【 HC32F4A0开发板】TFT-LCD驱动显示
HC32F4A0开发板通过EXMC总线的SMC方式来驱动TFT-LCD显示屏。
EXMC总线框图
显示屏硬件接口电路图
显示屏的接口和ATK-MD0430模块的接口是兼容的,手上正好有这款屏幕,下面用这个屏幕测试
程序部分
总线初始化部分:
static int32_t LCD_SMC_Init(void)
__IO uint32_t u32To = 0UL;
int32_t i32Ret = LL_OK;
stc_exmc_smc_init_t stcSmcInit;
stc_exmc_smc_chip_config_t stcChipConfig;
stc_exmc_smc_timing_config_t stcTimingConfig;
en_flag_status_t enChipStatus = RESET;
en_flag_status_t enTimingStatus = RESET;
LCD_Port_Init();
/* Enable SMC clock */
FCG_Fcg3PeriphClockCmd(FCG3_PERIPH_SMC, ENABLE);
/* Enable SMC. */
EXMC_SMC_Cmd(ENABLE);
EXMC_SMC_ExitLowPower();
while (EXMC_SMC_READY != EXMC_SMC_GetStatus()) {
if (u32To > SMC_MAX_TIMEOUT) {
i32Ret = LL_ERR;
break;
u32To++;
if (LL_OK == i32Ret) {
/* Configure SMC width && CS &chip & timing. */
(void)EXMC_SMC_StructInit(&stcSmcInit);
stcSmcInit.stcChipConfig.u32AddrMatch = BSP_NT35510_MATCH_ADDR;
stcSmcInit.stcChipConfig.u32AddrMask = BSP_NT35510_MASK_ADDR;
stcSmcInit.stcChipConfig.u32MemoryWidth = EXMC_SMC_MEMORY_WIDTH_16BIT;
stcSmcInit.stcChipConfig.u32BAA = EXMC_SMC_BAA_PORT_DISABLE;
stcSmcInit.stcChipConfig.u32ADV = EXMC_SMC_ADV_PORT_DISABLE;
stcSmcInit.stcChipConfig.u32BLS = EXMC_SMC_BLS_SYNC_CS;
stcSmcInit.stcChipConfig.u32ReadBurstLen = EXMC_SMC_READ_BURST_4BEAT;
stcSmcInit.stcChipConfig.u32WriteBurstLen = EXMC_SMC_WRITE_BURST_4BEAT;
stcSmcInit.stcChipConfig.u32ReadMode = EXMC_SMC_READ_SYNC;
stcSmcInit.stcChipConfig.u32WriteMode = EXMC_SMC_WRITE_SYNC;
stcSmcInit.stcTimingConfig.u8RC = 8U;
stcSmcInit.stcTimingConfig.u8WC = 4U;
stcSmcInit.stcTimingConfig.u8CEOE = 1U;
stcSmcInit.stcTimingConfig.u8WP = 2U;
stcSmcInit.stcTimingConfig.u8PC = 4U;
stcSmcInit.stcTimingConfig.u8TR = 1U;
(void)EXMC_SMC_Init(BSP_NT35510_CHIP, &stcSmcInit);
/* Set command: updateregs */
EXMC_SMC_SetCommand(BSP_NT35510_CHIP, EXMC_SMC_CMD_UPDATEREGS, 0UL, 0UL);
/* Check timing status */
u32To = 0UL;
while ((enChipStatus != SET) || (enTimingStatus != SET)) {
(void)EXMC_SMC_GetTimingConfig(BSP_NT35510_CHIP, &stcTimingConfig);
if (0 == memcmp(&stcTimingConfig, &stcSmcInit.stcTimingConfig, sizeof(stcTimingConfig))) {
enTimingStatus = SET;
(void)EXMC_SMC_GetChipConfig(BSP_NT35510_CHIP, &stcChipConfig);
if (0 == memcmp(&stcChipConfig, &stcSmcInit.stcChipConfig, sizeof(stcChipConfig))) {
enChipStatus = SET;
i32Ret = LL_ERR;
break;
u32To++;
return i32Ret;
lcd初始化部分
static void LCD_NT35310_Config(stc_lcd_controller_t *pstcLCD)
NT35510_WriteReg(pstcLCD, 0xED);
NT35510_WriteData(pstcLCD, 0x01);
NT35510_WriteData(pstcLCD, 0xFE);
NT35510_WriteReg(pstcLCD, 0xEE);
NT35510_WriteData(pstcLCD, 0xDE);
NT35510_WriteData(pstcLCD, 0x21);
NT35510_WriteReg(pstcLCD, 0xF1);
NT35510_WriteReg(pstcLCD, 0xDF);
NT35510_WriteData(pstcLCD, 0x10);
//VCOMvoltage//
NT35510_WriteReg(pstcLCD, 0xC4);
NT35510_WriteData(pstcLCD, 0x8F);
NT35510_WriteReg(pstcLCD, 0xC6);
NT35510_WriteData(pstcLCD, 0x00);
NT35510_WriteData(pstcLCD, 0xE2);
NT35510_WriteReg(pstcLCD, 0xBF);
NT35510_WriteData(pstcLCD, 0xAA);
NT35510_WriteReg(pstcLCD, 0xB0);
NT35510_WriteData(pstcLCD, 0x0D);
NT35510_WriteData(pstcLCD, 0x11);
NT35510_WriteData(pstcLCD, 0x19);
NT35510_WriteData(pstcLCD, 0x2D);
NT35510_WriteData(pstcLCD, 0x3D);
NT35510_WriteData(pstcLCD, 0x5D);
NT35510_WriteReg(pstcLCD, 0xB1);
NT35510_WriteData(pstcLCD, 0x80);
NT35510_WriteData(pstcLCD, 0x8B);
NT35510_WriteData(pstcLCD, 0x96);
NT35510_WriteReg(pstcLCD, 0xB2);
NT35510_WriteData(pstcLCD, 0x02);
NT35510_WriteData(pstcLCD, 0x03);
NT35510_WriteReg(pstcLCD, 0xB3);
NT35510_WriteReg(pstcLCD, 0xB4);
NT35510_WriteData(pstcLCD, 0xA1);
NT35510_WriteReg(pstcLCD, 0xB5);
NT35510_WriteData(pstcLCD, 0x04);
NT35510_WriteReg(pstcLCD, 0xB6);
NT35510_WriteReg(pstcLCD, 0xB7);
NT35510_WriteData(pstcLCD, 0x3F);
NT35510_WriteData(pstcLCD, 0x5E);
NT35510_WriteData(pstcLCD, 0x64);
NT35510_WriteData(pstcLCD, 0x8C);
NT35510_WriteData(pstcLCD, 0xAC);
NT35510_WriteData(pstcLCD, 0xDC);
NT35510_WriteData(pstcLCD, 0x70);
NT35510_WriteData(pstcLCD, 0x90);
NT35510_WriteData(pstcLCD, 0xEB);
NT35510_WriteReg(pstcLCD, 0xB8);
NT35510_WriteReg(pstcLCD, 0xBA);
NT35510_WriteData(pstcLCD, 0x24);
NT35510_WriteReg(pstcLCD, 0xC1);
NT35510_WriteData(pstcLCD, 0x20);
NT35510_WriteData(pstcLCD, 0x54);
NT35510_WriteData(pstcLCD, 0xFF);
NT35510_WriteReg(pstcLCD, 0xC2);
NT35510_WriteData(pstcLCD, 0x0A);
NT35510_WriteReg(pstcLCD, 0xC3);
NT35510_WriteData(pstcLCD, 0x3C);
NT35510_WriteData(pstcLCD, 0x3A);
NT35510_WriteData(pstcLCD, 0x39);
NT35510_WriteData(pstcLCD, 0x37);
NT35510_WriteData(pstcLCD, 0x36);
NT35510_WriteData(pstcLCD, 0x32);
NT35510_WriteData(pstcLCD, 0x2F);
NT35510_WriteData(pstcLCD, 0x2C);
NT35510_WriteData(pstcLCD, 0x29);
NT35510_WriteData(pstcLCD, 0x26);
NT35510_WriteData(pstcLCD, 0x23);
NT35510_WriteData(pstcLCD, 0x62);
NT35510_WriteData(pstcLCD, 0x05);
NT35510_WriteData(pstcLCD, 0x84);
NT35510_WriteData(pstcLCD, 0xF0);
NT35510_WriteData(pstcLCD, 0x18);
NT35510_WriteData(pstcLCD, 0xA4);
NT35510_WriteData(pstcLCD, 0x50);
NT35510_WriteData(pstcLCD, 0x0C);
NT35510_WriteData(pstcLCD, 0x17);
NT35510_WriteData(pstcLCD, 0x95);
NT35510_WriteData(pstcLCD, 0xF3);
NT35510_WriteData(pstcLCD, 0xE6);
NT35510_WriteReg(pstcLCD, 0xC5);
NT35510_WriteData(pstcLCD, 0x44);
NT35510_WriteData(pstcLCD, 0x65);
NT35510_WriteData(pstcLCD, 0x76);
NT35510_WriteData(pstcLCD, 0x88);
NT35510_WriteReg(pstcLCD, 0xC7);
NT35510_WriteReg(pstcLCD, 0xC8);
NT35510_WriteReg(pstcLCD, 0xC9);
NT35510_WriteReg(pstcLCD, 0xE0);
NT35510_WriteData(pstcLCD, 0x16);
NT35510_WriteData(pstcLCD, 0x1C);
NT35510_WriteData(pstcLCD, 0x46);
NT35510_WriteData(pstcLCD, 0x52);
NT35510_WriteData(pstcLCD, 0x7A);
NT35510_WriteData(pstcLCD, 0x99);
NT35510_WriteData(pstcLCD, 0xA8);
NT35510_WriteData(pstcLCD, 0xB9);
NT35510_WriteData(pstcLCD, 0xC4);
NT35510_WriteData(pstcLCD, 0xCA);
NT35510_WriteData(pstcLCD, 0xD2);
NT35510_WriteData(pstcLCD, 0xD9);
NT35510_WriteData(pstcLCD, 0xE0);
NT35510_WriteReg(pstcLCD, 0xE1);
NT35510_WriteData(pstcLCD, 0x22);
NT35510_WriteData(pstcLCD, 0x45);
NT35510_WriteData(pstcLCD, 0xD8);
NT35510_WriteReg(pstcLCD, 0xE2);
NT35510_WriteData(pstcLCD, 0x0B);
NT35510_WriteData(pstcLCD, 0x1B);
NT35510_WriteData(pstcLCD, 0x34);
NT35510_WriteData(pstcLCD, 0x4F);
NT35510_WriteData(pstcLCD, 0x61);
NT35510_WriteData(pstcLCD, 0x79);
NT35510_WriteData(pstcLCD, 0x97);
NT35510_WriteData(pstcLCD, 0xA6);
NT35510_WriteData(pstcLCD, 0xB7);
NT35510_WriteData(pstcLCD, 0xC2);
NT35510_WriteData(pstcLCD, 0xC7);
NT35510_WriteData(pstcLCD, 0xD1);
NT35510_WriteData(pstcLCD, 0xD6);
NT35510_WriteData(pstcLCD, 0xDD);
NT35510_WriteReg(pstcLCD, 0xE3);
NT35510_WriteData(pstcLCD, 0xA);
NT35510_WriteData(pstcLCD, 0x33);
NT35510_WriteData(pstcLCD, 0x78);
NT35510_WriteData(pstcLCD, 0xD5);
NT35510_WriteReg(pstcLCD, 0xE4);
NT35510_WriteData(pstcLCD, 0x2A);
NT35510_WriteData(pstcLCD, 0x4B);
NT35510_WriteData(pstcLCD, 0x74);
NT35510_WriteData(pstcLCD, 0x93);
NT35510_WriteData(pstcLCD, 0xA2);
NT35510_WriteData(pstcLCD, 0xB3);
NT35510_WriteData(pstcLCD, 0xBE);
NT35510_WriteData(pstcLCD, 0xCD);
NT35510_WriteData(pstcLCD, 0xD3);
NT35510_WriteReg(pstcLCD, 0xE5);
NT35510_WriteReg(pstcLCD, 0xE6);
NT35510_WriteData(pstcLCD, 0x56);
NT35510_WriteData(pstcLCD, 0x77);
NT35510_WriteData(pstcLCD, 0x66);
NT35510_WriteData(pstcLCD, 0xBB);
NT35510_WriteData(pstcLCD, 0x55);
NT35510_WriteData(pstcLCD, 0x43);
NT35510_WriteReg(pstcLCD, 0xE7);
NT35510_WriteData(pstcLCD, 0x67);
NT35510_WriteData(pstcLCD, 0x87);
NT35510_WriteReg(pstcLCD, 0xE8);
NT35510_WriteReg(pstcLCD, 0xE9);
NT35510_WriteReg(pstcLCD, 0x00);
NT35510_WriteReg(pstcLCD, 0xCF);
NT35510_WriteReg(pstcLCD, 0xF0);
NT35510_WriteReg(pstcLCD, 0xF3);
NT35510_WriteReg(pstcLCD, 0xF9);
NT35510_WriteData(pstcLCD, 0x06);
NT35510_WriteReg(pstcLCD, 0x3A);
NT35510_WriteReg(pstcLCD, 0x11);
LCD_Delay(100);
NT35510_WriteReg(pstcLCD, 0x29);
NT35510_WriteReg(pstcLCD, 0x35);
NT35510_WriteReg(pstcLCD, 0x51);
NT35510_WriteReg(pstcLCD, 0x53);
NT35510_WriteReg(pstcLCD, 0x55);
NT35510_WriteData(pstcLCD, 0x82);
NT35510_WriteReg(pstcLCD, 0x2c);
主程序
#include "main.h"
#include "lcd.h"
/* LED_G Port/Pin definition */
#define LED_G_PORT (GPIO_PORT_C)
#define LED_G_PIN (GPIO_PIN_09)
/* LED toggle definition */
#define LED_G_TOGGLE() (GPIO_TogglePins(LED_G_PORT, LED_G_PIN))
#define DLY_MS (2000UL)
static void LED_Init(void)
stc_gpio_init_t stcGpioInit;
(void)GPIO_StructInit(&stcGpioInit);
stcGpioInit.u16PinState = PIN_STAT_RST;
stcGpioInit.u16PinDir = PIN_DIR_OUT;
(void)GPIO_Init(LED_G_PORT, LED_G_PIN, &stcGpioInit);
void init_lcd(void)
BSP_LCD_RSTCmd(EIO_PIN_RESET); /* RST# to low */
DDL_DelayMS(50UL);
BSP_LCD_RSTCmd(EIO_PIN_SET); /* RST# to high */
DDL_DelayMS(50UL);
BSP_NT35510_Init();
/* Clear LCD screen */
BSP_NT35510_Clear(LCD_COLOR_BLACK);
BSP_LCD_BKLCmd(EIO_PIN_SET);
/* Set LCD cursor */
BSP_NT35510_SetCursor(0U, 0U);
int32_t main(void)
uint16_t u=0;
uint16_t cord[6]={WHITE, BLUE, BRED, GBLUE, RED, YELLOW};
/* Register write enable for some required peripherals. */
LL_PERIPH_WE(LL_PERIPH_GPIO | LL_PERIPH_FCG | LL_PERIPH_PWC_CLK_RMU | LL_PERIPH_EFM | LL_PERIPH_SRAM);
BSP_CLK_Init();
DDL_PrintfInit(BSP_PRINTF_DEVICE, BSP_PRINTF_BAUDRATE, BSP_PRINTF_Preinit);
BSP_IO_Init();
BSP_LCD_IO_Init();
BSP_GT9XX_Init();
init_lcd();
LL_PERIPH_WP(LL_PERIPH_GPIO | LL_PERIPH_FCG | LL_PERIPH_PWC_CLK_RMU | LL_PERIPH_EFM | LL_PERIPH_SRAM);
POINT_COLOR=RED;
LCD_Clear(WHITE);
for (;;)
LCD_Clear(cord[u]);
LCD_ShowString(20,400,210,24,24,"HC32F4A0 LCD TEST");
LCD_ShowxNum(20,430,u,5,24,0);
DDL_DelayMS(500UL);
u++;
if(u>6)
u=0;
运行视频
20230219120506
