6047|9
67
完全提供TCC8900/TCC8901/TCC8902开发设计图纸和PCB图,WINCE包 [复制链接]
产品应用领域:
* PVR PVR PMP
* Portable Navigation Portable Navigation
* Car AV / AVN Car AV / AVN
* Jukebox
* H.264相关监控产品,如3G视频监控等
H.264应用领域机会难得
有诚意者请速联系:QQ:570615487 MSN/email:kingpolar@gmail.com
1.完全提供相关芯片技术手册,最新开发板硬件图纸(orcad与pdf格式)和PCB图
2.完全提供WINCE6.0 BSP开发包以及相关编译步骤和下载烧写方法手册
3.如需要可以协助调试BSP,直到板子跑起WINCE
4.也可以提供LINUX android 相关开发包
估计要花几K的MONEY 不过这东东我要的话,找原厂三下两个拿得到的   详情 回复 发表于 2009-12-1 16:30
TCC8900/TCC8901/TCC8902规格:
  ARM 1176JZF-S ARM 1176JZF-S
CPU 500 MHz @ 1.2V, 600MHz (TBD) CPU 500 MHz @ 1.2V, 600MHz (TBD)
65nm CMOS Process 65nm CMOS Process
400 Pin FBGA, 17x17mm2, 0.8 Ball Pitch 400 Pin FBGA, 17x17mm2, 0.8 Ball Pitch
Video Processor (up to 1920x1080p) Video Processor (up to 1920x1080p)
Video Encoding (up to 1280x720p) Video Encoding (up to 1280x720p)
Video Enhancement Video Enhancement
2D/3D Graphic Processor 2D/3D Graphic Processor
Video Input Video Input
Camera Interface Camera Interface
Display & Video Output Display & Video Output
Audio Interfaces Audio Interfaces
Serial/Parallel Streaming Interface Serial/Parallel Streaming Interface
mDDR/DDR/DDR2Memory Support mDDR/DDR/DDR2Memory Support
Storage I/F Support Storage I/F Support
Peripherals & Other Features Peripherals & Other Features
特性如下:
  The TCC8900 is a system LSI for digital multimedia applications based on ARM1176JZF-S, an ARM's proprietary RISC CPU core. It is designed for high-end multimedia entertainment devices such as car AVN, portable multimedia player and home entertainment. The TCC8900 supports decoding and encoding various types of video and audio standards with software and dedicated hardware codecs including JPEG / MPEG1 / MPEG2 / MPEG4 / H.264 / VC-1 / RV up to Full HD (1080p) and MP3 / WMA / EAAC+ / AC3, etc. In addition, TCC8900 offers a hardwired 3D graphic accelerator to enrich next generation GUI and other graphical applications. For easy and cost effective solutions for GPS navigation devices, it also provides GPS correlator. The TCC8900 is a system LSI for digital multimedia applications based on ARM1176JZF-S, an ARM's proprietary RISC CPU core. It is designed for high-end multimedia entertainment devices such as car AVN, portable multimedia player and home entertainment. The TCC8900 supports decoding and encoding various types of video and audio standards with software and dedicated hardware codecs including JPEG / MPEG1 / MPEG2 / MPEG4 / H.264 / VC-1 / RV up to Full HD (1080p) and MP3 / WMA / EAAC+ / AC3, etc. In addition, TCC8900 offers a hardwired 3D graphic accelerator to enrich next generation GUI and other graphical applications. For easy and cost effective solutions for GPS navigation devices, it also provides GPS correlator.
产品应用领域:
* PVR PVR PMP
* Jukebox
H.264应用领域机会难得
我不信有这么好。
66
可以随时联系我的,全套,一条龙服务,谢谢支持
78
夸张了吧
65
引用 3 楼 gooogleman 的回复:
我不信有这么好。
看法相同
59
我信,先发给我。
都有的,it is true!
有诚意者请联系我,QQ:570615487 MSN/email:kingpolar@gmail.com
估计要花几K的MONEY
