1531|2
47
上海航芯 ACM32F070开发板+触控功能评估板评估 - 第三篇 时钟和温度显示界面 [复制链接]
本测评实验使用RTC获取实时时间,使用I2C从板载传感器获取温度数据,将时间和温度像是在LCD屏幕上。
代码实现主要参考了SDK中LCD_TK和RTC 两个例程。SDK的架构设计还是不错的,添加新的driver文件都很方便。
本实验主要的实现代码如下:
void App_Test()
	uint32_t fu32_Seconds;
    uint32_t fu32_Days;
	float ff_getTempHum[2];
    uint16_t fu16_num_up, fu16_num_down;
	uint32_t fu32_Displayup[4]={0},fu32_Displaydown[4]={0},fu32_num_123567p[7]=0},fu32_num_col[2]={0},fu32_num_s=0;
	LCD_Config();
	BUZZER_Init();
    SHT30_Init();
	RTC_Handle.u32_ClockSource       = RTC_CLOCK_XTL;
	RTC_Handle.u32_Compensation =COMPENSATION_INCREASE;
    RTC_Handle.u32_CompensationValue = 0x05;
	HAL_RTC_Config(&RTC_Handle);
	gstr_Time_Set.u8_Hours   = 0x12;
	gstr_Time_Set.u8_Minutes = 0x30;
	gstr_Time_Set.u8_Seconds = 0x00;
	HAL_RTC_SetTime(&gstr_Time_Set);
	gstr_Date_Set.u8_Year    = 0x21;    // 2021
	gstr_Date_Set.u8_Month   = RTC_MONTH_MARCH;
	gstr_Date_Set.u8_Date    = 0x20;
	gstr_Date_Set.u8_WeekDay = RTC_WEEKDAY_FRIDAY;
	HAL_RTC_SetDate(&gstr_Date_Set);
	while (1)
		HAL_RTC_GetTime(&gstr_Time_Get);
		HAL_RTC_GetDate(&gstr_Date_Get);
		HAL_RTC_GetTime(&gstr_Time_Get_Again);
		if (gstr_Time_Get.u8_Seconds != gstr_Time_Get_Again.u8_Seconds)
			continue;
		if (fu32_Seconds != gstr_Time_Get.u8_Seconds)
			fu32_Seconds = gstr_Time_Get.u8_Seconds;
			//fu32_num_col[0] = 1;
			fu32_num_col[1] = ~fu32_num_col[1];
			//fu32_num_123567p[6] |=1;
			fu32_num_123567p[1] |=1;
			fu32_num_s |=S_DATA[1];
			fu32_num_s |=(S_DATA[5] | S_DATA[6] | S_DATA[7] | S_DATA[8]);
			fu32_num_s &=~S_DATA[0];
			fu32_num_s |=S_DATA[12];//S13_BATW,S14_BAT1,S15_BAT2,S16_BAT3
			fu32_num_s |=S_DATA[13];
			fu32_num_s |=S_DATA[14];
			fu32_num_s |=S_DATA[15];
			SHT30_Read_Dat(I2C_Handle,gu8_RxBuffer);
			SHT30_Read_Result(gu8_RxBuffer,ff_getTempHum);
			fu16_num_up=(uint16_t)(ff_getTempHum[0]*100);
			if(fu16_num_up>9999) fu16_num_up=9999;
			fu32_Displayup[0]=fu16_num_up/1000%10;
			fu32_Displayup[1]=fu16_num_up/100%10;
			fu32_Displayup[2]=fu16_num_up/10%10;
			fu32_Displayup[3]=fu16_num_up/1%10;
			fu32_Displaydown[0] = gstr_Time_Get.u8_Minutes/16%16;;
			fu32_Displaydown[1] = gstr_Time_Get.u8_Minutes/1%16;
			fu32_Displaydown[2] = gstr_Time_Get.u8_Seconds/16%16;
			fu32_Displaydown[3] = gstr_Time_Get.u8_Seconds/1%16;
       LCD_YR1618A_VIEW(fu32_Displayup,fu32_Displaydown,fu32_num_123567p,fu32_num_col,fu32_num_s);
Demo视频:
3-1
参考的SDK中LCD_TK和RTC 两个例程是官方提供的么   详情 回复 发表于 2022-10-26 08:38
6828
是的  详情 回复 发表于 2022-10-26 09:28
47
Jacktang 发表于 2022-10-26 08:38 参考的SDK中LCD_TK和RTC 两个例程是官方提供的么
是的
