6167|11
61
config.bib文件的问题。No room left in memory section, Image is too large。分不多了大家帮帮忙吧。 [复制链接]
一下是config.bib文件的内容
IF IMGMULTIBIN
IF BSP_DDR128MB
    ; Multibin + 128MB DDR configuration
    ARGS        80000000  00001000  RESERVED
    CHAIN       80001000  00001000  RESERVED
    XIPKERN     80002000  00500000  RAMIMAGE
    OEMDRIVER   80502000  00200000  NANDIMAGE
IF BSP_PCB_ZYLONITE_V1
    NK          80702000  02000000  NANDIMAGE
    RAM         80502000  07AEE000  RAM
    DISPLAY     87FF0000  00010000  RESERVED
ELSE
    NK          80702000  02A00000  NANDIMAGE
    RAM         80502000  079FE000  RAM
    DISPLAY     87F00000  00100000  RESERVED
ENDIF
ENDIF ; BSP_DDR128MB
ELSE ; IMGMULTIBIN
IF BSP_DDR128MB
    ; not Multibin, 128MB DDR configuration
    NK          80001000  02000000  RAMIMAGE
    RAM         82001000  05FEF000  RAM
ENDIF ;BSP_DDR128MB
ENDIF ; IMGMULTIBIN
CONFIG
    AUTOSIZE=ON
    KERNELFIXUPS=ON
    COMPRESSION=ON
    FSRAMPERCENT=0x0A0A0A0A
IF IMGMULTIBIN
    DLLADDR_AUTOSIZE=ON
    XIPSCHAIN=80001000
ENDIF
IF IMGPROFILER
    PROFILE=ON
ELSE
    PROFILE=OFF
ENDIF
; ROMFLAGS is a bitmask of options for the kernel
;   ROMFLAGS    0x0001      Disallow Paging
;   ROMFLAGS    0x0002      Not all KMode
;   ROMFLAGS    0x0010      Trust Module only
IF IMGTRUSTROMONLY
    IF IMGNOTALLKMODE
       ROMFLAGS=13
    ELSE
       ROMFLAGS=11
    ENDIF
ELSE
    IF IMGNOTALLKMODE
       ROMFLAGS=03
    ELSE
       ROMFLAGS=01
    ENDIF
ENDIF
; NOR nbo
;ROMSTART=97C00000
; ram image .nb0
ROMSTART=80001000
IF WINCEDEBUG=debug
; For DEBUG build, give it more ROM. Changes must be along with the Eboot\loader.h
    ROMSIZE=03000000
ELSE
    ROMSIZE=02000000
ENDIF WINCEDEBUG=debug
; NB0 file should contain image
ROMWIDTH=32
本文来自eeworld博客,转载请标明出处:http://blog.eeworld.net/sailorlyq/archive/2009/07/30/4394761.aspx
   问题解决一下三个端都进行了扩大。     XIPKERN    80002000  00500000  RAMIMAGE     OEMDRIVER  80502000  00200000  NANDIMAGE     NK          80702000  02000000  NANDIMAGE 但生成的镜像很吓人呀,六十多M。 这个俺就结贴了。 不过俺有遇到新问题了,这么大的东西下载不了。可以获得active target devices 。提示错误检查网络。 大侠们如果知道就发消息通知俺吧,谢谢了。   详情 回复 发表于 2009-8-3 17:47
错误报告是这样的。
Error: No room left in memory section.  Image is too large for defined regions.
  Region XIPKERN from 80002000 to 80502000, has grown to 8086eb14
Fatal error hit, exiting...
makeimg: FATAL ERROR: Command returned non-zero exit code 1 (dec).
上面说的比较明显了,XIPKERN。但不知道具体怎么改。我曾经试图改大,但是冲突了。
78
你的提示里面有这么一句:Region XIPKERN from 80002000 to 80502000, has grown to 8086eb14 ;而你在config.bib里面只给XIPKERN分配了00500000的大小,明显小于它要求的0086eb14;所以你需要将XIPKERN    80002000  00500000  RAMIMAGE更改为XIPKERN    80002000  00900000  RAMIMAGE;当然后面的OEMDRIVER、NK、RAM、DISPLAY对应的地址要相应的改变;看你上面的bib文件,地址分配比较乱啊
78
引用 2 楼 xingjling 的回复:
你的提示里面有这么一句:Region XIPKERN from 80002000 to 80502000, has grown to 8086eb14;而你在config.bib里面只给XIPKERN分配了00500000的大小,明显小于它要求的0086eb14;所以你需要将XIPKERN? ? 80002000? 00500000? RAMIMAGE更改为XIPKERN? ? 80002000???
ls高人 学习了
75
顺便问一下 lz是做pxa310的开发么?
77
空间太小把空间加大,注意地址不要有覆盖!!!
引用 4 楼 aaassd_cn 的回复:
PXA303 刚弄没多久。谢谢!
81
谢谢几位的指点,我的修改是这样的。
    OEMDRIVER   81002000  00200000  NANDIMAGE
    NK          81102000  02000000  NANDIMAGE
    RAM         80902000  06AEE000  RAM
ELSE
    NK          81102000  02A00000  NANDIMAGE
    RAM         80902000  069FE000  RAM
我感觉我的RAM和NANDIMAGE的修改应该是正确的,但DISPLAY哪项是什么呀?困惑。
而且感觉里面的这个if else分支方法有问题。
  IF BSP_DDR128MB
  ELSE ; IMGMULTIBIN
  IF BSP_DDR128MB
这两个BSP_DDR128MB
是不是条件重叠,第二个BSP_DDR128MB
能执行到吗?
57
DISPLAY那个段1M,应该是显存 有相关的.h文件 看看引用 查找A7F00000就知道了
58
重新做了修改,请大侠们检阅。
    OEMDRIVER   80902000  00200000  NANDIMAGE
    NK          81102000  03A00000  NANDIMAGE
    RAM         80902000  076EE000  RAM
ELSE
    RAM         80902000  075FE000  RAM
  ROMSIZE=03A00000
那个if else的问题是我看错了。文件没有错。
修改后出现错误
  Failed to find a range for data of size 611530
Error: Ran out of space in ROM for wince.nls
size 611530
   问题解决一下三个端都进行了扩大。
但生成的镜像很吓人呀,六十多M。
这个俺就结贴了。
