1534|5
1513
【上海航芯 ACM32F070开发板+触控功能评估板测评】+RTC电子时钟 [复制链接]
在ACM32F070内部配有RTC计时器,如使用段码LCD屏来显示会有时间内容显示不完整的问题。为此,可使用前面介绍的OLED屏来完成显示工作,其显示效果如图1和图2所示。
 图1  显示效果
 图2  显示效果
显示RTC时间设置与显示的函数为:
void RTC_Test(void)
            uint32_t fu32_Seconds;
            RTC_ConfigTypeDef RTC_Handle;
            RTC_TimeTypeDef  gstr_Time_Set;
            RTC_TimeTypeDef  gstr_Time_Get;
            RTC_TimeTypeDef  gstr_Time_Get_Again;
            RTC_DateTypeDef  gstr_Date_Set;
            RTC_DateTypeDef  gstr_Date_Get;
            RTC_Handle.u32_ClockSource       = RTC_CLOCK_XTL;
            RTC_Handle.u32_Compensation      = COMPENSATION_INCREASE;
            RTC_Handle.u32_CompensationValue = 0x05;
            HAL_RTC_Config(&RTC_Handle);
            gstr_Time_Set.u8_Hours   = 0x12;
            gstr_Time_Set.u8_Minutes = 0x30;
            gstr_Time_Set.u8_Seconds = 0x00;
            HAL_RTC_SetTime(&gstr_Time_Set);
            gstr_Date_Set.u8_Year    = 0x22;
            gstr_Date_Set.u8_Month   = RTC_MONTH_ OCTOBER;
            gstr_Date_Set.u8_Date    = 0x10;
            gstr_Date_Set.u8_WeekDay = RTC_WEEKDAY_ MONDAY;
            HAL_RTC_SetDate(&gstr_Date_Set);
            while (1)
                HAL_RTC_GetTime(&gstr_Time_Get);
                HAL_RTC_GetDate(&gstr_Date_Get);
                HAL_RTC_GetTime(&gstr_Time_Get_Again);
                if (gstr_Time_Get.u8_Seconds != gstr_Time_Get_Again.u8_Seconds)
                    continue;
                if (fu32_Seconds != gstr_Time_Get.u8_Seconds)
                    fu32_Seconds = gstr_Time_Get.u8_Seconds;
                    OLED_ShowNum(0,5,gstr_Time_Get.u8_Hours,2,16);
                    OLED_ShowNum(24,5,gstr_Time_Get.u8_Minutes,2,16);
                    OLED_ShowNum(48,5,gstr_Time_Get.u8_Seconds,2,16);
由于读取的RTC时间值是以十六进制数来输出的,因此需配置一个 相对应的数值实现函数,其内容如下:
void OLED_ShowNum(uint8_t x,uint8_t y,uint32_t num,uint8_t len,uint8_t size2)
    uint8_t t,temp;
    uint8_t enshow=0;
    for(t=0;t<len;t++)
        temp=(num/oled_pow(16,len-t-1))%16;
        if(enshow==0&&t<(len-1))
            if(temp==0)
                OLED_ShowChar(x+(size2/2)*t,y,' ',size2);
                continue;
            else enshow=1;
        OLED_ShowChar(x+(size2/2)*t,y,temp+'0',size2);
在此基础上,实现图示效果的主程序为:
int main(void)
    System_Init();
    GPIO_Test();
    app_OLED_Init();
    OLED_Init();
    OLED_Clear();
    OLED_ShowString(0,0,"ACM32F070",16);
    OLED_ShowString(0,2,"OLED & RTC",16);
    OLED_ShowString(0,5,"  :  :",16);
    RTC_Test();
    while (1);
必须的!   详情 回复 发表于 2022-10-20 11:59
7608
谢谢分享!期待后续!
感谢支持!!!  详情 回复 发表于 2022-10-19 15:42
默认摸鱼,再摸鱼。2022、9、28
1513
freebsder 发表于 2022-10-19 15:13 谢谢分享!期待后续!
感谢支持!!!
6968
老师的帖子每篇必看,工整,典型的教学帖!
感谢支持!!!  详情 回复 发表于 2022-10-20 09:10
1513
lugl4313820 发表于 2022-10-20 07:08 老师的帖子每篇必看,工整,典型的教学帖!
感谢支持!!!
6968
必须的!
