5806|3
77
串口ClearCommError问题。 [复制链接]
                    ClearCommError(hComm, ref dwErrorFlags, ref ComStat);
                    if (dwErrorFlags != 0)
                        PurgeComm(hComm, PURGE_RXCLEAR | PURGE_RXABORT);
                    if (ComStat.cbInQue >= 5)
                    ReadFile(hComm, rectmp, 5, ref BytesRead, ref ovlCommPort);
现在问题是,ComStat.cbInQue 有时候是0,但可以确认对方已经发出数据了。有时候是正确的.但
ComStat.cbInQue >0时,使用ReadFile去读取数据时,也不能读到数据.
BOOL WINAPI ClearCommError(   __in       HANDLE hFile,   __out_opt  LPDWORD lpErrors,   __out_opt  LPCOMSTAT lpStat ); Value Meaning CE_BREAK 0x0010 The hardware detected a break condition. CE_FRAME 0x0008 The hardware detected a framing error. CE_OVERRUN 0x0002 A character-buffer overrun has occurred. The next character is lost. CE_RXOVER 0x0001 An input buffer overflow has occurred. There is either no room in the input buffer, or a character was received after the end-of-file (EOF) character. CE_RXPARITY 0x0004 The hardware detected a parity error.   详情 回复 发表于 2010-4-22 10:28
90
                uint err = GetLastError();
ComStat.cbInQue 有数据来,但是使用readfile就是读不到数据.这是为什么?
err值为0x80000005
64
现在是dwErrorFlags =8,清掉读的数据了,现在不知道为什么会是8
  __in       HANDLE hFile,
Value Meaning
CE_BREAK
0x0010
CE_FRAME
0x0008
CE_OVERRUN
0x0002
CE_RXOVER
0x0001
CE_RXPARITY
0x0004
快来报名!
