2640
41
coooooooool
谢谢鼓励  详情 回复 发表于 2022-11-7 20:52
希望做一些大家觉得好用的东西!
3386
42
谢谢鼓励
的确好玩!  详情 回复 发表于 2022-11-8 07:48
2640
43
eagler8 发表于 2022-11-7 20:52 谢谢鼓励
的确好玩!
谢谢,这两天开始研究LED单元板......  详情 回复 发表于 2022-11-9 06:47
3386
44
等你好玩的东西出来  详情 回复 发表于 2022-11-9 10:15
2640
45
eagler8 发表于 2022-11-9 06:47 谢谢,这两天开始研究LED单元板......
等你好玩的东西出来
这个有的难度,老是不得要领  详情 回复 发表于 2022-11-11 07:31
希望做一些大家觉得好用的东西!
3386
46
xutong 发表于 2022-11-9 10:15 等你好玩的东西出来
这个有的难度,老是不得要领
3386
47
  【Arduino】168种传感器模块系列实验(资料代码+仿真编程+图形编程)
  实验一百七十七:Wemos D1 R32 ESP32开发板
  项目之四十七:快速傅里叶变换256位频谱仪
#include  "arduinoFFT.h"
#include <FastLED.h>
#define NUM_LEDS 256
#define LED_TYPE WS2812
#define COLOR_ORDER GRB
arduinoFFT FFT = arduinoFFT();
CRGB leds[NUM_LEDS];
#define CHANNEL 39
#define DATA_PIN 23
const uint8_t max_bright = 2;
const uint16_t samples = NUM_LEDS / 4;
const byte halfsamples = samples / 2;
uint8_t gHue;
int value;
double vReal[samples];
double vImag[samples];
char toData[halfsamples];
int pointJump[halfsamples];
int uJump[halfsamples];
int dJump[halfsamples];
int uValue;
int dValue;
int tValue;
int toDown = 0;
uint8_t toDownSpeed = 3;
int pointDown = 0;
uint8_t pointDownSpeed = 9;
void setup(){
  delay(100);
  Serial.println("Ready");
  FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  FastLED.setBrightness(max_bright);
void loop(){
  FastLED.clear();
  EVERY_N_MILLISECONDS(10) {
    gHue += 10;
  for (int i = 0; i < samples; i++)
    value = analogRead(CHANNEL);
    vReal[i] = value;
    vImag[i] = 0.0;
  FFT.Windowing(vReal, samples, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
  FFT.Compute(vReal, vImag, samples, FFT_FORWARD);
  FFT.ComplexToMagnitude(vReal, vImag, samples);
  for (int i = 0; i < halfsamples; i++)
    toData[i] = vReal[i + halfsamples / 2];
    toData[i] = constrain(toData[i], 0, 100);
    toData[i] = map(toData[i], 0, 100, 1, 7);
    uValue = toData[i];
    uJump[i]++;
    if (uValue > uJump[i])
      uValue = uJump[i];
    else
      uJump[i] = uValue;
    dValue = uValue;
    toDown++;
    if (toDown % toDownSpeed == 0)
      dJump[i]--;
      toDown = 0;
    if (dValue > pointJump[i])
      dJump[i] = dValue;
    else
      dValue = dJump[i];
    tValue = uValue;
    pointDown++;
    if (pointDown % pointDownSpeed == 0)
      pointJump[i]--;
      pointDown = 0;
    if (tValue > pointJump[i])
      pointJump[i] = tValue;
    else
      tValue = pointJump[i];
    fill_rainbow(leds + 8 * i, uValue, gHue, 30);
    fill_rainbow(leds + 8 * i, dValue, gHue, 30);
    fill_solid(leds + 8 * i + tValue, 1, CRGB::White);
  FastLED.show();
  delay(2);
3386
48
实验场景图
3386
49
实验场景图  动态图
3386
实验的视频记录
优酷:
B站:https://www.bilibili.com/video/BV1nD4y147xD/?vd_source=98c6b1fc23b2787403d97f8d3cc0b7e5
3386
51
实验的视频记录
优酷:https://v.youku.com/v_show/id_XNTkyMTA0MDkwMA==.html?spm=a2hcb.playlsit.page.1
B站:
