2221|5
441
【 HC32F4A0开发板】定时器0测试 [复制链接]
这篇来学习下定时器0的配置和应用,通过定时器0来学习,实现1MS定时中断。
一、定时器0时钟
定时器0有两个通道A和B,这里使用定时器0的通道B,时钟选择PCLK1。
PCLK1在主时钟的位置
二、程序部分
2.1、主时钟部分
PCLK1经2分频后得到120MHz频率的时钟。
__WEAKDEF void BSP_CLK_Init(void)
    stc_clock_xtal_init_t stcXtalInit;
    stc_clock_pll_init_t stcPLLHInit;
    /* PCLK0, HCLK  Max 240MHz */
    /* PCLK1, PCLK4 Max 120MHz */
    /* PCLK2, PCLK3 Max 60MHz  */
    /* EX BUS Max 120MHz */
    CLK_SetClockDiv(CLK_BUS_CLK_ALL, \
                    (CLK_PCLK0_DIV1 | CLK_PCLK1_DIV2 | CLK_PCLK2_DIV4 | \
                     CLK_PCLK3_DIV4 | CLK_PCLK4_DIV2 | CLK_EXCLK_DIV2 | \
                     CLK_HCLK_DIV1));
    GPIO_AnalogCmd(BSP_XTAL_PORT, BSP_XTAL_IN_PIN | BSP_XTAL_OUT_PIN, ENABLE);
    (void)CLK_XtalStructInit(&stcXtalInit);
    /* Config Xtal and enable Xtal */
    stcXtalInit.u8Mode   = CLK_XTAL_MD_OSC;
    stcXtalInit.u8Drv    = CLK_XTAL_DRV_ULOW;
    stcXtalInit.u8State  = CLK_XTAL_ON;
    stcXtalInit.u8StableTime = CLK_XTAL_STB_2MS;
    (void)CLK_XtalInit(&stcXtalInit);
    (void)CLK_PLLStructInit(&stcPLLHInit);
    /* VCO = (8/1)*120 = 960MHz*/
    stcPLLHInit.u8PLLState = CLK_PLL_ON;
    stcPLLHInit.PLLCFGR = 0UL;
    stcPLLHInit.PLLCFGR_f.PLLM = 1UL - 1UL;
    stcPLLHInit.PLLCFGR_f.PLLN = 120UL - 1UL;
    stcPLLHInit.PLLCFGR_f.PLLP = 4UL - 1UL;
    stcPLLHInit.PLLCFGR_f.PLLQ = 4UL - 1UL;
    stcPLLHInit.PLLCFGR_f.PLLR = 4UL - 1UL;
    stcPLLHInit.PLLCFGR_f.PLLSRC = CLK_PLL_SRC_XTAL;
    (void)CLK_PLLInit(&stcPLLHInit);
    /* Highspeed SRAM set to 0 Read/Write wait cycle */
    SRAM_SetWaitCycle(SRAM_SRAMH, SRAM_WAIT_CYCLE0, SRAM_WAIT_CYCLE0);
    /* SRAM1_2_3_4_backup set to 1 Read/Write wait cycle */
    SRAM_SetWaitCycle((SRAM_SRAM123 | SRAM_SRAM4 | SRAM_SRAMB), SRAM_WAIT_CYCLE1, SRAM_WAIT_CYCLE1);
    /* 0-wait @ 40MHz */
    (void)EFM_SetWaitCycle(EFM_WAIT_CYCLE5);
    /* 4 cycles for 200 ~ 250MHz */
    GPIO_SetReadWaitCycle(GPIO_RD_WAIT4);
    CLK_SetSysClockSrc(CLK_SYSCLK_SRC_PLL);
2.2、timer0.c
#include "main.h"
#include "led.h"
/* TMR0 unit and channel definition */
#define TMR0_UNIT                       (CM_TMR0_1)
#define TMR0_CH                         (TMR0_CH_B)
#define TMR0_CH_INT                     (TMR0_INT_CMP_B)
#define TMR0_CH_FLAG                    (TMR0_FLAG_CMP_B)
#define TMR0_INT_SRC                    (INT_SRC_TMR0_1_CMP_B)
#define TMR0_IRQn                       (INT006_IRQn)
void init_timer0(void)
    stc_tmr0_init_t stcTmr0Init;
    stc_irq_signin_config_t stcIrqSignConfig;
    (void)TMR0_StructInit(&stcTmr0Init);
    stcTmr0Init.u32ClockSrc     = TMR0_CLK_SRC_INTERN_CLK;
    stcTmr0Init.u32ClockDiv     = TMR0_CLK_DIV8;
    stcTmr0Init.u32Func         = TMR0_FUNC_CMP;
    stcTmr0Init.u16CompareValue = 15000;
    (void)TMR0_Init(TMR0_UNIT, TMR0_CH, &stcTmr0Init);
    TMR0_HWStopCondCmd(TMR0_UNIT, TMR0_CH, ENABLE);
    TMR0_IntCmd(TMR0_UNIT, TMR0_CH_INT, ENABLE);
    stcIrqSignConfig.enIntSrc    = TMR0_INT_SRC;
    stcIrqSignConfig.enIRQn      = TMR0_IRQn;
    stcIrqSignConfig.pfnCallback = &TMR0_CompareIrqCallback;
    (void)INTC_IrqSignIn(&stcIrqSignConfig);
    NVIC_ClearPendingIRQ(stcIrqSignConfig.enIRQn);
    NVIC_SetPriority(stcIrqSignConfig.enIRQn, DDL_IRQ_PRIO_DEFAULT);
    NVIC_EnableIRQ(stcIrqSignConfig.enIRQn);
    TMR0_Start(TMR0_UNIT, TMR0_CH);
定时器输入时钟的选择
a> 时钟选择内部的PCLK1时钟
b> 分频选择分频 ,输入时钟的内部时钟=120/8=15MHz
c> 输出比较功能
d> 实现1ms的比较值=15000,15个时钟是1us,15*1000实现1MS;
2.3、定时器0中断
 uint32_t t0_cnt=0;
static void TMR0_CompareIrqCallback(void)
		t0_cnt++;
		if(t0_cnt>99)
			t0_cnt=0;
			BSP_LED_Toggle(LED_BLUE);
		led1_tog();
    TMR0_ClearStatus(TMR0_UNIT, TMR0_CH_FLAG);
三、输出波形
测量led1(PE2)的波形:
挺好,国产满意   详情 回复 发表于 2023-2-24 16:14
6534
通道A和通道B有什么区别吗?为什么要这么分
从资料上看,通道A和通道B有着相同的结构,可以单独配置,不通的中断地址。和之前使用的其他芯片定时器不太一样。  详情 回复 发表于 2023-2-24 05:56
在爱好的道路上不断前进,在生活的迷雾中播撒光引
441
秦天qintian0303 发表于 2023-2-23 21:35 通道A和通道B有什么区别吗?为什么要这么分
7044
例子配置非常详细,这示波器非常有特色呀。什么牌子的。
老掉牙的TEK示波器  详情 回复 发表于 2023-2-24 13:59
441
lugl4313820 发表于 2023-2-24 07:50 例子配置非常详细,这示波器非常有特色呀。什么牌子的。
老掉牙的TEK示波器
7671
挺好,国产满意
默认摸鱼,再摸鱼。2022、9、28
