4283|1
504
【贝能高性价比ATSAMD51评估板】基准性能测试之四:并发计算基准测试livermore_loops [复制链接]
前言
  利弗莫尔循环 [1]  (英语:Livermore loops,也称为利弗莫尔Fortran核或LFK)是计算机并发计算的基准测试。
过程
添加代码
获取代码
http://www.roylongbottom.org.uk/classic_benchmarks.tar.gz
解压classic_benchmarks.tar.gz将\classic_benchmarks\classic_benchmarks\source_code\livermore_loops文件夹复制到自己的工程。
添加代码
将\classic_benchmarks\source_code\livermore_loops文件夹复制到工程目录,并添加工程中
移植接口
lloops.c中
23行注释掉//#include "cpuidh.h"
327行 main(int argc, char *argv[])
改为
int main(int argc, char *argv[])
注释掉378行
#if 0
    outfile = fopen("LLloops.txt","a+");
    if (outfile == NULL)
        printf (" Cannot open results file LLloops.txt\n\n");
        printf(" Press Enter\n\n");
        gg = getchar();
        exit (0);
    getDetails();
    for (i=1; i<10; i++)
        printf("%s\n", configdata);
    printf("\n");
    fprintf (outfile, " #####################################################\n\n");
        fprintf(outfile, "%s \n", configdata);
    fprintf (outfile, "\n");
    local_time();
    fprintf (outfile, " Livermore Loops Benchmark %s via C/C++ %s\n", options, timeday);
    if (reliability)
        fprintf (outfile, " Reliability test %3.0f seconds each loop x 24 x 3\n\n", runSecs);
    fflush(outfile);
#endif
start_time();改为
uint32_t s_stime_u32 = SYSTICK_GetTickCounter();
end_time();改为
uint32_t s_etime_u32 = SYSTICK_GetTickCounter();
double secs = (s_etime_u32-s_stime_u32)/1000.0;
添加
#include <stdint.h>
 #include "definitions.h"
#include <string.h>
注释掉480行
             ///local_time();
             ///fprintf (outfile, " Part %ld of 3 start at %s\n", section + 1, timeday);
             ///fflush(outfile);
编译空间不够
需要修改减小loops大小
101改为LOOPS1 替换
#define LOOPS1 11
100改为LOOPS4 替换
#define LOOPS4 10
1001改为LOOPS2 替换
#define LOOPS2 101
1000改为LOOPS3 替换
#define LOOPS3 100
2042行
     //for ( k=0 ; k<19977 + 34132 ; k++)改为
   for ( k=0 ; k<LOOPS2 ; k++)
测试
main.c中
申明 int livermore_loops_main (int argc, char *argv[]);
int main ( void )
    /* Initialize all modules */
    SYS_Initialize ( NULL );
  SYSTICK_TimerStart();
    PORT_REGS->GROUP[1].PORT_PINCFG[24] = 0x1U;
    PORT_REGS->GROUP[1].PORT_PINCFG[25] = 0x1U;
    PORT_REGS->GROUP[1].PORT_PMUX[12] = 0x33U;
  livermore_loops_main(0,0);
    while ( true )
        /* Maintain state machines of all polled MPLAB Harmony modules. */
        SYS_Tasks ( );
    /* Execution should not come here during normal operation */
    return ( EXIT_FAILURE );
结果如下
这里值不对待确认
http://www.roylongbottom.org.uk/livermore%20loops%20results.htm
对比得分比AMD 80386高些
总结
本文进行了并发运算性能测试,也和其他芯片对比,可以横向参考下芯片的性能。
附录代码
 *   gcc lloops.c cpuidc64.o cpuida64.o -m64 -lrt -lc -lm -o lloops     *
 * L. L. N. L.  " C "  K E R N E L S:  M F L O P S  P C  V E R S I O N  *
 *  #define Version not used
 *  Different compilers can produce different floating point numeric
 *  results, probably due to compiling instructions in a different
 *  sequence. As the program checks these, they may need to be changed.
 *  The log file indicates non-standard results and these values can
 *  be copied and pasted into this program. See // Values near the end
 *  in checkOut(). Some values are for optimised compiling and non-
 *  optimised results might be different.
 *  Change #define options for print of optimisation level and
#include <stdio.h>
#include <math.h>
#include <stdlib.h>
#include <time.h>
#include <stdint.h>
#include <string.h>
#define LOOPS1 11
#define LOOPS4 10
#define LOOPS2 101
#define LOOPS3 100
   struct Arrays
     double U[LOOPS2];
     double V[LOOPS2];
     double W[LOOPS2];
     double X[LOOPS2];
     double Y[LOOPS2];
     double Z[LOOPS2];
     double G[LOOPS2];
     double Du1[LOOPS1];
     double Du2[LOOPS1];
     double Du3[LOOPS1];
     double Grd[LOOPS2];
     double Dex[LOOPS2];
     double Xi[LOOPS2];
     double Ex[LOOPS2];
     double Ex1[LOOPS2];
     double Dex1[LOOPS2];
     double Vx[LOOPS2];
     double Xx[LOOPS2];
     double Rx[LOOPS2];
     double Rh[2048];
     double Vsp[LOOPS1];
     double Vstp[LOOPS1];
     double Vxne[LOOPS1];
     double Vxnd[LOOPS1];
     double Ve3[LOOPS1];
     double Vlr[LOOPS1];
     double Vlin[LOOPS1];
     double B5[LOOPS1];
     double Plan[300];
     double D[300];
     double Sa[LOOPS1];
     double Sb[LOOPS1];
     double P[512][4];
     double Px[LOOPS1][25];
     double Cx[LOOPS1][25];
     double Vy[25][LOOPS1];
     double Vh[7][LOOPS1];
     double Vf[7][LOOPS1];
     double Vg[7][LOOPS1];
     double Vs[7][LOOPS1];
     double Za[7][LOOPS1];
     double Zp[7][LOOPS1];
     double Zq[7][LOOPS1];
     double Zr[7][LOOPS1];
     double Zm[7][LOOPS1];
     double Zb[7][LOOPS1];
     double Zu[7][LOOPS1];
     double Zv[7][LOOPS1];
     double Zz[7][LOOPS1];
     double B[64][64];
     double C[64][64];
     double H[64][64];
     double U1[2][LOOPS1][5];
     double U2[2][LOOPS1][5];
     double U3[2][LOOPS1][5];
     double Xtra[40];
     long   E[96];
     long   F[96];
     long   Ix[LOOPS2];
     long   Ir[LOOPS2];
     long   Zone[301];
     double X0[LOOPS2];
     double W0[LOOPS2];
     double Px0[LOOPS1][25];
     double P0[512][4];
     double H0[64][64];
     double Rh0[2048];
     double Vxne0[LOOPS1];
     double Zr0[7][LOOPS1];
     double Zu0[7][LOOPS1];
     double Zv0[7][LOOPS1];
     double Zz0[7][LOOPS1];
     double Za0[LOOPS1][25];
     double Stb50;
     double Xx0;
  }as1;
   #define u        as1.U
   #define v        as1.V
   #define w        as1.W
   #define x        as1.X
   #define y        as1.Y
   #define z        as1.Z
   #define g        as1.G
   #define du1      as1.Du1
   #define du2      as1.Du2
   #define du3      as1.Du3
   #define grd      as1.Grd
   #define dex      as1.Dex
   #define xi       as1.Xi
   #define ex       as1.Ex
   #define ex1      as1.Ex1
   #define dex1     as1.Dex1
   #define vx       as1.Vx
   #define xx       as1.Xx
   #define rx       as1.Rx
   #define rh       as1.Rh
   #define vsp      as1.Vsp
   #define vstp     as1.Vstp
   #define vxne     as1.Vxne
   #define vxnd     as1.Vxnd
   #define ve3      as1.Ve3
   #define vlr      as1.Vlr
   #define vlin     as1.Vlin
   #define b5       as1.B5
   #define plan     as1.Plan
   #define d        as1.D
   #define sa       as1.Sa
   #define sb       as1.Sb
   #define p        as1.P
   #define px       as1.Px
   #define cx       as1.Cx
   #define vy       as1.Vy
   #define vh       as1.Vh
   #define vf       as1.Vf
   #define vg       as1.Vg
   #define vs       as1.Vs
   #define za       as1.Za
   #define zb       as1.Zb
   #define zp       as1.Zp
   #define zq       as1.Zq
   #define zr       as1.Zr
   #define zm       as1.Zm
   #define zz       as1.Zz
   #define zu       as1.Zu
   #define zv       as1.Zv
   #define b        as1.B
   #define c        as1.C
   #define h        as1.H
   #define u1       as1.U1
   #define u2       as1.U2
   #define u3       as1.U3
   #define xtra     as1.Xtra
   #define a11      as1.Xtra[1]
   #define a12      as1.Xtra[2]
   #define a13      as1.Xtra[3]
   #define a21      as1.Xtra[4]
   #define a22      as1.Xtra[5]
   #define a23      as1.Xtra[6]
   #define a31      as1.Xtra[7]
   #define a32      as1.Xtra[8]
   #define a33      as1.Xtra[9]
   #define c0       as1.Xtra[12]
   #define dk       as1.Xtra[15]
   #define dm22     as1.Xtra[16]
   #define dm23     as1.Xtra[17]
   #define dm24     as1.Xtra[18]
   #define dm25     as1.Xtra[19]
   #define dm26     as1.Xtra[20]
   #define dm27     as1.Xtra[21]
   #define dm28     as1.Xtra[22]
   #define expmax   as1.Xtra[26]
   #define flx      as1.Xtra[27]
   #define q        as1.Xtra[28]
   #define r        as1.Xtra[30]
   #define s        as1.Xtra[32]
   #define sig      as1.Xtra[34]
   #define stb5     as1.Xtra[35]
   #define t        as1.Xtra[36]
   #define xnm      as1.Xtra[39]
   #define e        as1.E
   #define f        as1.F
   #define ix       as1.Ix
   #define ir       as1.Ir
   #define zone     as1.Zone
   #define x0       as1.X0
   #define w0       as1.W0
   #define px0      as1.Px0
   #define p0       as1.P0
   #define h0       as1.H0
   #define rh0      as1.Rh0
   #define vxne0    as1.Vxne0
   #define zr0      as1.Zr0
   #define zu0      as1.Zu0
   #define zv0      as1.Zv0
   #define zz0      as1.Zz0
   #define za0      as1.Za0
   #define stb50    as1.Stb50
   #define xx0      as1.Xx0
   struct Parameters
       long   Inner_loops;
       long   Outer_loops;
       long   Loop_mult;
       double Flops_per_loop;
       double Sumcheck[3][25];
       long   Accuracy[3][25];
       double LoopTime[3][25];
       double LoopSpeed[3][25];
       double LoopFlos[3][25];
       long   Xflops[25];
       long   Xloops[3][25];
       long   Nspan[3][25];
       double TimeStart;
       double TimeEnd;
       double Loopohead;
       long   Count;
       long   Count2;
       long   Pass;
       long   Extra_loops[3][25];
       long   K2;
       long   K3;
       long   M16;
       long   J5;
       long   Section;
       long   N16;
       double Mastersum;
       long   M24;
   }as2;
   #define n            as2.Inner_loops
   #define loop         as2.Outer_loops
   #define mult         as2.Loop_mult
   #define nflops       as2.Flops_per_loop
   #define Checksum     as2.Sumcheck
   #define accuracy     as2.Accuracy
   #define RunTime      as2.LoopTime
   #define Mflops       as2.LoopSpeed
   #define FPops        as2.LoopFlos
   #define nspan        as2.Nspan
   #define xflops       as2.Xflops
   #define xloops       as2.Xloops
   #define StartTime    as2.TimeStart
   #define EndTime      as2.TimeEnd
   #define overhead_l   as2.Loopohead
   #define count        as2.Count
   #define count2       as2.Count2
   #define pass         as2.Pass
   #define extra_loops  as2.Extra_loops
   #define k2           as2.K2
   #define k3           as2.K3
   #define m16          as2.M16
   #define j5           as2.J5
   #define section      as2.Section
   #define n16          as2.N16
   #define MasterSum    as2.Mastersum
   #define m24          as2.M24
 // VERSION
 #ifdef CNNT
    #define options   "Non-optimised"
    #define opt "0"
 #else
//    #define options   "Optimised"
    #define options   "Opt 3 64 Bit"
    #define opt "3"
 #endif
typedef int   Boolean;
#define TRUE  1
#define FALSE 0
double      runSecs = 1;
Boolean     reliability = FALSE;
Boolean     runRel;
Boolean     nsRes = FALSE;
double      sumscomp[3][25];
int         compareFail = 0;
int         failCount;
FILE        *outfile;
   void init(long which);
        /* Initialises arrays and variables  */
   long endloop(long which);
        /* Controls outer loops and stores results */
   long parameters(long which);
        /* Gets loop parameters and variables, starts timer */
   void kernels();
        /* The 24 kernels */
   void check(long which);
        /* Calculates checksum accuracy */
   void iqranf();
        /* Random number generator for Kernel 14 */
   void checkOut(int which);
       // Check results
static uint32_t s_stime_u32;
static uint32_t s_etime_u32;
int livermore_loops_main(int argc, char *argv[])
    double pass_time, least, lmult, now = 1.0, wt;
    long   i, k, loop_passes;
    long   mul[3] = {1, 2, 8};
    double weight[3] = {1.0, 2.0, 1.0};
    long   Endit, which;
    double maximum[4];
    double minimum[4];
    double average[4];
    double harmonic[4];
    double geometric[4];
    long   xspan[4];
    char   general[9][80] = {" "};
    int    param;
    int    gg;
    int    nopause = 1;
     if (argc > 1)
       switch (argv[1][0])
             case 'N':
                nopause = 0;
                break;
             case 'n':
                nopause = 0;
                break;
    if (argc > 2)
       sscanf(argv[2], "%d", &param);
       if (param > 0)
           runSecs = param;
           reliability = TRUE;
           if (runSecs > 60) runSecs = 60;
    printf ("L.L.N.L. 'C' KERNELS: MFLOPS   P.C.  VERSION 4.0\n\n");
    printf("Optimisation  %s\n\n",options);
 *                  Open results file LLloops.txt                       *
#if 0
        gg = getchar();
        exit (0);
    getDetails();
    printf("\n");
    local_time();
    if (reliability)
    fflush(outfile);
#endif
 *       Calculate overhead of executing endloop procedure              *
    printf ("Calculating outer loop overhead\n");
    pass = -20;
    extra_loops[0][0] = 1;
    loop = LOOPS3;
    which = 0;
    section = 0;
    runRel = FALSE;
    do
        //start_time();
        count = 0;
        count2 = 0;
        pass = pass + 1;
        do
            endloop (0);
        while (count < loop);
        //end_time();
        overhead_l = secs;
        printf ("%10ld times %6.2f seconds\n", loop, overhead_l);
        if (overhead_l > 0.2)
            pass = 0;
        if (pass < 0)
            if (overhead_l < (double)runSecs / 50)
                loop = loop * 10;
            else
                loop = loop * 2;
    while (pass < 0);
    overhead_l = overhead_l / (double)(loop);
    printf ("Overhead for each loop %12.4e seconds\n\n", overhead_l);
 *      Execute the kernels three times at different Do Spans           *
    for ( section=0 ; section<3 ; section++ )
        loop_passes = 200 * mul[section];
        pass = -20;
        mult = 2 * mul[section];
        runRel = FALSE;
        for ( i=1; i<25; i++)
            extra_loops[section] = 1;
        if (reliability)
             ///local_time();
             ///fflush(outfile);
 *   Calculate extra loops for running time of runSecs seconds per kernel     *
             printf ("Calibrating part %ld of 3\n\n", section + 1);
        do
        /* Run a number of times with increased number of loops
         or until the time for each loop is at least 0.001 seconds */
            pass = pass + 1;
            mult = mult * 2;
            count2 = 0;
                 RunTime[section] = 0.0;
            //start_time();
            kernels();
            //end_time();
            pass_time = secs;
            least = 1.0;
                if (RunTime[section] < 0.001)
                    least = 0.0;
                    RunTime[section] = 0.0008;
                    extra_loops[section] = extra_loops[section] * 2;
            printf ("Loop count %10ld %5.2f seconds\n", mult, pass_time);
            if (least > 0.0 )
                pass = 0;
            else
                if (pass_time < (double)runSecs / 5)
                    mult = mult * 2;
        while (pass < 0);
        lmult = (double)(mult) / (double)(loop_passes);
          /* Calculate extra loops to produce a run time of about runSecs seconds
           for each kernel. For each of the extra loops the parameters
           are re-initialised. The time for initialising parameters is
           not included in the loop time. */
            extra_loops[section] = (long)(runSecs / RunTime[section]
                                * (double)extra_loops[section] * lmult) +1;
        mult = loop_passes;
        printf ("\nLoops  200 x %2ld x Passes\n\n", mul[section]);
        printf ("Kernel       Floating Pt ops\n");
        printf ("No  Passes E No    Total      Secs.  MFLOPS Span     "
                                        "Checksums          OK\n");
        printf ("------------ -- ------------- ----- ------- ---- "
                                         "---------------------- --\n");
        pass = 1;
        count2 = 0;
        if (reliability) runRel = TRUE;
 *                      Execute the kernels                             *
        kernels();
        maximum[section] = 0.0;
        minimum[section] = Mflops[section][1];
        average[section] = 0.0;
        harmonic[section] = 0.0;
        geometric[section] = 0.0;
        xspan[section] = 0;
 *                        Calculate averages etc.                       *
            for ( k=1 ; k<=24 ; k++ )
           average[section] = average[section] + Mflops[section][k];
           harmonic[section] = harmonic[section] + 1 / Mflops[section][k];
           geometric[section] = geometric[section] + log(Mflops[section][k]);
           xspan[section] = xspan[section] + nspan[section][k];
           if (Mflops[section][k] < minimum[section])
               minimum[section] = Mflops[section][k];
           if (Mflops[section][k] > maximum[section])
               maximum[section] = Mflops[section][k];
        average[section] = average[section] / 24.0;
        harmonic[section] = 24.0 / harmonic[section];
        geometric[section] = exp(geometric[section] / 24.0);
        xspan[section] = xspan[section] / 24;
        if (pass > 0)
 *        Display averages etc. except during calibration               *
           printf ("\n");
           printf ("                     Maximum   Rate%8.2f \n",
                                                  maximum[section]);
           printf ("                     Average   Rate%8.2f \n",
                                                  average[section]);
           printf ("                     Geometric Mean%8.2f \n",
                                                  geometric[section]);
           printf ("                     Harmonic  Mean%8.2f \n",
                                                  harmonic[section]);
           printf ("                     Minimum   Rate%8.2f \n\n",
                                                  minimum[section]);
           printf ("                     Do Span   %4ld\n\n",
                                                  xspan[section]);
 *    End of executing the kernels three times at different Do Spans    *
    maximum[3] = 0.0;
    minimum[3] = Mflops[0][1];
    average[3] = 0.0;
    harmonic[3] = 0.0;
    geometric[3] = 0.0;
    xspan[3] = 0;
    wt = 0.0;
 *     Calculate weighted averages for all Do Spans and display         *
           average[3] = average[3] + weight[section]
                                     * Mflops[section][k];
           harmonic[3] = harmonic[3] + weight[section]
           geometric[3] = geometric[3] + weight[section]
                                     * log(Mflops[section][k]);
           xspan[3] = xspan[3] + (long)weight[section]
                                     * nspan[section][k];
           if (Mflops[section][k] < minimum[3])
               minimum[3] = Mflops[section][k];
           if (Mflops[section][k] > maximum[3])
               maximum[3] = Mflops[section][k];
        wt = wt + weight[section];
    average[3] = average[3] / (24.0 * wt);
    harmonic[3] = 24.0 * wt / harmonic[3];
    geometric[3] = exp(geometric[3] / (24.0 * wt));
    xspan[3] = (long)((double)xspan[3] / (24.0 * wt));
    printf ("                Overall\n\n");
    printf ("                Part 1 weight 1\n");
    printf ("                Part 2 weight 2\n");
    printf ("                Part 3 weight 1\n\n");
    printf ("                     Maximum   Rate%8.2f \n", maximum[3]);
    printf ("                     Average   Rate%8.2f \n", average[3]);
    printf ("                     Geometric Mean%8.2f \n", geometric[3]);
    printf ("                     Harmonic  Mean%8.2f \n", harmonic[3]);
    printf ("                     Minimum   Rate%8.2f \n\n", minimum[3]);
    printf ("                     Do Span   %4ld\n\n", xspan[3]);
    if (reliability)
        if (!compareFail)
            if (nsRes)
               fprintf(outfile, "\n Numeric results were consistent with first\n\n");
            else
               fprintf(outfile, " Numeric results were as expected\n\n");
        else
            printf("\n ERRORS have occurred - see log file\n");
 *              Add results to output file LLloops.txt                  *
    fprintf (outfile, " MFLOPS for 24 loops\n");
    for ( which=1; which<13 ; which++ )
       if (Mflops[0][which] < 10000)
          fprintf (outfile, "%7.1f", Mflops[0][which]);
       else
          fprintf (outfile, "%7.0f", Mflops[0][which]);
    for ( which=13; which<25 ; which++ )
       else
    fprintf (outfile, "\n\n");
    fprintf (outfile, " Overall Ratings\n");
    fprintf (outfile, " Maximum Average Geomean Harmean Minimum\n");
    fprintf (outfile, "%8.1f%8.1f%8.1f%8.1f%8.1f\n\n",
               maximum[3], average[3], geometric[3], harmonic[3], minimum[3]);
    if (!reliability)
        checkOut(which);
    if (nopause)
        gg = getchar();
    return 0;
 *                          The Kernels                                 *
void kernels()
   long   lw;
   long   ipnt, ipntp, ii;
   double temp;
   long   nl1, nl2;
   long   kx, ky;
   double ar, br, cr;
   long   i, j, k, m;
   long   ip, i1, i2, j1, j2, j4, lb;
   long   ng, nz;
   double tmp;
   double scale, xnei, xnc, e3,e6;
   long   ink, jn, kn, kb5i;
   double di, dn;
   double qa;
   for ( k=0 ; k<25; k++)
        Checksum[section][k] = 0.0;
     *   Kernel 1 -- hydro fragment
    parameters (1);
    do
        for ( k=0 ; k<n ; k++ )
            x[k] = q + y[k]*( r*z[k+10] + t*z[k+11] );
        endloop (1);
     *   Kernel 2 -- ICCG excerpt (Incomplete Cholesky Conjugate Gradient)
    parameters (2);
    do
        ii = n;
        ipntp = 0;
        do
            ipnt = ipntp;
            ipntp += ii;
            ii /= 2;
            i = ipntp;
            for ( k=ipnt+1 ; k<ipntp ; k=k+2 )
                i++;
                x = x[k] - v[k]*x[k-1] - v[k+1]*x[k+1];
         } while ( ii>0 );
         endloop (2);
     *   Kernel 3 -- inner product
    parameters (3);
    do
        q = 0.0;
            q += z[k]*x[k];
        endloop (3);
     *   Kernel 4 -- banded linear equations
    parameters (4);
    m = ( LOOPS2-7 )/2;
    do
        for ( k=6 ; k<LOOPS2 ; k=k+m )
            lw = k - 6;
            temp = x[k-1];
            for ( j=4 ; j<n ; j=j+5 )
                temp -= x[lw]*y[j];
                lw++;
            x[k-1] = y[4]*temp;
         endloop (4);
     *   Kernel 5 -- tri-diagonal elimination, below diagonal
    parameters (5);
    do
        for ( i=1 ; i<n ; i++ )
            x = z*( y - x[i-1] );
         endloop (5);
     *   Kernel 6 -- general linear recurrence equations
    parameters (6);
    do
            w = 0.01;
            for ( k=0 ; k<i ; k++ )
                w += b[k] * w[(i-k)-1];
        endloop (6);
     *   Kernel 7 -- equation of state fragment
    parameters (7);
    do
            x[k] = u[k] + r*( z[k] + r*y[k] ) +
                   t*( u[k+3] + r*( u[k+2] + r*u[k+1] ) +
                      t*( u[k+6] + q*( u[k+5] + q*u[k+4] ) ) );
         endloop (7);
     *   Kernel 8 -- ADI integration
    nl1 = 0;
    nl2 = 1;
    parameters (8);
    do
        for ( kx=1 ; kx<3 ; kx++ )
           for ( ky=1 ; ky<n ; ky++ )
              du1[ky] = u1[nl1][ky+1][kx] - u1[nl1][ky-1][kx];
              du2[ky] = u2[nl1][ky+1][kx] - u2[nl1][ky-1][kx];
              du3[ky] = u3[nl1][ky+1][kx] - u3[nl1][ky-1][kx];
              u1[nl2][ky][kx]=
                 u1[nl1][ky][kx]+a11*du1[ky]+a12*du2[ky]+a13*du3[ky] + sig*
                  (u1[nl1][ky][kx+1]-2.0*u1[nl1][ky][kx]+u1[nl1][ky][kx-1]);
              u2[nl2][ky][kx]=
                 u2[nl1][ky][kx]+a21*du1[ky]+a22*du2[ky]+a23*du3[ky] + sig*
                  (u2[nl1][ky][kx+1]-2.0*u2[nl1][ky][kx]+u2[nl1][ky][kx-1]);
              u3[nl2][ky][kx]=
                 u3[nl1][ky][kx]+a31*du1[ky]+a32*du2[ky]+a33*du3[ky] + sig*
                  (u3[nl1][ky][kx+1]-2.0*u3[nl1][ky][kx]+u3[nl1][ky][kx-1]);
        endloop (8);
     *   Kernel 9 -- integrate predictors
    parameters (9);
    do
        for ( i=0 ; i<n ; i++ )
            px[0] = dm28*px[12] + dm27*px[11] + dm26*px[10] +
                       dm25*px[ 9] + dm24*px[ 8] + dm23*px[ 7] +
                       dm22*px[ 6] + c0*( px[ 4] + px[ 5])
                                                       + px[ 2];
        endloop (9);
     *   Kernel 10 -- difference predictors
    parameters (10);
    do
            ar        =      cx[ 4];
            br        = ar - px[ 4];
            px[ 4] = ar;
            cr        = br - px[ 5];
            px[ 5] = br;
            ar        = cr - px[ 6];
            px[ 6] = cr;
            br        = ar - px[ 7];
            px[ 7] = ar;
            cr        = br - px[ 8];
            px[ 8] = br;
            ar        = cr - px[ 9];
            px[ 9] = cr;
            br        = ar - px[10];
            px[10] = ar;
            cr        = br - px[11];
            px[11] = br;
            px[13] = cr - px[12];
            px[12] = cr;
        endloop (10);
     *   Kernel 11 -- first sum
    parameters (11);
    do
        x[0] = y[0];
        for ( k=1 ; k<n ; k++ )
            x[k] = x[k-1] + y[k];
        endloop (11);
     *   Kernel 12 -- first difference
    parameters (12);
    do
            x[k] = y[k+1] - y[k];
        endloop (12);
     *   Kernel 13 -- 2-D PIC (Particle In Cell)
   parameters (13);
   do
        for ( ip=0; ip<n; ip++)
            i1 = (long)p[ip][0];
            j1 = (long)p[ip][1];
            i1 &= 64-1;
            j1 &= 64-1;
            p[ip][2] += b[j1][i1];
            p[ip][3] += c[j1][i1];
            p[ip][0] += p[ip][2];
            p[ip][1] += p[ip][3];
            i2 = (long)p[ip][0];
            j2 = (long)p[ip][1];
            i2 = ( i2 & 64-1 ) - 1 ;
            j2 = ( j2 & 64-1 ) - 1 ;
            p[ip][0] += y[i2+32];
            p[ip][1] += z[j2+32];
            i2 += e[i2+32];
            j2 += f[j2+32];
            h[j2][i2] += 1.0;
        endloop (13);
     *   Kernel 14 -- 1-D PIC (Particle In Cell)
    parameters (14);
    do
            vx[k] = 0.0;
            xx[k] = 0.0;
            ix[k] = (long) grd[k];
            xi[k] = (double) ix[k];
            ex1[k] = ex[ ix[k] - 1 ];
            dex1[k] = dex[ ix[k] - 1 ];
            vx[k] = vx[k] + ex1[k] + ( xx[k] - xi[k] )*dex1[k];
            xx[k] = xx[k] + vx[k]  + flx;
            ir[k] = (long)xx[k];
            rx[k] = xx[k] - ir[k];
            ir[k] = ( ir[k] & 2048-1 ) + 1;
            xx[k] = rx[k] + ir[k];
            rh[ ir[k]-1 ] += 1.0 - rx[k];
            rh[ ir[k]   ] += rx[k];
        endloop (14);
     *   Kernel 15 -- Casual Fortran.  Development version
    parameters (15);
    do
        ng = 7;
        nz = n;
        ar = 0.053;
        br = 0.073;
        for ( j=1 ; j<ng ; j++ )
            for ( k=1 ; k<nz ; k++ )
                if ( (j+1) >= ng )
                    vy[j][k] = 0.0;
                    continue;
                if ( vh[j+1][k] > vh[j][k] )
                    t = ar;
                else
                    t = br;
                if ( vf[j][k] < vf[j][k-1] )
                    if ( vh[j][k-1] > vh[j+1][k-1] )
                        r = vh[j][k-1];
                    else
                        r = vh[j+1][k-1];
                    s = vf[j][k-1];
                else
                    if ( vh[j][k] > vh[j+1][k] )
                        r = vh[j][k];
                    else
                        r = vh[j+1][k];
                    s = vf[j][k];
                vy[j][k] = sqrt( vg[j][k]*vg[j][k] + r*r )* t/s;
                if ( (k+1) >= nz )
                    vs[j][k] = 0.0;
                    continue;
                if ( vf[j][k] < vf[j-1][k] )
                    if ( vg[j-1][k] > vg[j-1][k+1] )
                        r = vg[j-1][k];
                    else
                        r = vg[j-1][k+1];
                    s = vf[j-1][k];
                    t = br;
                else
                    if ( vg[j][k] > vg[j][k+1] )
                        r = vg[j][k];
                    else
                        r = vg[j][k+1];
                    s = vf[j][k];
                    t = ar;
                vs[j][k] = sqrt( vh[j][k]*vh[j][k] + r*r )* t / s;
        endloop (15);
     *   Kernel 16 -- Monte Carlo search loop
    parameters (16);
    ii = n / 3;
    lb = ii + ii;
    k3 = k2 = 0;
    do
        i1 = m16 = 1;
        label410:
        j2 = ( n + n )*( m16 - 1 ) + 1;
        for ( k=1 ; k<=n ; k++ )
            k2++;
            j4 = j2 + k + k;
            j5 = zone[j4-1];
            if ( j5 < n )
                if ( j5+lb < n )
                {                             /* 420 */
                    tmp = plan[j5-1] - t;       /* 435 */
                else
                    if ( j5+ii < n )
                    {                           /* 415 */
                        tmp = plan[j5-1] - s;   /* 430 */
                    else
                        tmp = plan[j5-1] - r;   /* 425 */
            else if( j5 == n )
                break;                          /* 475 */
            else
                k3++;                           /* 450 */
                tmp=(d[j5-1]-(d[j5-2]*(t-d[j5-3])*(t-d[j5-3])+(s-d[j5-4])*
                              (s-d[j5-4])+(r-d[j5-5])*(r-d[j5-5])));
            if ( tmp < 0.0 )
                if ( zone[j4-2] < 0 )            /* 445 */
                    continue;                   /* 470 */
                else if ( !zone[j4-2] )
                    break;                      /* 480 */
            else if ( tmp )
                if ( zone[j4-2] > 0 )           /* 440 */
                    continue;                   /* 470 */
                    break;                      /* 480 */
            else break;                       /* 485 */
            m16++;                              /* 455 */
            if ( m16 > zone[0] )
                m16 = 1;                          /* 460 */
            if ( i1-m16 )                         /* 465 */
                goto label410;
            else
                break;
        endloop (16);
     *   Kernel 17 -- implicit, conditional computation
    parameters (17);
    do
        i = n-1;
        j = 0;
        ink = -1;
        scale = 5.0 / 3.0;
        xnm = 1.0 / 3.0;
        e6 = 1.03 / 3.07;
        goto l61;
l60:    e6 = xnm*vsp + vstp;
        vxne = e6;
        xnm = e6;
        ve3 = e6;
        i += ink;
        if ( i==j ) goto l62;
l61:    e3 = xnm*vlr + vlin;
        xnei = vxne;
        vxnd = e6;
        xnc = scale*e3;
        if ( xnm > xnc ) goto l60;
        if ( xnei > xnc ) goto l60;
        ve3 = e3;
        e6 = e3 + e3 - xnm;
        vxne = e3 + e3 - xnei;
        xnm = e6;
        i += ink;
        if ( i != j ) goto l61;
l62:;
        endloop (17);
     *   Kernel 18 - 2-D explicit hydrodynamics fragment
    parameters (18);
    do
       t = 0.0037;
       s = 0.0041;
       kn = 6;
       jn = n;
       for ( k=1 ; k<kn ; k++ )
         for ( j=1 ; j<jn ; j++ )
           za[k][j] = ( zp[k+1][j-1] +zq[k+1][j-1] -zp[k][j-1] -zq[k][j-1] )*
                      ( zr[k][j] +zr[k][j-1] ) / ( zm[k][j-1] +zm[k+1][j-1]);
           zb[k][j] = ( zp[k][j-1] +zq[k][j-1] -zp[k][j] -zq[k][j] ) *
                      ( zr[k][j] +zr[k-1][j] ) / ( zm[k][j] +zm[k][j-1]);
                zu[k][j] += s*( za[k][j]   *( zz[k][j] - zz[k][j+1] ) -
                                za[k][j-1] *( zz[k][j] - zz[k][j-1] ) -
                                zb[k][j]   *( zz[k][j] - zz[k-1][j] ) +
                                zb[k+1][j] *( zz[k][j] - zz[k+1][j] ) );
                zv[k][j] += s*( za[k][j]   *( zr[k][j] - zr[k][j+1] ) -
                                za[k][j-1] *( zr[k][j] - zr[k][j-1] ) -
                                zb[k][j]   *( zr[k][j] - zr[k-1][j] ) +
                                zb[k+1][j] *( zr[k][j] - zr[k+1][j] ) );
                zr[k][j] = zr[k][j] + t*zu[k][j];
                zz[k][j] = zz[k][j] + t*zv[k][j];
        endloop (18);
     *   Kernel 19 -- general linear recurrence equations
    parameters (19);
    kb5i = 0;
    do
            b5[k+kb5i] = sa[k] + stb5*sb[k];
            stb5 = b5[k+kb5i] - stb5;
        for ( i=1 ; i<=n ; i++ )
            k = n - i;
        endloop (19);
     * Kernel 20 - Discrete ordinates transport, conditional recurrence on xx
    parameters (20);
    do
           di = y[k] - g[k] / ( xx[k] + dk );
           dn = 0.2;
           if ( di )
               dn = z[k]/di ;
               if ( t < dn ) dn = t;
               if ( s > dn ) dn = s;
           x[k] = ( ( w[k] + v[k]*dn )* xx[k] + u[k] ) / ( vx[k] + v[k]*dn );
           xx[k+1] = ( x[k] - xx[k] )* dn + xx[k];
        endloop (20);
     *   Kernel 21 -- matrix*matrix product
    parameters (21);
    do
        for ( k=0 ; k<25 ; k++ )
            for ( i=0 ; i<25 ; i++ )
                for ( j=0 ; j<n ; j++ )
                    px[j] += vy[k] * cx[j][k];
        endloop (21);
     *   Kernel 22 -- Planckian distribution
    parameters (22);
    expmax = 20.0;
    u[n-1] = 0.99*expmax*v[n-1];
    do
            y[k] = u[k] / v[k];
            w[k] = x[k] / ( exp( y[k] ) -1.0 );
        endloop (22);
     *   Kernel 23 -- 2-D implicit hydrodynamics fragment
    parameters (23);
    do
        for ( j=1 ; j<6 ; j++ )
                qa = za[j+1][k]*zr[j][k] + za[j-1][k]*zb[j][k] +
                     za[j][k+1]*zu[j][k] + za[j][k-1]*zv[j][k] + zz[j][k];
                za[j][k] += 0.175*( qa - za[j][k] );
        endloop (23);
     *   Kernel 24 -- find location of first minimum in array
    parameters (24);
    x[n/2] = -1.0e+10;
    do
        m24 = 0;
            if ( x[k] < x[m24] ) m24 = k;
        endloop (24);
   return;
 } // kernels
 *        endloop procedure - calculate checksums and MFLOPS            *
  double now = 1.0, useflops;
  long   i, j, k, m;
  double Scale = 1000000.0;
  Boolean  reinit = TRUE;
  Boolean  getend = FALSE;
  count = count + 1;
  if (count >= loop)   /* else return */
 *               End of standard set of loops for one kernel            *
     count2 = count2 + 1;
     if (count2 == extra_loops[section][which]) getend = TRUE;
     if (count2 == extra_loops[section][which] || runRel)
                          /* else re-initialise parameters if required */
         reinit = FALSE;
 *           End of extra loops for runSecs seconds execution time            *
       Checksum[section][which] = 0;
       if (which == 1)
                Checksum[section][1] =  Checksum[section][1] + x[k]
                                          * (double)(k+1);
           useflops = nflops * (double)(n * loop);
       if (which == 2)
          for ( k=0 ; k<n*2 ; k++ )
               Checksum[section][2] = Checksum[section][2] + x[k]
                                         * (double)(k+1);
          useflops = nflops * (double)((n-4) * loop);
       if (which == 3)
           Checksum[section][3] = q;
       if (which == 4)
          for ( k=0 ; k<3 ; k++ )
                Checksum[section][4] = Checksum[section][4] + v[k]
                                          * (double)(k+1);
          useflops = nflops * (double) ((((n-5)/5)+1) * 3 * loop);
       if (which == 5)
              Checksum[section][5] = Checksum[section][5] + x[k]
                                        * (double)(k);
          useflops = nflops * (double)((n-1) * loop);
       if (which == 6)
             Checksum[section][6] = Checksum[section][6] + w[k]
                                       * (double)(k+1);
          useflops = nflops * (double)(n * ((n - 1) / 2) * loop);
       if (which == 7)
              Checksum[section][7] = Checksum[section][7] + x[k]
                                        * (double)(k+1);
       if (which == 8)
          for ( i=0 ; i<2 ; i++ )
              for ( j=0 ; j<LOOPS1 ; j++ )
                  for ( k=0 ; k<5 ; k++ )
                      m = LOOPS1 * 5 * i + 5 * j + k + 1;
                      if (m < 10 * n + 1)
                          Checksum[section][8] = Checksum[section][8]
                                  + u1[j][k] * m
                                  + u2[j][k] * m + u3[j][k] * m;
          useflops = nflops * (double)(2 * (n - 1) * loop);
       if (which == 9)
               for ( j=0 ; j<25 ; j++ )
                   m = 25 * i + j + 1;
                   if (m < 15 * n + 1)
                       Checksum[section][9] = Checksum[section][9]
                                             + px[j] * (double)(m);
       if (which == 10)
               for (j=0 ; j<25 ; j++ )
                   m = 25 * i + j + 1;
                   if (m < 15 * n + 1)
                       Checksum[section][10] = Checksum[section][10]
       if (which == 11)
                Checksum[section][11] = Checksum[section][11]
                                           + x[k] * (double)(k);
           useflops = nflops * (double)((n - 1) * loop);
       if (which == 12)
           for ( k=0 ; k<n-1 ; k++ )
                Checksum[section][12] = Checksum[section][12] + x[k]
                                           * (double)(k+1);
       if (which == 13)
          for ( k=0 ; k<2*n ; k++ )
             for ( j=0 ; j<4 ; j++ )
                  m = 4 * k + j + 1;
                  Checksum[section][13] = Checksum[section][13]
                                             + p[k][j]* (double)(m);
          for ( i=0 ; i<8*n/64 ; i++ )
              for ( j=0 ; j<64 ; j++ )
                  m = 64 * i + j + 1;
                  if (m < 8 * n + 1)
                                                  + h[j] * (double)(m);
       if (which == 14)
                Checksum[section][14] = Checksum[section][14]
                                           + (xx[k] + vx[k]) * (double)(k+1);
          for ( k=0 ; k<67 ; k++ )
              Checksum[section][14] = Checksum[section][14] + rh[k]
                                         * (double)(k+1);
       if (which == 15)
           for ( j=0 ; j<7 ; j++ )
               for ( k=0 ; k<LOOPS1 ; k++ )
                  m = LOOPS1 * j + k + 1;
                  if (m < n * 7 + 1)
                      Checksum[section][15] = Checksum[section][15]
                                       + (vs[j][k] + vy[j][k]) * (double)(m);
           useflops = nflops * (double)((n - 1) * 5 * loop);
       if (which == 16)
           Checksum[section][16] =  (double)(k3 + k2 + j5 + m16);
           useflops = (k2 + k2 + 10 * k3);
       if (which == 17)
           Checksum[section][17] = xnm;
               Checksum[section][17] = Checksum[section][17]
                                       + (vxne[k] + vxnd[k]) * (double)(k+1);
       if (which == 18)
          for ( k=0 ; k<7 ; k++ )
                   m = LOOPS1 * k + j + 1;
                   if (m < 7 * n + 1)
                       Checksum[section][18] = Checksum[section][18]
                                        + (zz[k][j] + zr[k][j]) * (double)(m);
       if (which == 19)
          Checksum[section][19] = stb5;
              Checksum[section][19] = Checksum[section][19] + b5[k]
                                         * (double)(k+1);
       if (which == 20)
            for ( k=1 ; k<n+1 ; k++ )
                Checksum[section][20] = Checksum[section][20] + xx[k]
                                           * (double)(k);
       if (which == 21)
                  m = 25 * k + i + 1;
                  Checksum[section][21] = Checksum[section][21]
                                             + px[k] * (double)(m);
           useflops = nflops * (double)(n * 625 * loop);
       if (which == 22)
                Checksum[section][22] = Checksum[section][22] + w[k]
                                           * (double)(k+1);
       if (which == 23)
                    if (m < 7 * n + 1)
                         Checksum[section][23] = Checksum[section][23]
                                                + za[j][k] * (double)(m);
           useflops = nflops * (double)((n-1) * 5 * loop);
       if (which == 24)
           Checksum[section][24] =  (double)(m24);
       if (runRel) checkOut(which);
       if (getend)
 *                           End of timing                              *
          count2 = 0;
          //end_time();
          RunTime[section][which] = secs;
 *     Deduct overheads from time, calculate MFLOPS, display results    *
          RunTime[section][which] = RunTime[section][which]
                       - (loop * extra_loops[section][which]) * overhead_l;
          FPops[section][which] =  useflops * extra_loops[section][which];
          Mflops[section][which] = FPops[section][which] / Scale
                                            / RunTime[section][which];
          if (pass > 0)
 *      Compare sumcheck with standard result, calculate accuracy       *
             check(which);
             printf ("%2ld %3ld x%4ld %2ld %13.6e %5.2f%8.2f %4ld %22.15e %2ld\n",
                  which, xloops[section][which], extra_loops[section][which],
                  xflops[which], FPops[section][which], RunTime[section][which],
                  Mflops[section][which], nspan[section][which],
                  Checksum[section][which], accuracy[section][which]);
             if (reliability)
                 if (compareFail)
                     printf(" ERRORS have occurred - see log file\n");
     if (reinit || runRel && !getend)
 *                     Re-initialise data if reqired                    *
       count = 0;
       if (which == 2)
              x[k] = x0[k];
       if (which == 4)
          m = (LOOPS2-7)/2;
              x[k] = x0[k];
       if (which == 5)
              x[k] = x0[k];
       if (which == 6)
              w[k] = w0[k];
       if (which == 10)
               for (j=4 ; j<13 ; j++ )
                  px[j] = px0[j];
       if (which == 13)
               for (j=0 ; j<4 ; j++ )
                   p[j] = p0[j];
           for ( i=0 ; i<64 ; i++ )
               for (j=0 ; j<64 ; j++ )
                   h[j] = h0[j];
       if (which == 14)
           for ( i=0; i<n ; i++ )
               rh[ir - 1] = rh0[ir - 1];
               rh[ir ] = rh0[ir ];
       if (which == 17)
               vxne = vxne0;
       if (which == 18)
          for ( i=1 ; i<6 ; i++ )
              for (j=1 ; j<n ; j++ )
                  zr[j] = zr0[j];
                  zu[j] = zu0[j];
                  zv[j] = zv0[j];
                  zz[j] = zz0[j];
       if (which == 21)
                  px[j] = px0[j];
       if (which == 23)
                  za[j] = za0[j];
       k3 = k2 = 0;
       stb5 = stb50;
       xx[0] = xx0;
  return 0;
} // endloop
 *          init procedure - initialises data for all loops             *
    long   i, j, k, l, m, nn;
    double ds, dw, rr, ss;
    double fuzz, fizz, buzz, scaled, one;
     scaled =  (double)(10.0);
     scaled =  (double)(1.0) / scaled;
     fuzz =    (double)(0.0012345);
     buzz =    (double)(1.0) + fuzz;
     fizz =    (double)(1.1) * fuzz;
     one =     (double)(1.0);
         if (k == 19977)
                buzz = (double) (1.0) + fuzz;
                fizz = (double) (1.1) * fuzz;
         buzz = (one - fuzz) * buzz + fuzz;
         fuzz = - fuzz;
         u[k] = (buzz - fizz) * scaled;
     for ( k=1 ; k<40 ; k++)
         fuzz = - fuzz;
         xtra[k] = (buzz - fizz) * scaled;
    ds = 1.0;
    dw = 0.5;
    for ( l=0 ; l<4 ; l++ )
         for ( i=0 ; i<512 ; i++ )
            p[l] = ds;
            ds = ds + dw;
     for ( i=0 ; i<96 ; i++ )
         e = 1;
         f = 1;
         iqranf();
         dw = -100.0;
         for ( i=0; i<LOOPS2 ; i++ )
             dex = dw * dex;
             grd = ix;
         flx = 0.001;
         d[0]= 1.01980486428764;
         nn = n16;
         for ( l=1 ; l<300 ; l++ )
              d[l] = d[l-1] + 1.000e-4 / d[l-1];
         rr = d[nn-1];
         for ( l=1 ; l<=2 ; l++ )
             m = (nn+nn)*(l-1);
             for ( j=1 ; j<=2 ; j++ )
                 for ( k=1 ; k<=nn ; k++ )
                     m = m + 1;
                     ss = (double)(k);
                     plan[m-1] = rr * ((ss + 1.0) / ss);
                     zone[m-1] = k + k;
        k = nn + nn + 1;
        zone[k-1] = nn;
        if (which == 16)
             r = d[n-1];
             s = d[n-2];
             t = d[n-3];
             k3 = k2 = 0;
        expmax = 20.0;
        if (which == 22)
        if (which == 24)
             x[n/2] = -1.0e+10;
 *                 Make copies of data for extra loops                  *
            x0 = x;
            w0 = w;
        for ( i=0 ; i<LOOPS1 ; i++ )
                px0[j] = px[j];
                p0[j] = p[j];
                h0[j] = h[j];
        for ( i=0; i<2048 ; i++ )
            rh0 = rh;
        for ( i=0; i<LOOPS1 ; i++ )
            vxne0 = vxne;
        for ( i=0 ; i<7 ; i++ )
            for (j=0 ; j<LOOPS1 ; j++ )
                zr0[j] = zr[j];
                zu0[j] = zu[j];
                zv0[j] = zv[j];
                zz0[j] = zz[j];
                za0[j] = za[j];
        stb50 = stb5;
        xx0 = xx[0];
    return;
 *   parameters procedure for loop counts, Do spans, sumchecks, FLOPS   *
       long nloops[3][25] =
            { {0, LOOPS2, LOOPS1, LOOPS2, LOOPS2, LOOPS2, 64, 995, LOOPS4,
                   LOOPS1, LOOPS1, LOOPS2, LOOPS3, 64, LOOPS2, LOOPS1, 75,
                   LOOPS1, LOOPS4, LOOPS1, LOOPS3, LOOPS1, LOOPS1, LOOPS4, LOOPS2  },
              {0,  LOOPS1, LOOPS1, LOOPS1, LOOPS1, LOOPS1,  32, LOOPS1, LOOPS4,
                   LOOPS1, LOOPS1, LOOPS1, LOOPS4,  32, LOOPS1, LOOPS1,  40,
                   LOOPS1, LOOPS4, LOOPS1, LOOPS4,  50, LOOPS1, 100, LOOPS1    },
              {0,   27, 15, 27, 27, 27,  8, 21, 14,
                    15, 15, 27, 26,  8, 27, 15, 15,
                    15, 14, 15, 26, 20, 15, 14, 27           }  };
       long lpass[3][25] =
             { {0, 7, 67,  9, 14, 10,  3,  4, 10, 36, 34, 11, 12,
                  36, 2,  1,  25, 35,  2, 39,  1,  1, 11,  8,  5  },
               {0, 40, 40, 53, 70, 55,  7, 22,  6, 21, 19, 64, 68,
                   41, 10,  1, 27, 20,  1, 23,  8,  1,  7,  5, 31   },
               {0, 28, 46, 37, 38, 40, 21, 20,  9, 26, 25, 46, 48,
                   31,  8,  1, 14, 26,  2, 28,  7,  1,  8,  7, 23 } };
       double sums[3][25] =
         { 0.0,
         5.114652693224671e+04, 1.539721811668385e+03, 1.000742883066363e+01,
         5.999250595473891e-01, 4.548871642387267e+03, 4.375116344729986e+03,
         6.104251075174761e+04, 1.501268005625798e+05, 1.189443609974981e+05,
         7.310369784325296e+04, 3.342910972650109e+07, 2.907141294167248e-05,
         1.202533961842803e+11, 3.165553044000334e+09, 3.943816690352042e+04,
         5.650760000000000e+05, 1.114641772902486e+03, 1.015727037502300e+05,
         5.421816960147207e+02, 3.040644339351239e+07, 1.597308280710199e+08,
         2.938604376566697e+02, 3.549900501563623e+04, 5.000000000000000e+02
         { 0.0,
         5.253344778937972e+02, 1.539721811668385e+03, 1.009741436578952e+00,
         5.999250595473891e-01, 4.589031939600982e+01, 8.631675645333210e+01,
         6.345586315784055e+02, 1.501268005625798e+05, 1.189443609974981e+05,
         7.310369784325296e+04, 3.433560407475758e+04, 7.127569130821465e-06,
         9.816387810944345e+10, 3.039983465145393e+07, 3.943816690352042e+04,
         6.480410000000000e+05, 1.114641772902486e+03, 1.015727037502300e+05,
         5.421816960147207e+02, 3.126205178815431e+04, 7.824524877232093e+07,
         2.938604376566697e+02, 3.549900501563623e+04, 5.000000000000000e+01
         { 0.0,
         3.855104502494961e+01, 3.953296986903059e+01, 2.699309089320672e-01,
         5.999250595473891e-01, 3.182615248447483e+00, 1.120309393467088e+00,
         2.845720217644024e+01, 2.960543667875003e+03, 2.623968460874250e+03,
         1.651291227698265e+03, 6.551161335845770e+02, 1.943435981130448e-06,
         3.847124199949426e+10, 2.923540598672011e+06, 1.108997288134785e+03,
         5.152160000000000e+05, 2.947368618589360e+01, 9.700646212337040e+02,
         1.268230698051003e+01, 5.987713249475302e+02, 5.009945671204667e+07,
         6.109968728263972e+00, 4.850340602749970e+02, 1.300000000000000e+01
       double number_flops[25] = {0, 5., 4., 2., 2., 2., 2., 16., 36., 17.,
                                      9., 1., 1., 7., 11., 33.,10., 9., 44.,
                                      6., 26., 2., 17., 11., 1.};
       double now = 1.0;
       n = nloops[section][which];
       nspan[section][which] = n;
       n16 = nloops[section][16];
       nflops = number_flops[which];
       xflops[which] = (long)nflops;
       loop = lpass[section][which];
       xloops[section][which] = loop;
       loop = loop * mult;
       MasterSum = sums[section][which];
       count = 0;
       init(which);
 *                   Start timing first pass only                       *
       if (count2 == 0)
           //start_time();
       return 0;
   } // parameters
 *          check procedure to check accuracy of calculations           *
        long maxs = 16;
        double xm, ym, re, min1, max1;
        xm = MasterSum;
        ym = Checksum[section][which];
       if (xm * ym < 0.0)
           accuracy[section][which] = 0;
       else
           if ( xm == ym)
               accuracy[section][which] = maxs;
           else
               xm = fabs(xm);
               ym = fabs(ym);
               min1 = xm;
               max1 = ym;
               if (ym < xm)
                   min1 = ym;
                   max1 = xm;
               re = 1.0 - min1 / max1;
                                        (long)( fabs(log10(fabs(re))) + 0.5);
       return;
 *      iqranf procedure - random number generator for Kernel 14        *
    void iqranf()
        long   inset, Mmin, Mmax, nn, i, kk;
        double span, spin, realn, per, scale1, qq, dkk, dp, dq;
        long   seed[3] = { 256, 12491249, 1499352848 };
        nn = LOOPS2;
        Mmin = 1;
        Mmax = LOOPS2;
        kk = seed[section];
        inset= Mmin;
        span= Mmax - Mmin;
        spin= 16807;
        per= 2147483647;
        realn= nn;
        scale1= 1.00001;
        qq= scale1 * (span / realn);
        dkk= kk;
        for ( i=0 ; i<nn ; i++)
            dp= dkk*spin;
            dkk= dp - (long)( dp/per)*per;
            dq= dkk*span;
            ix = inset + (long)( dq/ per);
            if ((ix < Mmin) | (ix > Mmax))
                ix = inset + i + 1 * (long)qq;
        return;
    int i, j;
    int errors = 0;
    char chek1[30];
    char chek2[30];
    // Values Watcom
    double sumsOut[3][25] =
         { 0.0,
         5.114652693224671e+04, 1.539721811668384e+03, 1.000742883066364e+01,
         6.104251075174761e+04, 1.501268005625795e+05, 1.189443609974981e+05,
         1.202533961842804e+11, 3.165553044000335e+09, 3.943816690352044e+04,
         5.650760000000000e+05, 1.114641772902486e+03, 1.015727037502299e+05,
         5.421816960147207e+02, 3.040644339351238e+07, 1.597308280710200e+08,
         2.938604376566698e+02, 3.549900501563624e+04, 5.000000000000000e+02
         { 0.0,
         5.253344778937972e+02, 1.539721811668384e+03, 1.009741436578952e+00,
         6.345586315784055e+02, 1.501268005625795e+05, 1.189443609974981e+05,
         9.816387810944356e+10, 3.039983465145392e+07, 3.943816690352044e+04,
         6.480410000000000e+05, 1.114641772902486e+03, 1.015727037502299e+05,
         5.421816960147207e+02, 3.126205178815432e+04, 7.824524877232093e+07,
         2.938604376566698e+02, 3.549900501563624e+04, 5.000000000000000e+01
         { 0.0,
         3.855104502494961e+01, 3.953296986903060e+01, 2.699309089320672e-01,
         2.845720217644024e+01, 2.960543667875005e+03, 2.623968460874250e+03,
         3.847124199949431e+10, 2.923540598672009e+06, 1.108997288134785e+03,
         1.268230698051004e+01, 5.987713249475302e+02, 5.009945671204667e+07,
         6.109968728263973e+00, 4.850340602749970e+02, 1.300000000000000e+01
    // Values MS Visual C++
         { 0.0,
         5.114652693224671e+04, 1.539721811668385e+03, 1.000742883066364e+01,
         6.104251075174761e+04, 1.501268005625799e+05, 1.189443609974981e+05,
         1.202533961842805e+11, 3.165553044000335e+09, 3.943816690352044e+04,
         5.421816960147207e+02, 3.040644339351239e+07, 1.597308280710200e+08,
         2.938604376566698e+02, 3.549900501563623e+04, 5.000000000000000e+02
         { 0.0,
         6.345586315784055e+02, 1.501268005625799e+05, 1.189443609974981e+05,
         2.938604376566698e+02, 3.549900501563623e+04, 5.000000000000000e+01
         { 0.0,
         2.845720217644024e+01, 2.960543667875003e+03, 2.623968460874251e+03,
         5.152160000000000e+05, 2.947368618589361e+01, 9.700646212337041e+02,
    // Values Ubuntu GCC
    // (opt == 0)
         { 0.0,
         5.114652693224700e+04, 1.539721811668511e+03, 1.000742883066627e+01,
         5.999250595474077e-01, 4.548871642388569e+03, 4.375116344743279e+03,
         6.104251075174964e+04, 1.501268005627179e+05, 1.189443609975087e+05,
         7.310369784325996e+04, 3.342910972650542e+07, 2.907141426432280e-05,
         1.202533961843102e+11, 3.165553044001659e+09, 3.943816690352318e+04,
         5.650760000000000e+05, 1.114641772903105e+03, 1.015727037502807e+05,
         5.421816960150461e+02, 3.040644339316077e+07, 1.597308280710881e+08,
         2.938604376567110e+02, 3.549900501566216e+04, 5.000000000000000e+02
         { 0.0,
         5.253344778938000e+02, 1.539721811668511e+03, 1.009741436579191e+00,
         5.999250595474077e-01, 4.589031939602152e+01, 8.631675645346239e+01,
         6.345586315784147e+02, 1.501268005627179e+05, 1.189443609975087e+05,
         7.310369784325996e+04, 3.433560407476172e+04, 7.127569142936774e-06,
         9.816387817138181e+10, 3.039983465147583e+07, 3.943816690352318e+04,
     6.480410000000000e+05, 1.114641772903105e+03, 1.015727037502807e+05,
         5.421816960150461e+02, 3.126205178810877e+04, 7.824524877235231e+07,
         2.938604376567110e+02, 3.549900501566216e+04, 5.000000000000000e+01
         { 0.0,
         3.855104502494983e+01, 3.953296986903390e+01, 2.699309089321306e-01,
         5.999250595474077e-01, 3.182615248448286e+00, 1.120309393467609e+00,
         2.845720217644062e+01, 2.960543667877695e+03, 2.623968460874420e+03,
         1.651291227698378e+03, 6.551161335846556e+02, 1.943435981782704e-06,
         3.847124173932957e+10, 2.923540598700804e+06, 1.108997288135077e+03,
     5.152160000000000e+05, 2.947368618590745e+01, 9.700646212341645e+02,
         1.268230698051762e+01, 5.987713249471701e+02, 5.009945671206634e+07,
         6.109968728264812e+00, 4.850340602751722e+02, 1.300000000000000e+01
    // (opt == 2)
         { 0.0,
         5.114652693224706e+04, 1.539721811668509e+03, 1.000742883066623e+01,
         5.999250595474070e-01, 4.548871642388545e+03, 4.375116344743014e+03,
         6.104251075174961e+04, 1.501268005627157e+05, 1.189443609975086e+05,
         7.310369784325988e+04, 3.342910972650532e+07, 2.907141429123183e-05,
         1.202533961843096e+11, 3.165553044001604e+09, 3.943816690352310e+04,
         5.650760000000000e+05, 1.114641772903092e+03, 1.015727037502793e+05,
         5.421816960150400e+02, 3.040644339317274e+07, 1.597308280710857e+08,
         2.938604376567100e+02, 3.549900501566157e+04, 5.000000000000000e+02
         { 0.0,
         5.253344778938001e+02, 1.539721811668509e+03, 1.009741436579188e+00,
         5.999250595474070e-01, 4.589031939602133e+01, 8.631675645345986e+01,
         6.345586315784150e+02, 1.501268005627157e+05, 1.189443609975086e+05,
         7.310369784325988e+04, 3.433560407476163e+04, 7.127569145018442e-06,
         9.816387817138104e+10, 3.039983465147494e+07, 3.943816690352310e+04,
         6.480410000000000e+05, 1.114641772903092e+03, 1.015727037502793e+05,
         5.421816960150400e+02, 3.126205178811007e+04, 7.824524877235141e+07,
         2.938604376567100e+02, 3.549900501566157e+04, 5.000000000000000e+01
         { 0.0,
         3.855104502494984e+01, 3.953296986903387e+01, 2.699309089321297e-01,
         5.999250595474070e-01, 3.182615248448272e+00, 1.120309393467599e+00,
         2.845720217644062e+01, 2.960543667877650e+03, 2.623968460874420e+03,
         1.651291227698377e+03, 6.551161335846538e+02, 1.943435981782704e-06,
         3.847124173932906e+10, 2.923540598699676e+06, 1.108997288135067e+03,
         5.152160000000000e+05, 2.947368618590714e+01, 9.700646212341514e+02,
         1.268230698051747e+01, 5.987713249471802e+02, 5.009945671206567e+07,
         6.109968728264795e+00, 4.850340602751676e+02, 1.300000000000000e+01
    // (opt == 3)
         { 0.0,
         7.310369784325988e+04, 3.342910972650531e+07, 2.907141429123183e-05,
         { 0.0,
         9.816387817138106e+10, 3.039983465147494e+07, 3.943816690352310e+04,
         { 0.0,
    // Values Ubuntu GCC 64 Bit
         { 0.0,
         { 0.0,
         { 0.0,
    if (reliability)
        i = section;
        j = which;
        if (count2 == 1)
            failCount = 0;
            sumscomp[j] = sumsOut[j];
            sprintf(chek1, "%22.15e", Checksum[j]);
            sprintf(chek2, "%22.15e", sumscomp[j]);
            if (strcmp (chek1, chek2)  != 0)
                nsRes = TRUE;
                sumscomp[j] = Checksum[j];
                fprintf(outfile, " Section %d Test %2d pass %5ld Non-standard result was %s expected %s\n",
                                    i+1, j, count2, chek1, chek2);
        else
                compareFail = compareFail + 1;
                failCount = failCount + 1;
                if (compareFail == 1)
                    fprintf(outfile, " ERRORS - maximum of 5 reported per loop\n");
                if (failCount < 6)
                    fprintf(outfile, " Section %d Test %2d pass %5ld Different result was %s expected %s\n",
                    fflush(outfile);
    else
        for (i=0; i<3; i++)
            for (j=1; j<25; j++)
                sprintf(chek2, "%22.15e", sumsOut[j]);
                    errors = errors + 1;
                    fprintf(outfile, " Section %d Test %2d Non-standard result was %s expected %s\n",
                                        i+1, j, chek1, chek2);
        if (errors == 0)
            fprintf(outfile, " Numeric results were as expected\n");
        fprintf(outfile, "\n");
看了楼主的并发计算基准测试livermore_loops,谢谢分享   详情 回复 发表于 2022-12-2 07:33
1715
