3882|16
请教大侠:2440启动代码中函数ReadImageFromNand读起来有点费劲,能帮忙分析下吗? [复制链接]
具体函数如下:
TOC toc; // made global because it's too big for our tiny stack
DWORD ReadImageFromNand(DWORD dwEntry, DWORD dwSig)
    DWORD dwSectorsNeeded;
    DWORD dwSector, dwLength;         // Start Sector & Length
    DWORD dwRAM, i;
        //这里是如何从Nand读到DRAM的?
    if ( !FMD_ReadSector(TOC_SECTOR,        //起始page地址:TOC_SECTOR = BLOCK_TO_SECTOR(TOC_BLOCK)=32*1
                        (LPBYTE)&toc,        //要复制到的地址,一般为DRAM,不能等于0
                        NULL, 1) )
        Uart_SendString("ERR_DISK_OP_FAIL1\n");
        return ERR_DISK_OP_FAIL1;
        //VALID_TOC(&toc)是用来干什么的?
    if ( !VALID_TOC(&toc) ) {
        Uart_SendString("ERR_INVALID_TOC: ");
        Uart_SendDWORD(toc.dwSignature, TRUE);
        return ERR_INVALID_TOC;
        //这下面的基本上都读不懂
    if ( !(toc.id[dwEntry].dwImageType & IMAGE_TYPE_RAMIMAGE) ) {
        Uart_SendString("ERR_INVALID_FILE_TYPE: ");
        Uart_SendDWORD(toc.id[dwEntry].dwImageType, TRUE);
        return ERR_INVALID_FILE_TYPE;
    dwSectorsNeeded = toc.id[dwEntry].dwTtlSectors;                // xipkernel size = 0x9B4
        // Record The Total Sectors
        totalSec=toc.id[dwEntry].dwTtlSectors+toc.chainInfo.dwLength;
        Uart_SendString("Total Sectors:");
        Uart_SendDWORD(totalSec,TRUE);
        Uart_SendString("Sector addr on NAND: ");
        Uart_SendDWORD(toc.id[dwEntry].sgList[0].dwSector, TRUE);
    Uart_SendString("TotalSector: ");
    Uart_SendDWORD(dwSectorsNeeded, TRUE);
    dwRAM    = VIRTUAL_TO_PHYSICAL(toc.id[dwEntry].dwLoadAddress);
    JumpAddr = toc.id[dwEntry].dwJumpAddress ? VIRTUAL_TO_PHYSICAL(toc.id[dwEntry].dwJumpAddress) :
    // Load the disk image directly into RAM
    // .BUGBUG: recover from read failures
        Uart_SendString("Reading Kernel Image from NAND\r\n");
    i = 0;
        while (dwSectorsNeeded && i < MAX_SG_SECTORS)
        dwSector = toc.id[dwEntry].sgList.dwSector;
        dwLength = toc.id[dwEntry].sgList.dwLength;
                Uart_SendString("    dwSector: ");
                Uart_SendDWORD(dwSector, TRUE);
                Uart_SendString("    dwLength: ");
                Uart_SendDWORD(dwLength, TRUE);
                Uart_SendString("    dwRAM: ");
                Uart_SendDWORD(dwRAM, TRUE);
        // read each sg segment
        while (dwLength)
        {        //这里还有一个读NAND的函数?
            if ( !FMD_ReadSector(dwSector,
                                (LPBYTE)dwRAM,
                                NULL, 1) )
                Uart_SendString("ERR_DISK_OP_FAIL2: ");
                            dwSector++;
                                continue;
                    dwSector++;
                    dwLength--;
            dwRAM += SECTOR_SIZE;
            drawProcessBar(totalSec,currSec);        //显示启动进度条
        dwSectorsNeeded -= toc.id[dwEntry].sgList.dwLength;
        i++;
    //  We only do this if the dwRAM is not zero (The default tocblock1
    //  set the dwRAM to be 0)
    if (toc.chainInfo.dwLoadAddress == 0)
        return ERR_SUCCESS;
    // Load the Chain.bin stored from NAND to the SDRAM
        dwRAM = VIRTUAL_TO_PHYSICAL(toc.chainInfo.dwLoadAddress);                // 0x303c0000
        dwSectorsNeeded = toc.chainInfo.dwLength;                                                // 0x20
        dwSector = toc.chainInfo.dwFlashAddress;                                                // 0x103c0
    while(dwSectorsNeeded)
    {   //这里还有一个?
        if (!FMD_ReadSector(dwSector,
                            (LPBYTE) dwRAM,
                            NULL, 1) )
            Uart_SendString("Failed reading Chain.bin:");
                        dwSector++;
                        continue;
        dwSector++;
        dwSectorsNeeded--;
        return ERR_SUCCESS;
请问谁能帮提供一份2440的UMON的源代码程序吗? 即在ADS工程里面能够通过EBOOT列出一些菜单继而进行相关操作, 如通过USB下载NK,格式化FLASH等的源代码? 我邮箱:phosphor88@yahoo.cn 谁能提供给我一份,感激不尽!  详情 回复 发表于 2009-5-20 22:11
84
这段之前没细看过,得翻一下老bsp了。
你可以问问gooogleman,他对2440的研究很不错的。
TOC toc。我也对这个不了解,toc是干什么用的,好像还必须用到,我升级eboot.bin的时候,没有弄好它,就失败了,但是不清楚怎么弄呢?
86
VALID_TOC从字面上都可以明白,它就是判断TOC是否有效。这段代码其实不复杂,只要搞明白TOC,应该没什么困难的。第一次读的就是TOC的内容。
78
TOC 其实是 table of content的缩写。
其实就是用来组织nk.bin的。记得是个结构体,(去年看的了,但愿不要记错)
因为NK.bin 是微软自己搞的一套数据格式。不是裸体二进制,不能直接在内存运行。
TOC 正好对NK.bin的结构进行一些简单的描述。
楼主看代码 把所有相关代码放在一个路径,用sourceinsight看,什么都明白了。
这方面 网上很多人写了博客的,多看看吧。
这是用来给bootloader提取image中的pe文件用的。
pe文件是可以重定位的,有了这个ptoc,bootloader就可以知道nk.exe在哪,找到nk.exe的entry point并fixup,然后nk.exe会接着利用toc的chain去依次寻找kernel.dll等文件,获取entry point并fixup。
引用 5 楼 codewarrior 的回复:
所言极是。但是和PE文件又有点不同,不过都是换汤不换药的。
81
引用 6 楼 gooogleman 的回复:
nk.exe就是一个不折不扣的pe文件,只不过被打包进了一个“不知道天南地北”的大包裹NK.bin里面去了。bootloader面对这样一个大包裹,如果没有指点,是没办法去取到nk.exe并为其fixup的。pTOC的用处简言之,就四个字:顺藤摸瓜。
89
mark。
TOC一般都会在烧录程序前需要检查一下的。呵呵。
S&C社的东东烧录eboot的时候就要擦写一次 Erase and Reset TOC。然后再来烧录eboot。
codewarrior大牛已经讲的很明确了。一个chain的功能。链子将所有需要的东西链起来。呵呵。
65
仔细查了TOC的相关资料,发现它是用来描述ce内核镜像文件image的xipkernel段核心结构体。
typedef struct _TOC {
//和CSW中的认证域类似,只用来验证接下去内容的合法
DWORD       dwSignature;
//包含image的索引(我的是1)、启动delay时间、ip地址、MAC地址和掩码等
BOOT_CFG       BootCfg;
//用来描述3个之多的ce内核image数组,我用的是id[1]
IMAGE_DESCRIPTOR   id[MAX_TOC_DESCRIPTORS];
CHAININFO     chainInfo;
} TOC, *PTOC;                   // 512 字节
但是这里仍然有点模糊,不是那么清晰。
这里不一定非 得NK.bin才用到TOC吧!nk.bin只不过是对nk.nb0打包,加了些校验而已,如果要加载nk.nb0同样需要用到TOC,个人理解!
dwEntry=1:TOC结构体中使用ID[1]描述CE内核image.
    DWORD dwSectorsNeeded;                                //定义ce内核镜像文件image的xipkernel需要的扇区大小
    DWORD dwSector, dwLength;                 //定义起始扇区及长度
    DWORD dwRAM, i;                                                //定义DRAM的物理地址
        //这里是读取block1的第一个page,检查是否有坏块。
         //这个函数到底想做什么?将block1的page0的数据全读到&toc地址吗?
                        (LPBYTE)&toc,        //扇区数据buffer,从NandFlash中读出的每一个扇区的数据都存放在这个buffer中。
                        NULL,                        //NULL表示不读取扇区信息?
                        1) )                        //一次只读取一个扇区,即一个page = 512byte
        //这个函数是不是与上面的FMD_ReadSector函数有着一定的联系???
    i = 0;
        dwSector = toc.id[dwEntry].sgList.dwSector;        //计算xipkernel需要的扇区数量
        dwLength = toc.id[dwEntry].sgList.dwLength;        //计算xipkernel需要的长度
        while (dwLength)
        {        //校验NK存放扇区是否有坏块,如果有则自动读取下一个扇区
                  //这里又出现了一个FMD_ReadSector,是对存储NK的扇区进行校验吗?
                                (LPBYTE)dwRAM,
                                NULL, 1) )
                            dwSector++;
                                continue;
                    dwSector++;
                    dwLength--;
        i++;
        return ERR_SUCCESS;
        //为什么这里又出来了一个FMD_ReadSector???
                            (LPBYTE) dwRAM,
                            NULL, 1) )
                        dwSector++;
                        continue;
        dwSector++;
        dwSectorsNeeded--;
        return ERR_SUCCESS;
对这段程序仍然不是很懂,很高人继续指点指点!感激不尽!
84
_我就是没有使用TOC的。
我用的是NK.nb0文件,
使用NK.nb0很简单,什么TOC等等格式问题都不用考虑。
46
其他的呢?一并帮分析一下,讲解一下
66
FMD_ReadSector——读一个扇区而已。但是里面已经包含了ECC校验的功能。
。还有我的博客有FMD驱动分析。你去看看吧。
62
如果是RAM版的nk,eboot直接将所有的文件一股脑全扔到sdram里,这时是不需要TOC的,只要知道起始地址和长度即可。
但现在用的更多的是binfs格式的xip kernel,这种“需要时再加载”的方法,就需要知道各个文件在flash里的具体分布了。
不过在系统里用的又不一样,没细看。看过的dx解释一番。
83
借贵帖问个问题!DWORD ReadImageFromNand(DWORD dwEntry, DWORD dwSig)
我在mini2440上 用自带的Nboot 自己做的Eboot,NK,下载运行串口出现
** Downloading UNKNOWN image type ***
dwImageStart : 0x8c200000
dwImageLength: 0x1887850
LaunchAddr   : 0x8c201000
rom_offset=0x0.
Run eboot, JumpAddr = 0x30038000
WinCE NAND Boot v1.00
Oct 27 2008 16:11:22
dwEntry is 0x00000001
ERR_DISK_OP_FAIL1
Boot ERROR:0x00000001
这是为什么啊!可能什么地方不对,帮忙分析下!今天上网搜这个问题发现了这个帖子!
继续关注中!
66
FMD_ReadSector。。那就是这个FMD的这个函数除了问题呗。。返回了FALSE.是你的nand驱动的问题吧
谁能提供给我一份,感激不尽!
