3270|0
88
Warning: Unable to do imports from schanError: Can't find import 84 in ceddk.dll [复制链接]
前辈们好!小弟遇到一下问题
我在移植wince的时候(5.0-》6.0)遇到一下问题
是否前辈遇到此类问题
Pass 1...
Warning: Unable to do imports from schannel.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from k.schannel.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from ipsec.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from ipsecsvc.dll to RSAENH.dll - will late bind
Error: Fatal import error in netui.dll
Warning: Unable to do imports from eapol.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from eapchap.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from crypt32.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from k.crypt32.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from cryptdll.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from k.cryptdll.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from credssp.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from k.credssp.dll to RSAENH.dll - will late bind
Warning: Unable to do imports from mstscax.dll to CREDUI.dll - will late bind
Warning: Unable to do imports from cetsc.exe to CREDUI.dll - will late bind
Fatal error hit, exiting...
makeimg: FATAL ERROR: Command returned non-zero exit code 1 (dec).
试着一些帖子上说的 config.bib中ram和kenerl 大小匹配方法去解决,但是无法解决
哪位前辈指点一二
谢谢
