7765|8
急切求助!为什么我定义了m_osWrite还报错undeclared identifier? [复制链接]
我是在EVC中写的MFC程序,已经定义了m_osWrite,但还是报错,不知为什么,如下:
OVERLAPPED m_osWrite;
memset(&m_osWrite,0,sizeof(OVERLAPPED));//这一行报错:error C2065: 'm_osWrite' : undeclared identifier
    m_osWrite.hEvent=CreateEvent(NULL,TRUE,FALSE,NULL);//error C2228: left of '.hEvent' must have class/struct/union type
所有代码如下:
void CLq28Dlg::OnSend()
        // TODO: Add your control notification handler code here
     if( !m_comm.GetPortOpen() )
       m_comm.SetPortOpen(TRUE);//打开串口
       UpdateData(TRUE);
                FILE  *fp1 ;
   if((fp1 = fopen("\\sdmmc\\a.txt","rt"))==NULL)
                printf("ERROR on open a.txt!\n");
                exit(1);
   char  ch='m';
        while(ch!=EOF) {
        CLq28Dlg  dlg;
        if(dlg.DoModal()==IDC_SLEEP||dlg.DoModal()==IDC_STOP)  break;
    if(dlg.DoModal()==IDC_STOP && dlg.DoModal()!=IDC_CONPLAY)
        CString s;
        while(ch!=','&&ch!='!'&&ch!='。'&&ch!='!')
            s+=ch;
                ch=fgetc(fp1);
            int i,j,Count;
            CString m_Data;
        CString   recive;
        m_Data=s;
            Count=m_Data.GetLength();
            CByteArray m_Array;
        j=(Count >> 8)&&0xFF;
            m_Array.RemoveAll();
            m_Array.SetSize(Count);
        m_Array.Add(0xFE);
                m_Array.Add(0x01);
                m_Array.Add(j);
                m_Array.Add(Count-j);
                char  lqq[100];
                for(i=0;i            lqq=m_Data;
                   m_Array.Add(m_Data);
                   recive+=m_Data;
           //m_comm.SetOutput(COleVariant(m_Array));
                DWORD dwBytesWrite= Count;
       COMSTAT ComStat;
       DWORD dwErrorFlags;
        BOOL bWriteStat;
        ClearCommError(hCom,&dwErrorFlags,&ComStat);
        bWriteStat=WriteFile(hCom,lqq,
        dwBytesWrite,& dwBytesWrite,&m_osWrite);
       if(!bWriteStat)
          if(GetLastError()==ERROR_IO_PENDING)
            WaitForSingleObject(m_osWrite.hEvent,1000);
           }//if(!bWriteStat)
           CString  stem1="";
    SetDlgItemText(IDC_EDIT1,stem1);
        CString  stem2=recive;
        SetDlgItemText(IDC_EDIT1,stem2);
         for(i=0;i            lqq=0;
        }//while(ch!=EOF)
同样问题  详情 回复 发表于 2009-9-3 10:19
59
OVERLAPPED:Windows CE: Unsupported.
看帮助吧,里面有说明。
91
没查到啊?
93
我在evc4里添加前两行,没有任何错误提示。
63
那为什么我的总报错呢?程序开始为声明为,请问zzhll有什么区别吗?
#include
#include "stdafx.h"
#include "lq28.h"
#include "lq28Dlg.h"
#define ONESTOPBIT          0
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
75
这种语法错误也会发生,LZ好好学习学习C++基础了。
这必然报错。因为你的m_osWrite定义是包含在if语句中的,而memset()却步包含在if语句当中,也就是说if如果不成立,这个m_osWrite变量当然不会被定义,直接执行memset()函数。
你给
{OVERLAPPED m_osWrite;
加上括号。这样就OK了。。楼主以后要注意了。。。。
79
同意5楼的,
lz的代码太乱了。
86
的确是if的原因,谢谢!这种错误实在是令人汗颜……
59
同样问题
