3610|2
61
12864液晶屏检测忙出问题!? [复制链接]
带字库的,控制器是st7920,检测忙总是不成功,DB口接在P0上的
#define  LcdData P0
bit Check_Busy()
    bit busy;
    RS = 0;
    RW = 1;
    E = 1;
      _nop_();
    busy = (bit)(LcdData&0x80);
    E = 0;
    return busy;
检查结果总是忙。
我用的HS1286410A; [code] struct PIN {         unsigned char bit0 :1;         unsigned char bit1 :1;         unsigned char bit2 :1;         unsigned char bit3 :1;         unsigned char other:4; }; #define STA0 ((struct PIN *)&SIR_io.p2.in.byte[2])->bit0        //input indicate bit #define STA1 ((struct PIN *)&SIR_io.p2.in.byte[2])->bit1 #define OUTDATA SIR_io.p2.out.byte[2] //output data #define INDATA SIR_io.p2.in.byte[2]   //input data #define DIR           SIR_io.p2.dir.byte[2]  //direction #define WR ((struct PIN *)&SIR_io.p2.out.byte[3])->bit3           //write #define CS ((struct PIN *)&SIR_io.p2.out.byte[3])->bit2           //cs #define CD ((struct PIN *)&SIR_io.p2.out.byte[3])->bit1           //command #define RD ((struct PIN *)&SIR_io.p2.out.byte[3])->bit0           //read #define BL ((struct PIN *)&SIR_io.p1.out.byte[0])->bit0                //black light #define RC ((struct PIN *)&SIR_io.p1.out.byte[0])->bit1                //receive message #define LCD_T_BASE 0X0000              // 文本区内存首地址 #define LCD_A_BASE 0X1000              // 属性区内存首地址 #define WD 0x16                                   // 定义屏幕文本宽度为21字节 void Pr0() {         DIR = 0x00;         RD = 1;         WR = 1;         CD = 1;         OUTDATA = OUTDATA|0xFF;         RD = 0;         asm("nop");         DIR = 0xFF;         RD = 1;         asm("nop"); } void OutCommand(uint8 accept) {         DIR = 0x00;         WR = 0;         asm("nop");         OUTDATA = accept;         WR = 1;         asm("nop");         DIR = 0xFF;         CD = 1;         asm("nop"); } void CheckSTA1() { Ptemp01:         Pr0();         if (STA0 == 0)        {                 goto Ptemp01;                 }         if (STA1 == 0)        {                 goto Ptemp01;         } }   详情 回复 发表于 2009-5-19 14:30
忘了我用的是啥片子了
也是,老在忙
后来干脆我就不检测了,延时一定时间,直接写缓冲
反正也用着,呵呵
我用的HS1286410A;
[code]
struct PIN
void Pr0()
        DIR = 0x00;
        RD = 1;
        WR = 1;
        CD = 1;
        RD = 0;
        asm("nop");
        DIR = 0xFF;
        RD = 1;
        asm("nop");
        DIR = 0x00;
        WR = 0;
        asm("nop");
        OUTDATA = accept;
        WR = 1;
        asm("nop");
        DIR = 0xFF;
        CD = 1;
        asm("nop");
void CheckSTA1()
Ptemp01:
        Pr0();
        if (STA0 == 0)        {
                goto Ptemp01;
        if (STA1 == 0)        {
                goto Ptemp01;
