3222|2
arm linux驱动make发生的错误,大家帮忙看看 [复制链接]
编的一个驱动,用的是2.6.22内核,交叉编译器是arm-linux-gcc 3.4.1。
下面是我的makefile文件:
KERNELDIR :=/home/arm/linux-2.6.22.19
PWD :=$(shell pwd)
CFLAGS =-D__KERNEL__ -DMODULE -I$(KERNELDIR)/include/
CROSS_COMPILE =/home/arm/3.4.1/bin/arm-linux-
CC =$(CROSS_COMPILE)gcc
obj-m := mydev_driver.o
mydev_driver.o : s3c2440_mydev.o
        $(CC) $(CFLAGS) -c  $^ -o $@
modules:
        $(MAKE) -C $(KERNELDIR) M=$(PWD) modules
modules_install:
        $(MAKE) -C $(KERNELDIR) M=$(PWD) modules_install
clean:
        rm -rf *.o *.ko *.mod.o *.mod.c
make的时候,提示的错误信息如下:
debian:/home/arm-drivers/mydev-drviver# make
/home/arm/3.4.1/bin/arm-linux-gcc -D__KERNEL__ -DMODULE -I/home/arm/linux-2.6.22.19/include/   -c -o s3c2440_mydev.o s3c2440_mydev.c
In file included from /home/arm/linux-2.6.22.19/include/linux/notifier.h:14,
                 from /home/arm/linux-2.6.22.19/include/linux/memory_hotplug.h:7,
                 from /home/arm/linux-2.6.22.19/include/linux/mmzone.h:466,
                 from /home/arm/linux-2.6.22.19/include/linux/gfp.h:4,
                 from /home/arm/linux-2.6.22.19/include/linux/slab.h:14,
                 from /home/arm/linux-2.6.22.19/include/linux/percpu.h:5,
                 from /home/arm/linux-2.6.22.19/include/asm-generic/local.h:4,
                 from /home/arm/linux-2.6.22.19/include/asm/local.h:1,
                 from /home/arm/linux-2.6.22.19/include/linux/module.h:19,
                 from s3c2440_mydev.h:7,
                 from s3c2440_mydev.c:1:
/home/arm/linux-2.6.22.19/include/linux/rwsem.h:24:65: asm/rwsem.h: No such file or directory
In file included from /home/arm/linux-2.6.22.19/include/linux/memory_hotplug.h:7,
/home/arm/linux-2.6.22.19/include/linux/notifier.h:62: error: field `rwsem' has incomplete type
In file included from /home/arm/linux-2.6.22.19/include/linux/sched.h:51,
                 from /home/arm/linux-2.6.22.19/include/asm/uaccess.h:14,
                 from s3c2440_mydev.h:13,
/home/arm/linux-2.6.22.19/include/linux/jiffies.h:33:3: #error You lose.
/home/arm/linux-2.6.22.19/include/linux/jiffies.h:225:31: division by zero in #if
In file included from /home/arm/linux-2.6.22.19/include/asm/uaccess.h:14,
/home/arm/linux-2.6.22.19/include/linux/sched.h:339: error: field `mmap_sem' has incomplete type
In file included from mac_headers.h:66,
                 from s3c2440_mydev.h:33,
2440_headers/2440lib.h:19:1: warning: "min" redefined
In file included from /home/arm/linux-2.6.22.19/include/linux/spinlock.h:53,
                 from /home/arm/linux-2.6.22.19/include/linux/module.h:9,
/home/arm/linux-2.6.22.19/include/linux/kernel.h:285:1: warning: this is the location of the previous definition
s3c2440_mydev.c: At top level:
s3c2440_mydev.c:225: error: storage size of `s3c2440_mydev_fops' isn't known
make: *** [s3c2440_mydev.o] Error 1
还有一些warning没列出来。
s3c2440_mydev.h中包含的前几个头文件是:
#include
#include
#include
#include
#include
#include
#include
我已经指定了内核源码的路径了,为什么会有这些错误呢?提示的错误都是在发生在内核代码里面。
2.6下驱动编译还能用-D__KERNEL__ -DMODULE选项吗?我把这个选项去掉错误就更多了。
大家帮忙看看,谢谢!
此帖出自Linux开发论坛
遇到过和lz相同的问题,无非是一些头文件找不到 当时我是进了目录,发现这些头文件不是不存在,而是路径错了,于是自己修改了,有几个头文件找不到的,到网上下了一个,然后编译就通过了。  详情 回复 发表于 2009-6-26 23:13
我想把驱动编译成可以insmod的模块。
此帖出自Linux开发论坛
此帖出自Linux开发论坛
