按照网上的教程交叉编译了一个linux的内核,在下载到arm2440上运行不了。显示的输出信息为:
Read chip id = ec76
Nand flash status = c0, NandAddr=1
buf address :0x30008000
Set boot params = root=/dev/mtdblock2 load_ramdisk=0 init=/linuxrc console=ttySAC0 display=shp240 mem=64M devfs=mount
Linux version 2.6.12-h1940 (root@Decell-tts) (gcc version 3.4.5) #283 Wed Jun 24 12:37:07 HKT 2009
CPU: ARM920Tid(wb) [41129200] revision 0 (ARMv4T)
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Machine: SMDK2410
ATAG_INITRD is deprecated; please update your bootloader.
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C2440: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
S3C2410 Clocks, (c) 2004 Simtec Electronics
Built 1 zonelists
Kernel command line: root=/dev/mtdblock2 load_ramdisk=0 init=/linuxrc console=ttySAC0 display=shp240 mem=64M devfs=mount
irq: clearing pending ext status 00080200
irq: clearing subpending status 00000093
irq: clearing subpending status 00000092
PID hash table entries: 512 (order: 9, 8192 bytes)
timer tcon=00090000, tcnt a2c1, tcfg 00000200,00001000, usec 00001eb8
Console: colour dummy device 80x30
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 64MB = 64MB total
Memory: 61056KB available (2931K code, 745K data, 108K init)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C2440: Clock Support, UPLL 48.000 MHz
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
S3C2410 DMA Driver, (c) 2003-2004 Simtec Electronics
DMA channel 0 at c4800000, irq 33
DMA channel 1 at c4800040, irq 34
DMA channel 2 at c4800080, irq 35
DMA channel 3 at c48000c0, irq 36
NetWinder Floating Point Emulator V0.97 (double precision)
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
NTFS driver 2.1.22 [Flags: R/W].
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
yaffs Mar 23 2009 04:06:15 Installing.
Initializing Cryptographic API
--- s3c2410fb init ---!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
pxafb_probe start!!!!!!!!!!!!!!!!!!!!!!!!!!
VA=0xffc00000, PA=0x305c0000, size=0x00027000
Console: switching to colour frame buffer device 30x40
success to register framebuffer device: 0!!!
done probe!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
fb1: Virtual frame buffer device, using 1024K of video memory
c03ae1f8
c03ae244
c03ae290
c03ae2dc
c05fe204
c05fe004
c06c2e04
c06c2c04
c06c2a04
in s3c2410ts init()
success get major number!!!!!!
s3c2410-ts device driver MAJOR:253
success to get adc clock source!
base_addr = 0xc4962000
line 532 passed!
register s3c2410-ts driver success, return code is 0
S3C2410 RTC, (c) 2004 Simtec Electronics
c06c2804
s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
loop: loaded (max 8 devices)
nbd: registered device at major 43
ub: sizeof ub_scsi_cmd 68 ub_dev 2384 ub_lun 140
usbcore: registered new driver ub
dm9000 Ethernet Driver
eth0: dm9000 at c496e300,c4970304 IRQ 53 MAC: 00:12:34:56:78:90
Linux video capture interface: v1.00
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2410-nand: mapped registers at c4980000
s3c2410-nand: timing: Tacls 10ns, Twrph0 40ns, Twrph1 10ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit)
Scanning device for bad blocks
Creating 4 MTD partitions on "NAND 64MiB 3,3V 8-bit":
0x00000000-0x00040000 : "Bootload"
0x00040000-0x00200000 : "Kernel"
0x00200000-0x02000000 : "RootFileSystem"
0x02000000-0x04000000 : "ExtendFileSystem"
usbmon: debugs is not available
hello,enter new ohci-s3c2410.c
CLKDIVN = 00000005
CLKSLOW = 00000004
CLKCON = 00f2e770
UPLLCON = 00038022
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
usb usb1: Product: S3C24XX OHCI
usb usb1: Manufacturer: Linux 2.6.12-h1940 ohci_hcd
usb usb1: SerialNumber: s3c24xx
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.01:USB HID core driver
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 48 KHz
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
globalmem device init Enter!
we have major158
we have got a device number!
Fram i2c init Enter!
&i2cFramDriver = 0xc0352d94
i2cFramAttachAdapter = 0xc023b2a0
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c0004000
[00000000] *pgd=00000000
Internal error: Oops: 805 [#1]
Modules linked in:
CPU: 0
PC is at __memzero+0x24/0x80
LR is at __init_begin+0x3fff8000/0x2c
pc : [] lr : [<00000000>] Not tainted
sp : c0485f9c ip : 00000000 fp : c0485fb4
r10: 00000000 r9 : 00000000 r8 : 00000000
r7 : c03b36d8 r6 : c0352e78 r5 : c0352e78 r4 : 00000000
r3 : 00000000 r2 : 00000000 r1 : 0000000c r0 : 00000000
Flags: nzCv IRQs on FIQs on Mode SVC_32 Segment kernel
Control: C000717F Table: 30004000 DAC: 00000017
Process swapper (pid: 1, stack limit = 0xc0484194)
Stack: (0xc0485f9c to 0xc0486000)
5f80: c007daf4
5fa0: 09e00000 00000000 c0485fd8 c0485fb8 c001a9e0 c007dad8 09e00001 c0484000
5fc0: c001e7f0 00000000 00000000 c0485ff4 c0485fdc c00230d4 c001a910 00000000
5fe0: 00000000 00000000 00000000 c0485ff8 c003bce8 c0023064 6f636564 615f6564
Backtrace:
[] (cdev_init+0x0/0x58) from [] (framInit+0xe0/0x180)
r5 = 00000000 r4 = 09E00000
[] (framInit+0x0/0x180) from [] (init+0x80/0x1c4)
r7 = 00000000 r6 = 00000000 r5 = C001E7F0 r4 = C0484000
[] (init+0x0/0x1c4) from [] (do_exit+0x0/0xa94)
r6 = 00000000 r5 = 00000000 r4 = 00000000
Code: e52de004 e1a0c002 e1a0e002 e2511040 (a8a0500c)
<0>Kernel panic - not syncing: Attempted to kill init!
就这样死掉了,请问怎么才行啊?
