1614|1
92
泰凌微B91开发套件---freertos [复制链接]
一:叙述
       本来这篇是想做一个总结的,但是因为测评使用过程中出现的问题已经记录,并且在实际开发过程中要用到freertos实时系统,所以不再总结,而是在官方提供的freertos_demo中进行了更改,算是做一个小小的测试!
二:程序
            在FreeRTOSConfig.h文件中,将configTICK_RATE_HZ宏定义由500修改为了1000;
  • * @File main.c
  • * @brief This is the source file for B91m
  • * @author Driver Group
  • * @date 2019
  • * @par Copyright (c) 2019, Telink Semiconductor (Shanghai) Co., Ltd. ("TELINK")
  • * All rights reserved.
  • * Licensed under the Apache License, Version 2.0 (the "License");
  • * you may not use this file except in compliance with the License.
  • * You may obtain a copy of the License at
  • * http://www.apache.org/licenses/LICENSE-2.0
  • * Unless required by applicable law or agreed to in writing, software
  • * distributed under the License is distributed on an "AS IS" BASIS,
  • * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  • * See the License for the specific language governing permissions and
  • * limitations under the License.
  • #include "app_config.h"
  • #include "calibration.h"
  • #include <FreeRTOS.h>
  • #include <task.h>
  • #include <queue.h>
  • #include <timers.h>
  • #include <stdio.h>
  • #define timerTick 4
  • static TaskHandle_t test_handle=NULL;
  • static TimerHandle_t softWaveTimer=NULL;
  • static uint32_t MboxValue;
  • static void test_task(void *pvParameters){
  • uint32_t notifyValue;
  • while(1){
  • if(pdTRUE == xTaskNotifyWait((uint32_t )0x00,(uint32_t)0xffffffff,(uint32_t*)¬ifyValue,0)){
  • printf("Hello!\r\n");
  • if(notifyValue >= timerTick){
  • xTimerStop(softWaveTimer,0);
  • vTaskDelay(10);
  • (void)(pvParameters);
  • extern void vPortRestoreTask();
  • void pxSoftWaveTimer(TimerHandle_t xTimer)
  • uint32_t TimerID;
  • TimerID = (uint32_t)pvTimerGetTimerID(xTimer);//获取定时器ID
  • if(TimerID == 1){
  • xTaskNotify((TaskHandle_t )test_handle,(uint32_t )MboxValue,(eNotifyAction)eSetValueWithOverwrite);
  • MboxValue++;
  • * @brief This is main function
  • * @return none
  • int main (void)
  • sys_init(LDO_1P4_LDO_1P8, VBAT_MAX_VALUE_GREATER_THAN_3V6);
  • user_read_flash_value_calib();
  • CCLK_24M_HCLK_24M_PCLK_24M;
  • if(0 ){// deepRetWakeUp
  • vPortRestoreTask();
  • }else{
  • xTaskCreate( test_task,"test",configMINIMAL_STACK_SIZE,NULL,0,&test_handle );
  • softWaveTimer = xTimerCreate("softwaveTimer",1000,pdTRUE,(void*)1,pxSoftWaveTimer);
  • xTimerStart(softWaveTimer,0);
  • vTaskStartScheduler();
  • return 0;
三:现象
查看本帖全部内容,请登录或者注册
此帖出自无线连接论坛
这个总结好!   详情 回复 发表于 2022-10-20 07:18
7188
这个总结好!
此帖出自无线连接论坛
