3617|2
79
VIVI 的menuconfig 时 提示错误了,如何修改呢? [复制链接]
下了VIVI 后
先做如下操作:
[root@localhost vivi2410]# vi Makefile
LINUX_INCLUDE_DIR       = /usr/local/arm/2.95.3/arm-linux/sys-include
CROSS_COMPILE   = /usr/local/arm/2.95.3/bin/arm-linux-
ARM_GCC_LIBS    = /usr/local/arm/2.95.3/lib/gcc-lib/arm-linux/2.95.3
其中一个, 做make menuconfig
[root@localhost vivi2410]# make menuconfig
[root@localhost vivi]# make -C scripts/lxdialog all
make[1]: Entering directory `/vivi-fft/vivi/scripts/lxdialog'
make[1]: Leaving directory `/vivi-fft/vivi/scripts/lxdialog'
/bin/sh scripts/Menuconfig arch/config.in
Using defaults found in .config
Preparing scripts: functionsYour lxdialog utility does not exist
make: *** [menuconfig] Error 1
报错误一个
另一个的VIVI 操作也一样
make[1]: Entering directory `/vivi2410/scripts/lxdialog'
make[1]: Leaving directory `/vivi2410/scripts/lxdialog'
/bin/sh scripts/Menuconfig arch/Config.in
Preparing scripts: functions, parsing..............done.
能进入界面去,配置
Your kernel configuration changes were NOT saved.
第一个版本的VIVI ,哪里出错了呢???
自己顶下 结贴都没法子里   详情 回复 发表于 2009-4-4 14:57
自己顶下
90
自己顶下
结贴都没法子里
