3299|4
65
用c#怎样获取PDA的电池地电量(所占的比例)? [复制链接]
原来C#也是一样一样的呀。 public   class   SYSTEM_POWER_STATUS_EX2 {         //   Fields         public   byte   ACLineStatus;         public   byte   BackupBatteryFlag;         public   uint   BackupBatteryFullLifeTime;         public   byte   BackupBatteryLifePercent;         public   uint   BackupBatteryLifeTime;         public   uint   BackupBatteryVoltage;         public   uint   BatteryAverageCurrent;         public   uint   BatteryAverageInterval;         public   byte   BatteryChemistry;         public   uint   BatteryCurrent;         public   byte   BatteryFlag;         public   uint   BatteryFullLifeTime;         public   byte   BatteryLifePercent;         public   uint   BatteryLifeTime;         public   uint   BatterymAHourConsumed;         public   uint   BatteryTemperature;         public   uint   BatteryVoltage;         public   byte   Reserved1;         public   byte   Reserved2;         public   byte   Reserved3;         //   Methods         public   SYSTEM_POWER_STATUS_EX2()       {         } }   [DllImport( "coredll ")] private   static   extern   uint   GetSystemPowerStatusEx2(SYSTEM_POWER_STATUS_EX2   lpSystemPowerStatus,   uint   dwLen,   bool   fUpdate);        SYSTEM_POWER_STATUS_EX2   status2   =   new   SYSTEM_POWER_STATUS_EX2(); 复制代码  详情 回复 发表于 2008-7-3 09:23
65
DWORD   GetSystemPowerStatusEx2(
  PSYSTEM_POWER_STATUS_EX2   pSystemPowerStatusEx2,
  DWORD   dwLen,
  BOOL   fUpdate
  PSYSTEM_POWER_STATUS_EX2   pwrstat=0;
  if   (!GetSystemPowerStatusEx2(pwrstat,sizeof(pwrstat),FALSE))
    MessageBox(hWnd,_T("Couldn't   get   power   state"),
        _T("Error"),MB_OK);
  else
  //   extract   the   power   status   information   that   you   need
63
sorry,没注意是C#的。
81
还有谁知道??帮忙啊
原来C#也是一样一样的呀。
  1. public   class   SYSTEM_POWER_STATUS_EX2
  2. {
  3.         //   Fields
  4.         public   byte   ACLineStatus;
  5.         public   byte   BackupBatteryFlag;
  6.         public   uint   BackupBatteryFullLifeTime;
  7.         public   byte   BackupBatteryLifePercent;
  8.         public   uint   BackupBatteryLifeTime;
  9.         public   uint   BackupBatteryVoltage;
  10.         public   uint   BatteryAverageCurrent;
  11.         public   uint   BatteryAverageInterval;
  12.         public   byte   BatteryChemistry;
  13.         public   uint   BatteryCurrent;
  14.         public   byte   BatteryFlag;
  15.         public   uint   BatteryFullLifeTime;
  16.         public   byte   BatteryLifePercent;
  17.         public   uint   BatteryLifeTime;
  18.         public   uint   BatterymAHourConsumed;
  19.         public   uint   BatteryTemperature;
  20.         public   uint   BatteryVoltage;
  21.         public   byte   Reserved1;
  22.         public   byte   Reserved2;
  23.         public   byte   Reserved3;
  24.         //   Methods
  25.         public   SYSTEM_POWER_STATUS_EX2()
  26.       {
  27.         }
  28. }
  29.   [DllImport( "coredll ")]
  30. private   static   extern   uint   GetSystemPowerStatusEx2(SYSTEM_POWER_STATUS_EX2   lpSystemPowerStatus,   uint   dwLen,   bool   fUpdate);
  31.   SYSTEM_POWER_STATUS_EX2   status2   =   new   SYSTEM_POWER_STATUS_EX2();
复制代码
