2555|0
CC2430 RF接收问题请教。 [复制链接]
使用CC2430,在KEIL环境下DMA使用不了,直接使用RADIO中断,发送部分完成,但接收始终产生不了中断?
根据资料:接收到定界符后产生SFD中断,初始化部分程序如下:
// Clearing the RF interrupt flags and enable mask and enabling RF interrupts
   RFIF = 0;
   RFIM = 0;
   INT_SETFLAG(INUM_RF,INT_CLR);                                                //清除中断标志
   INT_ENABLE(INUM_RF,INT_ON);                                                         //允许RF中断
   // Setting the frequency and initialising the radio
   if(halRfConfig(lFrequency) == FALSE){                                 //RF硬件配置
      return FALSE;
   // Setting the number of bytes to assert the FIFOP flag
   IOCFG0 = 7;
   INT_SETFLAG(INUM_RFERR, INT_CLR);
   INT_ENABLE(INUM_RFERR, INT_ON);
   // Flushing both Tx and Rx FiFo. The flush-Rx is issued twice to reset the SFD.
   // Calibrating the radio and turning on Rx to evaluate the CCA.
   // SFD 开始帧定界符
   SRXON;
   SFLUSHTX;
   SFLUSHRX;
   SFLUSHRX;
   STXCALN;
   ISSTART;
   if(iType == RF_RX)
          ISFLUSHRX;   // Making sure that the rX FIFO is empty.
           ISFLUSHRX;   // Issuing the command twice to reset the SFD.
           RFIF &= ~IRQ_FIFOP;
        RFIM &= ~IRQ_SFD;
        INT_SETFLAG(INUM_RF, INT_CLR);                                         //清除RF标志
           // Turning on RX
           ISRXON;
        RFIM |= IRQ_SFD;
//        RFIM |= IRQ_FIFOP;
顺便问一下:在KEIL环境,为什么DAM中断无法实现??IAR没问题。
50分帮忙!!!
