4075|3
错误,使用MPLAB IDE编译程序时出现的错误 [复制链接]
碰到了这个错误,不知道如何解决,有人遇到过没?
Executing: "C:\Program Files\Microchip\MPLAB C32 Suite\bin\pic32-gcc.exe" -mprocessor=32MX460F512L -x c -c "D:\isr\hs_ir.c" -o"hs_ir.o" -MMD -MF"hs_ir.d" -D__DEBUG -g
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp/ccoTHVTd.s: Assembler messages:
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp/ccoTHVTd.s:2779: Error: symbol `__vector_dispatch_7' is already defined
Halting build on first failure as requested.
Debug build of project `d:\isr\test.mcp' failed.
LZ好厉害    afei8856  详情 回复 发表于 2010-4-2 04:11
79
symbol `__vector_dispatch_7' is already defined,应该是这个被重复定义了
79
检查一下你的程序有没有重复定义的变量
LZ好厉害    afei8856
