上一篇我们进行了串口的收发测试,在串口接收中断时原样返回数据,测试了收发回环。这显然不能直接给应用层使用,实际项目中需要给应用层提供好用的串口收发接口。这里通过环形缓冲区的方式实现串口的接收,应用层只需要调用读接口从缓冲区不断查询接收数据即可。
#include
#include "stm32u575xx.h"
#include "stm32u5xx_ll_gpio.h"
#include "stm32u5xx_ll_bus.h"
#include "stm32u5xx_ll_lpuart.h"
uint8_t uart_ring_buffer[128];
typedef struct
uint32_t datalen_u32;
uint32_t maxlen_u32;
uint32_t in_u32;
uint32_t out_u32;
uint8_t* buffer_pu8;
}ring_buffer_t;
ring_buffer_t s_ring_buffer_t=
.datalen_u32 = 0,
.maxlen_u32 = sizeof(uart_ring_buffer),
.in_u32 = 0,
.out_u32 = 0,
.buffer_pu8 = uart_ring_buffer,
void uart_rx_handler(const uint8_t *buffer, uint32_t length)
for(uint32_t i=0;i
if(s_ring_buffer_t.datalen_u32 < s_ring_buffer_t.maxlen_u32)
s_ring_buffer_t.buffer_pu8[s_ring_buffer_t.in_u32] = buffer;
s_ring_buffer_t.datalen_u32++;
s_ring_buffer_t.in_u32++;
s_ring_buffer_t.in_u32 %= s_ring_buffer_t.maxlen_u32;
else
/* full */
break;
int uart_read(uint8_t *buff, uint32_t len)
uint32_t readlen = 0;
uint32_t mask;
if(s_ring_buffer_t.datalen_u32 == 0)
return 0;
__disable_irq();
for(uint32_t i=0;i
if(s_ring_buffer_t.datalen_u32 > 0)
buff = s_ring_buffer_t.buffer_pu8[s_ring_buffer_t.out_u32];
s_ring_buffer_t.datalen_u32--;
s_ring_buffer_t.out_u32++;
s_ring_buffer_t.out_u32 %= s_ring_buffer_t.maxlen_u32;
readlen++;
else
break;
__enable_irq();
return readlen;
int uart_write(uint8_t *buff, uint32_t len)
for(uint32_t i=0; i
LL_LPUART_TransmitData8(LPUART1,buff);
while(LL_LPUART_IsActiveFlag_TXE_TXFNF(LPUART1)!=1);
return 0;
void LPUART1_IRQHandler(void)
uint8_t ch;
if(LL_LPUART_IsActiveFlag_RXNE_RXFNE(LPUART1) == SET)
ch = LL_LPUART_ReceiveData8(LPUART1);
uart_rx_handler(&ch, 1);
if(LL_LPUART_IsActiveFlag_TXE_TXFNF(LPUART1))
void uart_init(void)
LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_GPIOG);
/* PG7 TX */
LL_GPIO_InitTypeDef GPIO_InitStruct;
//LL_GPIO_StructInit(&GPIO_InitStruct);
GPIO_InitStruct.Pin = LL_GPIO_PIN_7;
GPIO_InitStruct.Mode = LL_GPIO_MODE_ALTERNATE;
GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_VERY_HIGH;
GPIO_InitStruct.OutputType = LL_GPIO_OUTPUT_PUSHPULL;
GPIO_InitStruct.Pull = LL_GPIO_PULL_UP;
GPIO_InitStruct.Alternate = LL_GPIO_AF_8;
LL_GPIO_Init(GPIOG, &GPIO_InitStruct);
/* PG8 RX */
GPIO_InitStruct.Pin = LL_GPIO_PIN_8;
LL_APB3_GRP1_EnableClock(LL_APB3_GRP1_PERIPH_LPUART1);
LL_LPUART_InitTypeDef LPUART_InitStruct;
LPUART_InitStruct.BaudRate = 115200;
LPUART_InitStruct.DataWidth = LL_LPUART_DATAWIDTH_8B;
LPUART_InitStruct.HardwareFlowControl = LL_LPUART_HWCONTROL_NONE;
LPUART_InitStruct.Parity = LL_LPUART_PARITY_NONE;
LPUART_InitStruct.PrescalerValue = LL_LPUART_PRESCALER_DIV1;
LPUART_InitStruct.StopBits = LL_LPUART_STOPBITS_1;
LPUART_InitStruct.TransferDirection = LL_LPUART_DIRECTION_TX_RX;
LL_LPUART_Init(LPUART1, &LPUART_InitStruct);
LL_LPUART_EnableIT_RXNE_RXFNE(LPUART1);
//LL_LPUART_EnableIT_TXE_TXFNF(LPUART1);
__NVIC_EnableIRQ(LPUART1_IRQn);
__NVIC_SetPriority(LPUART1_IRQn, 3);
LL_LPUART_Enable(LPUART1);
#include "uart.h"
void SysTick_Handler(void)
static volatile uint32_t num = 0;
if(num++ >= 1000)
LL_GPIO_TogglePin(GPIOB, 1u<<7);
LL_GPIO_TogglePin(GPIOG, 1u<<2);
LL_GPIO_TogglePin(GPIOC, 1u<<7);
num=0;
HAL_IncTick();
void delay(uint32_t t)
volatile uint32_t timeout = t;
while(t--);
int main(void)
HAL_Init();
LL_AHB3_GRP1_EnableClock(LL_AHB3_GRP1_PERIPH_PWR);
HAL_PWREx_EnableVddIO2();
HAL_PWREx_ConfigSupply(PWR_SMPS_SUPPLY);
#if 1
HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1);
RCC_OscInitTypeDef pRCC_OscInitStruct;
pRCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
pRCC_OscInitStruct.HSIState = RCC_HSI_ON;
pRCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
pRCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
pRCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
pRCC_OscInitStruct.PLL.PLLM = 1;
pRCC_OscInitStruct.PLL.PLLMBOOST = RCC_PLLMBOOST_DIV1;
pRCC_OscInitStruct.PLL.PLLN = 20;
pRCC_OscInitStruct.PLL.PLLP = 1;
pRCC_OscInitStruct.PLL.PLLQ = 1;
pRCC_OscInitStruct.PLL.PLLR = 2;
pRCC_OscInitStruct.PLL.PLLRGE = RCC_PLLVCIRANGE_0;
pRCC_OscInitStruct.PLL.PLLFRACN = 0; /* */
HAL_RCC_OscConfig(&pRCC_OscInitStruct);
RCC_ClkInitTypeDef pRCC_ClkInitStruct;
pRCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK;
pRCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
pRCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
pRCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
pRCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
pRCC_ClkInitStruct.APB3CLKDivider = RCC_HCLK_DIV2;
HAL_RCC_ClockConfig(&pRCC_ClkInitStruct, FLASH_LATENCY_4);
#endif
LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_GPIOB);
LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_GPIOC);
GPIO_InitStruct.Mode = LL_GPIO_MODE_OUTPUT;
GPIO_InitStruct.Alternate = LL_GPIO_AF_0;
LL_GPIO_Init(GPIOB, &GPIO_InitStruct);
GPIO_InitStruct.Pin = LL_GPIO_PIN_2;
GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_HIGH;
LL_GPIO_Init(GPIOC, &GPIO_InitStruct);
uart_init();
uint8_t buffer[128];
while(1)
int len=0;
if((len = uart_read(buffer, sizeof(buffer))) >0)
uart_write(buffer, len);
