175|0
65
Wallys industrial WiFi6 MiniPCIe Module/2T2R 2×2.4GHz 2x5GHz MT7915 MT7975 [复制链接]
MT7915+MT7975 Chipset
2.4GHz max 23dBm & 5GHz max 20dBm output power
IEEE 802.11ac / ax compliant & backward compatible with 802.11ax/ac/a/b/g/n
2×2 2.4G & 2×2 5G  MIMO Technology, up to 1.8Gbps Mini PCI Express edge connector
SupporttheFrequency2412MHz~2482MHz
SupporttheFrequency5180MHz~5825MHz
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing,Cyclic-Delay Diversity (CDD), Low-Density Parity Check  (LDPC) Codes,Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Supports Dynamic Frequency Selection (DFS)
CardsareindividuallycalibratedforQualityAssurance
  Wallys provides all services from r&d, design to production and post-maintenance. There can be a buyout or an unbuyout mode.
    China has a complete wireless communication industry group, which enables ODM manufacturers to obtain the supply of low-cost components. Years of reform and opening-up have made China an ideal low-cost manufacturing base. Compared with the rapid development of the market, ODM services which focus more on design capability and production experience become more competitive.
Lower production costs
Strong design capability
Rich production experience
Higher productivity
Complete after-sales service
Product Description
DR 7915 based on MT7915 + MT7975 Chipset is an enterprise wireless module integrated with 2x2 2.4G high power Radio module and 2x2 5G high power Radio module designed
specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment infactories, warehousese stablishment.
   Specifications
Chipset
MT7915+MT7975
Host Interface
Mini PCI Express 2.1
Antenna Connector
2 x UF.L
Frequency Range
2.4GHz: 2.412GHz to 2.472GHz
5GHz: 5.180GHz to 5.825GHz
Operating Voltage
3.3V DC
Power Consumption
TBD
Modulation Techniques
OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM
Environmental Temperature
Operating: -40°C to 70°C, Storage: -40°C to 90°C
Environmental Humidity, non-condensing
Operating: 5% to 95%, Storage: Max. 90%
ROHS Compliance
YES
Dimensions (W×H×D)
51mm × 30mm × 5.8mm
   RF Performance Table
Operating Mode
Data Rate
TX Power
Tolerance
1 Chain
2 Chains
2.4 GHz
802.11b
11Mbps
20dBm
23dBm
±2dB
2.4 GHz
802.11g
54Mbps
17dBm
20dBm
±2dB
2.4 GHz
802.11n HT20
MCS7
17dBm
20dBm
±2dB
2.4 GHz
802.11n HT40
MCS7
14dBm
17dBm
±2dB
Operating Mode
Data Rate
RX Sensitivity
Tolerance
2.4 GHz
802.11b
11Mbps
-96dBm
±2dB
2.4 GHz
802.11g
54Mbps
-93dBm
±2dB
2.4 GHz
802.11n HT20
MCS7
-89dBm
±2dB
2.4 GHz
802.11n HT40
MCS7
-86dBm
±2dB
Operating Mode
Data Rate
TXPower
Tolerance
1 Chain 2 Chain
   5 GHz
  802.11a
54Mbps 17dBm 20dBm ±2dB
   5 GHz
  802.11n/ac HT20
MCS8 15dBm 20dBm ±2dB
  5 GHz
  802.11n/ac HT40
MCS9 14dBm 17dBm ±2dB
  5 GHz
  802.11n/ac HT80
MCS9 11.5dBm 14.5dBm ±2dB
  5 GHz
  802.11n/ac HT20
MCS9 17dBm 20dBm ±2dB
  5 GHz
  802.11n/ac HT40
  5 GHz
  802.11n/ac HT80
MCS11 11dBm 14dBm ±2dB
Operating Mode Data Rate RX Sensitivity Tolerance
5 GHz
802.11a
54Mbps -80dBm ±2dB
5 GHz
802.11n/ac HT20
MCS8 -71dBm ±2dB
5 GHz
802.11n/ac HT40
MCS9 -68dBm ±2dB
5 GHz
802.11n/ac HT80
 MCS9 -65dBm ±2dB
5 GHz
802.11n/ac HT20
 MCS9 -61dBm ±2dB
5 GHz
802.11n/ac HT40
 MCS9  -58dBm ±2dB
5 GHz
802.11n/ac HT80
 MCS11 -55dBm ±2dB
   MiniPCIe Slot Pin Assignment
TOP Side
Bottom Side
PCIE_WAKE_L
VCC_3V3
BT_PCM_DO
GND
BT_PCM_DI
BT_PCM_CLK
PCIE_CLKREQ_L
BT_PCM_SYNC
GND
PTA_TX
PCIE_REFCLK_N
BT_RTS
PCIE_REFCLK_P
BT_CTS
GND
PTA_RX
Mechanical key
NC
GND
NC
WIFI_EN
21
GND
22
PCIE_RST_L
23
PCIE_TX_N
24
VCC_3V3
PCIE_TX_P
26
GND
27
GND
28
BT_RX
29
GND
PTA_WLAN_ACT
31
PCIE_RX_P
32
PTA_ZB_PRI
33
PCIE_RX_N
34
GND
GND
36
LED_WPS
37
GND
38
LED_BT
39
VCC_3V3
     (RESERVED)
GND
41
VCC_3V3
     (RESERVED)
42
PTA_ZB_ACT
43
GND
44
LED_WIFI_2.4G
45
LED_WIFI5
46
NC
47
NC
48
NC
49
NC
GND
51
BT_EN
52
VCC_3V3
Commercial processes and communications are all managed utilising wireless technologies, and the number of users, devices and apps are only going to increase.  Therefore, it is essential to have a robust, secure and high performing WiFi solution that is future-proofed, mobile, and scalable.  Not only is business WiFi vital for your workforce and organisation, it is now imperative for visitors to be able to access a secure guest wireless network.
Wallys  has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.  (Web:wallystech  com)
Skype/EMAIL:sales@wallystech.com
WEB:https://www.wallystech.com/
