
self.pwms = []
if (not (pin is None)):
pins = [pin]
self.pins = pins
for pin in pins:
self.pwms.append(PWM(pin))
self.notes = []
self.playingNotes = []
self.playingDurations = []
#Find the end of the song
self.end = 0
splitSong = self.song.split(";")
for note in splitSong:
snote = note.split(" ")
testEnd = round(float(snote[0])) + ceil(float(snote[2]))
if (testEnd > self.end):
self.end = testEnd
#Create empty song structure
while (self.end > len(self.notes)):
self.notes.append(None)
#Populate song structure with the notes
beat = round(float(snote[0]));
if (self.notes[beat] == None):
self.notes[beat] = []
self.notes[beat].append([snote[1],ceil(float(snote[2]))]) #Note, Duration
#Round up end of song to nearest bar
self.end = ceil(self.end / 8) * 8
def stop(self):
for pwm in self.pwms:
pwm.deinit()
self.stopped = True
def restart(self):
self.beat = -1
self.timer = 0
self.stop()
self.pwms = []
for pin in self.pins:
def resume(self):
self.stop()
self.pwms = []
def tick(self):
if (not self.stopped):
self.timer = self.timer + 1
#Loop
if (self.timer % (self.tempo * self.end) == 0 and (not (self.timer == 0))):
if (not self.looping):
self.stop()
return False
self.beat = -1
self.timer = 0
#On Beat
if (self.timer % self.tempo == 0):
self.beat = self.beat + 1
#Remove expired notes from playing list
i = 0
while (i < len(self.playingDurations)):
self.playingDurations[i] = self.playingDurations[i] - 1
if (self.playingDurations[i] <= 0):
self.playingNotes.pop(i)
self.playingDurations.pop(i)
else:
i = i + 1
#Add new notes and their durations to the playing list
#Old method runs for every note, slow to process on every beat and causes noticeable delay
ssong = song.split(";")
for note in ssong:
if int(snote[0]) == beat:
playingNotes.append(snote[1])
playingDurations.append(int(snote[2]))
if (self.beat < len(self.notes)):
if (self.notes[self.beat] != None):
for note in self.notes[self.beat]:
self.playingNotes.append(note[0])
self.playingDurations.append(note[1])
#Only need to run these checks on beats
i = 0
if (i >= len(self.playingNotes)):
if hasattr(pwm, 'duty_u16'):
pwm.duty_u16(0)
else:
pwm.duty(0)
else:
#Play note
pwm.duty_u16(self.duty)
else:
pwm.duty(self.duty)
pwm.freq(tones[self.playingNotes[i]])
i = i + 1
#Play arp of all playing notes
if (len(self.playingNotes) > len(self.pwms)):
p = self.pwms[len(self.pwms)-1];
if hasattr(p, 'duty_u16'):
p.duty_u16(self.duty)
else:
p.duty(self.duty)
if (self.arpnote > len(self.playingNotes)-len(self.pwms)):
self.arpnote = 0
self.pwms[len(self.pwms)-1].freq(tones[self.playingNotes[self.arpnote+(len(self.pwms)-1)]])
self.arpnote = self.arpnote + 1
return True
else:
return False
main.py
from buzzer_music import music
#Example songs
# https://onlinesequencer.net/195547
#song = '0 A#4 1 1;2 F5 1 1;4 D#5 1 1;8 D5 1 1;11 D5 1 1;6 A#4 1 1;14 D#5 1 1;18 A#4 1 1;20 D#5 1 1;22 A#4 1 1;24 D5 1 1;27 D5 1 1;30 D#5 1 1;32 A#4 1 1;34 F5 1 1;36 D#5 1 1;38 A#4 1 1;40 D5 1 1;43 D5 1 1;46 D#5 1 1;50 A#4 1 1;52 D#5 1 1;54 G5 1 1;56 F5 1 1;59 D#5 1 1;62 F5 1 1;64 A#4 1 1;66 F5 1 1;68 D#5 1 1;70 A#4 1 1;72 D5 1 1;75 D5 1 1;78 D#5 1 1;82 A#4 1 1;84 D#5 1 1;86 A#4 1 1;88 D5 1 1;91 D5 1 1;94 D#5 1 1;96 A#4 1 1;100 D#5 1 1;102 A#4 1 1;104 D5 1 1;107 D5 1 1;110 D#5 1 1;114 A#4 1 1;116 D#5 1 1;118 G5 1 1;120 F5 1 1;123 D#5 1 1;126 F5 1 1;98 F5 1 1'
# https://onlinesequencer.net/1864273
#song = '0 D5 4 14;4 A5 4 14;8 C6 4 14;12 B5 4 14;16 G5 2 14;18 F5 2 14;20 E5 2 14;22 F5 2 14;24 G5 8 14;4 E5 8 16;4 C5 8 16;4 F4 8 16;12 D5 8 16;12 B4 8 16;12 E4 8 16;20 C5 8 16;20 A4 8 16;20 D4 8 16;0 E4 4 16;0 B4 4 16;28 E4 4 16;28 B4 4 16'
# https://onlinesequencer.net/1864297 - Tetris
#song = '0 E3 1 0;2 E4 1 0;4 E3 1 0;6 E4 1 0;8 E3 1 0;10 E4 1 0;12 E3 1 0;14 E4 1 0;16 A3 1 0;18 A4 1 0;20 A3 1 0;22 A4 1 0;24 A3 1 0;26 A4 1 0;28 A3 1 0;30 A4 1 0;32 G#3 1 0;34 G#4 1 0;36 G#3 1 0;38 G#4 1 0;40 E3 1 0;42 E4 1 0;44 E3 1 0;46 E4 1 0;48 A3 1 0;50 A4 1 0;52 A3 1 0;54 A4 1 0;56 A3 1 0;58 B3 1 0;60 C4 1 0;62 D4 1 0;64 D3 1 0;66 D4 1 0;68 D3 1 0;70 D4 1 0;72 D3 1 0;74 D4 1 0;76 D3 1 0;78 D4 1 0;80 C3 1 0;82 C4 1 0;84 C3 1 0;86 C4 1 0;88 C3 1 0;90 C4 1 0;92 C3 1 0;94 C4 1 0;96 G2 1 0;98 G3 1 0;100 G2 1 0;102 G3 1 0;104 E3 1 0;106 E4 1 0;108 E3 1 0;110 E4 1 0;114 A4 1 0;112 A3 1 0;116 A3 1 0;118 A4 1 0;120 A3 1 0;122 A4 1 0;124 A3 1 0;0 E6 1 1;4 B5 1 1;6 C6 1 1;8 D6 1 1;10 E6 1 1;11 D6 1 1;12 C6 1 1;14 B5 1 1;0 E5 1 6;4 B4 1 6;6 C5 1 6;8 D5 1 6;10 E5 1 6;11 D5 1 6;12 C5 1 6;14 B4 1 6;16 A5 1 1;20 A5 1 1;22 C6 1 1;24 E6 1 1;28 D6 1 1;30 C6 1 1;32 B5 1 1;36 B5 1 1;36 B5 1 1;37 B5 1 1;38 C6 1 1;40 D6 1 1;44 E6 1 1;48 C6 1 1;52 A5 1 1;56 A5 1 1;20 A4 1 6;16 A4 1 6;22 C5 1 6;24 E5 1 6;28 D5 1 6;30 C5 1 6;32 B4 1 6;36 B4 1 6;37 B4 1 6;38 C5 1 6;40 D5 1 6;44 E5 1 6;48 C5 1 6;52 A4 1 6;56 A4 1 6;64 D5 1 6;64 D6 1 1;68 D6 1 1;70 F6 1 1;72 A6 1 1;76 G6 1 1;78 F6 1 1;80 E6 1 1;84 E6 1 1;86 C6 1 1;88 E6 1 1;92 D6 1 1;94 C6 1 1;96 B5 1 1;100 B5 1 1;101 B5 1 1;102 C6 1 1;104 D6 1 1;108 E6 1 1;112 C6 1 1;116 A5 1 1;120 A5 1 1;72 A5 1 6;80 E5 1 6;68 D5 1 7;70 F5 1 7;76 G5 1 7;84 E5 1 7;78 F5 1 7;86 C5 1 7;88 E5 1 6;96 B4 1 6;104 D5 1 6;112 C5 1 6;120 A4 1 6;92 D5 1 7;94 C5 1 7;100 B4 1 7;101 B4 1 7;102 C5 1 7;108 E5 1 7;116 A4 1 7'
# https://onlinesequencer.net/1210132
#song = '4 C#5 1 0;8 D#5 1 0;12 C5 1 0;16 C#5 1 0;18 C5 1 0;20 A#4 1 0;22 C5 1 0;24 G#4 1 0;30 G#4 1 0;31 A4 1 0;32 A#4 1 0;36 C#5 1 0;40 A#4 1 0;42 A#5 1 0;44 G#5 1 0;46 F#5 1 0;48 F5 1 0;50 F#5 1 0;52 G#5 1 0;54 F5 1 0;56 D#5 1 0;0 F5 1 0;68 C#5 1 0;72 D#5 1 0;76 C5 1 0;80 C#5 1 0;82 C5 1 0;84 A#4 1 0;86 C5 1 0;88 G#4 1 0;94 G#4 1 0;95 A4 1 0;96 A#4 1 0;100 C#5 1 0;104 A#4 1 0;106 A#5 1 0;108 G#5 1 0;110 F#5 1 0;64 F5 1 0;112 G#5 1 0;114 A#5 1 0;116 C6 1 0;118 C#6 1 0;120 D#6 1 0;128 C#6 1 0;134 F6 1 0;140 C#6 1 0;144 C6 1 0;150 D#6 1 0;156 C6 1 0;158 G#5 1 0;159 A5 1 0;160 A#5 1 0;166 C#6 1 0;172 A#5 1 0;176 C6 1 0;180 D#6 1 0;182 G#5 1 0;184 A#5 1 0;186 B5 1 0;188 C6 1 0;192 C#6 1 0;198 F6 1 0;204 C#6 1 0;208 C6 1 0;214 D#6 1 0;220 C6 1 0;222 G#5 1 0;223 A5 1 0;224 A#5 1 0;230 C#6 1 0;236 A#5 1 0;240 C6 1 0;244 D#6 1 0;246 F6 1 0;248 D#6 1 0;250 C#6 1 0;252 C6 1 0;254 G#5 1 0'
# https://onlinesequencer.net/1327293
#song = '2 A5 1 4;1 B4 1 4;3 A5 1 4;4 G5 1 4;5 G5 1 4;10 F#5 1 4;7 F#5 1 4;8 A4 1 4;9 A4 1 4;11 A4 1 4;13 C#6 1 4;14 B5 1 4;12 C#6 1 4;6 F#5 1 4;15 B4 2 4;18 A5 1 4;17 B4 1 4;19 A5 1 4;20 G5 1 4;21 G5 1 4;26 F#5 1 4;23 F#5 1 4;24 A4 1 4;25 A4 1 4;27 A4 1 4;29 C#6 1 4;30 B5 1 4;28 C#6 1 4;22 F#5 1 4;31 B4 2 4;34 A5 1 4;33 B4 1 4;35 A5 1 4;36 G5 1 4;37 G5 1 4;42 F#5 1 4;39 F#5 1 4;40 A4 1 4;41 A4 1 4;43 A4 1 4;45 C#6 1 4;46 B5 1 4;44 C#6 1 4;38 F#5 1 4;47 B4 2 4;50 A5 1 4;49 B4 1 4;51 A5 1 4;52 G5 1 4;53 G5 1 4;58 F#5 1 4;55 F#5 1 4;56 A4 1 4;57 A4 1 4;59 A4 1 4;61 C#6 1 4;62 B5 1 4;60 C#6 1 4;54 F#5 1 4;63 B4 2 4;98 A5 1 4;97 B4 1 4;99 A5 1 4;100 G5 1 4;101 G5 1 4;106 F#5 1 4;103 F#5 1 4;104 A4 1 4;105 A4 1 4;107 A4 1 4;109 C#6 1 4;110 B5 1 4;108 C#6 1 4;102 F#5 1 4;111 B4 2 4;114 A5 1 4;113 B4 1 4;115 A5 1 4;116 G5 1 4;117 G5 1 4;122 F#5 1 4;119 F#5 1 4;120 A4 1 4;121 A4 1 4;123 A4 1 4;125 C#6 1 4;126 B5 1 4;124 C#6 1 4;118 F#5 1 4;127 B4 2 4;66 A5 1 4;65 B4 1 4;67 A5 1 4;68 G5 1 4;69 G5 1 4;74 F#5 1 4;71 F#5 1 4;72 A4 1 4;73 A4 1 4;75 A4 1 4;77 C#6 1 4;78 B5 1 4;76 C#6 1 4;70 F#5 1 4;79 B4 2 4;82 A5 1 4;81 B4 1 4;83 A5 1 4;84 G5 1 4;85 G5 1 4;90 F#5 1 4;87 F#5 1 4;88 A4 1 4;89 A4 1 4;91 A4 1 4;93 C#6 1 4;94 B5 1 4;92 C#6 1 4;86 F#5 1 4;95 B4 2 4;129 B4 1 4;130 B4 1 4;131 B4 1 4;132 B4 1 4;135 B4 1 4;136 B4 1 4;137 B4 1 4;138 B4 1 4;145 D5 1 4;146 D5 1 4;147 D5 1 4;148 D5 1 4;151 E5 1 4;152 E5 1 4;153 E5 1 4;154 E5 1 4;161 B4 1 4;162 B4 1 4;163 B4 1 4;164 B4 1 4;167 B4 1 4;168 B4 1 4;169 B4 1 4;170 B4 1 4;177 D5 1 4;178 D5 1 4;179 D5 1 4;180 D5 1 4;183 E5 1 4;184 E5 1 4;185 E5 1 4;186 E5 1 4;193 B4 1 4;194 B4 1 4;195 B4 1 4;196 B4 1 4;199 B4 1 4;200 B4 1 4;201 B4 1 4;202 B4 1 4;209 D5 1 4;210 D5 1 4;211 D5 1 4;212 D5 1 4;215 E5 1 4;216 E5 1 4;217 E5 1 4;218 E5 1 4;194 D5 1 4;196 F#5 1 4;197 D5 1 4;198 B4 1 4;199 D5 1 4;200 A5 2 4;202 F#5 2 4;204 D5 1 4;205 E5 1 4;206 D5 1 4;207 D5 2 4;0 B4 1 4;209 B4 1 4;211 B4 1 4;212 F#5 1 4;213 D5 1 4;214 B4 1 4;215 D5 1 4;216 G5 2 4;218 F#5 2 4;220 A5 1 4;221 C#6 1 4;222 A5 1 4;223 F#5 2 4;225 B4 1 4;226 B4 1 4;227 B4 1 4;228 B4 1 4;231 B4 1 4;232 B4 1 4;233 B4 1 4;234 B4 1 4;241 D5 1 4;242 D5 1 4;243 D5 1 4;244 D5 1 4;226 D5 1 4;228 F#5 1 4;229 D5 1 4;230 B4 1 4;231 D5 1 4;232 A5 2 4;234 F#5 2 4;236 D5 1 4;237 E5 1 4;238 D5 1 4;239 D5 2 4;241 B4 1 4;243 B4 1 4;244 F#5 1 4;245 D5 1 4;246 B4 1 4;247 D5 1 4;248 G5 2 4;250 F#5 2 4;252 D5 2 4;254 E5 2 4;247 E5 1 4;248 E5 1 4;249 E5 1 4;250 E5 1 4;65 B2 1 4;66 B2 1 4;67 B2 1 4;68 B2 1 4;71 B2 1 4;72 B2 1 4;73 B2 1 4;74 B2 1 4;81 D3 1 4;82 D3 1 4;83 D3 1 4;84 D3 1 4;87 E3 1 4;88 E3 1 4;89 E3 1 4;90 E3 1 4;97 B2 1 4;98 B2 1 4;99 B2 1 4;100 B2 1 4;103 B2 1 4;104 B2 1 4;105 B2 1 4;106 B2 1 4;113 D3 1 4;114 D3 1 4;115 D3 1 4;116 D3 1 4;119 E3 1 4;120 E3 1 4;121 E3 1 4;122 E3 1 4;129 B2 1 4;130 B2 1 4;131 B2 1 4;132 B2 1 4;135 B2 1 4;136 B2 1 4;137 B2 1 4;138 B2 1 4;145 D3 1 4;146 D3 1 4;147 D3 1 4;148 D3 1 4;151 E3 1 4;152 E3 1 4;153 E3 1 4;154 E3 1 4;161 B2 1 4;162 B2 1 4;163 B2 1 4;164 B2 1 4;167 B2 1 4;168 B2 1 4;169 B2 1 4;170 B2 1 4;177 D3 1 4;178 D3 1 4;179 D3 1 4;180 D3 1 4;183 E3 1 4;184 E3 1 4;185 E3 1 4;186 E3 1 4;193 B2 1 4;194 B2 1 4;195 B2 1 4;196 B2 1 4;199 B2 1 4;200 B2 1 4;201 B2 1 4;202 B2 1 4;209 D3 1 4;210 D3 1 4;211 D3 1 4;212 D3 1 4;215 E3 1 4;216 E3 1 4;217 E3 1 4;218 E3 1 4;225 B2 1 4;226 B2 1 4;227 B2 1 4;228 B2 1 4;231 B2 1 4;232 B2 1 4;233 B2 1 4;241 D3 1 4;242 D3 1 4;243 D3 1 4;244 D3 1 4;247 E3 1 4;248 E3 1 4;249 E3 1 4;250 E3 1 4;256 E4 1 4;257 E4 1 4;260 E4 1 4;261 E4 1 4;264 D4 1 4;265 D4 1 4;268 D4 1 4;269 D4 1 4;272 E4 1 4;273 E4 1 4;276 E4 1 4;277 E4 1 4;262 F#5 1 4;266 D5 1 4;270 G5 1 4;274 E5 1 4;278 F#5 1 4;140 F#5 1 4;141 F#5 1 4;143 B4 1 4;156 G5 1 4;158 F#5 1 4;171 B4 1 4;172 F#5 1 4;173 B4 1 4;174 D5 1 4;187 B4 1 4;188 E5 1 4;190 B4 1 4;258 E5 1 4;280 B4 1 4;282 B4 1 4;288 E4 1 4;289 E4 1 4;292 D4 1 4;293 D4 1 4;296 D4 1 4;297 D4 1 4;300 E4 1 4;301 E4 1 4;304 E4 1 4;305 E4 1 4;290 F#5 1 4;294 D5 1 4;298 G5 1 4;302 E5 1 4;306 F#5 1 4;286 E5 1 4;308 B4 1 4;310 B4 1 4;256 F#2 1 4;257 F#2 1 4;258 F#2 1 4;259 F#2 1 4;260 F#2 1 4;261 F#2 1 4;262 F#2 1 4;263 F#2 1 4;264 B2 1 4;265 B2 1 4;266 B2 1 4;267 B2 1 4;268 B2 1 4;269 B2 1 4;270 B2 1 4;271 B2 1 4;272 F#2 1 4;273 F#2 1 4;274 F#2 1 4;275 F#2 1 4;276 F#2 1 4;277 F#2 1 4;278 F#2 1 4;279 F#2 1 4;280 B2 2 4;282 B2 2 4;286 F#2 1 4;287 F#2 1 4;288 F#2 1 4;289 F#2 1 4;290 F#2 1 4;291 F#2 1 4;292 B2 1 4;293 B2 1 4;294 B2 1 4;295 B2 1 4;296 B2 1 4;297 B2 1 4;298 B2 1 4;299 B2 1 4;300 D3 1 4;301 D3 1 4;302 D3 1 4;303 D3 1 4;304 D3 1 4;305 D3 1 4;306 D3 1 4;307 D3 1 4;308 D3 1 4;309 D3 1 4;310 D3 1 4;311 D3 1 4;312 D3 1 4;313 D3 1 4;314 D3 1 4;315 D3 1 4;300 G5 1 4;302 F#5 1 4;304 D5 1 4;300 G5 1 4;306 A4 1 4;308 G5 1 4;310 F#5 1 4;312 C#5 1 4;313 D5 1 4;314 E5 2 4;310 F#5 1 4;316 F#5 1 4;316 E4 1 4;317 E4 1 4;320 E4 1 4;321 E4 1 4;324 D4 1 4;325 D4 1 4;328 D4 1 4;329 D4 1 4;332 E4 1 4;333 E4 1 4;336 E4 1 4;337 E4 1 4;322 F#5 1 4;326 D5 1 4;330 G5 1 4;334 E5 1 4;338 F#5 1 4;318 E5 1 4;340 B4 1 4;342 B4 1 4;348 E4 1 4;349 E4 1 4;352 D4 1 4;353 D4 1 4;356 D4 1 4;357 D4 1 4;360 E4 1 4;361 E4 1 4;364 E4 1 4;365 E4 1 4;350 F#5 1 4;354 D5 1 4;358 G5 1 4;362 E5 1 4;346 E5 1 4;368 B4 1 4;370 B4 1 4;316 F#2 1 4;317 F#2 1 4;318 F#2 1 4;319 F#2 1 4;320 F#2 1 4;321 F#2 1 4;322 F#2 1 4;323 F#2 1 4;324 B2 1 4;325 B2 1 4;326 B2 1 4;327 B2 1 4;328 B2 1 4;329 B2 1 4;330 B2 1 4;331 B2 1 4;332 F#2 1 4;333 F#2 1 4;334 F#2 1 4;335 F#2 1 4;336 F#2 1 4;337 F#2 1 4;338 F#2 1 4;339 F#2 1 4;340 B2 2 4;342 B2 2 4;346 F#2 1 4;347 F#2 1 4;348 F#2 1 4;349 F#2 1 4;350 F#2 1 4;351 F#2 1 4;352 B2 1 4;353 B2 1 4;354 B2 1 4;355 B2 1 4;356 B2 1 4;357 B2 1 4;358 B2 1 4;359 B2 1 4;360 D3 1 4;361 D3 1 4;362 D3 1 4;363 D3 1 4;364 D3 1 4;365 D3 1 4;366 D3 1 4;367 D3 1 4;368 D3 1 4;369 D3 1 4;370 D3 1 4;371 D3 1 4;372 D3 1 4;373 D3 1 4;374 D3 1 4;375 D3 1 4;360 G5 1 4;362 F#5 1 4;364 D5 1 4;360 G5 1 4;366 A4 1 4;368 G5 1 4;372 C#5 1 4;373 D5 1 4;374 E5 2 4;376 F#5 1 4;361 G5 1 4;363 F#5 1 4;369 G5 1 4;366 F#5 1 4;371 B4 1 4;372 G5 1 4;373 G5 1 4;374 G5 1 4;375 G5 1 4;376 G5 1 4;377 G5 1 4;378 F#5 6 4;448 G5 1 4;449 F#5 5 4;456 G5 1 4;457 F#5 1 4;459 E5 1 4;460 D5 1 4;466 A4 1 4;467 A4 1 4;468 G5 1 4;469 G5 1 4;470 G5 1 4;471 G5 1 4;472 G5 1 4;473 G5 1 4;474 F#5 1 4;480 A5 1 4;482 G5 1 4;484 F#5 1 4;486 E5 1 4;489 F#5 1 4;490 D5 1 4;376 B3 1 4;377 B3 1 4;378 B3 1 4;379 B3 1 4;380 B3 1 4;381 B3 1 4;382 B3 1 4;383 B3 1 4;384 A3 1 4;385 A3 1 4;386 A3 1 4;387 A3 1 4;388 A3 1 4;389 A3 1 4;390 A3 1 4;391 A3 1 4;392 G3 1 4;393 G3 1 4;394 G3 1 4;395 G3 1 4;396 G3 1 4;397 G3 1 4;398 G3 1 4;399 G3 1 4;400 D3 1 4;401 D3 1 4;402 C#3 1 4;403 C#3 1 4;404 G3 1 4;405 G3 1 4;406 F#3 1 4;407 F#3 1 4;408 B3 1 4;409 B3 1 4;410 B3 1 4;411 B3 1 4;412 B3 1 4;413 B3 1 4;414 B3 1 4;415 B3 1 4;416 A3 1 4;417 A3 1 4;418 A3 1 4;419 A3 1 4;420 A3 1 4;421 A3 1 4;422 A3 1 4;423 A3 1 4;424 G3 1 4;425 G3 1 4;426 G3 1 4;427 G3 1 4;428 G3 1 4;429 G3 1 4;430 G3 1 4;431 G3 1 4;432 D3 1 4;433 D3 1 4;434 C#3 1 4;435 C#3 1 4;436 G3 1 4;437 G3 1 4;438 F#3 1 4;439 F#3 1 4;440 B3 1 4;441 B3 1 4;442 B3 1 4;443 B3 1 4;444 B3 1 4;445 B3 1 4;446 B3 1 4;447 B3 1 4;448 A3 1 4;449 A3 1 4;450 A3 1 4;451 A3 1 4;452 A3 1 4;453 A3 1 4;454 A3 1 4;455 A3 1 4;456 G3 1 4;457 G3 1 4;458 G3 1 4;459 G3 1 4;460 G3 1 4;461 G3 1 4;462 G3 1 4;463 G3 1 4;464 D3 1 4;465 D3 1 4;466 C#3 1 4;467 C#3 1 4;468 G3 1 4;469 G3 1 4;470 F#3 1 4;471 F#3 1 4;472 B3 1 4;473 B3 1 4;474 B3 1 4;475 B3 1 4;476 B3 1 4;477 B3 1 4;478 B3 1 4;479 B3 1 4;480 A3 1 4;481 A3 1 4;482 A3 1 4;483 A3 1 4;484 A3 1 4;485 A3 1 4;486 A3 1 4;487 A3 1 4;488 G3 1 4;489 G3 1 4;490 G3 1 4;491 G3 1 4;492 G3 1 4;493 G3 1 4;494 G3 1 4;495 G3 1 4;496 D3 1 4;497 D3 1 4;498 C#3 1 4;499 C#3 1 4;500 G3 1 4;501 G3 1 4;502 F#3 1 4;503 F#3 1 4;448 C#4 1 4;449 C#4 1 4;450 C#4 1 4;451 C#4 1 4;452 C#4 1 4;453 C#4 1 4;454 C#4 1 4;455 C#4 1 4;456 D4 1 4;457 D4 1 4;458 D4 1 4;459 D4 1 4;460 D4 1 4;461 D4 1 4;462 D4 1 4;463 D4 1 4;480 C#4 1 4;481 C#4 1 4;482 C#4 1 4;483 C#4 1 4;484 C#4 1 4;485 C#4 1 4;486 C#4 1 4;487 C#4 1 4;488 D4 1 4;489 D4 1 4;490 D4 1 4;491 D4 1 4;492 D4 1 4;493 D4 1 4;494 D4 1 4;495 D4 1 4;234 B2 1 4;522 E3 1 4;378 E5 1 4;382 F#5 1 4;382 E5 1 4;386 F#5 1 4;386 E5 1 4;390 C5 1 4;390 D5 1 4'
# https://onlinesequencer.net/1536953
#song = '0 B5 1 0;4 A5 1 0;14 E5 1 0;10 G#5 1 0;18 C#5 1 0;26 F#5 1 0;28 G#5 1 0;30 A5 1 0;32 B5 1 0;36 A5 1 0;0 E5 1 0;0 F#5 1 0;0 C#5 1 0;4 E5 1 0;4 F#5 1 0;4 C#5 1 0;0 F#3 1 0;14 F#3 1 0;18 F#4 1 0;20 A4 1 0;22 C#5 1 0;24 F#4 1 0;26 A4 1 0;28 C#5 1 0;30 A4 1 0;32 F#5 1 0;36 F#5 1 0;32 D5 1 0;36 D5 1 0;42 G#5 1 0;50 C#6 1 0;46 E5 1 0;32 D3 1 0;46 D3 1 0;56 B5 1 0;60 C#6 1 0;56 B6 1 0;60 C#7 1 0;60 C#7 1 0;50 D4 1 0;52 F#4 1 0;54 C#5 1 0;56 D4 1 0;58 F#4 1 0;60 C#5 1 0;62 D4 1 0;64 B6 1 0;68 A6 1 0;64 B6 1 0;68 A6 1 0;64 C#6 1 0;68 C#6 1 0;64 E6 1 0;64 F#6 1 0;68 E6 1 0;68 F#6 1 0;64 F#3 1 0;64 F#2 1 0;68 F#4 1 0;68 A4 1 0;68 C#5 1 0;68 E5 1 0;74 G#6 1 0;78 E6 1 0;82 C#6 1 0;74 G#6 1 0;78 E6 1 0;82 C#6 1 0;72 F#4 1 0;74 A4 1 0;74 C#5 1 0;74 E5 1 0;78 F#3 1 0;78 F#2 1 0;86 F#4 1 0;86 A4 1 0;86 C#5 1 0;86 F#5 1 0;92 E4 1 0;92 A4 1 0;92 C#5 1 0;90 F#6 1 0;92 G#6 1 0;94 A6 1 0;96 B6 1 0;100 A6 1 0;90 F#6 1 0;92 G#6 1 0;94 A6 1 0;96 B6 1 0;100 A6 1 0;96 D3 1 0;96 D2 1 0;100 F#4 1 0;100 A4 1 0;100 C#5 1 0;100 F#5 1 0;96 B5 1 0;96 D6 1 0;96 F#6 1 0;100 D6 1 0;100 F#6 1 0;100 A5 1 0;106 G#6 1 0;110 E6 1 0;114 C#7 1 0;106 G#5 1 0;110 E5 1 0;114 C#6 1 0;106 G#6 1 0;104 C#5 1 0;106 A4 1 0;110 D3 1 0;110 D2 1 0;116 D4 1 0;116 F#4 1 0;116 A4 1 0;116 C#5 1 0;134 G#5 1 0;132 A5 1 0;140 B5 1 0;142 A5 1 0;138 G#5 1 0;128 F#4 1 0;128 G#4 1 0;128 A4 1 0;128 C#5 1 0;140 F#4 1 0;142 A4 1 0;148 A5 1 0;150 G#5 1 0;156 B5 1 0;154 A5 1 0;144 F#4 1 0;144 A4 1 0;144 C#5 1 0;144 E5 1 0;154 E5 1 0;156 C#5 1 0;158 A4 1 0;160 F#4 1 0;160 D4 1 0;160 A4 1 0;160 C#5 1 0;164 A5 1 0;166 G#5 1 0;170 G#5 1 0;172 B5 1 0;174 A5 1 0;176 D4 1 0;176 E4 1 0;176 F#4 1 0;176 A4 1 0;178 B5 1 0;182 C#6 1 0;188 C#4 1 0;192 B3 1 0;192 D4 1 0;192 F#4 1 0;192 A4 1 0;196 A5 1 0;198 G#5 1 0;202 G#5 1 0;204 B5 1 0;206 A5 1 0;202 B3 1 0;204 D4 1 0;206 F#4 1 0;208 E4 1 0;208 C#4 1 0;208 G#4 1 0;208 B4 1 0;210 B5 1 0;214 C#6 1 0;218 E5 1 0;222 F#5 1 0;218 B4 1 0;220 G#4 1 0;222 E4 1 0;224 D4 1 0;224 F#4 1 0;224 A4 1 0;224 C#5 1 0;228 D4 1 0;230 F#4 1 0;232 A4 1 0;234 C#5 1 0;236 D5 1 0;238 F#5 1 0;240 G#5 1 0;244 A5 1 0;246 G#5 1 0;240 E4 1 0;240 F#4 1 0;240 G#4 1 0;240 B4 1 0;246 E5 1 0;252 B4 1 0;256 F#4 1 0;256 G#4 1 0;256 A4 1 0;256 C#5 1 0;260 F#4 1 0;262 F#3 1 0;262 F#3 1 0;260 A5 1 0;262 G#5 1 0;262 G#5 1 0;268 B5 1 0;266 G#5 1 0;270 A5 1 0;266 A3 1 0;268 C#4 1 0;270 F#4 1 0;268 B5 1 0;272 A4 1 0;272 C#5 1 0;272 E5 1 0;276 A5 1 0;278 G#5 1 0;282 A5 1 0;284 B5 1 0;276 F#4 1 0;276 F#3 1 0;282 E4 1 0;282 E3 1 0;288 D4 1 0;288 D3 1 0;292 A5 1 0;294 G#5 1 0;298 G#5 1 0;300 B5 1 0;302 A5 1 0;292 D4 1 0;292 F#4 1 0;292 A4 1 0;292 C#5 1 0;298 D4 1 0;300 F#4 1 0;300 A4 1 0;300 C#5 1 0;302 D4 1 0;306 B5 1 0;310 C#6 1 0;314 E5 1 0;304 F#4 1 0;304 C#5 1 0;308 D4 1 0;308 E4 1 0;308 F#4 1 0;308 A4 1 0;312 D4 1 0;314 C#4 1 0;312 D3 1 0;314 C#3 1 0;320 B3 1 0;320 B2 1 0;320 F#5 1 0;326 F#5 1 0;332 B5 1 0;334 G#5 1 0;326 B3 1 0;326 D4 1 0;326 F#4 1 0;326 A4 1 0;332 C#4 1 0;332 C#3 1 0;338 C#4 1 0;338 E4 1 0;338 G#4 1 0;338 B4 1 0;344 D4 1 0;344 D3 1 0;348 B3 1 0;348 D4 1 0;348 F#4 1 0;348 A4 1 0;348 F#5 1 0;344 D5 1 0;344 A4 1 0;344 F4 1 0;352 C#4 1 0;352 C#3 1 0;352 G#5 1 0;358 G#5 1 0;362 G#5 1 0;364 A5 1 0;366 B5 1 0;358 C#4 1 0;358 E4 1 0;358 G#4 1 0;358 B4 1 0;364 D4 1 0;364 D3 1 0;370 C6 1 0;374 D6 1 0;376 E6 1 0;380 B5 1 0;384 C#6 1 0;370 D4 1 0;370 F4 1 0;370 A4 1 0;370 C5 1 0;376 E4 1 0;376 E3 1 0;384 C#7 1 0;384 F#2 1 0;384 F#3 1 0;388 A4 1 0;388 C#5 1 0;388 E5 1 0;390 F#4 1 0;392 G#4 1 0;392 A4 1 0;392 C#5 1 0;394 F#4 1 0;394 G#4 1 0;394 A4 1 0;394 C#5 1 0;398 F#3 1 0;400 F#3 1 0;400 F#2 1 0;404 C#5 1 0;406 C#5 1 0;404 A4 1 0;404 G#4 1 0;405 F#4 1 0;406 A4 1 0;406 G#4 1 0;407 F#4 1 0;408 F#3 1 0;408 F#2 1 0;410 C#6 1 0;412 E6 1 0;414 C#6 1 0;410 C#5 1 0;412 E5 1 0;414 C#5 1 0;410 C#6 1 0;412 E6 1 0;414 C#6 1 0;416 G#6 1 0;418 F#6 1 0;416 G#5 1 0;418 F#5 1 0;416 G#6 1 0;418 F#6 1 0;420 F#6 1 0;422 E6 1 0;426 F#6 1 0;430 G#6 1 0;434 A6 1 0;440 A6 1 0;442 G#6 1 0;444 B5 1 0;446 B5 1 0;440 E6 1 0;440 E6 1 0;416 F#3 1 0;416 F#2 1 0;416 F#2 1 0;420 F#4 1 0;422 A4 1 0;422 C#5 1 0;422 E5 1 0;426 A4 1 0;426 C#5 1 0;426 E5 1 0;428 F#4 1 0;430 F#3 1 0;430 F#2 1 0;430 F#2 1 0;434 F#4 1 0;436 A4 1 0;436 C#5 1 0;436 E5 1 0;440 A4 1 0;440 C#5 1 0;440 E5 1 0;442 F#4 1 0;444 G#4 1 0;444 A4 1 0;444 C#5 1 0;450 C#6 1 0;452 C#6 1 0;452 F#6 1 0;454 E6 1 0;458 F#6 1 0;462 G#6 1 0;466 A6 1 0;470 B6 1 0;472 C#7 1 0;474 A6 1 0;476 B6 1 0;478 F#6 1 0;448 F#3 1 0;448 F#2 1 0;448 F#2 1 0;452 F#4 1 0;454 A4 1 0;454 C#5 1 0;454 E5 1 0;458 E5 1 0;458 C#5 1 0;458 A4 1 0;460 F#4 1 0;462 F#3 1 0;462 F#2 1 0;462 F#2 1 0;466 F#4 1 0;468 A4 1 0;468 C#5 1 0;468 E5 1 0;472 A4 1 0;472 C#5 1 0;472 E5 1 0;476 F#4 1 0;476 G#4 1 0;476 A4 1 0;476 C#5 1 0;474 C#6 1 0;476 E6 1 0;478 C#6 1 0;480 B6 1 0;482 A6 1 0;480 B5 1 0;482 A5 1 0;480 B6 1 0;482 A6 1 0;484 F#6 1 0;486 E6 1 0;490 F#6 1 0;494 G#6 1 0;498 A6 1 0;506 F#6 1 0;508 B6 1 0;510 A6 1 0;508 B5 1 0;510 A5 1 0;506 F#5 1 0;506 F#6 1 0;508 B6 1 0;510 A6 1 0;500 A4 1 0;500 C#5 1 0;504 A4 1 0;504 C#5 1 0;480 D3 1 0;480 D2 1 0;480 D2 1 0;494 D3 1 0;494 D2 1 0;494 D2 1 0;484 D4 1 0;486 F#4 1 0;486 A4 1 0;486 C#5 1 0;490 F#4 1 0;490 A4 1 0;490 C#5 1 0;492 D4 1 0;498 D4 1 0;500 F#4 1 0;504 F#4 1 0;506 D4 1 0;508 E4 1 0;508 F#4 1 0;508 A4 1 0;512 D3 1 0;512 D2 1 0;512 D2 1 0;516 D4 1 0;518 F#4 1 0;518 A4 1 0;518 C#5 1 0;522 F#4 1 0;522 A4 1 0;522 C#5 1 0;524 D4 1 0;526 D3 1 0;526 D2 1 0;526 D2 1 0;530 D4 1 0;532 F#4 1 0;532 A4 1 0;532 C#5 1 0;536 F#4 1 0;536 A4 1 0;536 C#5 1 0;540 D4 1 0;540 E4 1 0;540 F#4 1 0;540 A4 1 0;516 F#6 1 0;518 E6 1 0;522 F#6 1 0;526 G#6 1 0;530 A6 1 0;534 B6 1 0;536 C#7 1 0;538 A6 1 0;540 B6 1 0;542 F#6 1 0;538 C#6 1 0;540 E6 1 0;542 C#6 1 0;544 G#6 1 0;546 F#6 1 0;544 G#6 1 0;546 F#6 1 0;544 G#5 1 0;546 F#5 1 0;548 F#6 1 0;550 E6 1 0;554 F#6 1 0;558 G#6 1 0;562 A6 1 0;568 A6 1 0;570 G#6 1 0;572 B5 1 0;574 B5 1 0;568 E6 1 0;568 E6 1 0;544 F#3 1 0;544 F#2 1 0;544 F#2 1 0;548 F#4 1 0;550 A4 1 0;550 C#5 1 0;550 E5 1 0;554 A4 1 0;554 C#5 1 0;554 E5 1 0;556 F#4 1 0;558 F#3 1 0;558 F#2 1 0;558 F#2 1 0;562 F#4 1 0;564 A4 1 0;564 C#5 1 0;564 E5 1 0;568 A4 1 0;568 C#5 1 0;568 E5 1 0;570 F#4 1 0;572 G#4 1 0;572 A4 1 0;572 C#5 1 0;578 C#6 1 0;580 C#6 1 0;598 B6 1 0;600 C#7 1 0;602 A6 1 0;604 B6 1 0;606 F#6 1 0;580 F#6 1 0;582 E6 1 0;586 F#6 1 0;590 G#6 1 0;594 A6 1 0;576 F#3 1 0;576 F#2 1 0;576 F#2 1 0;580 F#4 1 0;582 A4 1 0;582 C#5 1 0;582 E5 1 0;586 E5 1 0;586 C#5 1 0;586 A4 1 0;588 F#4 1 0;590 F#3 1 0;590 F#2 1 0;590 F#2 1 0;580 C#6 1 0;602 C#6 1 0;604 E6 1 0;606 C#6 1 0;594 F#4 1 0;596 A4 1 0;596 C#5 1 0;596 E5 1 0;600 A4 1 0;600 C#5 1 0;600 E5 1 0;604 F#4 1 0;604 G#4 1 0;604 A4 1 0;604 C#5 1 0;608 B6 1 0;610 A6 1 0;608 B6 1 0;610 A6 1 0;608 B5 1 0;610 A5 1 0;608 D3 1 0;608 D2 1 0;608 D2 1 0;612 D4 1 0;614 F#4 1 0;614 A4 1 0;614 C#5 1 0;618 F#4 1 0;618 A4 1 0;618 C#5 1 0;620 D4 1 0;622 D3 1 0;622 D2 1 0;622 D2 1 0;612 F#6 1 0;614 E6 1 0;618 F#6 1 0;622 G#6 1 0;626 A6 1 0;634 F#5 1 0;636 B5 1 0;638 A5 1 0;634 F#6 1 0;636 B6 1 0;638 A6 1 0;634 F#6 1 0;636 B6 1 0;638 A6 1 0;626 D4 1 0;628 F#4 1 0;628 A4 1 0;628 C#5 1 0;632 F#4 1 0;632 A4 1 0;632 C#5 1 0;634 D4 1 0;636 E4 1 0;636 F#4 1 0;636 A4 1 0;640 D3 1 0;640 D2 1 0;640 D2 1 0;644 D4 1 0;646 F#4 1 0;646 A4 1 0;646 C#5 1 0;650 F#4 1 0;650 A4 1 0;650 C#5 1 0;652 D4 1 0;654 D3 1 0;654 D2 1 0;654 D2 1 0;644 F#6 1 0;646 E6 1 0;650 F#6 1 0;654 G#6 1 0;658 A6 1 0;662 B6 1 0;664 C#7 1 0;666 A6 1 0;668 B6 1 0;670 F#6 1 0;658 D4 1 0;660 F#4 1 0;660 A4 1 0;660 C#5 1 0;664 D4 1 0;664 F#4 1 0;664 A4 1 0;664 C#5 1 0;668 E3 1 0;668 E2 1 0;668 E2 1 0;680 F#3 1 0;672 A6 1 0;676 A6 1 0;680 A6 1 0;672 A6 1 0;676 A6 1 0;680 A6 1 0;672 A5 1 0;676 A5 1 0;680 A5 1 0;672 C#6 1 0;672 E6 1 0;676 C#6 1 0;676 E6 1 0;680 C#6 1 0;680 E6 1 0;672 F#3 1 0;676 F#3 1 0;672 F#2 1 0;674 F#2 1 0;676 F#2 1 0;678 F#2 1 0;680 F#2 1 0;672 F#2 1 0;676 F#2 1 0;680 F#2 1 0;686 A5 1 0;686 C#6 1 0;686 E6 1 0;686 A6 1 0;686 A6 1 0;690 A5 1 0;690 C#6 1 0;690 E6 1 0;690 A6 1 0;694 A5 1 0;694 C#6 1 0;694 E6 1 0;694 A6 1 0;696 G#5 1 0;700 B5 1 0;696 G#6 1 0;700 B6 1 0;696 G#6 1 0;700 B6 1 0;682 A2 1 0;682 A3 1 0;684 C#4 1 0;684 C#3 1 0;684 C#3 1 0;686 F#3 1 0;686 F#4 1 0;696 C#6 1 0;696 E6 1 0;700 C#6 1 0;700 E6 1 0;690 F#3 1 0;692 F#3 1 0;694 F#3 1 0;696 E3 1 0;698 E3 1 0;700 E3 1 0;702 E3 1 0;692 F#3 1 0;692 F#4 1 0;696 E4 1 0;696 E3 1 0;700 E3 1 0;700 E4 1 0;686 F#3 1 0;704 A5 1 0;704 A6 1 0;704 A6 1 0;712 A6 1 0;718 A6 1 0;718 A6 1 0;712 A6 1 0;708 A6 1 0;708 A6 1 0;708 A5 1 0;712 A5 1 0;718 A5 1 0;704 C#6 1 0;704 E6 1 0;708 C#6 1 0;708 E6 1 0;712 C#6 1 0;712 E6 1 0;718 C#6 1 0;718 E6 1 0;704 D4 1 0;708 D4 1 0;712 D4 1 0;704 D3 1 0;704 D3 1 0;706 D3 1 0;708 D3 1 0;708 D3 1 0;710 D3 1 0;712 D3 1 0;712 D3 1 0;714 A3 1 0;714 A2 1 0;716 F#3 1 0;716 F#2 1 0;716 F#2 1 0;718 D2 1 0;718 D2 1 0;718 D3 1 0;722 D2 1 0;724 D2 1 0;724 D2 1 0;726 D2 1 0;728 E2 1 0;728 E2 1 0;730 E2 1 0;732 E2 1 0;732 E2 1 0;734 E2 1 0;722 D3 1 0;726 D3 1 0;728 E3 1 0;732 E3 1 0;722 A6 1 0;726 A6 1 0;728 G#6 1 0;732 B6 1 0;722 A5 1 0;726 A5 1 0;728 G#5 1 0;732 B5 1 0;722 C#6 1 0;722 E6 1 0;726 C#6 1 0;726 E6 1 0;728 C#6 1 0;728 E6 1 0;732 C#6 1 0;732 E6 1 0;736 F#2 1 0;736 F#2 1 0;738 F#2 1 0;740 F#2 1 0;740 F#2 1 0;742 F#2 1 0;744 F#2 1 0;744 F#2 1 0;736 F#3 1 0;740 F#3 1 0;744 F#3 1 0;746 A2 1 0;748 C#3 1 0;746 A3 1 0;748 C#4 1 0;748 C#3 1 0;750 E2 1 0;750 E3 1 0;750 E2 1 0;736 A6 1 0;740 A6 1 0;744 A6 1 0;750 A6 1 0;750 A6 1 0;744 A6 1 0;740 A6 1 0;736 A6 1 0;736 A5 1 0;740 A5 1 0;744 A5 1 0;750 A5 1 0;736 C#6 1 0;736 E6 1 0;740 C#6 1 0;740 E6 1 0;744 C#6 1 0;744 E6 1 0;750 C#6 1 0;750 E6 1 0;754 A6 1 0;758 A6 1 0;760 G#6 1 0;764 B6 1 0;768 A6 1 0;774 F#6 1 0;780 C#7 1 0;754 A6 1 0;758 A6 1 0;760 G#6 1 0;764 B6 1 0;768 A6 1 0;774 F#6 1 0;780 C#7 1 0;754 A5 1 0;758 A5 1 0;760 G#5 1 0;764 B5 1 0;768 A5 1 0;774 F#5 1 0;780 C#6 1 0;754 C#6 1 0;754 E6 1 0;758 C#6 1 0;758 E6 1 0;760 C#6 1 0;760 E6 1 0;764 C#6 1 0;764 E6 1 0;754 E2 1 0;756 E2 1 0;758 E2 1 0;760 E2 1 0;762 E2 1 0;756 E3 1 0;760 E3 1 0;756 E2 1 0;760 E2 1 0;764 A3 1 0;766 C#4 1 0;764 A2 1 0;766 C#3 1 0;764 A2 1 0;768 D3 1 0;768 D4 1 0;768 D3 1 0;768 D4 1 0;774 D4 1 0;774 D3 1 0;774 D3 1 0;774 D4 1 0;780 D3 1 0;780 D2 1 0;780 D2 1 0;780 D3 1 0;768 C#6 1 0;768 E6 1 0;774 D6 1 0;774 B5 1 0;780 F#6 1 0;780 A6 1 0;784 C2 1 8'
# https://onlinesequencer.net/1087370 - Battle Music
#song = '0 F4 1 0;0 G#4 1 0;0 C4 1 0;0 F3 1 0;0 F2 1 0;12 A#4 1 0;18 G4 1 0;12 G4 1 0;18 D#4 1 0;24 A#4 1 0;30 C5 1 0;24 F4 1 0;24 C#4 1 0;12 F3 1 0;18 F3 1 0;12 F2 1 0;18 F2 1 0;24 F2 1 0;24 F3 1 0;36 F3 1 0;36 F2 1 0;36 D#5 1 0;36 D#4 1 0;36 G4 1 0;36 A#4 1 0;48 G#4 1 0;48 C5 1 0;48 F4 1 0;48 C4 1 0;48 F3 1 0;48 F2 1 0;60 F2 1 0;66 F2 1 0;60 F3 1 0;66 F3 1 0;60 G#4 1 0;60 F4 1 0;66 D#4 1 0;66 G4 1 0;72 A#4 1 0;72 F3 1 0;72 F2 1 0;72 C#4 1 0;72 F4 1 0;84 F2 1 0;84 F3 1 0;84 E4 1 0;84 E5 1 0;90 G5 1 0;90 G4 1 0;84 A#4 1 0;90 A#4 1 0;96 F5 1 0;96 F6 1 0;96 G#5 1 0;96 C6 1 0;96 F2 1 0;96 F3 1 0;98 C4 1 0;98 G#4 1 0;99 F4 1 0;100 G#4 1 0;102 G#4 1 0;101 F4 1 0;103 F4 1 0;100 C4 1 0;102 C4 1 0;104 G#4 1 0;106 G#4 1 0;105 F4 1 0;107 F4 1 0;104 C4 1 0;106 C4 1 0;108 A#4 1 0;110 A#4 1 0;112 A#4 1 0;114 A#4 1 0;116 A#4 1 0;118 A#4 1 0;109 F4 1 0;111 F4 1 0;113 F4 1 0;115 F4 1 0;117 F4 1 0;119 F4 1 0;108 C#4 1 0;110 C#4 1 0;112 C#4 1 0;114 C#4 1 0;116 C#4 1 0;118 C#4 1 0;114 E5 1 0;114 E6 1 0;114 E6 1 0;120 G6 1 0;120 G5 1 0;120 A#5 1 0;120 C#6 1 0;120 C#5 1 0;122 C#5 1 0;124 C#5 1 0;126 C#5 1 0;128 C#5 1 0;130 C#5 1 0;120 F4 1 0;122 F4 1 0;124 F4 1 0;126 F4 1 0;128 F4 1 0;130 F4 1 0;121 A#4 1 0;123 A#4 1 0;125 A#4 1 0;127 A#4 1 0;129 A#4 1 0;131 A#4 1 0;132 C5 1 0;134 C5 1 0;136 C5 1 0;138 C5 1 0;140 C5 1 0;142 C5 1 0;132 F4 1 0;134 F4 1 0;136 F4 1 0;138 F4 1 0;140 F4 1 0;142 F4 1 0;133 G#4 1 0;135 G#4 1 0;137 G#4 1 0;139 G#4 1 0;141 G#4 1 0;143 G#4 1 0;138 F5 1 0;138 F6 1 0;144 G#6 1 0;144 F3 1 0;145 C4 1 0;146 G#4 1 0;146 C4 1 0;147 F4 1 0;148 G#4 1 0;149 F4 1 0;148 C4 1 0;150 G#4 1 0;152 G#4 1 0;154 G#4 1 0;151 F4 1 0;153 F4 1 0;155 F4 1 0;150 C4 1 0;152 C4 1 0;154 C4 1 0;144 G#5 1 0;144 C6 1 0;144 F6 1 0;156 C#4 1 0;156 A#4 1 0;158 A#4 1 0;160 A#4 1 0;162 A#4 1 0;164 A#4 1 0;166 A#4 1 0;157 F4 1 0;159 F4 1 0;161 F4 1 0;163 F4 1 0;165 F4 1 0;167 F4 1 0;158 C#4 1 0;160 C#4 1 0;162 C#4 1 0;164 C#4 1 0;166 C#4 1 0;156 G6 1 0;156 G5 1 0;162 G#6 1 0;162 G#5 1 0;168 A#6 1 0;168 A#5 1 0;168 C#5 1 0;170 C#5 1 0;172 C#5 1 0;174 C#5 1 0;176 C#5 1 0;178 C#5 1 0;168 F4 1 0;170 F4 1 0;172 F4 1 0;174 F4 1 0;176 F4 1 0;178 F4 1 0;169 A#4 1 0;171 A#4 1 0;173 A#4 1 0;175 A#4 1 0;177 A#4 1 0;179 A#4 1 0;180 C5 1 0;182 C5 1 0;184 C5 1 0;186 C5 1 0;188 C5 1 0;190 C5 1 0;180 F4 1 0;182 F4 1 0;184 F4 1 0;186 F4 1 0;188 F4 1 0;190 F4 1 0;181 G#4 1 0;183 G#4 1 0;185 G#4 1 0;187 G#4 1 0;189 G#4 1 0;191 G#4 1 0;168 C#6 1 0;168 F6 1 0;180 G5 1 0;180 G6 1 0;178 G#6 1 0;178 G#5 1 0;192 F3 1 0;192 F2 1 0;192 F2 1 0;198 C4 1 0;200 C4 1 0;202 C4 1 0;204 C#4 1 0;206 C#4 1 0;208 C#4 1 0;210 C#4 1 0;212 C#4 1 0;214 C#4 1 0;198 F4 1 0;200 F4 1 0;202 F4 1 0;204 F4 1 0;206 F4 1 0;208 F4 1 0;210 F4 1 0;212 F4 1 0;214 F4 1 0;198 G#4 1 0;200 G#4 1 0;202 G#4 1 0;204 A#4 1 0;206 A#4 1 0;208 A#4 1 0;210 A#4 1 0;212 A#4 1 0;214 A#4 1 0;192 F6 1 0;192 F5 1 0;192 G#5 1 0;192 C6 1 0;216 F3 1 0;216 F2 1 0;216 F2 1 0;198 F5 1 0;204 E5 1 0;210 G5 1 0;198 C5 1 0;204 C#5 1 0;210 C#5 1 0;210 E5 1 0;222 G#4 1 0;224 G#4 1 0;226 G#4 1 0;228 A#4 1 0;230 A#4 1 0;232 A#4 1 0;234 A#4 1 0;236 A#4 1 0;238 A#4 1 0;222 F4 1 0;224 F4 1 0;226 F4 1 0;228 F4 1 0;230 F4 1 0;232 F4 1 0;234 F4 1 0;236 F4 1 0;238 F4 1 0;222 C4 1 0;224 C4 1 0;226 C4 1 0;228 C#4 1 0;230 C#4 1 0;232 C#4 1 0;234 C#4 1 0;236 C#4 1 0;238 C#4 1 0;222 F5 1 0;222 C5 1 0;228 C#5 1 0;228 E5 1 0;228 G5 1 0;234 A#5 1 0;234 G5 1 0;234 E5 1 0;234 C#5 1 0;240 F3 1 0;240 F2 1 0;240 F2 1 0;246 C4 1 0;248 C4 1 0;250 C4 1 0;252 C#4 1 0;254 C#4 1 0;256 C#4 1 0;258 C#4 1 0;260 C#4 1 0;262 C#4 1 0;246 F4 1 0;248 F4 1 0;250 F4 1 0;252 F4 1 0;254 F4 1 0;256 F4 1 0;258 F4 1 0;260 F4 1 0;262 F4 1 0;246 G#4 1 0;248 G#4 1 0;250 G#4 1 0;252 A#4 1 0;254 A#4 1 0;256 A#4 1 0;258 A#4 1 0;260 A#4 1 0;262 A#4 1 0;246 F6 1 0;252 E6 1 0;258 G6 1 0;246 F5 1 0;252 E5 1 0;258 G5 1 0;246 G#5 1 0;246 C6 1 0;252 G5 1 0;252 A#5 1 0;258 A#5 1 0;258 C#6 1 0;264 F3 1 0;264 F2 1 0;264 F2 1 0;270 G#4 1 0;272 G#4 1 0;274 G#4 1 0;276 A#4 1 0;278 A#4 1 0;280 A#4 1 0;282 A#4 1 0;284 A#4 1 0;286 A#4 1 0;270 F4 1 0;272 F4 1 0;274 F4 1 0;276 F4 1 0;278 F4 1 0;280 F4 1 0;282 F4 1 0;284 F4 1 0;286 F4 1 0;270 C4 1 0;272 C4 1 0;274 C4 1 0;276 C#4 1 0;278 C#4 1 0;280 C#4 1 0;282 C#4 1 0;284 C#4 1 0;286 C#4 1 0;270 C7 1 0;270 C6 1 0;270 F6 1 0;270 G#6 1 0;276 A#6 1 0;282 G6 1 0;276 A#5 1 0;282 G5 1 0;276 C#6 1 0;276 F6 1 0;282 A#5 1 0;282 C#6 1 0;288 F5 1 0;288 F6 1 0;288 G#5 1 0;288 C6 1 0;288 F3 1 0;288 F2 1 0;290 G#4 1 0;291 F4 1 0;290 C4 1 0;292 C4 1 0;294 C4 1 0;296 C4 1 0;298 C4 1 0;293 F4 1 0;295 F4 1 0;297 F4 1 0;299 F4 1 0;292 G#4 1 0;294 G#4 1 0;296 G#4 1 0;298 G#4 1 0;300 G#4 1 0;302 G#4 1 0;304 G#4 1 0;306 G#4 1 0;308 G#4 1 0;310 G#4 1 0;301 F4 1 0;303 F4 1 0;305 F4 1 0;307 F4 1 0;309 F4 1 0;311 F4 1 0;300 C4 1 0;302 C4 1 0;304 C4 1 0;306 C4 1 0;308 C4 1 0;310 C4 1 0;312 C#4 1 0;312 A#4 1 0;314 A#4 1 0;316 A#4 1 0;318 A#4 1 0;320 A#4 1 0;322 A#4 1 0;324 A#4 1 0;326 A#4 1 0;328 A#4 1 0;330 A#4 1 0;332 A#4 1 0;334 A#4 1 0;313 F4 1 0;315 F4 1 0;317 F4 1 0;319 F4 1 0;321 F4 1 0;323 F4 1 0;325 F4 1 0;327 F4 1 0;329 F4 1 0;331 F4 1 0;333 F4 1 0;335 F4 1 0;314 C#4 1 0;316 C#4 1 0;318 C#4 1 0;320 C#4 1 0;322 C#4 1 0;324 C#4 1 0;326 C#4 1 0;328 C#4 1 0;330 C#4 1 0;332 C#4 1 0;334 C#4 1 0;312 G6 1 0;312 G5 1 0;312 A#5 1 0;312 C#6 1 0;324 A#6 1 0;324 A#5 1 0;324 C#6 1 0;324 F6 1 0;336 G#6 1 0;336 G#5 1 0;336 F3 1 0;337 C4 1 0;338 G#4 1 0;338 C4 1 0;339 F4 1 0;340 G#4 1 0;341 F4 1 0;340 C4 1 0;342 G#4 1 0;344 G#4 1 0;346 G#4 1 0;343 F4 1 0;345 F4 1 0;347 F4 1 0;342 C4 1 0;344 C4 1 0;346 C4 1 0;348 G#4 1 0;350 G#4 1 0;352 G#4 1 0;354 G#4 1 0;356 G#4 1 0;358 G#4 1 0;348 C4 1 0;350 C4 1 0;352 C4 1 0;354 C4 1 0;356 C4 1 0;358 C4 1 0;349 F4 1 0;351 F4 1 0;353 F4 1 0;355 F4 1 0;357 F4 1 0;359 F4 1 0;336 C6 1 0;336 F6 1 0;348 G6 1 0;354 G#6 1 0;348 G5 1 0;354 G#5 1 0;360 A#5 1 0;360 A#6 1 0;360 A#4 1 0;362 A#4 1 0;364 A#4 1 0;366 A#4 1 0;368 A#4 1 0;370 A#4 1 0;372 A#4 1 0;374 A#4 1 0;376 A#4 1 0;378 A#4 1 0;380 A#4 1 0;382 A#4 1 0;361 F4 1 0;363 F4 1 0;365 F4 1 0;367 F4 1 0;369 F4 1 0;371 F4 1 0;373 F4 1 0;375 F4 1 0;377 F4 1 0;379 F4 1 0;381 F4 1 0;383 F4 1 0;360 C#4 1 0;362 C#4 1 0;364 C#4 1 0;366 C#4 1 0;368 C#4 1 0;370 C#4 1 0;372 C#4 1 0;374 C#4 1 0;376 C#4 1 0;378 C#4 1 0;380 C#4 1 0;382 C#4 1 0;360 C#6 1 0;360 F6 1 0;372 G5 1 0;372 G6 1 0;378 E6 1 0;378 E5 1 0;384 F6 1 0;384 F5 1 0;384 G#5 1 0;384 C6 1 0;384 F2 1 0;384 F3 1 0;386 A#3 1 0;387 C4 1 0;388 A#3 1 0;390 F4 1 0;392 A#3 1 0;394 C4 1 0;396 F3 1 0;396 F2 1 0;398 A#3 1 0;399 C4 1 0;400 A#3 1 0;401 C4 1 0;402 F4 1 0;403 A#3 1 0;404 C4 1 0;405 F4 1 0;406 A#3 1 0;407 C4 1 0;408 G5 1 0;408 G6 1 0;408 A#5 1 0;408 C#6 1 0;408 F3 1 0;408 F2 1 0;410 A#3 1 0;411 C#4 1 0;412 A#3 1 0;413 C#4 1 0;414 G4 1 0;415 A#3 1 0;416 C#4 1 0;417 G4 1 0;418 A#3 1 0;419 C#4 1 0;420 G4 1 0;423 G4 1 0;426 G4 1 0;429 G4 1 0;421 A#3 1 0;422 C#4 1 0;424 A#3 1 0;425 C#4 1 0;427 A#3 1 0;428 C#4 1 0;430 A#3 1 0;431 C#4 1 0;420 A#5 1 0;420 A#6 1 0;426 C#6 1 0;426 C#7 1 0;420 C#6 1 0;420 F6 1 0;426 F6 1 0;426 A#6 1 0;384 F3 1 0;396 F3 1 0;408 F3 1 0;432 C7 1 0;432 C6 1 0;432 F6 1 0;432 G#6 1 0;432 F3 1 0;432 F2 1 0;434 A#3 1 0;435 C4 1 0;436 A#3 1 0;438 F4 1 0;440 A#3 1 0;442 C4 1 0;432 F3 1 0;444 F3 1 0;444 F3 1 0;444 F2 1 0;446 A#3 1 0;447 C4 1 0;448 A#3 1 0;449 C4 1 0;450 F4 1 0;451 A#3 1 0;452 C4 1 0;453 F4 1 0;454 A#3 1 0;455 C4 1 0;444 G6 1 0;444 G5 1 0;450 A#5 1 0;450 A#6 1 0;456 C6 1 0;456 C7 1 0;456 A#6 1 0;456 F6 1 0;456 F3 1 0;456 F2 1 0;456 F3 1 0;458 A#3 1 0;459 C#4 1 0;460 A#3 1 0;461 C#4 1 0;462 G4 1 0;463 A#3 1 0;465 G4 1 0;466 A#3 1 0;464 C#4 1 0;467 C#4 1 0;468 G4 1 0;471 G4 1 0;474 G4 1 0;477 G4 1 0;469 A#3 1 0;470 C#4 1 0;472 A#3 1 0;473 C#4 1 0;475 A#3 1 0;476 C#4 1 0;478 A#3 1 0;479 C#4 1 0;468 C#7 1 0;468 C#6 1 0;468 F6 1 0;468 A#6 1 0;474 C7 1 0;474 A#6 1 0;474 F6 1 0;474 C6 1 0;480 F3 1 0;480 F2 1 0;480 F5 1 0;480 F4 1 0;480 C5 1 0;488 G5 1 0;490 G#5 1 0;492 F5 1 0;492 F4 1 0;492 C#5 1 0;492 C#3 1 0;492 C#4 1 0;488 G4 1 0;490 G#4 1 0;500 G5 1 0;502 G#5 1 0;504 F5 1 0;504 F4 1 0;500 G4 1 0;502 G#4 1 0;504 B4 1 0;504 B3 1 0;504 B2 1 0;512 G5 1 0;514 G#5 1 0;516 F5 1 0;522 E5 1 0;512 G4 1 0;514 G#4 1 0;516 F4 1 0;522 E4 1 0;516 C5 1 0;516 C4 1 0;516 C3 1 0;522 C5 1 0;528 A#3 1 0;528 A#2 1 0;528 F4 1 0;528 F5 1 0;528 A#4 1 0;536 G5 1 0;538 G#5 1 0;540 F5 1 0;536 G4 1 0;538 G#4 1 0;540 F4 1 0;540 G#4 1 0;540 G#3 1 0;540 G#2 1 0;548 G4 1 0;550 G#4 1 0;552 F4 1 0;548 G5 1 0;550 G#5 1 0;552 F5 1 0;552 B4 1 0;552 B3 1 0;552 B2 1 0;560 G5 1 0;562 G#5 1 0;564 F5 1 0;570 E5 1 0;560 G4 1 0;562 G#4 1 0;564 F4 1 0;570 E4 1 0;564 C5 1 0;564 C4 1 0;564 C3 1 0;570 C5 1 0;576 F2 1 0;576 F3 1 0;578 F3 1 0;580 F3 1 0;582 F3 1 0;584 F3 1 0;586 F3 1 0;588 F3 1 0;590 F3 1 0;592 F3 1 0;594 F3 1 0;596 F3 1 0;598 F3 1 0;578 C4 1 0;580 C4 1 0;582 C4 1 0;584 C4 1 0;586 C4 1 0;588 C4 1 0;590 C4 1 0;592 C4 1 0;594 C4 1 0;596 C4 1 0;598 C4 1 0;576 C5 1 0;582 C#5 1 0;588 C5 1 0;576 F4 1 0;582 F4 1 0;588 F4 1 0;594 B4 1 0;594 F4 1 0;600 C5 1 0;606 C#5 1 0;612 C5 1 0;618 B4 1 0;600 F4 1 0;606 F4 1 0;612 F4 1 0;618 F4 1 0;602 C4 1 0;604 C4 1 0;606 C4 1 0;608 C4 1 0;610 C4 1 0;612 C4 1 0;614 C4 1 0;616 C4 1 0;618 C4 1 0;620 C4 1 0;622 C4 1 0;600 F3 1 0;602 F3 1 0;604 F3 1 0;606 F3 1 0;608 F3 1 0;610 F3 1 0;612 F3 1 0;614 F3 1 0;616 F3 1 0;618 F3 1 0;620 F3 1 0;622 F3 1 0;600 F2 1 0;624 F3 1 0;624 F2 1 0;626 C5 1 0;627 C#5 1 0;628 C5 1 0;626 F4 1 0;632 C5 1 0;633 C#5 1 0;634 C5 1 0;632 F4 1 0;630 F3 1 0;630 F2 1 0;648 F3 1 0;654 F3 1 0;648 F2 1 0;654 F2 1 0;650 C5 1 0;651 C#5 1 0;652 C5 1 0;650 F4 1 0;656 C5 1 0;657 C#5 1 0;658 C5 1 0;656 F4 1 0;672 C2 1 17'
# https://onlinesequencer.net/49771 - Pokemon HGSS Dark Cave / Ice Path
#song = '200 C7 8 0;208 D7 2 0;210 C7 2 0;212 A#6 2 0;214 G6 4 0;218 A#6 2 0;220 D7 4 0;224 C#7 16 0;240 C7 16 0;264 C7 8 0;272 D7 2 0;274 C7 2 0;276 A#6 2 0;278 G6 4 0;282 A#6 2 0;284 D7 4 0;288 C#7 12 0;300 C7 2 0;302 C#7 2 0;304 D#7 16 0;320 F6 4 0;324 D#6 2 0;326 D6 2 0;328 D#6 4 0;332 D6 2 0;334 C6 2 0;336 D6 2 0;338 C6 2 0;340 A#5 2 0;342 C6 2 0;344 D6 4 0;348 C6 2 0;350 A#5 2 0;352 C#6 8 0;360 A#5 8 0;368 D#6 2 0;370 D6 2 0;372 C6 2 0;374 A#5 2 0;376 C6 8 0;384 F6 4 0;388 D#6 2 0;390 D6 2 0;392 D#6 4 0;396 D6 2 0;398 C6 2 0;400 D6 2 0;402 C6 2 0;404 A#5 2 0;406 C6 2 0;408 D6 4 0;412 C6 2 0;414 A#5 2 0;416 C#6 4 0;420 C6 2 0;422 C#6 2 0;424 C6 2 0;426 C#6 2 0;428 A#5 2 0;430 C#6 2 0;432 C6 16 0;456 C7 8 0;464 D7 2 0;466 C7 2 0;468 A#6 2 0;470 G6 4 0;474 A#6 2 0;476 D7 4 0;480 C#7 16 0;496 C7 16 0;520 C7 8 0;528 D7 2 0;530 C7 2 0;532 A#6 2 0;534 G6 4 0;538 A#6 2 0;540 D7 4 0;544 C#7 16 0;560 C7 16 0;600 A#5 2 0;602 C6 2 0;604 C#6 4 0;608 C6 16 0;632 C#6 2 0;634 C6 2 0;636 C#6 4 0;640 C6 16 0;656 D#6 2 0;664 A#5 2 0;666 C6 2 0;668 C#6 4 0;672 C6 16 0;688 A#5 2 0;696 C#6 2 0;698 C6 2 0;700 C#6 4 0;768 D#7 16 0;784 D7 16 0;800 F7 16 0;816 D#7 16 0;904 C7 8 0;912 D7 2 0;914 C7 2 0;916 A#6 2 0;918 G6 4 0;922 A#6 2 0;924 D7 4 0;928 C#7 16 0;944 C7 16 0;968 C7 8 0;976 D7 2 0;978 C7 2 0;980 A#6 2 0;982 G6 4 0;986 A#6 2 0;988 D7 4 0;992 C#7 12 0;1004 C7 2 0;1006 C#7 2 0;1008 D#7 16 0;1024 F6 4 0;1028 D#6 2 0;1030 D6 2 0;1032 D#6 4 0;1036 D6 2 0;1038 C6 2 0;1040 D6 2 0;1042 C6 2 0;1044 A#5 2 0;1046 C6 2 0;1048 D6 4 0;1052 C6 2 0;1054 A#5 2 0;1056 C#6 8 0;1064 A#5 8 0;1072 D#6 2 0;1074 D6 2 0;1076 C6 2 0;1078 A#5 2 0;1080 C6 8 0;1088 F6 4 0;1092 D#6 2 0;1094 D6 2 0;1096 D#6 4 0;1100 D6 2 0;1102 C6 2 0;1104 D6 2 0;1106 C6 2 0;1108 A#5 2 0;1110 C6 2 0;1112 D6 4 0;1116 C6 2 0;1118 A#5 2 0;1120 C#6 4 0;1124 C6 2 0;1126 C#6 2 0;1128 C6 2 0;1130 C#6 2 0;1132 A#5 2 0;1134 C#6 2 0;1136 C6 16 0;1160 C7 8 0;1168 D7 2 0;1170 C7 2 0;1172 A#6 2 0;1174 G6 4 0;1178 A#6 2 0;1180 D7 4 0;1184 C#7 16 0;1200 C7 16 0;1224 C7 8 0;1232 D7 2 0;1234 C7 2 0;1236 A#6 2 0;1238 G6 4 0;1242 A#6 2 0;1244 D7 4 0;1248 C#7 16 0;1264 C7 16 0;1304 A#5 2 0;1306 C6 2 0;1308 C#6 4 0;1312 C6 16 0;1336 C#6 2 0;1338 C6 2 0;1340 C#6 4 0;1344 C6 16 0;1360 D#6 2 0;1368 A#5 2 0;1370 C6 2 0;1372 C#6 4 0;1376 C6 16 0;1392 A#5 2 0;1400 C#6 2 0;1402 C6 2 0;1404 C#6 4 0;1472 D#7 16 0;1488 D7 16 0;1504 F7 16 0;1520 D#7 16 0;64 G5 12 0;64 D#5 12 0;80 A#5 12 0;80 D5 12 0;96 F5 12 0;96 C#5 12 0;112 G5 12 0;112 C5 12 0;128 D#6 2 0;130 G#5 2 0;132 C6 2 0;134 D#6 2 0;136 G#5 2 0;138 C6 2 0;140 D#6 2 0;142 C6 2 0;144 D6 2 0;146 G5 2 0;148 A#5 2 0;150 D6 2 0;152 G5 2 0;154 A#5 2 0;156 D6 2 0;158 A#5 2 0;160 C#6 2 0;162 F5 2 0;164 A#5 2 0;166 C#6 2 0;168 F5 2 0;170 A#5 2 0;172 C#6 2 0;174 A#5 2 0;176 C6 2 0;178 G5 2 0;180 A#5 2 0;182 C6 2 0;184 G5 2 0;186 A#5 2 0;188 C6 2 0;190 A#5 2 0;192 D#6 2 0;194 G#5 2 0;196 C6 2 0;198 D#6 2 0;200 G#5 2 0;202 C6 2 0;204 D#6 2 0;206 C6 2 0;208 D6 2 0;210 G5 2 0;212 A#5 2 0;214 D6 2 0;216 G5 2 0;218 A#5 2 0;220 D6 2 0;222 A#5 2 0;224 C#6 2 0;226 F5 2 0;228 A#5 2 0;230 C#6 2 0;232 F5 2 0;234 A#5 2 0;236 C#6 2 0;238 A#5 2 0;240 C6 2 0;242 G5 2 0;244 A#5 2 0;246 C6 2 0;248 G5 2 0;250 A#5 2 0;252 C6 2 0;254 A#5 2 0;256 D#6 2 0;258 G#5 2 0;260 C6 2 0;262 D#6 2 0;264 G#5 2 0;266 C6 2 0;268 D#6 2 0;270 C6 2 0;272 D6 2 0;274 G5 2 0;276 A#5 2 0;278 D6 2 0;280 G5 2 0;282 A#5 2 0;284 D6 2 0;286 A#5 2 0;288 C#6 2 0;290 F5 2 0;292 A#5 2 0;294 C#6 2 0;296 F5 2 0;298 A#5 2 0;300 C#6 2 0;302 A#5 2 0;304 C6 2 0;306 G5 2 0;308 A#5 2 0;310 C6 2 0;312 G5 2 0;314 A#5 2 0;316 C6 2 0;318 A#5 2 0;320 G#5 8 0;328 D#5 8 0;336 G5 8 0;344 D5 8 0;352 F5 8 0;360 C#5 8 0;368 D#5 8 0;376 G5 8 0;384 G#5 8 0;392 D#5 8 0;400 G5 8 0;408 D5 8 0;416 F5 8 0;424 C#5 8 0;432 D#5 8 0;440 C5 8 0;448 D#6 2 0;450 G#5 2 0;452 C6 2 0;454 D#6 2 0;456 G#5 2 0;458 C6 2 0;460 D#6 2 0;462 C6 2 0;464 D6 2 0;466 G5 2 0;468 A#5 2 0;470 D6 2 0;472 G5 2 0;474 A#5 2 0;476 D6 2 0;478 A#5 2 0;480 C#6 2 0;482 F5 2 0;484 A#5 2 0;486 C#6 2 0;488 F5 2 0;490 A#5 2 0;492 C#6 2 0;494 A#5 2 0;496 C6 2 0;498 G5 2 0;500 A#5 2 0;502 C6 2 0;504 G5 2 0;506 A#5 2 0;508 C6 2 0;510 A#5 2 0;512 D#6 2 0;514 G#5 2 0;516 C6 2 0;518 D#6 2 0;520 G#5 2 0;522 C6 2 0;524 D#6 2 0;526 C6 2 0;528 D6 2 0;530 G5 2 0;532 A#5 2 0;534 D6 2 0;536 G5 2 0;538 A#5 2 0;540 D6 2 0;542 A#5 2 0;544 C#6 2 0;546 F5 2 0;548 A#5 2 0;550 C#6 2 0;552 F5 2 0;554 A#5 2 0;556 C#6 2 0;558 A#5 2 0;560 C6 2 0;562 G5 2 0;564 A#5 2 0;566 C6 2 0;568 G5 2 0;570 A#5 2 0;572 C6 2 0;574 A#5 2 0;576 C5 4 0;580 G5 2 0;582 D#5 4 0;586 G5 2 0;588 F5 4 0;592 D#5 2 0;596 A#4 12 0;608 C5 4 0;612 G5 2 0;614 D#5 4 0;618 G5 2 0;620 D#5 4 0;624 F5 2 0;628 A#4 12 0;640 D#5 16 0;656 G5 2 0;664 F5 2 0;666 G5 2 0;668 G#5 4 0;672 G5 16 0;696 G#5 2 0;698 G5 2 0;700 G#5 4 0;704 D#6 2 0;706 G#5 2 0;708 C6 2 0;710 D#6 2 0;712 G#5 2 0;714 C6 2 0;716 D#6 2 0;718 C6 2 0;720 D6 2 0;722 G5 2 0;724 A#5 2 0;726 D6 2 0;728 G5 2 0;730 A#5 2 0;732 D6 2 0;734 A#5 2 0;736 C#6 2 0;738 F5 2 0;740 A#5 2 0;742 C#6 2 0;744 F5 2 0;746 A#5 2 0;748 C#6 2 0;750 A#5 2 0;752 C6 2 0;754 G5 2 0;756 A#5 2 0;758 C6 2 0;760 G5 2 0;762 A#5 2 0;764 C6 2 0;766 A#5 2 0;768 D#6 2 0;770 G#5 2 0;772 C6 2 0;774 D#6 2 0;776 G#5 2 0;778 C6 2 0;780 D#6 2 0;782 C6 2 0;784 D6 2 0;786 G5 2 0;788 A#5 2 0;790 D6 2 0;792 G5 2 0;794 A#5 2 0;796 D6 2 0;798 A#5 2 0;800 C#6 2 0;802 F5 2 0;804 A#5 2 0;806 C#6 2 0;808 F5 2 0;810 A#5 2 0;812 C#6 2 0;814 A#5 2 0;816 C6 2 0;818 G5 2 0;820 A#5 2 0;822 C6 2 0;824 G5 2 0;826 A#5 2 0;828 C6 2 0;830 A#5 2 0;832 D#6 2 0;834 G#5 2 0;836 C6 2 0;838 D#6 2 0;840 G#5 2 0;842 C6 2 0;844 D#6 2 0;846 C6 2 0;848 D6 2 0;850 G5 2 0;852 A#5 2 0;854 D6 2 0;856 G5 2 0;858 A#5 2 0;860 D6 2 0;862 A#5 2 0;864 C#6 2 0;866 F5 2 0;868 A#5 2 0;870 C#6 2 0;872 F5 2 0;874 A#5 2 0;876 C#6 2 0;878 A#5 2 0;880 C6 2 0;882 G5 2 0;884 A#5 2 0;886 C6 2 0;888 G5 2 0;890 A#5 2 0;892 C6 2 0;894 A#5 2 0;896 D#6 2 0;898 G#5 2 0;900 C6 2 0;902 D#6 2 0;904 G#5 2 0;906 C6 2 0;908 D#6 2 0;910 C6 2 0;912 D6 2 0;914 G5 2 0;916 A#5 2 0;918 D6 2 0;920 G5 2 0;922 A#5 2 0;924 D6 2 0;926 A#5 2 0;928 C#6 2 0;930 F5 2 0;932 A#5 2 0;934 C#6 2 0;936 F5 2 0;938 A#5 2 0;940 C#6 2 0;942 A#5 2 0;944 C6 2 0;946 G5 2 0;948 A#5 2 0;950 C6 2 0;952 G5 2 0;954 A#5 2 0;956 C6 2 0;958 A#5 2 0;960 D#6 2 0;962 G#5 2 0;964 C6 2 0;966 D#6 2 0;968 G#5 2 0;970 C6 2 0;972 D#6 2 0;974 C6 2 0;976 D6 2 0;978 G5 2 0;980 A#5 2 0;982 D6 2 0;984 G5 2 0;986 A#5 2 0;988 D6 2 0;990 A#5 2 0;992 C#6 2 0;994 F5 2 0;996 A#5 2 0;998 C#6 2 0;1000 F5 2 0;1002 A#5 2 0;1004 C#6 2 0;1006 A#5 2 0;1008 C6 2 0;1010 G5 2 0;1012 A#5 2 0;1014 C6 2 0;1016 G5 2 0;1018 A#5 2 0;1020 C6 2 0;1022 A#5 2 0;1024 G#5 8 0;1032 D#5 8 0;1040 G5 8 0;1048 D5 8 0;1056 F5 8 0;1064 C#5 8 0;1072 D#5 8 0;1080 G5 8 0;1088 G#5 8 0;1096 D#5 8 0;1104 G5 8 0;1112 D5 8 0;1120 F5 8 0;1128 C#5 8 0;1136 D#5 8 0;1144 C5 8 0;1152 D#6 2 0;1154 G#5 2 0;1156 C6 2 0;1158 D#6 2 0;1160 G#5 2 0;1162 C6 2 0;1164 D#6 2 0;1166 C6 2 0;1168 D6 2 0;1170 G5 2 0;1172 A#5 2 0;1174 D6 2 0;1176 G5 2 0;1178 A#5 2 0;1180 D6 2 0;1182 A#5 2 0;1184 C#6 2 0;1186 F5 2 0;1188 A#5 2 0;1190 C#6 2 0;1192 F5 2 0;1194 A#5 2 0;1196 C#6 2 0;1198 A#5 2 0;1200 C6 2 0;1202 G5 2 0;1204 A#5 2 0;1206 C6 2 0;1208 G5 2 0;1210 A#5 2 0;1212 C6 2 0;1214 A#5 2 0;1216 D#6 2 0;1218 G#5 2 0;1220 C6 2 0;1222 D#6 2 0;1224 G#5 2 0;1226 C6 2 0;1228 D#6 2 0;1230 C6 2 0;1232 D6 2 0;1234 G5 2 0;1236 A#5 2 0;1238 D6 2 0;1240 G5 2 0;1242 A#5 2 0;1244 D6 2 0;1246 A#5 2 0;1248 C#6 2 0;1250 F5 2 0;1252 A#5 2 0;1254 C#6 2 0;1256 F5 2 0;1258 A#5 2 0;1260 C#6 2 0;1262 A#5 2 0;1264 C6 2 0;1266 G5 2 0;1268 A#5 2 0;1270 C6 2 0;1272 G5 2 0;1274 A#5 2 0;1276 C6 2 0;1278 A#5 2 0;1280 C5 4 0;1284 G5 2 0;1286 D#5 4 0;1290 G5 2 0;1292 F5 4 0;1296 D#5 2 0;1300 A#4 12 0;1312 C5 4 0;1316 G5 2 0;1318 D#5 4 0;1322 G5 2 0;1324 D#5 4 0;1328 F5 2 0;1332 A#4 12 0;1344 D#5 16 0;1360 G5 2 0;1368 F5 2 0;1370 G5 2 0;1372 G#5 4 0;1376 G5 16 0;1400 G#5 2 0;1402 G5 2 0;1404 G#5 4 0;1408 D#6 2 0;1410 G#5 2 0;1412 C6 2 0;1414 D#6 2 0;1416 G#5 2 0;1418 C6 2 0;1420 D#6 2 0;1422 C6 2 0;1424 D6 2 0;1426 G5 2 0;1428 A#5 2 0;1430 D6 2 0;1432 G5 2 0;1434 A#5 2 0;1436 D6 2 0;1438 A#5 2 0;1440 C#6 2 0;1442 F5 2 0;1444 A#5 2 0;1446 C#6 2 0;1448 F5 2 0;1450 A#5 2 0;1452 C#6 2 0;1454 A#5 2 0;1456 C6 2 0;1458 G5 2 0;1460 A#5 2 0;1462 C6 2 0;1464 G5 2 0;1466 A#5 2 0;1468 C6 2 0;1470 A#5 2 0;1472 D#6 2 0;1474 G#5 2 0;1476 C6 2 0;1478 D#6 2 0;1480 G#5 2 0;1482 C6 2 0;1484 D#6 2 0;1486 C6 2 0;1488 D6 2 0;1490 G5 2 0;1492 A#5 2 0;1494 D6 2 0;1496 G5 2 0;1498 A#5 2 0;1500 D6 2 0;1502 A#5 2 0;1504 C#6 2 0;1506 F5 2 0;1508 A#5 2 0;1510 C#6 2 0;1512 F5 2 0;1514 A#5 2 0;1516 C#6 2 0;1518 A#5 2 0;1520 C6 2 0;1522 G5 2 0;1524 A#5 2 0;1526 C6 2 0;1528 G5 2 0;1530 A#5 2 0;1532 C6 2 0;1534 A#5 2 0;0 C4 4 0;4 G4 2 0;6 D#4 4 0;10 G4 2 0;12 F4 4 0;16 D#4 2 0;20 A#3 6 0;26 C4 2 0;28 C#4 4 0;32 C4 4 0;36 G4 2 0;38 D#4 4 0;42 G4 2 0;44 D#4 4 0;48 F4 2 0;52 A#3 4 0;56 C#4 2 0;58 C4 2 0;60 C#4 4 0;64 C4 4 0;68 G4 2 0;70 D#4 4 0;74 G4 2 0;76 F4 4 0;80 D#4 2 0;84 A#3 6 0;90 C4 2 0;92 C#4 4 0;96 C4 4 0;100 G4 2 0;102 D#4 4 0;106 G4 2 0;108 D#4 4 0;112 F4 2 0;116 A#3 4 0;120 C#4 2 0;122 C4 2 0;124 C#4 4 0;128 C4 4 0;132 G4 2 0;134 D#4 4 0;138 G4 2 0;140 F4 4 0;144 D#4 2 0;148 A#3 6 0;154 C4 2 0;156 C#4 4 0;160 C4 4 0;164 G4 2 0;166 D#4 4 0;170 G4 2 0;172 D#4 4 0;176 F4 2 0;180 A#3 4 0;184 C#4 2 0;186 C4 2 0;188 C#4 4 0;192 C4 4 0;196 G4 2 0;198 D#4 4 0;202 G4 2 0;204 F4 4 0;208 D#4 2 0;212 A#3 6 0;218 C4 2 0;220 C#4 4 0;224 C4 4 0;228 G4 2 0;230 D#4 4 0;234 G4 2 0;236 D#4 4 0;240 F4 2 0;244 A#3 4 0;248 C#4 2 0;250 C4 2 0;252 C#4 4 0;256 C4 4 0;260 G4 2 0;262 D#4 4 0;266 G4 2 0;268 F4 4 0;272 D#4 2 0;276 A#3 6 0;282 C4 2 0;284 C#4 4 0;288 C4 4 0;292 G4 2 0;294 D#4 4 0;298 G4 2 0;300 D#4 4 0;304 F4 2 0;308 A#3 4 0;312 C#4 2 0;314 C4 2 0;316 C#4 4 0;320 C4 4 0;324 G4 2 0;326 D#4 4 0;330 G4 2 0;332 F4 4 0;336 D#4 2 0;340 A#3 6 0;346 C4 2 0;348 C#4 4 0;352 C4 4 0;356 G4 2 0;358 D#4 4 0;362 G4 2 0;364 D#4 4 0;368 F4 2 0;372 A#3 4 0;376 C#4 2 0;378 C4 2 0;380 C#4 4 0;384 C4 4 0;388 G4 2 0;390 D#4 4 0;394 G4 2 0;396 F4 4 0;400 D#4 2 0;404 A#3 6 0;410 C4 2 0;412 C#4 4 0;416 C4 4 0;420 G4 2 0;422 D#4 4 0;426 G4 2 0;428 D#4 4 0;432 F4 2 0;436 A#3 4 0;440 C#4 2 0;442 C4 2 0;444 C#4 4 0;448 C4 4 0;452 G4 2 0;454 D#4 4 0;458 G4 2 0;460 F4 4 0;464 D#4 2 0;468 A#3 6 0;474 C4 2 0;476 C#4 4 0;480 C4 4 0;484 G4 2 0;486 D#4 4 0;490 G4 2 0;492 D#4 4 0;496 F4 2 0;500 A#3 4 0;504 C#4 2 0;506 C4 2 0;508 C#4 4 0;512 C4 4 0;516 G4 2 0;518 D#4 4 0;522 G4 2 0;524 F4 4 0;528 D#4 2 0;532 A#3 6 0;538 C4 2 0;540 C#4 4 0;544 C4 4 0;548 G4 2 0;550 D#4 4 0;554 G4 2 0;556 D#4 4 0;560 F4 2 0;564 A#3 4 0;568 C#4 2 0;570 C4 2 0;572 C#4 4 0;600 F4 2 0;602 G4 2 0;604 G#4 4 0;608 D#5 16 0;632 G#4 2 0;634 G4 2 0;636 G#4 4 0;640 C5 4 0;644 G5 2 0;646 D#5 4 0;650 G5 2 0;652 F5 4 0;656 D#5 2 0;660 A#4 12 0;672 C5 4 0;676 G5 2 0;678 D#5 4 0;682 G5 2 0;684 D#5 4 0;688 F5 2 0;692 A#4 4 0;696 C#5 2 0;698 C5 2 0;700 C#5 4 0;704 C5 4 0;708 G5 2 0;710 D#5 4 0;714 G5 2 0;716 F5 4 0;720 D#5 2 0;724 A#4 6 0;730 C5 2 0;732 C#5 4 0;736 C5 4 0;740 G5 2 0;742 D#5 4 0;746 G5 2 0;748 D#5 4 0;752 F5 2 0;756 A#4 4 0;760 C#5 2 0;762 C5 2 0;764 C#5 4 0;768 C5 4 0;772 G5 2 0;774 D#5 4 0;778 G5 2 0;780 F5 4 0;784 D#5 2 0;788 A#4 6 0;794 C5 2 0;796 C#5 4 0;800 C5 4 0;804 G5 2 0;806 D#5 4 0;810 G5 2 0;812 D#5 4 0;816 F5 2 0;820 A#4 4 0;824 C#5 2 0;826 C5 2 0;828 C#5 4 0;832 C4 4 0;836 G4 2 0;838 D#4 4 0;842 G4 2 0;844 F4 4 0;848 D#4 2 0;852 A#3 6 0;858 C4 2 0;860 C#4 4 0;864 C4 4 0;868 G4 2 0;870 D#4 4 0;874 G4 2 0;876 D#4 4 0;880 F4 2 0;884 A#3 4 0;888 C#4 2 0;890 C4 2 0;892 C#4 4 0;896 C4 4 0;900 G4 2 0;902 D#4 4 0;906 G4 2 0;908 F4 4 0;912 D#4 2 0;916 A#3 6 0;922 C4 2 0;924 C#4 4 0;928 C4 4 0;932 G4 2 0;934 D#4 4 0;938 G4 2 0;940 D#4 4 0;944 F4 2 0;948 A#3 4 0;952 C#4 2 0;954 C4 2 0;956 C#4 4 0;960 C4 4 0;964 G4 2 0;966 D#4 4 0;970 G4 2 0;972 F4 4 0;976 D#4 2 0;980 A#3 6 0;986 C4 2 0;988 C#4 4 0;992 C4 4 0;996 G4 2 0;998 D#4 4 0;1002 G4 2 0;1004 D#4 4 0;1008 F4 2 0;1012 A#3 4 0;1016 C#4 2 0;1018 C4 2 0;1020 C#4 4 0;1024 C4 4 0;1028 G4 2 0;1030 D#4 4 0;1034 G4 2 0;1036 F4 4 0;1040 D#4 2 0;1044 A#3 6 0;1050 C4 2 0;1052 C#4 4 0;1056 C4 4 0;1060 G4 2 0;1062 D#4 4 0;1066 G4 2 0;1068 D#4 4 0;1072 F4 2 0;1076 A#3 4 0;1080 C#4 2 0;1082 C4 2 0;1084 C#4 4 0;1088 C4 4 0;1092 G4 2 0;1094 D#4 4 0;1098 G4 2 0;1100 F4 4 0;1104 D#4 2 0;1108 A#3 6 0;1114 C4 2 0;1116 C#4 4 0;1120 C4 4 0;1124 G4 2 0;1126 D#4 4 0;1130 G4 2 0;1132 D#4 4 0;1136 F4 2 0;1140 A#3 4 0;1144 C#4 2 0;1146 C4 2 0;1148 C#4 4 0;1152 C4 4 0;1156 G4 2 0;1158 D#4 4 0;1162 G4 2 0;1164 F4 4 0;1168 D#4 2 0;1172 A#3 6 0;1178 C4 2 0;1180 C#4 4 0;1184 C4 4 0;1188 G4 2 0;1190 D#4 4 0;1194 G4 2 0;1196 D#4 4 0;1200 F4 2 0;1204 A#3 4 0;1208 C#4 2 0;1210 C4 2 0;1212 C#4 4 0;1216 C4 4 0;1220 G4 2 0;1222 D#4 4 0;1226 G4 2 0;1228 F4 4 0;1232 D#4 2 0;1236 A#3 6 0;1242 C4 2 0;1244 C#4 4 0;1248 C4 4 0;1252 G4 2 0;1254 D#4 4 0;1258 G4 2 0;1260 D#4 4 0;1264 F4 2 0;1268 A#3 4 0;1272 C#4 2 0;1274 C4 2 0;1276 C#4 4 0;1304 F4 2 0;1306 G4 2 0;1308 G#4 4 0;1312 D#5 16 0;1336 G#4 2 0;1338 G4 2 0;1340 G#4 4 0;1344 C5 4 0;1348 G5 2 0;1350 D#5 4 0;1354 G5 2 0;1356 F5 4 0;1360 D#5 2 0;1364 A#4 12 0;1376 C5 4 0;1380 G5 2 0;1382 D#5 4 0;1386 G5 2 0;1388 D#5 4 0;1392 F5 2 0;1396 A#4 4 0;1400 C#5 2 0;1402 C5 2 0;1404 C#5 4 0;1408 C5 4 0;1412 G5 2 0;1414 D#5 4 0;1418 G5 2 0;1420 F5 4 0;1424 D#5 2 0;1428 A#4 6 0;1434 C5 2 0;1436 C#5 4 0;1440 C5 4 0;1444 G5 2 0;1446 D#5 4 0;1450 G5 2 0;1452 D#5 4 0;1456 F5 2 0;1460 A#4 4 0;1464 C#5 2 0;1466 C5 2 0;1468 C#5 4 0;1472 C5 4 0;1476 G5 2 0;1478 D#5 4 0;1482 G5 2 0;1484 F5 4 0;1488 D#5 2 0;1492 A#4 6 0;1498 C5 2 0;1500 C#5 4 0;1504 C5 4 0;1508 G5 2 0;1510 D#5 4 0;1514 G5 2 0;1516 D#5 4 0;1520 F5 2 0;1524 A#4 4 0;1528 C#5 2 0;1530 C5 2 0;1532 C#5 4 0;0 C3 4 0;4 G3 2 0;6 D#3 4 0;10 G3 2 0;12 F3 4 0;16 D#3 2 0;20 A#2 6 0;26 C3 2 0;28 C#3 4 0;32 C3 4 0;36 G3 2 0;38 D#3 4 0;42 G3 2 0;44 D#3 4 0;48 F3 2 0;52 A#2 4 0;56 C#3 2 0;58 C3 2 0;60 C#3 4 0;64 C3 4 0;68 G3 2 0;70 D#3 4 0;74 G3 2 0;76 F3 4 0;80 D#3 2 0;84 A#2 6 0;90 C3 2 0;92 C#3 4 0;96 C3 4 0;100 G3 2 0;102 D#3 4 0;106 G3 2 0;108 D#3 4 0;112 F3 2 0;116 A#2 4 0;120 C#3 2 0;122 C3 2 0;124 C#3 4 0;128 C3 4 0;132 G3 2 0;134 D#3 4 0;138 G3 2 0;140 F3 4 0;144 D#3 2 0;148 A#2 6 0;154 C3 2 0;156 C#3 4 0;160 C3 4 0;164 G3 2 0;166 D#3 4 0;170 G3 2 0;172 D#3 4 0;176 F3 2 0;180 A#2 4 0;184 C#3 2 0;186 C3 2 0;188 C#3 4 0;192 C3 4 0;196 G3 2 0;198 D#3 4 0;202 G3 2 0;204 F3 4 0;208 D#3 2 0;212 A#2 6 0;218 C3 2 0;220 C#3 4 0;224 C3 4 0;228 G3 2 0;230 D#3 4 0;234 G3 2 0;236 D#3 4 0;240 F3 2 0;244 A#2 4 0;248 C#3 2 0;250 C3 2 0;252 C#3 4 0;256 C3 4 0;260 G3 2 0;262 D#3 4 0;266 G3 2 0;268 F3 4 0;272 D#3 2 0;276 A#2 6 0;282 C3 2 0;284 C#3 4 0;288 C3 4 0;292 G3 2 0;294 D#3 4 0;298 G3 2 0;300 D#3 4 0;304 F3 2 0;308 A#2 4 0;312 C#3 2 0;314 C3 2 0;316 C#3 4 0;320 C3 4 0;324 G3 2 0;326 D#3 4 0;330 G3 2 0;332 F3 4 0;336 D#3 2 0;340 A#2 6 0;346 C3 2 0;348 C#3 4 0;352 C3 4 0;356 G3 2 0;358 D#3 4 0;362 G3 2 0;364 D#3 4 0;368 F3 2 0;372 A#2 4 0;376 C#3 2 0;378 C3 2 0;380 C#3 4 0;384 C3 4 0;388 G3 2 0;390 D#3 4 0;394 G3 2 0;396 F3 4 0;400 D#3 2 0;404 A#2 6 0;410 C3 2 0;412 C#3 4 0;416 C3 4 0;420 G3 2 0;422 D#3 4 0;426 G3 2 0;428 D#3 4 0;432 F3 2 0;436 A#2 4 0;440 C#3 2 0;442 C3 2 0;444 C#3 4 0;448 C3 4 0;452 G3 2 0;454 D#3 4 0;458 G3 2 0;460 F3 4 0;464 D#3 2 0;468 A#2 6 0;474 C3 2 0;476 C#3 4 0;480 C3 4 0;484 G3 2 0;486 D#3 4 0;490 G3 2 0;492 D#3 4 0;496 F3 2 0;500 A#2 4 0;504 C#3 2 0;506 C3 2 0;508 C#3 4 0;512 C3 4 0;516 G3 2 0;518 D#3 4 0;522 G3 2 0;524 F3 4 0;528 D#3 2 0;532 A#2 6 0;538 C3 2 0;540 C#3 4 0;544 C3 4 0;548 G3 2 0;550 D#3 4 0;554 G3 2 0;556 D#3 4 0;560 F3 2 0;564 A#2 4 0;568 C#3 2 0;570 C3 2 0;572 C#3 4 0;576 C4 4 0;580 G4 2 0;582 D#4 4 0;586 G4 2 0;588 F4 4 0;592 D#4 2 0;596 A#3 12 0;608 C4 4 0;612 G4 2 0;614 D#4 4 0;618 G4 2 0;620 D#4 4 0;624 F4 2 0;628 A#3 12 0;640 C4 4 0;644 G4 2 0;646 D#4 4 0;650 G4 2 0;652 F4 4 0;656 D#4 2 0;660 A#3 12 0;672 C4 4 0;676 G4 2 0;678 D#4 4 0;682 G4 2 0;684 D#4 4 0;688 F4 2 0;692 A#3 4 0;696 C#4 2 0;698 C4 2 0;700 C#4 4 0;704 C4 4 0;708 G4 2 0;710 D#4 4 0;714 G4 2 0;716 F4 4 0;720 D#4 2 0;724 A#3 6 0;730 C4 2 0;732 C#4 4 0;736 C4 4 0;740 G4 2 0;742 D#4 4 0;746 G4 2 0;748 D#4 4 0;752 F4 2 0;756 A#3 4 0;760 C#4 2 0;762 C4 2 0;764 C#4 4 0;768 C4 4 0;772 G4 2 0;774 D#4 4 0;778 G4 2 0;780 F4 4 0;784 D#4 2 0;788 A#3 6 0;794 C4 2 0;796 C#4 4 0;800 C4 4 0;804 G4 2 0;806 D#4 4 0;810 G4 2 0;812 D#4 4 0;816 F4 2 0;820 A#3 4 0;824 C#4 2 0;826 C4 2 0;828 C#4 4 0;832 C3 4 0;836 G3 2 0;838 D#3 4 0;842 G3 2 0;844 F3 4 0;848 D#3 2 0;852 A#2 6 0;858 C3 2 0;860 C#3 4 0;864 C3 4 0;868 G3 2 0;870 D#3 4 0;874 G3 2 0;876 D#3 4 0;880 F3 2 0;884 A#2 4 0;888 C#3 2 0;890 C3 2 0;892 C#3 4 0;896 C3 4 0;900 G3 2 0;902 D#3 4 0;906 G3 2 0;908 F3 4 0;912 D#3 2 0;916 A#2 6 0;922 C3 2 0;924 C#3 4 0;928 C3 4 0;932 G3 2 0;934 D#3 4 0;938 G3 2 0;940 D#3 4 0;944 F3 2 0;948 A#2 4 0;952 C#3 2 0;954 C3 2 0;956 C#3 4 0;960 C3 4 0;964 G3 2 0;966 D#3 4 0;970 G3 2 0;972 F3 4 0;976 D#3 2 0;980 A#2 6 0;986 C3 2 0;988 C#3 4 0;992 C3 4 0;996 G3 2 0;998 D#3 4 0;1002 G3 2 0;1004 D#3 4 0;1008 F3 2 0;1012 A#2 4 0;1016 C#3 2 0;1018 C3 2 0;1020 C#3 4 0;1024 C3 4 0;1028 G3 2 0;1030 D#3 4 0;1034 G3 2 0;1036 F3 4 0;1040 D#3 2 0;1044 A#2 6 0;1050 C3 2 0;1052 C#3 4 0;1056 C3 4 0;1060 G3 2 0;1062 D#3 4 0;1066 G3 2 0;1068 D#3 4 0;1072 F3 2 0;1076 A#2 4 0;1080 C#3 2 0;1082 C3 2 0;1084 C#3 4 0;1088 C3 4 0;1092 G3 2 0;1094 D#3 4 0;1098 G3 2 0;1100 F3 4 0;1104 D#3 2 0;1108 A#2 6 0;1114 C3 2 0;1116 C#3 4 0;1120 C3 4 0;1124 G3 2 0;1126 D#3 4 0;1130 G3 2 0;1132 D#3 4 0;1136 F3 2 0;1140 A#2 4 0;1144 C#3 2 0;1146 C3 2 0;1148 C#3 4 0;1152 C3 4 0;1156 G3 2 0;1158 D#3 4 0;1162 G3 2 0;1164 F3 4 0;1168 D#3 2 0;1172 A#2 6 0;1178 C3 2 0;1180 C#3 4 0;1184 C3 4 0;1188 G3 2 0;1190 D#3 4 0;1194 G3 2 0;1196 D#3 4 0;1200 F3 2 0;1204 A#2 4 0;1208 C#3 2 0;1210 C3 2 0;1212 C#3 4 0;1216 C3 4 0;1220 G3 2 0;1222 D#3 4 0;1226 G3 2 0;1228 F3 4 0;1232 D#3 2 0;1236 A#2 6 0;1242 C3 2 0;1244 C#3 4 0;1248 C3 4 0;1252 G3 2 0;1254 D#3 4 0;1258 G3 2 0;1260 D#3 4 0;1264 F3 2 0;1268 A#2 4 0;1272 C#3 2 0;1274 C3 2 0;1276 C#3 4 0;1280 C4 4 0;1284 G4 2 0;1286 D#4 4 0;1290 G4 2 0;1292 F4 4 0;1296 D#4 2 0;1300 A#3 12 0;1312 C4 4 0;1316 G4 2 0;1318 D#4 4 0;1322 G4 2 0;1324 D#4 4 0;1328 F4 2 0;1332 A#3 12 0;1344 C4 4 0;1348 G4 2 0;1350 D#4 4 0;1354 G4 2 0;1356 F4 4 0;1360 D#4 2 0;1364 A#3 12 0;1376 C4 4 0;1380 G4 2 0;1382 D#4 4 0;1386 G4 2 0;1388 D#4 4 0;1392 F4 2 0;1396 A#3 4 0;1400 C#4 2 0;1402 C4 2 0;1404 C#4 4 0;1408 C4 4 0;1412 G4 2 0;1414 D#4 4 0;1418 G4 2 0;1420 F4 4 0;1424 D#4 2 0;1428 A#3 6 0;1434 C4 2 0;1436 C#4 4 0;1440 C4 4 0;1444 G4 2 0;1446 D#4 4 0;1450 G4 2 0;1452 D#4 4 0;1456 F4 2 0;1460 A#3 4 0;1464 C#4 2 0;1466 C4 2 0;1468 C#4 4 0;1472 C4 4 0;1476 G4 2 0;1478 D#4 4 0;1482 G4 2 0;1484 F4 4 0;1488 D#4 2 0;1492 A#3 6 0;1498 C4 2 0;1500 C#4 4 0;1504 C4 4 0;1508 G4 2 0;1510 D#4 4 0;1514 G4 2 0;1516 D#4 4 0;1520 F4 2 0;1524 A#3 4 0;1528 C#4 2 0;1530 C4 2 0;1532 C#4 4 0'
# C418 - Haggstrom
#song = '0 G5 9 33;0 C6 9 33;4 D5 1 33;8 C5 1 33;12 C6 9 33;12 G5 9 33;16 D5 1 33;20 C5 1 33;24 A5 1 33;28 C6 9 33;28 G5 9 33;32 D5 1 33;36 C5 1 33;40 C6 9 33;40 G5 9 33;44 D5 1 33;48 C5 1 33;56 C6 9 33;56 G5 9 33;60 D5 1 33;64 C5 1 33;68 C6 9 33;68 G5 9 33;72 D5 1 33;76 C5 1 33;80 A5 1 33;84 C6 9 33;84 G5 9 33;88 D5 1 33;92 C5 1 33;96 C6 9 33;96 G5 9 33;100 D5 1 33;104 C5 1 33;112 C6 4 33;112 G5 4 33;112 C5 1 33;112 C4 8 7;116 B5 4 33;116 D5 1 33;120 C5 1 33;120 G5 3 33;124 C6 4 33;124 G5 3 33;124 C5 1 33;124 C4 8 7;128 B5 4 33;128 D5 1 33;128 G5 4 33;132 C5 4 33;132 E5 4 33;136 A5 4 33;140 C6 4 33;140 G5 4 33;140 C5 1 33;140 C4 8 7;144 D5 1 33;144 B5 4 33;148 C5 1 33;148 G5 3 33;152 C6 4 33;152 G5 4 33;152 C5 1 33;152 C4 8 7;156 D5 4 33;156 B5 8 33;160 C5 6 33;168 C6 4 33;168 G5 3 33;168 C5 1 33;168 E5 1 33;168 C4 8 7;172 B5 4 33;172 G5 3 33;172 D5 4 33;176 C5 3 33;176 G5 3 33;180 C6 4 33;180 G5 3 33;180 E5 1 33;180 C5 1 33;180 C4 8 7;184 B5 4 33;184 G5 3 33;184 D5 4 33;188 C5 3 33;188 E5 3 33;192 A5 4 33;192 D6 4 33;196 C4 8 7;196 C5 7 33;196 G5 4 33;196 E6 4 33;200 D5 4 33;200 G6 4 33;204 C6 4 33;204 C5 3 33;208 E6 4 33;208 G5 4 33;212 G6 4 33;212 D5 4 33;216 C6 4 33;216 C5 4 33;208 C5 7 33;208 C4 7 7;224 A3 8 7;224 E5 4 33;224 B5 4 33;228 D5 4 33;228 A5 4 33;232 E5 3 33;232 A4 4 33;236 B5 4 33;236 E5 4 33;236 A3 8 7;240 D5 4 33;240 A5 4 33;244 G#5 4 33;244 A4 4 33;248 F#4 4 33;252 B5 4 33;252 E5 4 33;252 A3 8 7;256 A5 4 33;256 D5 4 33;260 E5 4 33;260 A4 4 33;264 A3 15 7;264 D5 4 33;268 C#5 4 33;272 A4 4 33;280 A3 8 7;280 E5 4 33;280 B5 4 33;284 D5 4 33;284 A5 4 33;292 B5 4 33;292 E5 4 33;292 A3 8 7;296 D5 4 33;296 A5 4 33;300 G#5 4 33;300 A4 4 33;288 A4 4 33;288 E5 3 33;288 C#6 4 33;300 E6 4 33;304 F#4 4 33;308 E6 3 33;308 C#6 4 33;308 G#6 4 33;308 A3 8 7;320 A3 8 7;320 C#6 4 33;320 E6 3 33;320 G#6 4 33;312 E6 3 33;312 A6 4 33;312 D5 4 33;316 A4 4 33;316 A5 4 33;316 E6 3 33;324 E6 3 33;324 A6 4 33;324 D5 4 33;328 A5 4 33;328 A4 4 33;120 G3 4 7;148 G3 4 7;176 G3 4 7;204 G3 4 7;132 G3 4 7;232 E3 4 7;260 E3 4 7;288 E3 4 7;316 E3 4 7'
# https://onlinesequencer.net/1140127 C418 - Sweden
#song = '64 E3 4 13;64 E4 4 13;64 G4 4 13;64 B4 4 13;68 F#3 4 13;76 B3 4 13;80 A3 4 13;84 G3 4 13;88 D3 4 13;72 D5 4 13;72 A4 4 13;72 F#5 4 13;72 G3 4 13;80 F#4 4 13;80 A4 4 13;80 C#5 4 13;88 A4 4 13;88 C#5 4 13;88 E5 4 13;96 E3 4 13;96 E4 4 13;96 G4 4 13;96 B4 4 13;100 F#3 4 13;108 B3 4 13;112 A3 4 13;116 G3 4 13;120 D3 4 13;104 D5 4 13;104 A4 4 13;104 F#5 4 13;104 G3 4 13;112 F#4 4 13;112 A4 4 13;112 C#5 4 13;120 A4 4 13;120 C#5 4 13;120 E5 4 13;0 E3 4 13;4 F#3 4 13;12 B3 4 13;16 A3 4 13;20 G3 4 13;24 D3 4 13;8 G3 4 13;32 E3 4 13;36 F#3 4 13;44 B3 4 13;48 A3 4 13;52 G3 4 13;56 D3 4 13;40 G3 4 13;0 E4 4 13;0 G4 4 13;8 A4 4 13;8 D5 4 13;16 A4 4 13;16 F#4 4 13;24 A4 4 13;24 C#5 4 13;32 E4 4 13;32 G4 4 13;40 A4 4 13;40 D5 4 13;48 A4 4 13;48 F#4 4 13;56 A4 4 13;56 C#5 4 13;128 E3 4 13;128 E4 4 13;128 G4 4 13;128 B4 4 13;132 F#3 4 13;140 B3 4 13;144 A3 4 13;148 G3 4 13;152 D3 4 13;136 D5 4 13;136 A4 4 13;136 F#5 4 13;136 G3 4 13;144 F#4 4 13;144 A4 4 13;144 C#5 4 13;152 A4 4 13;152 C#5 4 13;152 E5 4 13;132 A5 2 13;134 B5 2 13;142 D5 1 13;143 E5 1 13;150 F#5 1 13;151 A5 1 13;160 E3 4 13;160 E4 2 13;160 G4 2 13;160 B4 2 13;164 F#3 4 13;172 B3 4 13;176 A3 4 13;180 G3 4 13;184 D3 4 13;168 D5 4 13;168 A4 4 13;168 F#5 4 13;168 G3 4 13;176 F#4 4 13;176 A4 4 13;176 C#5 4 13;184 A4 4 13;184 C#5 4 13;184 E5 4 13;162 D6 2 13;164 B5 2 13;166 A5 2 13;174 D5 1 13;175 E5 1 13;182 A5 1 13;183 F#5 1 13'
# https://onlinesequencer.net/1194533 C418 - Wet Hands
#song = '0 A3 1 32;4 E4 1 32;8 A4 1 32;12 B4 1 32;16 C#5 1 32;20 B4 1 32;24 A4 1 32;28 E4 1 32;32 D4 1 32;36 F#4 1 32;40 C#5 1 32;44 E5 1 32;48 C#5 1 32;52 A4 1 32;64 A3 1 32;68 E4 1 32;72 A4 1 32;76 B4 1 32;80 C#5 1 32;84 B4 1 32;88 A4 1 32;92 E4 1 32;96 D4 1 32;100 F#4 1 32;104 C#5 1 32;108 E5 1 32;112 C#5 1 32;116 A4 1 32;128 A3 1 32;132 E4 1 32;136 A4 1 32;140 B4 1 32;144 C#5 1 32;148 B4 1 32;152 A4 1 32;156 E4 1 32;160 D4 1 32;164 F#4 1 32;168 C#5 1 32;172 E5 1 32;176 C#5 1 32;180 A4 1 32;128 G#5 1 32;152 A5 1 32;160 F#5 1 32;184 E5 1 32;192 G#5 1 32;188 F#5 1 32;192 A3 1 32;196 E4 1 32;200 A4 1 32;204 B4 1 32;208 C#5 1 32;212 B4 1 32;216 A4 1 32;220 E4 1 32;224 D4 1 32;228 F#4 1 32;232 C#5 1 32;236 E5 1 32;240 C#5 1 32;244 A5 1 32;216 B5 1 32;220 C#6 1 32;228 F#5 1 32;248 C#6 1 32;252 E6 1 32;256 G6 1 32;256 G3 1 32;260 B3 1 32;264 D4 1 32;268 F#4 1 32;272 A4 1 32;268 F#6 1 32;244 A4 1 32;272 D6 1 32;276 F#4 1 32;280 D4 1 32;284 B3 1 32;288 G3 1 32;292 B3 1 32;296 D4 1 32;300 F#4 1 32;304 A4 1 32;280 A5 1 32;284 B5 1 32;320 G6 1 32;320 G3 1 32;324 B3 1 32;328 D4 1 32;332 F#4 1 32;328 F#6 1 32;336 D6 1 32;344 A5 1 32;348 B5 1 32;340 F#4 1 32;344 D4 1 32;348 B3 1 32;352 G3 1 32;356 B3 1 32;360 D4 1 32;364 F#4 1 32;368 A4 1 32;336 A4 1 32;376 A5 1 32;384 E5 1 32;384 A3 1 32;388 E4 1 32;392 A4 1 32;396 B4 1 32;400 C#5 1 32;404 B4 1 32;408 A4 1 32;412 E4 1 32;416 A3 1 32;432 C#5 1 32;436 E5 1 32;440 A5 1 32;444 C#6 1 32;460 B3 1 32;464 D4 1 32;468 F#4 1 32;472 A4 1 32;476 C#5 1 32;459 F#5 1 32;459 B5 1 32;459 D6 1 32;472 C#6 1 32;476 A5 1 32;484 E5 1 32;484 E6 1 32;488 F#6 1 32;488 F#5 1 32;492 B3 1 32;496 D4 1 32;500 F#4 1 32;504 A4 1 32;508 C#5 1 32;496 D6 1 32;516 B5 1 32;520 C#6 1 32;524 D6 1 32;532 C#6 1 32;536 D6 1 32;544 F#6 1 32;555 C#6 8 32;524 G3 1 32;528 B3 1 32;532 D4 1 32;536 F#4 1 32;540 A4 1 32;555 A5 8 32;555 E5 8 32;555 A4 9 32;556 E4 8 32;556 C#4 8 32;556 A3 8 32;572 B5 1 32;576 A5 1 32;580 B5 1 32;580 E3 1 32;584 G#3 1 32;588 B3 1 32;592 E4 1 32;596 G#4 1 32;600 E4 1 32;604 B3 1 32;608 G#3 1 32;612 E3 1 32;616 G#3 1 32;620 B3 1 32;624 E4 1 32;628 G#4 1 32;632 E4 1 32;636 A3 1 32;644 G3 1 32;648 B3 1 32;652 D4 1 32;656 F#4 1 32;644 G6 1 32;648 F#6 1 32;652 E6 1 32;656 D6 1 32;660 E6 1 32;664 D6 1 32;668 E6 1 32;672 F#6 1 32;660 A4 1 32;664 F#4 1 32;668 D4 1 32;672 B3 1 32;676 A3 1 32;680 C#4 1 32;684 E4 1 32;688 A4 1 32;692 C#5 1 32;696 A4 1 32;700 E4 1 32;680 E6 1 32;692 A6 1 32;704 C#4 1 32;708 E3 1 32;712 G#3 1 32;716 B3 1 32;720 E4 1 32;724 G#4 1 32;708 G#6 1 32;712 E6 1 32;716 B5 1 32;720 G#5 1 32;724 E5 1 32;738 E3 1 32;742 G#3 1 32;746 B3 1 32;750 E4 1 32;754 G#4 1 32;738 B5 1 32;742 G#5 1 32;746 E5 1 32;750 B4 1 32;766 E3 1 32;770 G#3 1 32;774 B3 1 32;778 E4 1 32;782 B3 1 32;794 E3 1 32;798 G#3 1 32;802 B3 1 32;806 E4 1 32;810 E4 1 32;818 A5 1 32;826 E5 1 32;826 A3 1 32;830 E4 1 32;834 A4 1 32;838 B4 1 32;842 C#5 1 32;846 B4 1 32;850 A4 1 32;854 E4 1 32;858 D4 1 32;862 F#4 1 32;866 C#5 1 32;870 E5 1 32;874 C#5 1 32;878 A4 1 32;882 A5 1 32;890 A5 1 32;890 A3 1 32;894 E4 1 32;898 A4 1 32;902 B4 1 32;906 C#5 1 32;910 B4 1 32;914 A4 1 32;918 E4 1 32;922 D4 1 32;926 F#4 1 32;930 C#5 1 32;934 E5 1 32;938 C#5 1 32;942 A4 1 32;420 C#4 1 32;424 E4 1 32;428 A4 1 32;953 A3 1 32;953 G#5 1 32;957 E4 1 32;961 A4 1 32;965 B4 1 32;969 C#5 1 32;974 B4 1 32;979 A4 1 32;985 E4 1 32;995 A5 1 32;995 A3 1 32;995 C#4 1 32;995 E4 1 32;995 A4 1 32;995 C#5 1 32;995 E5 1 32;1015 B7 1 5'
# https://onlinesequencer.net/1865394 C418 - Calm 3
#song = '0 E4 1 8;0 G4 1 8;8 A4 1 8;8 D5 1 8;16 F#4 1 8;16 A4 1 8;24 A4 1 8;24 C#5 1 8;32 E4 1 8;32 G4 1 8;32 B4 1 8;40 A4 1 8;40 D5 1 8;40 F#5 1 8;48 F#4 1 8;48 A4 1 8;48 C#5 1 8;56 A4 1 8;56 C#5 1 8;56 E5 1 8;64 E4 1 8;64 G4 1 8;64 B4 1 8;72 A4 1 8;72 D5 1 8;72 F#5 1 8;80 F#4 1 8;80 A4 1 8;80 C#5 1 8;88 A4 1 8;88 C#5 1 8;88 E5 1 8;96 E4 1 8;96 G4 1 8;96 B4 1 8;100 A5 1 8;102 B5 1 8;104 A4 1 8;104 D5 1 8;104 F#5 1 8;110 D5 1 8;111 E5 1 8;112 F#4 1 8;112 A4 1 8;112 C#5 1 8;118 F#5 1 8;119 A5 1 8;120 A4 1 8;120 C#5 1 8;120 E5 1 8;128 E4 1 8;128 G4 1 8;128 B4 1 8;130 D6 1 8;132 B5 1 8;134 A5 1 8;136 A4 1 8;136 D5 1 8;136 F#5 1 8;142 D5 1 8;143 E5 1 8;144 F#4 1 8;144 A4 1 8;144 C#5 1 8;150 A5 1 8;151 F#5 1 8;152 A4 1 8;152 C#5 1 8;152 E5 1 8;160 E4 1 8;160 G4 1 8;160 B4 1 8;164 A5 1 8;166 B5 1 8;168 D5 1 8;168 F#5 1 8;168 D6 1 8;174 D5 1 8;174 F#6 1 8;175 E5 1 8;175 E6 1 8;176 D5 1 8;176 C#6 1 8;182 F#5 1 8;182 D6 1 8;183 C#6 1 8;184 A4 1 8;184 C#5 1 8;184 E5 1 8;184 A5 1 8;192 E4 1 8;192 G4 1 8;192 B4 1 8;196 B5 1 8;198 A5 1 8;200 A4 1 8;200 D5 1 8;200 F#5 1 8;206 D5 1 8;207 E5 1 8;208 F#4 1 8;208 A4 1 8;208 C#5 1 8;214 F#5 1 8;215 A5 1 8;216 A4 1 8;216 C#5 1 8;216 E5 1 8;224 E4 1 8;224 G4 1 8;224 B4 1 8;228 A5 1 8;230 B5 1 8;232 A4 1 8;232 D5 1 8;232 F#5 1 8;238 D5 1 8;239 E5 1 8;240 F#4 1 8;240 A4 1 8;240 C#5 1 8;244 F#6 1 8;246 F#5 1 8;247 A5 1 8;248 A4 1 8;248 C#5 1 8;248 E5 1 8;256 B4 1 8;256 D5 1 8;256 F#5 1 8;262 B5 1 8;263 A5 1 8;264 G#4 1 8;264 B4 1 8;264 E5 1 8;268 E5 1 8;270 D5 1 8;272 E4 1 8;272 A4 1 8;272 C#5 1 8;278 D5 1 8;279 E5 1 8;280 D4 1 8;280 G4 1 8;280 B4 1 8;288 B4 1 8;288 D5 1 8;288 F#5 1 8;288 D6 1 8;294 B5 1 8;295 A5 1 8;296 G#4 1 8;296 B4 1 8;296 E5 1 8;300 E5 1 8;302 D5 1 8;302 E6 1 8;304 E4 1 8;304 A4 1 8;304 C#5 1 8;304 C#6 1 8;308 D6 1 8;310 F#6 1 8;312 B4 1 8;312 B5 1 8;0 E3 1 8;4 F#3 1 8;8 G3 1 8;12 B3 1 8;16 A3 1 8;20 G3 1 8;24 D3 1 8;32 E3 1 8;36 F#3 1 8;40 G3 1 8;44 B3 1 8;48 A3 1 8;52 G3 1 8;56 D3 1 8;64 E3 1 8;68 F#3 1 8;72 G3 1 8;76 B3 1 8;80 A3 1 8;84 G3 1 8;88 D3 1 8;96 E3 1 8;100 F#3 1 8;104 G3 1 8;108 B3 1 8;112 A3 1 8;116 G3 1 8;120 D3 1 8;128 E3 1 8;132 F#3 1 8;136 G3 1 8;140 B3 1 8;144 A3 1 8;148 G3 1 8;152 D3 1 8;160 E3 1 8;164 F#3 1 8;168 G3 1 8;168 A4 1 8;172 B3 1 8;176 A3 1 8;176 F#4 1 8;176 A4 1 8;180 G3 1 8;184 D3 1 8;192 E3 1 8;196 F#3 1 8;200 G3 1 8;204 B3 1 8;208 A3 1 8;212 G3 1 8;216 D3 1 8;224 E3 1 8;228 F#3 1 8;232 G3 1 8;236 B3 1 8;240 A3 1 8;244 G3 1 8;248 D3 1 8;256 B2 1 8;256 B3 1 8;264 E3 1 8;264 E4 1 8;272 A2 1 8;272 A3 1 8;280 G2 1 8;280 G3 1 8;288 B2 1 8;288 B3 1 8;296 E3 1 8;296 E4 1 8;304 A2 1 8;304 A3 1 8;312 G2 1 8;312 D4 1 8;312 G4 1 8;312 B4 1 8;0 E4 1 26;0 G4 1 26;8 A4 1 26;8 D5 1 26;16 F#4 1 26;16 A4 1 26;24 A4 1 26;24 C#5 1 26;32 E4 1 26;32 G4 1 26;32 B4 1 26;40 A4 1 26;40 D5 1 26;40 F#5 1 26;48 F#4 1 26;48 A4 1 26;48 C#5 1 26;56 A4 1 26;56 C#5 1 26;56 E5 1 26;64 E4 1 26;64 G4 1 26;64 B4 1 26;72 A4 1 26;72 D5 1 26;72 F#5 1 26;80 F#4 1 26;80 A4 1 26;80 C#5 1 26;88 A4 1 26;88 C#5 1 26;88 E5 1 26;96 E4 1 26;96 G4 1 26;96 B4 1 26;100 A5 1 26;102 B5 1 26;104 A4 1 26;104 D5 1 26;104 F#5 1 26;110 D5 1 26;111 E5 1 26;112 F#4 1 26;112 A4 1 26;112 C#5 1 26;118 F#5 1 26;119 A5 1 26;120 A4 1 26;120 C#5 1 26;120 E5 1 26;128 E4 1 26;128 G4 1 26;128 B4 1 26;130 D6 1 26;132 B5 1 26;134 A5 1 26;136 A4 1 26;136 D5 1 26;136 F#5 1 26;142 D5 1 26;143 E5 1 26;144 F#4 1 26;144 A4 1 26;144 C#5 1 26;150 A5 1 26;151 F#5 1 26;152 A4 1 26;152 C#5 1 26;152 E5 1 26;160 E4 1 26;160 G4 1 26;160 B4 1 26;164 A5 1 26;166 B5 1 26;168 D5 1 26;168 F#5 1 26;168 D6 1 26;174 D5 1 26;174 F#6 1 26;175 E5 1 26;175 E6 1 26;176 D5 1 26;176 C#6 1 26;182 F#5 1 26;182 D6 1 26;183 C#6 1 26;184 A4 1 26;184 C#5 1 26;184 E5 1 26;184 A5 1 26;192 E4 1 26;192 G4 1 26;192 B4 1 26;196 B5 1 26;198 A5 1 26;200 A4 1 26;200 D5 1 26;200 F#5 1 26;206 D5 1 26;207 E5 1 26;208 F#4 1 26;208 A4 1 26;208 C#5 1 26;214 F#5 1 26;215 A5 1 26;216 A4 1 26;216 C#5 1 26;216 E5 1 26;224 E4 1 26;224 G4 1 26;224 B4 1 26;228 A5 1 26;230 B5 1 26;232 A4 1 26;232 D5 1 26;232 F#5 1 26;238 D5 1 26;239 E5 1 26;240 F#4 1 26;240 A4 1 26;240 C#5 1 26;244 F#6 1 26;246 F#5 1 26;247 A5 1 26;248 A4 1 26;248 C#5 1 26;248 E5 1 26;256 B4 1 26;256 D5 1 26;256 F#5 1 26;262 B5 1 26;263 A5 1 26;264 G#4 1 26;264 B4 1 26;264 E5 1 26;268 E5 1 26;270 D5 1 26;272 E4 1 26;272 A4 1 26;272 C#5 1 26;278 D5 1 26;279 E5 1 26;280 D4 1 26;280 G4 1 26;280 B4 1 26;288 B4 1 26;288 D5 1 26;288 F#5 1 26;288 D6 1 26;294 B5 1 26;295 A5 1 26;296 G#4 1 26;296 B4 1 26;296 E5 1 26;300 E5 1 26;302 D5 1 26;302 E6 1 26;304 E4 1 26;304 A4 1 26;304 C#5 1 26;304 C#6 1 26;308 D6 1 26;310 F#6 1 26;312 B4 1 26;312 B5 1 26;0 E3 1 26;4 F#3 1 26;8 G3 1 26;12 B3 1 26;16 A3 1 26;20 G3 1 26;24 D3 1 26;32 E3 1 26;36 F#3 1 26;40 G3 1 26;44 B3 1 26;48 A3 1 26;52 G3 1 26;56 D3 1 26;64 E3 1 26;68 F#3 1 26;72 G3 1 26;76 B3 1 26;80 A3 1 26;84 G3 1 26;88 D3 1 26;96 E3 1 26;100 F#3 1 26;104 G3 1 26;108 B3 1 26;112 A3 1 26;116 G3 1 26;120 D3 1 26;128 E3 1 26;132 F#3 1 26;136 G3 1 26;140 B3 1 26;144 A3 1 26;148 G3 1 26;152 D3 1 26;160 E3 1 26;164 F#3 1 26;168 G3 1 26;168 A4 1 26;172 B3 1 26;176 A3 1 26;176 F#4 1 26;176 A4 1 26;180 G3 1 26;184 D3 1 26;192 E3 1 26;196 F#3 1 26;200 G3 1 26;204 B3 1 26;208 A3 1 26;212 G3 1 26;216 D3 1 26;224 E3 1 26;228 F#3 1 26;232 G3 1 26;236 B3 1 26;240 A3 1 26;244 G3 1 26;248 D3 1 26;256 B2 1 26;256 B3 1 26;264 E3 1 26;264 E4 1 26;272 A2 1 26;272 A3 1 26;280 G2 1 26;280 G3 1 26;288 B2 1 26;288 B3 1 26;296 E3 1 26;296 E4 1 26;304 A2 1 26;304 A3 1 26;312 G2 1 26;312 D4 1 26;312 G4 1 26;312 B4 1 26'
# https://onlinesequencer.net/59849 Never gonna give you up (by 3CHO)
#song = '0 A#4 1 0;0 D5 1 0;0 F5 1 0;6 C5 1 0;6 E5 1 0;6 G5 1 0;12 C5 1 0;16 C5 1 0;16 E5 1 0;16 G5 1 0;22 A5 1 0;22 F5 1 0;22 D5 1 0;28 C6 0.5 0;29 A#5 0.5 0;30 A5 1 0;32 F5 1 0;32 D5 1 0;32 A#4 1 0;38 C5 1 0;38 E5 1 0;38 G5 1 0;58 C5 1 0;59 C5 1 0;60 D5 1 0;61 F5 1 0;63 F5 1 0;64 F5 1 0;64 D5 1 0;64 A#4 1 0;44 C5 1 0;70 G5 1 0;70 E5 1 0;70 C5 1 0;80 C5 1 0;80 E5 1 0;80 G5 1 0;76 C5 1 0;86 A5 1 0;86 F5 1 0;86 D5 1 0;92 C6 1 0;93 A#5 1 0;94 A5 1 0;96 A#4 1 0;96 D5 1 0;96 F5 1 0;102 G5 1 0;102 E5 1 0;102 C5 1 0;108 C5 1 0;112 C5 1 0;112 E5 1 0;114 F5 1 0;116 A4 1 0;116 D5 1 0;116 F5 1 0'
# https://onlinesequencer.net/2419290 - Traditional Christmas - The First Noel (ver. 2)
song = '0 D4 2 41;2 A4 2 41;4 D5 2 41;6 F#5 2 41;8 A5 2 41;10 D5 2 41;12 D4 2 41;14 A4 2 41;16 D5 8 41;24 D4 2 41;26 A4 2 41;28 D5 2 41;30 A5 2 41;32 F#5 2 41;34 D5 2 41;36 D4 2 41;38 A4 2 41;40 D5 8 41;48 F#5 2 11;50 E5 2 11;52 D5 6 11;58 E5 2 11;60 F#5 2 11;62 G5 2 11;64 A5 8 11;52 D4 2 41;54 A4 2 41;56 D5 2 41;58 F#5 2 41;60 A4 4 41;60 D4 4 41;60 F#4 4 41;64 A3 2 41;66 E4 2 41;68 A4 4 41;72 B5 2 11;74 C#6 2 11;76 D6 4 11;80 C#6 4 11;84 B5 4 11;88 A5 8 11;76 B3 2 41;78 F#4 2 41;80 B4 4 41;72 E4 4 41;72 C#5 4 41;72 A4 4 41;84 F#4 4 41;84 D4 4 41;84 D5 4 41;88 F#3 2 41;90 C#4 2 41;92 F#4 4 41;96 B5 2 11;98 C#6 2 11;100 D6 4 11;104 C#6 4 11;108 B5 4 11;112 A5 4 11;116 B5 4 11;120 C#6 4 11;124 D6 4 11;128 A5 4 11;132 G5 4 11;136 F#5 8 11;96 F#4 4 41;96 A4 4 41;96 C#4 4 41;100 G3 2 41;102 D4 2 41;104 G4 4 41;108 D4 4 41;112 A3 2 41;114 E4 2 41;116 A4 4 41;120 E4 4 41;124 D4 4 41;124 D5 4 41;128 A4 4 41;128 A3 4 41;132 G4 4 41;132 G3 4 41;136 D4 8 41;136 D3 8 41;144 F#5 2 11;146 E5 2 11;148 D5 6 11;154 E5 2 11;156 F#5 2 11;158 G5 2 11;160 A5 8 11;148 D4 2 41;150 A4 2 41;152 D5 2 41;154 F#5 2 41;156 A4 4 41;156 D4 4 41;156 F#4 4 41;160 A3 2 41;162 E4 2 41;164 A4 4 41;168 B5 2 11;170 C#6 2 11;172 D6 4 11;176 C#6 4 11;180 B5 4 11;184 A5 8 11;172 B3 2 41;174 F#4 2 41;176 B4 4 41;168 E4 4 41;168 C#5 4 41;168 A4 4 41;180 F#4 4 41;180 D4 4 41;180 D5 4 41;184 F#3 2 41;186 C#4 2 41;188 F#4 4 41;192 B5 2 11;194 C#6 2 11;196 D6 4 11;200 C#6 4 11;204 B5 4 11;208 A5 4 11;212 B5 4 11;216 C#6 4 11;220 D6 4 11;224 A5 4 11;228 G5 4 11;232 F#5 8 11;192 F#4 4 41;192 A4 4 41;192 C#4 4 41;196 G3 2 41;198 D4 2 41;200 G4 4 41;204 D4 4 41;208 A3 2 41;210 E4 2 41;212 A4 4 41;216 E4 4 41;220 D4 4 41;220 D5 4 41;224 A4 4 41;224 A3 4 41;228 G4 4 41;228 G3 4 41;232 D4 8 41;232 D3 8 41;240 F#5 2 11;242 E5 2 11;244 D5 6 11;250 E5 2 11;252 F#5 2 11;254 G5 2 11;256 A5 8 11;264 D6 2 11;268 B5 8 11;276 B5 4 11;280 A5 12 11;266 C#6 2 11;292 D6 4 11;296 C#6 4 11;300 B5 4 11;304 A5 4 11;308 B5 4 11;312 C#6 4 11;316 D6 4 11;320 A5 4 11;324 G5 4 11;328 F#5 8 11;240 F#4 4 41;240 A3 4 41;244 D3 2 41;246 A3 2 41;248 D4 4 41;252 A3 4 41;256 A2 2 41;258 E3 2 41;260 A3 4 41;264 E3 4 41;268 B2 2 41;270 F#3 2 41;272 B3 4 41;276 F#3 4 41;280 F#2 2 41;282 C#3 2 41;284 F#3 4 41;288 F#3 4 41;252 D3 4 41;264 A2 4 41;276 B2 4 41;288 C#4 4 41;288 A4 4 41;292 G2 2 41;294 D3 2 41;296 G3 4 41;300 D3 4 41;304 A2 2 41;306 E3 2 41;308 A3 4 41;312 E3 4 41;316 D3 4 41;320 A3 4 41;324 A2 4 41;328 D3 8 41;664 D3 48 41;336 D4 2 41;338 A4 2 41;340 D5 2 41;342 F#5 2 41;344 A5 2 41;346 D5 2 41;348 D4 2 41;350 A4 2 41;352 D5 8 41;360 D4 2 41;362 A4 2 41;364 D5 2 41;366 A5 2 41;368 F#5 2 41;370 D5 2 41;372 D4 2 41;374 A4 2 41;376 D5 8 41;384 F#5 2 11;386 E5 2 11;388 D5 6 11;394 E5 2 11;396 F#5 2 11;398 G5 2 11;400 A5 8 11;388 D4 2 41;390 A4 2 41;392 D5 2 41;394 F#5 2 41;396 A4 4 41;396 D4 4 41;396 F#4 4 41;400 A3 2 41;402 E4 2 41;404 A4 4 41;408 B5 2 11;410 C#6 2 11;412 D6 4 11;416 C#6 4 11;420 B5 4 11;424 A5 8 11;412 B3 2 41;414 F#4 2 41;416 B4 4 41;408 E4 4 41;408 C#5 4 41;408 A4 4 41;420 F#4 4 41;420 D4 4 41;420 D5 4 41;424 F#3 2 41;426 C#4 2 41;428 F#4 4 41;432 B5 2 11;434 C#6 2 11;436 D6 4 11;440 C#6 4 11;444 B5 4 11;448 A5 4 11;452 B5 4 11;456 C#6 4 11;460 D6 4 11;464 A5 4 11;468 G5 4 11;472 F#5 8 11;432 F#4 4 41;432 A4 4 41;432 C#4 4 41;436 G3 2 41;438 D4 2 41;440 G4 4 41;444 D4 4 41;448 A3 2 41;450 E4 2 41;452 A4 4 41;456 E4 4 41;460 D4 4 41;460 D5 4 41;464 A4 4 41;464 A3 4 41;468 G4 4 41;468 G3 4 41;472 D4 8 41;472 D3 8 41;480 F#5 2 11;482 E5 2 11;484 D5 6 11;490 E5 2 11;492 F#5 2 11;494 G5 2 11;496 A5 8 11;484 D4 2 41;486 A4 2 41;488 D5 2 41;490 F#5 2 41;492 A4 4 41;492 D4 4 41;492 F#4 4 41;496 A3 2 41;498 E4 2 41;500 A4 4 41;504 B5 2 11;506 C#6 2 11;508 D6 4 11;512 C#6 4 11;516 B5 4 11;520 A5 8 11;508 B3 2 41;510 F#4 2 41;512 B4 4 41;504 E4 4 41;504 C#5 4 41;504 A4 4 41;516 F#4 4 41;516 D4 4 41;516 D5 4 41;520 F#3 2 41;522 C#4 2 41;524 F#4 4 41;528 B5 2 11;530 C#6 2 11;532 D6 4 11;536 C#6 4 11;540 B5 4 11;544 A5 4 11;548 B5 4 11;552 C#6 4 11;556 D6 4 11;560 A5 4 11;564 G5 4 11;568 F#5 8 11;528 F#4 4 41;528 A4 4 41;528 C#4 4 41;532 G3 2 41;534 D4 2 41;536 G4 4 41;540 D4 4 41;544 A3 2 41;546 E4 2 41;548 A4 4 41;552 E4 4 41;556 D4 4 41;556 D5 4 41;560 A4 4 41;560 A3 4 41;564 G4 4 41;564 G3 4 41;568 D4 8 41;568 D3 8 41;576 F#5 2 11;578 E5 2 11;580 D5 6 11;586 E5 2 11;588 F#5 2 11;590 G5 2 11;592 A5 8 11;600 D6 2 11;604 B5 8 11;612 B5 4 11;616 A5 12 11;602 C#6 2 11;628 D6 4 11;632 C#6 4 11;636 B5 4 11;640 A5 4 11;644 B5 4 11;648 C#6 4 11;652 D6 4 11;656 A5 4 11;660 G5 4 11;664 F#5 25 11;576 F#4 4 41;576 A3 4 41;580 D3 2 41;582 A3 2 41;584 D4 4 41;588 A3 4 41;592 A2 2 41;594 E3 2 41;596 A3 4 41;600 E3 4 41;604 B2 2 41;606 F#3 2 41;608 B3 4 41;612 F#3 4 41;616 F#2 2 41;618 C#3 2 41;620 F#3 4 41;624 F#3 4 41;588 D3 4 41;600 A3 4 41;612 B3 4 41;624 C#4 4 41;624 A4 4 41;628 G2 2 41;630 D3 2 41;632 G3 4 41;636 D3 4 41;640 A2 2 41;642 E3 2 41;644 A3 4 41;648 E3 4 41;652 D3 4 41;656 A3 4 41;660 A2 4 41;296 C#5 4 41;300 B4 4 41;304 A4 4 41;308 B4 4 41;312 C#5 4 41;316 D5 4 41;632 C#5 4 41;636 B4 4 41;640 A4 4 41;644 B4 4 41;648 C#5 4 41;652 D5 4 41'
# https://onlinesequencer.net/1696155 Undertale - Heartache
#song = '0 A#3 1 0;0 F#3 2 0;1 C#4 1 0;2 C4 1 0;3 C#4 1 0;4 A#3 1 0;6 A#3 1 0;6 F#3 2 0;7 C4 1 0;8 C#4 1 0;9 G#4 1 0;10 F4 1 0;12 A#3 1 0;12 F#3 2 0;13 C#4 1 0;14 C4 1 0;15 C#4 1 0;16 A#3 1 0;18 A#3 1 0;18 F#3 2 0;19 C4 1 0;20 C#4 1 0;21 G#4 1 0;22 F4 1 0;24 A#3 1 0;24 F3 2 0;25 C#4 1 0;26 C4 1 0;27 C#4 1 0;28 A#3 1 0;30 A#3 1 0;31 C4 1 0;30 F3 2 0;32 C#4 1 0;33 G#4 1 0;34 F4 1 0;36 F3 2 0;36 D#5 2 0;38 C6 2 0;38 G#3 2 0;40 C4 2 0;40 A#5 2 0;42 G#5 1 0;42 D#4 2 0;43 F#5 1 0;44 C4 1 0;45 G#3 1 0;44 F5 2 0;46 D#4 1 0;47 C4 1 0;46 G#5 2 0;48 A#3 1 0;48 F#3 2 0;49 C#4 1 0;50 C4 1 0;51 C#4 1 0;52 A#3 1 0;54 A#3 1 0;55 C4 1 0;54 F#3 2 0;56 C#4 1 0;57 G#4 1 0;58 F4 1 0;60 A#3 1 0;60 F#3 2 0;61 C#4 1 0;48 A#5 15 0;62 C4 1 0;63 C#4 1 0;64 A#3 1 0;66 A#3 1 0;66 F#3 2 0;67 C4 1 0;68 C#4 1 0;69 G#4 1 0;70 F4 1 0;72 A#3 1 0;72 F3 2 0;73 C#4 1 0;74 C4 1 0;75 C#4 1 0;76 A#3 1 0;78 A#3 1 0;78 F3 2 0;79 C4 1 0;80 C#4 1 0;81 G#4 1 0;82 F4 1 0;84 D#5 2 0;84 D#6 2 0;84 G#3 2 0;86 C7 2 0;86 D#3 2 0;86 C6 2 0;88 A#6 2 0;88 F3 2 0;88 A#5 2 0;90 G#5 1 0;90 G#6 1 0;90 G#3 2 0;91 F#6 1 0;91 F#5 1 0;92 F5 2 0;92 C4 2 0;92 F6 2 0;94 D#4 2 0;94 G#6 2 0;94 G#5 2 0;96 F#3 2 0;98 C4 1 0;99 C#4 1 0;100 A#3 1 0;101 F3 1 0;96 A#5 8 0;102 F#3 2 0;104 C4 1 0;104 F5 2 0;105 C#4 1 0;106 A#3 1 0;106 G#5 2 0;107 D#4 1 0;108 G#3 2 0;110 D#3 1 0;108 A#5 4 0;111 F3 1 0;112 G#3 1 0;112 C#6 2 0;113 F3 1 0;114 D#6 1 0;114 D#3 2 0;115 C#6 1 0;116 F3 2 0;116 C6 2 0;118 G#3 2 0;118 C#6 2 0;120 A#3 1 0;121 A#4 1 0;122 D#4 1 0;123 F4 1 0;124 C#4 1 0;125 G#3 1 0;126 A#3 1 0;127 A#4 1 0;128 D#4 1 0;129 F4 1 0;130 C#4 1 0;131 G#3 1 0;132 A#3 1 0;133 A#4 1 0;120 A#5 15 0;134 D#4 1 0;135 F4 1 0;136 C#4 1 0;137 F3 1 0;138 G#3 2 0;140 D#3 2 0;142 G#3 2 0;144 A#4 1 0;144 A#3 1 0;144 F#3 1 0;145 C#5 1 0;145 C#4 1 0;146 C5 1 0;146 C4 1 0;147 C#5 1 0;147 C#4 1 0;148 A#4 1 0;148 A#3 1 0;150 A#4 1 0;150 F#3 1 0;150 A#3 1 0;151 C4 1 0;151 C5 1 0;152 C#4 1 0;152 C#5 1 0;153 G#4 1 0;154 F4 1 0;154 F5 1 0;156 A#4 1 0;156 A#3 1 0;156 F#3 1 0;157 C#5 1 0;157 C#4 1 0;158 C5 1 0;158 C4 1 0;159 C#5 1 0;159 C#4 1 0;160 A#3 1 0;160 A#4 1 0;162 A#4 1 0;162 A#3 1 0;162 F#3 1 0;163 C5 1 0;163 C4 1 0;164 C#5 1 0;164 C#4 1 0;165 G#4 1 0;166 F5 1 0;166 F4 1 0;168 A#3 1 0;168 F3 1 0;168 A#4 1 0;169 C#5 1 0;169 C#4 1 0;170 C5 1 0;170 C4 1 0;171 C#4 1 0;171 C#5 1 0;172 A#3 1 0;172 A#4 1 0;174 A#4 1 0;174 A#3 1 0;174 F3 1 0;175 C5 1 0;175 C4 1 0;176 C#5 1 0;176 C#4 1 0;177 G#4 1 0;178 F4 1 0;178 F5 1 0;180 F3 2 0;180 D#6 2 0;180 F4 2 0;182 G#4 2 0;182 C7 2 0;182 G#3 2 0;184 C4 2 0;184 A#6 2 0;184 C5 2 0;186 G#6 1 0;186 D#5 2 0;186 D#4 2 0;187 F#6 1 0;188 C5 1 0;188 C4 1 0;189 G#3 1 0;189 G#4 1 0;188 F6 2 0;190 D#4 1 0;190 D#5 1 0;191 C5 1 0;190 G#6 2 0;191 C4 1 0;192 A#4 1 0;192 A#3 1 0;192 F#3 1 0;193 C#5 1 0;193 C#4 1 0;194 C4 1 0;194 C5 1 0;195 C#4 1 0;195 C#5 1 0;196 A#4 1 0;196 A#3 1 0;198 F#3 1 0;198 A#3 1 0;198 A#4 1 0;199 C5 1 0;199 C4 1 0;200 C#4 1 0;200 C#5 1 0;201 G#4 1 0;202 F4 1 0;202 F5 1 0;204 A#4 1 0;204 F#3 1 0;204 A#3 1 0;205 C#4 1 0;205 C#5 1 0;206 C5 1 0;192 A#6 15 0;206 C4 1 0;207 C#4 1 0;207 C#5 1 0;208 A#3 1 0;208 A#4 1 0;210 A#3 1 0;210 F#3 1 0;210 A#4 1 0;211 C5 1 0;211 C4 1 0;212 C#5 1 0;212 C#4 1 0;213 G#4 1 0;214 F5 1 0;214 F4 1 0;216 D#5 1 0;216 D#4 1 0;217 F4 1 0;217 F5 1 0;218 G#5 1 0;218 G#4 1 0;219 A#4 1 0;219 A#5 1 0;220 C6 1 0;220 C5 1 0;221 C#6 1 0;221 C#5 1 0;222 D#6 1 0;222 D#5 1 0;223 C#6 1 0;223 C#5 1 0;224 C6 1 0;224 C5 1 0;225 A#5 1 0;225 A#4 1 0;226 G#5 1 0;226 G#4 1 0;227 F4 1 0;227 F5 1 0;228 G#5 2 0;228 G#4 2 0;228 D#6 2 0;228 G#3 2 0;230 C7 2 0;230 D#3 2 0;230 D#4 2 0;230 D#6 2 0;232 F4 2 0;232 C#6 2 0;232 F3 2 0;232 A#6 2 0;234 G#6 1 0;234 C6 1 0;234 G#3 2 0;234 G#4 2 0;235 A#5 1 0;235 F#6 1 0;236 G#5 2 0;236 F6 2 0;236 C5 2 0;236 C4 2 0;238 G#6 2 0;238 F5 2 0;238 D#4 2 0;238 D#5 2 0;240 F#3 2 0;242 C4 1 0;243 C#4 1 0;244 A#3 1 0;245 F3 1 0;240 A#5 8 0;246 F#3 2 0;240 F#5 8 0;248 C4 1 0;248 F5 2 0;248 C5 2 0;249 C#4 1 0;250 A#3 1 0;250 G#5 2 0;250 D#5 2 0;251 D#4 1 0;252 G#3 2 0;254 D#3 1 0;252 F5 4 0;252 A#5 4 0;255 F3 1 0;256 G#3 1 0;256 F5 2 0;256 C#6 2 0;257 F3 1 0;258 F#5 1 0;258 D#6 1 0;258 D#3 2 0;259 C#6 1 0;259 F5 1 0;260 D#5 2 0;260 C6 2 0;260 F3 2 0;262 G#3 2 0;262 C#6 2 0;262 F5 2 0;264 A#3 1 0;265 A#4 1 0;266 D#4 1 0;267 F4 1 0;268 C#4 1 0;269 G#3 1 0;270 A#3 1 0;271 A#4 1 0;272 D#4 1 0;273 F4 1 0;274 C#4 1 0;275 G#3 1 0;276 A#3 1 0;277 A#4 1 0;278 D#4 1 0;264 A#5 15 0;264 F5 15 0;279 F4 1 0;280 C#4 1 0;281 F3 1 0;282 G#3 2 0;282 F5 2 0;282 A#5 2 0;284 C#6 2 0;284 G#5 2 0;284 D#3 2 0;286 D#6 2 0;286 A#5 2 0;286 F3 2 0;288 D#3 2 0;290 G#3 1 0;291 A#3 1 0;292 F#3 1 0;293 C#3 1 0;294 D#3 2 0;288 F6 8 0;288 G#5 8 0;296 G#3 1 0;296 G#5 2 0;296 C#6 2 0;297 A#3 1 0;298 D#6 2 0;298 A#5 2 0;298 C4 2 0;300 F3 2 0;302 C4 1 0;300 G#5 4 0;300 F6 4 0;303 G#4 1 0;304 F4 1 0;304 D#6 2 0;304 A#5 2 0;305 C4 1 0;306 G#5 1 0;306 C#6 1 0;306 F3 1 0;307 A#5 1 0;307 D#6 1 0;307 F4 1 0;308 G#3 1 0;309 F4 1 0;308 C6 2 0;308 D#5 2 0;310 A#3 1 0;311 G#4 1 0;310 G#5 2 0;310 F5 2 0;312 F#3 1 0;313 F#4 1 0;314 C#4 1 0;315 D#4 1 0;316 F4 1 0;317 F3 1 0;318 F#3 1 0;312 A#5 8 0;312 F5 8 0;319 F#4 1 0;320 C#4 1 0;320 C#5 2 0;321 D#4 1 0;322 F4 1 0;322 D#5 2 0;323 F#3 1 0;324 F3 1 0;325 F4 1 0;326 C4 1 0;324 F5 4 0;327 G#4 1 0;328 F4 1 0;328 D#5 2 0;329 C4 1 0;330 C#5 1 0;330 F3 1 0;331 F4 1 0;331 D#5 1 0;332 G#3 1 0;332 C5 2 0;333 F4 1 0;334 A#3 1 0;335 G#4 1 0;334 G#5 2 0;336 F#3 1 0;337 F#4 1 0;338 C#4 1 0;339 D#4 1 0;340 F4 1 0;341 F3 1 0;342 F#3 1 0;343 F#4 1 0;336 F5 8 0;344 C#4 1 0;344 G#5 2 0;344 C#6 2 0;345 D#4 1 0;346 F4 1 0;346 A#5 2 0;346 D#6 2 0;347 F#3 1 0;348 G#3 1 0;349 D#3 1 0;350 C4 1 0;348 G#5 4 0;348 F6 4 0;351 G#3 1 0;352 D#4 1 0;352 D#6 2 0;352 A#5 2 0;353 C4 1 0;354 C#6 1 0;354 G#5 1 0;354 G#4 1 0;355 D#6 1 0;355 G#3 1 0;355 A#5 1 0;356 C6 2 0;356 D#5 2 0;356 D#4 2 0;358 G#5 2 0;358 F5 2 0;358 C4 2 0;360 A#3 1 0;361 F3 1 0;362 C4 1 0;363 G#3 1 0;364 C#4 1 0;365 F3 1 0;366 B3 1 0;367 C#4 1 0;368 D#4 1 0;369 F#3 1 0;370 A#3 1 0;371 C#4 1 0;372 B3 1 0;373 F#3 1 0;374 C#4 1 0;360 F5 15 0;360 A#5 15 0;375 F#3 1 0;376 D#4 1 0;377 F#3 1 0;378 F#4 1 0;379 B3 1 0;380 G#4 1 0;381 B3 1 0;382 C#5 1 0;383 G#4 1 0;384 B3 1 0;384 D#6 1 0;384 D#5 1 0;385 F#3 1 0;385 D#6 2 0;385 D#5 2 0;386 C#4 1 0;387 F#3 1 0;388 D#4 1 0;387 D#6 2 0;387 D#5 2 0;389 D#6 1 0;389 F#3 1 0;389 D#5 1 0;390 B3 1 0;391 F#3 1 0;390 D#5 2 0;390 D#6 2 0;392 C#4 1 0;393 F#3 1 0;392 D#6 2 0;392 D#5 2 0;394 D#4 1 0;394 D#6 2 0;394 D#5 2 0;395 F#3 1 0;396 D#6 1 0;396 D#5 1 0;396 F#4 1 0;397 B3 1 0;398 G#4 1 0;397 D#5 2 0;397 D#6 2 0;399 C#4 1 0;399 D#6 2 0;399 D#5 2 0;400 C#5 1 0;401 G#4 1 0;401 D#6 1 0;401 D#5 1 0;402 B4 1 0;403 F#4 1 0;402 D#5 2 0;402 D#6 2 0;404 F#5 1 0;404 D#5 2 0;404 D#6 2 0;405 C#5 1 0;406 B5 1 0;406 D#5 2 0;406 D#6 2 0;407 F#5 1 0;408 B3 1 0;409 D#4 1 0;410 C#4 1 0;411 D#4 1 0;412 B3 1 0;414 B3 1 0;415 C#4 1 0;416 D#4 1 0;417 B4 1 0;418 F#4 1 0;420 B3 1 0;421 D#4 1 0;422 C#4 1 0;423 D#4 1 0;424 B3 1 0;426 B3 1 0;427 C#4 1 0;428 D#4 1 0;429 B4 1 0;430 F#4 1 0;432 F6 1 0;432 A#3 1 0;432.6600036621094 F#6 1 0;433 C#4 1 0;433.3299865722656 G6 1 0;434.010009765625 C4 1 0;434.010009765625 C#6 2 0;434.010009765625 G#6 2 0;435.010009765625 C#4 1 0;436.010009765625 A#3 1 0;436.010009765625 C#6 2 0;436.010009765625 G#6 2 0;438.010009765625 A#3 1 0;439.010009765625 C4 1 0;438.010009765625 C6 2 0;438.010009765625 G6 2 0;440.010009765625 C#4 1 0;440.010009765625 C6 2 0;440.010009765625 G6 2 0;441.010009765625 G#4 1 0;442.010009765625 F4 1 0;442.010009765625 G6 2 0;442.010009765625 C6 2 0;444.010009765625 F6 1 0;444.6700134277344 F#6 1 0;444.010009765625 F3 2 0;445.3399963378906 G6 1 0;446.0199890136719 C#6 2 0;446.0199890136719 G#3 2 0;446.0199890136719 G#6 2 0;448.0199890136719 G#6 2 0;448.0199890136719 C#6 2 0;448.0199890136719 C4 2 0;450.0199890136719 D#4 2 0;450.0199890136719 C6 2 0;450.0199890136719 G#6 2 0;452.0199890136719 G6 1 0;452.0199890136719 A#5 1 0;452.0199890136719 C4 1 0;453.0199890136719 G#3 1 0;453.0199890136719 F6 1 0;453.0199890136719 G#5 1 0;454.0199890136719 D#4 1 0;454.0199890136719 D#6 2 0;454.0199890136719 G#5 2 0;455.0199890136719 C4 1 0;456.0199890136719 B3 1 0;457.0199890136719 D#4 1 0;458.0199890136719 C#4 1 0;459.0199890136719 D#4 1 0;460.0199890136719 B3 1 0;462.0199890136719 B3 1 0;463.0199890136719 C#4 1 0;464.0199890136719 D#4 1 0;465.0199890136719 B4 1 0;466.0199890136719 F#4 1 0;468.0199890136719 B3 1 0;469.0199890136719 D#4 1 0;456.0199890136719 A#5 15 0;456.0199890136719 F6 15 0;470.0199890136719 C#4 1 0;471.0199890136719 D#4 1 0;472.0199890136719 B3 1 0;474.0199890136719 B3 1 0;475.0199890136719 C#4 1 0;476.0199890136719 D#4 1 0;477.0199890136719 B4 1 0;478.0199890136719 F#4 1 0;480.0199890136719 A#3 1 0;480.0199890136719 F6 1 0;480.67999267578125 F#6 1 0;481.0199890136719 C#4 1 0;481.3500061035156 G6 1 0;482.0299987792969 C4 1 0;482.0299987792969 C#6 2 0;482.0299987792969 G#6 2 0;483.0299987792969 C#4 1 0;484.0299987792969 A#3 1 0;484.0299987792969 C#6 2 0;484.0299987792969 G#6 2 0;486.0299987792969 A#3 1 0;487.0299987792969 C4 1 0;486.0299987792969 C6 2 0;486.0299987792969 G6 2 0;488.0299987792969 C#4 1 0;488.0299987792969 G6 2 0;488.0299987792969 C6 2 0;489.0299987792969 G#4 1 0;490.0299987792969 F4 1 0;490.0299987792969 G6 2 0;490.0299987792969 C6 2 0;492.0299987792969 D#5 2 0;492.0299987792969 G#3 2 0;494.0299987792969 C6 2 0;494.0299987792969 D#3 2 0;496.0299987792969 F3 2 0;496.0299987792969 A#5 2 0;498.0299987792969 G#5 1 0;498.0299987792969 G#3 2 0;499.0299987792969 F#5 1 0;500.0299987792969 F5 2 0;500.0299987792969 C4 2 0;502.0299987792969 G#5 2 0;502.0299987792969 D#4 2 0;504.0299987792969 B3 1 0;505.0299987792969 D#4 1 0;506.0299987792969 C#4 1 0;507.0299987792969 D#4 1 0;504.0299987792969 A#5 4 0;508.0299987792969 B3 1 0;508.0299987792969 C#6 2 0;510.0299987792969 B3 1 0;511.0299987792969 C#4 1 0;510.0299987792969 D#6 2 0;512.030029296875 D#4 1 0;512.030029296875 C#6 2 0;513.030029296875 B4 1 0;514.030029296875 F#4 1 0;514.030029296875 D#6 2 0;516.030029296875 B3 1 0;517.030029296875 D#4 1 0;518.030029296875 C#4 1 0;516.030029296875 F6 4 0;519.030029296875 D#4 1 0;520.030029296875 B3 1 0;520.030029296875 D#6 2 0;522.030029296875 B3 1 0;522.030029296875 F#6 2 0;523.030029296875 C#4 1 0;524.030029296875 D#4 1 0;524.030029296875 F6 2 0;525.030029296875 B4 1 0;526.030029296875 F#4 1 0;526.030029296875 D#6 2 0;528.030029296875 A#3 1 0;529.030029296875 C#4 1 0;530.030029296875 C4 1 0;528.030029296875 F6 4 0;531.030029296875 C#4 1 0;532.030029296875 A#3 1 0;532.030029296875 F#6 2 0;534.030029296875 F6 1 0;534.030029296875 A#3 1 0;535.030029296875 C4 1 0;535.030029296875 F#6 1 0;536.030029296875 C#4 1 0;536.030029296875 D#6 2 0;537.030029296875 G#4 1 0;538.030029296875 F4 1 0;538.030029296875 F6 2 0;540.030029296875 F3 2 0;540.030029296875 C#6 4 0;542.030029296875 G#3 2 0;544.030029296875 D#6 2 0;544.030029296875 C4 2 0;546.030029296875 C6 1 0;547.030029296875 C#6 1 0;546.030029296875 D#4 2 0;548.030029296875 C4 1 0;548.030029296875 A#5 2 0;549.030029296875 G#3 1 0;550.030029296875 D#4 1 0;551.030029296875 C4 1 0;550.030029296875 G#5 2 0;552.030029296875 B3 1 0;553.030029296875 D#4 1 0;554.030029296875 C#4 1 0;552.030029296875 F5 4 0;555.030029296875 D#4 1 0;556.030029296875 B3 1 0;556.030029296875 F#5 2 0;558.030029296875 B3 1 0;559.030029296875 C#4 1 0;560.030029296875 D#4 1 0;558.030029296875 G#5 4 0;561.030029296875 B4 1 0;562.030029296875 F#4 1 0;562.030029296875 A#5 2 0;564.030029296875 B3 1 0;565.030029296875 D#4 1 0;566.030029296875 C#4 1 0;564.030029296875 F5 4 0;567.030029296875 D#4 1 0;568.030029296875 B3 1 0;568.030029296875 F#5 2 0;570.030029296875 B3 1 0;571.030029296875 C#4 1 0;572.030029296875 D#4 1 0;570.030029296875 G#5 4 0;573.030029296875 B4 1 0;574.030029296875 F#4 1 0;574.030029296875 A#5 2 0;576.030029296875 A#3 1 0;576.030029296875 F5 1 0;576.030029296875 F6 1 0;576.6900024414062 F#6 1 0;577.030029296875 C#4 1 0;577.030029296875 F#5 1 0;577.3599853515625 G6 1 0;578.0399780273438 C4 1 0;579.0399780273438 C#4 1 0;578.0399780273438 C#6 2 0;578.0399780273438 G#6 2 0;580.0399780273438 A#3 1 0;580.0399780273438 G#6 2 0;580.0399780273438 C#6 2 0;582.0399780273438 A#3 1 0;582.0399780273438 C6 2 0;582.0399780273438 G6 2 0;583.0399780273438 C4 1 0;584.0399780273438 C#4 1 0;585.0399780273438 G#4 1 0;584.0399780273438 C6 2 0;584.0399780273438 G6 2 0;586.0399780273438 F4 1 0;586.0399780273438 C6 2 0;586.0399780273438 G6 2 0;588.0399780273438 F6 1 0;588.7000122070312 F#6 1 0;588.0399780273438 F3 2 0;589.3800048828125 G6 1 0;590.0499877929688 G#6 2 0;590.0499877929688 C#6 2 0;590.0499877929688 G#3 2 0;578.0399780273438 F5 15 0;592.0499877929688 G#6 2 0;592.0499877929688 C4 2 0;592.0499877929688 C#6 2 0;594.0499877929688 D#4 2 0;594.0499877929688 C6 2 0;594.0499877929688 G#6 2 0;596.0499877929688 C4 1 0;596.0499877929688 G6 1 0;596.0499877929688 A#5 1 0;597.0499877929688 G#3 1 0;597.0499877929688 F6 1 0;597.0499877929688 G#5 1 0;598.0499877929688 D#4 1 0;598.0499877929688 D#6 2 0;598.0499877929688 G#5 2 0;599.0499877929688 C4 1 0;600.0499877929688 B3 1 0;601.0499877929688 D#4 1 0;602.0499877929688 C#4 1 0;600.0499877929688 A#5 4 0;603.0499877929688 D#4 1 0;604.0499877929688 B3 1 0;604.0499877929688 C#6 2 0;606.0499877929688 B3 1 0;606.0499877929688 D#6 2 0;607.0499877929688 C#4 1 0;608.0499877929688 D#4 1 0;608.0499877929688 C#6 2 0;609.0499877929688 B4 1 0;610.0499877929688 F#4 1 0;610.0499877929688 D#6 2 0;612.0499877929688 B3 1 0;613.0499877929688 D#4 1 0;614.0499877929688 C#4 1 0;612.0499877929688 F6 4 0;615.0499877929688 D#4 1 0;616.0499877929688 B3 1 0;616.0499877929688 D#6 2 0;618.0499877929688 B3 1 0;618.0499877929688 F#6 2 0;619.0499877929688 C#4 1 0;620.0499877929688 D#4 1 0;621.0499877929688 B4 1 0;620.0499877929688 F6 2 0;622.0499877929688 F#4 1 0;622.0499877929688 D#6 2 0;624.0499877929688 A#3 1 0;625.0499877929688 C#4 1 0;626.0499877929688 C4 1 0;624.0499877929688 F6 4 0;627.0499877929688 C#4 1 0;628.0499877929688 A#3 1 0;628.0499877929688 F#6 2 0;630.0499877929688 A#3 1 0;630.0499877929688 F6 1 0;631.0499877929688 F#6 1 0;631.0499877929688 C4 1 0;632.0499877929688 C#4 1 0;633.0499877929688 G#4 1 0;632.0499877929688 D#6 2 0;634.0499877929688 F4 1 0;634.0499877929688 F6 2 0;636.0499877929688 F3 2 0;636.0499877929688 C#6 4 0;638.0499877929688 G#3 2 0;640.0499877929688 C4 2 0;640.0499877929688 D#6 2 0;642.0499877929688 C6 1 0;642.0499877929688 D#4 2 0;643.0499877929688 C#6 1 0;644.0499877929688 C4 1 0;644.0499877929688 A#5 2 0;645.0499877929688 G#3 1 0;646.0499877929688 D#4 1 0;646.0499877929688 G#5 2 0;647.0499877929688 C4 1 0;648.0499877929688 B3 1 0;649.0499877929688 D#4 1 0;650.0499877929688 C#4 1 0;651.0499877929688 D#4 1 0;648.0499877929688 F5 4 0;652.0499877929688 B3 1 0;652.0499877929688 F#5 2 0;654.0499877929688 B3 1 0;655.0499877929688 C#4 1 0;656.0499877929688 D#4 1 0;654.0499877929688 G#5 4 0;657.0499877929688 B4 1 0;658.0499877929688 F#4 1 0;658.0499877929688 A#5 2 0;660.0499877929688 B3 1 0;661.0499877929688 D#4 1 0;662.0499877929688 C#4 1 0;660.0499877929688 F5 4 0;663.0499877929688 D#4 1 0;664.0499877929688 B3 1 0;664.0499877929688 F#5 2 0;666.0499877929688 B3 1 0;667.0499877929688 C#4 1 0;668.0499877929688 D#4 1 0;669.0499877929688 B4 1 0;666.0499877929688 G#5 4 0;670.0499877929688 F#4 1 0;670.0499877929688 A#5 2 0;672.0499877929688 A#3 1 0;672.0499877929688 F5 1 0;673.0499877929688 C#4 1 0;673.0499877929688 F#5 1 0;674.0499877929688 C4 1 0;675.0499877929688 C#4 1 0;676.0499877929688 A#3 1 0;678.0499877929688 A#3 1 0;679.0499877929688 C4 1 0;680.0499877929688 C#4 1 0;674.0499877929688 F5 8 0;681.0499877929688 G#4 1 0;682.0499877929688 F4 1 0;684.0499877929688 G#3 2 0;684.0499877929688 D#6 2 0;684.0499877929688 G#5 2 0;686.0499877929688 D#6 2 0;686.0499877929688 C7 2 0;686.0499877929688 D#3 2 0;688.0499877929688 F3 2 0;688.0499877929688 C#6 2 0;688.0499877929688 A#6 2 0;690.0499877929688 G#6 1 0;690.0499877929688 C6 1 0;691.0499877929688 F#6 1 0;691.0499877929688 A#5 1 0;690.0499877929688 G#3 2 0;692.0499877929688 G#5 2 0;692.0499877929688 F6 2 0;692.0499877929688 C4 2 0;694.0499877929688 F5 2 0;694.0499877929688 G#6 2 0;694.0499877929688 D#4 2 0;696.0499877929688 F#3 2 0;698.0499877929688 C4 1 0;699.0499877929688 C#4 1 0;700.0499877929688 A#3 1 0;701.0499877929688 F3 1 0;702.0499877929688 F#3 2 0;696.0499877929688 A#5 8 0;696.0499877929688 F#5 8 0;704.0499877929688 C4 1 0;704.0499877929688 F5 2 0;705.0499877929688 C#4 1 0;704.0499877929688 C5 2 0;706.0499877929688 A#3 1 0;706.0499877929688 D#5 2 0;706.0499877929688 G#5 2 0;707.0499877929688 D#4 1 0;708.0499877929688 G#3 2 0;710.0499877929688 D#3 1 0;708.0499877929688 F5 4 0;711.0499877929688 F3 1 0;708.0499877929688 A#5 4 0;712.0499877929688 G#3 1 0;713.0499877929688 F3 1 0;712.0499877929688 F5 2 0;712.0499877929688 C#6 2 0;714.0499877929688 F#5 1 0;714.0499877929688 D#6 1 0;714.0499877929688 D#3 2 0;715.0499877929688 C#6 1 0;715.0499877929688 F5 1 0;716.0499877929688 D#5 2 0;716.0499877929688 F3 2 0;716.0499877929688 C6 2 0;718.0499877929688 G#3 2 0;718.0499877929688 F5 2 0;718.0499877929688 C#6 2 0;720.0499877929688 A#3 1 0;721.0499877929688 A#4 1 0;722.0499877929688 D#4 1 0;723.0499877929688 F4 1 0;724.0499877929688 C#4 1 0;725.0499877929688 G#3 1 0;726.0499877929688 A#3 1 0;727.0499877929688 A#4 1 0;728.0499877929688 D#4 1 0;729.0499877929688 F4 1 0;730.0499877929688 C#4 1 0;731.0499877929688 G#3 1 0;732.0499877929688 A#3 1 0;733.0499877929688 A#4 1 0;734.0499877929688 D#4 1 0;720.0499877929688 F5 15 0;720.0499877929688 A#5 15 0;735.0499877929688 F4 1 0;736.0499877929688 C#4 1 0;737.0499877929688 F3 1 0;738.0499877929688 A#5 2 0;738.0499877929688 F5 2 0;738.0499877929688 G#3 2 0;740.0499877929688 D#3 2 0;740.0499877929688 C#6 2 0;740.0499877929688 G#5 2 0;742.0499877929688 A#5 2 0;742.0499877929688 D#6 2 0;742.0499877929688 F3 2 0;744.0499877929688 D#3 2 0;746.0499877929688 G#3 1 0;747.0499877929688 A#3 1 0;748.0499877929688 F#3 1 0;749.0499877929688 C#3 1 0;744.0499877929688 G#5 8 0;750.0499877929688 D#3 2 0;744.0499877929688 F6 8 0;752.0499877929688 G#3 1 0;753.0499877929688 A#3 1 0;752.0499877929688 G#5 2 0;752.0499877929688 C#6 2 0;754.0499877929688 A#5 2 0;754.0499877929688 D#6 2 0;754.0499877929688 C4 2 0;756.0499877929688 F3 2 0;758.0499877929688 C4 1 0;756.0499877929688 G#5 4 0;756.0499877929688 F6 4 0;759.0499877929688 G#4 1 0;760.0499877929688 F4 1 0;760.0499877929688 D#6 2 0;761.0499877929688 C4 1 0;760.0499877929688 A#5 2 0;762.0499877929688 G#5 1 0;762.0499877929688 C#6 1 0;762.0499877929688 F3 1 0;763.0499877929688 A#5 1 0;763.0499877929688 D#6 1 0;763.0499877929688 F4 1 0;764.0499877929688 G#3 1 0;764.0499877929688 D#5 2 0;764.0499877929688 C6 2 0;765.0499877929688 F4 1 0;766.0499877929688 A#3 1 0;766.0499877929688 F5 2 0;766.0499877929688 G#5 2 0;767.0499877929688 G#4 1 0;768.0499877929688 F#3 1 0;769.0499877929688 F#4 1 0;770.0499877929688 C#4 1 0;771.0499877929688 D#4 1 0;772.0499877929688 F4 1 0;773.0499877929688 F3 1 0;774.0499877929688 F#3 1 0;775.0499877929688 F#4 1 0;768.0499877929688 F5 8 0;768.0499877929688 A#5 8 0;776.0499877929688 C#4 1 0;777.0499877929688 D#4 1 0;776.0499877929688 C#5 2 0;778.0499877929688 F4 1 0;778.0499877929688 D#5 2 0;779.0499877929688 F#3 1 0;780.0499877929688 F3 1 0;781.0499877929688 F4 1 0;782.0499877929688 C4 1 0;783.0499877929688 G#4 1 0;780.0499877929688 F5 4 0;784.0499877929688 F4 1 0;784.0499877929688 D#5 2 0;785.0499877929688 C4 1 0;786.0499877929688 F3 1 0;786.0499877929688 C#5 1 0;787.0499877929688 D#5 1 0;787.0499877929688 F4 1 0;788.0499877929688 G#3 1 0;788.0499877929688 C5 2 0;789.0499877929688 F4 1 0;790.0499877929688 A#3 1 0;791.0499877929688 G#4 1 0;790.0499877929688 G#5 2 0;792.0499877929688 F#3 1 0;793.0499877929688 F#4 1 0;794.0499877929688 C#4 1 0;795.0499877929688 D#4 1 0;796.0499877929688 F4 1 0;797.0499877929688 F3 1 0;798.0499877929688 F#3 1 0;792.0499877929688 F5 8 0;799.0499877929688 F#4 1 0;800.0499877929688 C#4 1 0;800.0499877929688 G#5 2 0;800.0499877929688 C#6 2 0;801.0499877929688 D#4 1 0;802.0499877929688 F4 1 0;803.0499877929688 F#3 1 0;802.0499877929688 D#6 2 0;802.0499877929688 A#5 2 0;804.0499877929688 G#3 1 0;805.0499877929688 D#3 1 0;806.0499877929688 C4 1 0;804.0499877929688 F6 4 0;804.0499877929688 G#5 4 0;807.0499877929688 G#3 1 0;808.0499877929688 D#4 1 0;809.0499877929688 C4 1 0;808.0499877929688 A#5 2 0;808.0499877929688 D#6 2 0;810.0499877929688 G#5 1 0;810.0499877929688 C#6 1 0;810.0499877929688 G#4 1 0;811.0499877929688 D#6 1 0;811.0499877929688 G#3 1 0;811.0499877929688 A#5 1 0;812.0499877929688 D#4 2 0;812.0499877929688 D#5 2 0;812.0499877929688 C6 2 0;814.0499877929688 G#5 2 0;814.0499877929688 F5 2 0;814.0499877929688 C4 2 0;816.0499877929688 F#3 1 0;817.0499877929688 F#4 1 0;818.0499877929688 C#4 1 0;819.0499877929688 D#4 1 0;820.0499877929688 F4 1 0;821.0499877929688 F3 1 0;822.0499877929688 F#3 1 0;816.0499877929688 A#5 8 0;816.0499877929688 F5 8 0;823.0499877929688 F#4 1 0;824.0499877929688 C#4 1 0;824.0499877929688 C#6 2 0;824.0499877929688 G#5 2 0;825.0499877929688 D#4 1 0;826.0499877929688 F4 1 0;826.0499877929688 A#5 2 0;826.0499877929688 D#6 2 0;827.0499877929688 F#3 1 0;828.0499877929688 F3 1 0;829.0499877929688 F4 1 0;830.0499877929688 C4 1 0;828.0499877929688 F6 4 0;828.0499877929688 G#5 4 0;831.0499877929688 G#4 1 0;832.0499877929688 F4 1 0;833.0499877929688 C4 1 0;832.0499877929688 D#6 2 0;832.0499877929688 A#5 2 0;834.0499877929688 G#5 1 0;834.0499877929688 C#6 1 0;834.0499877929688 F3 1 0;835.0499877929688 A#5 1 0;835.0499877929688 F4 1 0;835.0499877929688 D#6 1 0;836.0499877929688 G#3 1 0;836.0499877929688 D#5 2 0;836.0499877929688 C6 2 0;837.0499877929688 F4 1 0;838.0499877929688 A#3 1 0;838.0499877929688 F5 2 0;839.0499877929688 G#4 1 0;838.0499877929688 G#5 2 0;840.0499877929688 A#3 1 0;841.0499877929688 A#4 1 0;842.0499877929688 D#4 1 0;843.0499877929688 F4 1 0;844.0499877929688 C#4 1 0;845.0499877929688 G#3 1 0;846.0499877929688 A#3 1 0;847.0499877929688 A#4 1 0;848.0499877929688 D#4 1 0;849.0499877929688 F4 1 0;850.0499877929688 C#4 1 0;851.0499877929688 G#3 1 0;852.0499877929688 A#3 1 0;840.0499877929688 F5 15 0;840.0499877929688 A#5 15 0;855.0499877929688 A#3 1 0;858.0499877929688 A#3 1 0;860.0499877929688 A#3 1 0;862.0499877929688 A#3 1 0'
Find a piece of music on onlinesequencer.net, click edit,
then select all notes with CTRL+A and copy them with CTRL+C
Paste string as shown above after removing ";:" from
the end and "Online Sequencer:120233:" from the start
from machine import Pin
#One buzzer on pin 0
mySong = music(song, pins=[Pin(20)])
#Four buzzers
#mySong = music(song, pins=[Pin(0),Pin(1),Pin(2),Pin(3)])
while True:
print(mySong.tick())
sleep(0.04)
实际效果如下:
f164c7d482e079201b5b8139a5d6a437
