3148|4
63
CE6编译出错,请指教!急,在线等 [复制链接]
Done Doing PreMakeImage Custom Build Actions
makeimg: Check for C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\PreMakeImg.bat to run.
makeimg: Found localization settings.
makeimg: LOCALE: 0804  LOCALE3: (null)  TargetDir: 0804  CodePage=936  LocaleId: 804  PrimaryLandId: 4 SubLangId: 2
makeimg: Building international version for locale 0804
makeimg: Check C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\tokens\0804\ for tokens.
makeimg: Read string substitutions from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intltrns\0409\
makeimg: Read string substitutions from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intltrns\0409\common.str
makeimg: Read string substitutions from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intltrns\0409\ie.str
makeimg: Read string substitutions from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intltrns\0409\shell.str
makeimg: Read string substitutions from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intltrns\0409\wceshellfe.str
makeimg: Read string substitutions from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intltrns\0409\wceappsfe.str
makeimg: Read string substitutions from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intltrns\0409\datasync.str
makeimg: Read string substitutions from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intltrns\0409\cebase.str
makeimg: Copy files from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intlfile\0409\ to release directory.
makeimg: Read string substitutions from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intltrns\0804\
makeimg: Read string substitutions from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intltrns\0804\common.str
makeimg: Read string substitutions from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intltrns\0804\ie.str
makeimg: Read string substitutions from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intltrns\0804\shell.str
makeimg: Read string substitutions from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intltrns\0804\wceshellfe.str
makeimg: Read string substitutions from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intltrns\0804\wceappsfe.str
makeimg: Read string substitutions from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intltrns\0804\datasync.str
makeimg: Read string substitutions from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intltrns\0804\cebase.str
makeimg: Copy files from C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\intlfile\0804\ to release directory.
makeimg: Creating C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\nlscfg.out because C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\country.cfg doesn't exist or contains a locale different from 0804.
makeimg: run command: fmerge -nls C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\nlscfg.out C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\postproc\nlscfg.inf
fmerge for Windows CE (Release) (Built on Apr  5 2006 11:32:16)
makeimg: run command: fmerge -txt C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\postproc\nlssrc.txt C:\WINCE600\public\common\oak\files\locale.txt C:\WINCE600\OSDesigns\YG3501B\YG3501B\RelDir\NANO_ARMV4I_Release\nlssrc.txt
makeimg: FATAL ERROR: Command returned non-zero exit code 1 (dec).
BLDDEMO: YG3501B build complete.
YG3501B - 2 error(s), 771 warning(s)
========== 生成: 0 成功或最新,1 失败,0 被跳过 ==========
为什么每次都是这里出错,不知道什么原因.build.err,说是看makeimg.out .哪位给个提示,谢谢!
都是些很奇怪的问题,搞不明白。。哎。!  详情 回复 发表于 2009-10-8 09:48
79
把工程文件删了。重新建一个。
重建也不行.真是郁闷...
好像现在好了.我再MAKEIMG 一次试下..
61
都是些很奇怪的问题,搞不明白。。哎。!
福禄克有奖直播:高精度测温赋能电子制造 报名中!
直播时间:2025年2月28日(周五)上午10:00
直播主题:高精度测温赋能电子制造
小伙伴们儿快来报名直播吧~好礼等你拿!
