2518|2
75
Windows消息:请教当插入网线的时候发送的系统消息是什么,请具体阐述 [复制链接]
请帮忙阐述一下系统动作,在线等,马上结贴
检查网络连接的方法 C# code using System; using System.Runtime.InteropServices; //Creating the extern function... [DllImport("wininet.dll")] private extern static bool InternetGetConnectedState(out int Description, int ReservedValue); //Creating a function that uses the API function... public static bool IsConnectedToInternet() { int Desc; return InternetGetConnectedState(out Desc, 0); } //Use function if (IsConnectedToInternet()) { MessageBox.Show("Netwok Connection Up"); } else { MessageBox.Show("Sorry! Network Connection down."); } [Flags]         public enum InternetState         {             INTERNET_CONNECTION_MODEM = 0x01,             INTERNET_CONNECTION_LAN = 0x02,             INTERNET_CONNECTION_PROXY = 0x04,             INTERNET_CONNECTION_MODEM_BUSY = 0x08,             INTERNET_RAS_INSTALLED = 0x10,             INTERNET_CONNECTION_OFFLINE = 0x20,             INTERNET_CONNECTION_CONFIGURED = 0x40         }         [DllImport("wininet.dll", CharSet = CharSet.Auto)]         public static extern bool InternetGetConnectedStateEx(out InternetState lpdwFlags, StringBuilder lpszConnectionName, int dwNameLen, int dwReserved);         static void Main(string[] args)         {             InternetState connectionState;             StringBuilder connectionName = new StringBuilder(256);             bool isOnline = InternetGetConnectedStateEx(out connectionState, connectionName, 256, 0);             MessageBox.Show(isOnline.ToString());             MessageBox.Show(connectionState.ToString());             MessageBox.Show(connectionName.ToString());   详情 回复 发表于 2009-8-4 12:58
好奇 帮顶
77
检查网络连接的方法
C# code
using System;
int Desc;
//Use function
else
[Flags]
