1643|1
1144
基于【EVAL-ADICUP360】的毫欧计-上位机设计 [复制链接]
本来是准备用一个4.3寸的触摸屏来显示实时结果的,但由于出了点问题,只能做上位机,这样进度能够快点。
界面如图所示:
通过串口将数据显示出来。
代码比较简单:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.IO.Ports;
using System.Threading;
using System.Reflection.Emit;
namespace Aducm360毫欧计
	public partial class Form1 : Form
		List<string> bf = new List<string>();
		int offset;
		int LastAD = 0;
		SerialPort port;
		public Form1()
			InitializeComponent();
		private void btnRefresh_Click(object sender, EventArgs e)
			ReloadComs();
		void ReloadComs() {
			cmbCom.Items.Clear();
			cmbCom.Items.AddRange(SerialPort.GetPortNames());
			if (cmbCom.Items.Count > 0)
				cmbCom.SelectedIndex = 0;
		private void Form1_Load(object sender, EventArgs e)
			ReloadComs();
		private void btnConnction_Click(object sender, EventArgs e)
			if (cmbCom.Text == "")
				return;
			if (port != null&&port.IsOpen)
				port.Close();
			port = new SerialPort(cmbCom.Text);
			port.BaudRate = 115200;
			port.DataReceived += Port_DataReceived;
			port.Open();
		private void Port_DataReceived(object sender, SerialDataReceivedEventArgs e)
			bf.Add(port.ReadExisting());
			var temp = new string(bf.SelectMany(n => n).ToArray());
			if (temp.EndsWith("\r\n")) {
				var  temp2 = temp.Split(new string[] { "\r\n" }, StringSplitOptions.RemoveEmptyEntries);
				try
					var num= UInt32.Parse(temp2.Last());
					//128
					LastAD =(int) num;
					bf.Clear();
				catch { }
		private void timer1_Tick(object sender, EventArgs e)
			if (LastAD == 0x001FFFFF)
				labAD.Text = "开路";
				labRes.Text = "开路";
				return;
			var new_value = LastAD - offset;
			labAD.Text = LastAD.ToString();
			labCal.Text = new_value.ToString();
			var res = 1200.0f / (float)0x001FFFFF * new_value;      //mV
			//实测电流 1.081mA
			labRes.Text =(0.001081f*res).ToString("0.0000毫欧 ")+ res.ToString("0.0000毫伏");		//1.081*r=v
		private void btnZero_Click(object sender, EventArgs e)
			offset = LastAD;
上位机界面挺简洁的   详情 回复 发表于 2022-10-27 08:44
6807
上位机界面挺简洁的
