2329|2
64
关于HP hw6515的GPS [复制链接]
我的程序是采用单独线程轮询串口获取数据的方式。
刚开始可以正常获取$GPGGA $GPGSV $GPRMC等GPS数据。
后来莫名其妙的就获取不到了。得到的全是$PGLOR,RID,PPC,BTL.....
很晕。网上搜了,说不是设备原因,是程序的原因。
望高手帮忙解答
UINT PortReadThread(LPVOID lpvoid) {            DWORD dwCommModemStatus;             // Specify a set of events to be monitored for the port.     SetCommMask (m_hPort, EV_RXCHAR | EV_CTS | EV_DSR | EV_RLSD | EV_RING);         //=============================         int ReadFalge=0,ReadCount=0;             while (m_hPort != INVALID_HANDLE_VALUE)         {                 // Wait for an event to occur for the port.                 WaitCommEvent (m_hPort, &dwCommModemStatus, 0);                                 // Re-specify the set of events to be monitored for the port.                 SetCommMask (m_hPort, EV_RXCHAR | EV_CTS | EV_DSR | EV_RING);                                 if (dwCommModemStatus & EV_RXCHAR)                 {                         // Loop for waiting for the data.                         int                K;                         BYTE        bText[MAXLENGTH];                                                 K                = 0;                                                 for(;;)                         {                                 DWORD        nLength;                                 COMSTAT ComStat;                                 DWORD        dwErrorFlags;                                 BYTE        bBuffer[MAXLENGTH];        ClearCommError(m_hPort,&dwErrorFlags,&ComStat);        nLength        = 1;        //每次只读一个字节                                 ReadFile(m_hPort,bBuffer,nLength,&nLength,NULL);        if(bBuffer[0] == '\n')                                 {                                                bText[K]        = 0;        if ((bText[0] == '$') &        (bText[1] == 'G') &        (bText[2] == 'P') &                                                 (bText[3] == 'G') &        (bText[4] == 'G') &        (bText[5] == 'A') )                                         {                                                 WriteGGAToFile(bText);                                         }                                         else if ((bText[0] == '$') & (bText[1] == 'G') & (bText[2] == 'P') &                                                 (bText[3] == 'G') &        (bText[4] == 'S') &        (bText[5] == 'V') )                                         {                                                 WriteGSVToFile(bText);                                         }                                         else if ((bText[0] == '$') & (bText[1] == 'G') & (bText[2] == 'P') &                                                 (bText[3] == 'R') &        (bText[4] == 'M') &        (bText[5] == 'C') )                                         {                                                 WriteRMCToFile(bText);                                         }                                         K                        = 0;                                 }                                 else if(bBuffer[0] == '$')                                 {                                         K                        = 0;                                         bText[K]        = bBuffer[0];                                         K++;                                 }                                 else                                 {                                         bText[K]        = bBuffer[0];                                         K++;                                 }                                 Sleep(1);                         }                 }                 // Retrieve modem control-register values.s                 // GetCommModemStatus (m_hPort, &dwCommModemStatus);         }                 return true; }   详情 回复 发表于 2008-9-16 08:51
怎么没人回复啊!
                        int                K;
                        K                = 0;
                        for(;;)
                                DWORD        nLength;
                                COMSTAT ComStat;
                                DWORD        dwErrorFlags;
                                        bText[K]        = 0;
                                        K                        = 0;
                                        K                        = 0;
                                        K++;
                                else
                                        K++;
                                Sleep(1);
        return true;
