5105|12
at2402程序的问题, [复制链接]
最近在学习《郭天祥老师10天学会51单片机和C语言》视频第9课最后留个课后作业:让两位数码管自动增长,当断电时自动存入AT24C02A,上电时还能自动在数码管上显示断电前的数字,并继续自动增长。以下是我写的程序,当上电时先显示“00”后在继续增长,不知为何,还请高手指教。[br]
#include  //52单片机头文件
#include
#define uint unsigned int    //宏定义
#define uchar unsigned char //宏定义
sbit sda=P3^7;
sbit scl=P3^6;
uchar numwe,ge,shi,temp,temp1,aa,t1,a;
uchar code table[]={
0xc0,0xf9,0xa4,0xb0,
0x99,0x92,0x82,0xf8,
0x80,0x98,0x88,0x80,
0xc6,0xc0,0x86,0x8e};  //0,1,2,3,4,5,6,7,8,9,a,b,c,e,f
uchar code tablewe[]={
0xfe,0xfd,0xfb,0xf7};
void delay()
void start()  //开始信号
        sda=1;
        delay();
        scl=1;
        delay();
        sda=0;
        delay();
void stop()   //停止
        sda=0;
        delay();
        scl=1;
        delay();
        sda=1;
        delay();
void respons()  //应答
        uchar i;
        scl=1;
        delay();
        while((sda==1)&&(i<250))i++;
        scl=0;
        delay();
void write_byte(uchar date)
        uchar i,temp1;
        temp1=date;
        for(i=0;i<8;i++)
                temp1=temp1<<1;
                scl=0;
            delay();
                sda=CY;
                delay();
                scl=1;
                delay();
        //        scl=0;
     //   delay();
        scl=0;
        delay();
        sda=1;
        delay();
uchar read_byte()
        uchar i,k;
        scl=0;
        delay();
        sda=1;
        delay();
        for(i=0;i<8;i++)
                scl=1;
                delay();
                k=(k<<1)|sda;
                scl=0;
                delay();
        return k;
void write_add(uchar address,uchar date)
        start();
        write_byte(0xa0);
        respons();
        write_byte(address);
        respons();
        write_byte(date);
        respons();
        stop();
uchar read_add(uchar address)
        uchar date;
        start();
        write_byte(0xa0);
        respons();
        respons();
        start();
        write_byte(0xa1);
        respons();
        date=read_byte();
        stop();
        return date;
void delay1(uint z)     //延时子函数
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void display(uchar ge,uchar shi)
        if(numwe==2)
                        numwe=0;
                        P2=tablewe[numwe];
                        P0=table[shi];
                        numwe++;
                        delay1(5);
                        P2=tablewe[numwe];
                        P0=table[ge];
                        numwe++;
                        delay1(5);
void init()
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
        sda=1;
        delay();
        scl=1;
        delay();
        temp=read_add(23);
void timer0() interrupt 1
        aa++;
void main()                    //主函数
        init();//初始化子程序
        while(1)
        if(aa==20)
                        aa=0;
                        temp++;
                        write_add(23,temp);
                        delay1(100);
                        if(temp==99)
                                        temp=0;
                        shi=temp%100/10;
                        ge=temp%10;
                display(ge,shi);
[br]
连接图[br]
[br]
我把正确答案给大家共享一下,谢谢huxinhui的指教。 #include #define uchar unsigned char char shu[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff}; char wei[4]={0xfe,0xfd,0xfb,0xf7}; char dis[4]={0x00,0x00,0x00,0x00}; char timedata[2]={0x00,0x00}; sbit sda=P3^7; sbit scl=P3^6; char ms50=0x00; void delay1ms(int t) {   int i,j;   for(i=0;i  详情 回复 发表于 2010-4-25 14:43
63
自己先顶一下
79
中断服务程序中得把当时的时间值放在EEPROM,然后再主函数的初始化程序上读EEPROM放时间的地址用显示代码刷一遍时间!
86
引用 2 楼 huxinhui 的回复:
看着有点复杂,能提供点代码,看看吗
82
留个邮箱
好,hanyouxi3@163.com
63
都没有人会吗??
EmF63D2as
NMYSvUIv7
53
实在不想动手, 帮你顶吧
78
收到你的邮件了,不知道怎么给你分
呵呵,点“结贴”……建议一下LZ(52内置了EEPROM,可以设置寄存器来使用它)不需要买个外围芯片,比较经济,学得也多
66
求24C02页写和连续读的函数
63
#include
sbit sda=P3^7;
sbit scl=P3^6;
char ms50=0x00;
  int i,j;
  for(i=0;i   for(j=0;j<100;j++);
scan()
  char k;
          dis[1]=timedata[0]%10;
        dis[0]=timedata[0]/10;
//          dis[2]=timedata[1]%10;
//        dis[3]=timedata[1]/10;
  for(k=0;k<2;k++)
    P0=shu[dis[k]];
        P2=wei[k];
        delay1ms(1);
//        P2=0xfd;
void delay()
void start()
  sda=1;
  delay();
  scl=1;
  delay();
  sda=0;
  delay();
void stop()
  sda=0;
  delay();
  scl=1;
  delay();
  sda=1;
  delay();
void respons()
  uchar i;
  scl=1;
  delay();
  scl=0;
  delay();
  uchar i,temp;
  temp=date;
  for(i=0;i<8;i++)
    temp=temp<<1;
        scl=0;
        delay();
    sda=CY;
        delay();
        scl=1;
        delay();
        scl=0;
        delay();
        sda=1;
        delay();
uchar read_byte()
        uchar i,k;
        scl=0;
        delay();
        sda=1;
        delay();
        for(i=0;i<8;i++)
          scl=1;
          delay();
          k=(k<<1)|sda;
          scl=0;
          delay();
        return k;
void delay1(uchar x)
   uchar a,b;
   for(a=x;a>0;a--)
   for(b=100;b>0;b--);
  start();
  write_byte(0xa0);
  respons();
  respons();
  write_byte(date);
  respons();
  stop();
  uchar date;
  start();
  write_byte(0xa0);
  respons();
  respons();
  start();
  write_byte(0xa1);
  respons();
  date=read_byte();
  stop();
  return date;
uchar shuju()
   uchar Time;
   Time=timedata[0]+timedata[1]*100;
   return Time;
void time(void) interrupt 1
   ET0=0;TR0=0;TH0=0x3c;TL0=0xb0;TR0=1;ms50++;
   if(ms50==20)
         ms50=0x00;timedata[0]++;
     if(timedata[0]==100)
           timedata[0]=0;timedata[1]++;
       if(timedata[1]==100)
             timedata[1]=0;
         write_add(12,shuju());
   ET0=1;
void init()
  uchar x;
  sda=1;
  delay();
  scl=1;
  delay();
  x=read_add(12);
  timedata[0]=x%100;
  timedata[1]=x/100;
  scan();
  delay1(1);
main()
        init();
        shuju();
        TMOD=0x01;
        TH0=0x3c;
        TL0=0xb0;
        TR0=1;
        ET0=1;
        EA=1;
   while(1)
        {scan();}
【直播时间】5月28日(周三)上午10:00
