2796|3
82
请大侠帮忙解决一下apc插入的问题 [复制链接]
问题:以下是apc插入代码,也就是在内核执行ring3级程序。用DDK编译后能够执行成功,即可以启动ring3级程序。但是在DriverStudio环境下,将此段代码作为一个功能模块时,编译无误。但在执行时,ring3级程序并没有成功启动,不知道什么原因?(驱动入口函数略)操作系统:XP。
代码如下:
#include "ntddk.h"
#include "ntifs.h"
typedef enum
    OriginalApcEnvironment,
    AttachedApcEnvironment,
    CurrentApcEnvironment
} KAPC_ENVIRONMENT;
void RunUserModeProcess(char* command_line);
NTSTATUS InstallUserModeApc(char* CommandLine, PKTHREAD pTargetThread, PEPROCESS pTargetProcess);
void ApcCreateProcess(PVOID NormalContext, PVOID SystemArgument1, PVOID SystemArgument2);
void ApcKernelRoutine( IN struct _KAPC *Apc, IN OUT PKNORMAL_ROUTINE *NormalRoutine,
IN OUT PVOID *NormalContext, IN OUT PVOID *SystemArgument1, IN OUT PVOID *SystemArgument2 );
void ApcCreateProcessEnd();
//内核中枚举explorer.exe进程,然后调用InstallUserModeApc函数。
PMDL pMdl = NULL;
        //PKEVENT pEvent;
        if (Apc)
                ExFreePool(Apc);
        //pEvent = (PKEVENT)*SystemArgument1;
        //KeSetEvent (pEvent,IO_NO_INCREMENT,FALSE);
        PRKAPC pApc = NULL; //Our APC
        //PKEVENT pEvent = NULL;
        PVOID pMappedAddress = NULL; //This is where the UserMode routine's code will be placed at
        ULONG dwSize = 0; //Size of code to be executed in Explorer's address space
        KAPC_STATE ApcState; // Needed for KeStackAttachProcess
        ULONG *data_addr=0; //just a helper to change the address of the 'push' instruction
        //in the ApcCreateProcess routine
        ULONG dwMappedAddress = 0; //same as above
        NTSTATUS Status = STATUS_UNSUCCESSFUL;
        if (!pTargetThread || !pTargetProcess)
                return STATUS_UNSUCCESSFUL;
        DbgPrint("Daytime: command_line = %s \n",CommandLine);
        //Allocate memory for our APC
        pApc = (PRKAPC) ExAllocatePool (NonPagedPool,sizeof (KAPC));
        if (!pApc)
                DbgPrint("Daytime: Failed to allocate memory for the APC structure \n");
                return STATUS_INSUFFICIENT_RESOURCES;
        //pEvent = (PKEVENT) ExAllocatePool (NonPagedPool,sizeof (KEVENT));
        //if (!pEvent)
        //        ExFreePool (pApc);
        //        return STATUS_INSUFFICIENT_RESOURCES;
        //Get the size of our UserMode code
        dwSize = (unsigned char*)ApcCreateProcessEnd-(unsigned char*)ApcCreateProcess;
        //Allocate an MDL describing our ApcCreateProcess' memory
        pMdl = IoAllocateMdl (ApcCreateProcess, dwSize, FALSE,FALSE,NULL);
        if (!pMdl)
                DbgPrint("Daytime: Failed to allocate MDL \n");
                ExFreePool (pApc);
        __try
                //Probe the pages for Write access and make them memory resident
                MmProbeAndLockPages (pMdl,KernelMode,IoWriteAccess);
        __except (EXCEPTION_EXECUTE_HANDLER)
                DbgPrint("Daytime: Exception during MmProbeAndLockPages \n");
                IoFreeMdl (pMdl);
                ExFreePool (pApc);
                //ExFreePool (pEvent);
        //Attach to the Explorer's address space
        KeStackAttachProcess(&(pTargetProcess->Pcb),&ApcState);
        //Now map the physical pages (our code) described by 'pMdl'
        pMappedAddress = MmMapLockedPagesSpecifyCache (pMdl,UserMode,MmCached,NULL,FALSE,NormalPagePriority);
        if (!pMappedAddress)
                DbgPrint("Daytime: Cannot map address \n");
                KeUnstackDetachProcess (&ApcState);
                IoFreeMdl (pMdl);
                ExFreePool (pApc);
        else
                DbgPrint("Daytime: UserMode memory at address: 0x%p \n",pMappedAddress);
        dwMappedAddress = (ULONG)pMappedAddress;
        // copy commandline
        memset ((unsigned char*)pMappedAddress + 163, 0, 260);
        memcpy ((unsigned char*)pMappedAddress + 163, CommandLine,strlen (CommandLine));
        //all done, detach now
        //Initialize the APC...
        //KeInitializeEvent(pEvent,NotificationEvent,FALSE);
        KeInitializeApc(pApc,pTargetThread,
                &ApcKernelRoutine,NULL,
                (PKNORMAL_ROUTINE) pMappedAddress, UserMode, (PVOID) NULL);
        //...and queue it
        if (!KeInsertQueueApc(pApc,NULL,NULL,0))
                DbgPrint("Daytime: Failed to insert APC \n");
                MmUnlockPages(pMdl);
                IoFreeMdl (pMdl);
                ExFreePool (pApc);
        //        ExFreePool(pEvent);
        else
                DbgPrint("Daytime: APC delivered \n");
        //is this a non-alertable thread?
        if(!pTargetThread->ApcState.UserApcPending)
                //if yes then alert it
                pTargetThread->ApcState.UserApcPending = TRUE;
        // apc is fired, wait event to signal completion
        //KeWaitForSingleObject (pEvent,Executive,KernelMode,FALSE,NULL);
        //DbgPrint("Daytime: Get the Event \n");
        // free event
        if(pMdl)
                IoFreeMdl (pMdl);
                pMdl = NULL;
        DbgPrint("Daytime: ApcKernelRoutine called. Memory freed. \n");
        return 0;
__declspec(naked) void ApcCreateProcess(PVOID NormalContext, PVOID SystemArgument1, PVOID SystemArgument2)
__asm{
; //代码略
void ApcCreateProcessEnd(){}
顶,新手  详情 回复 发表于 2009-3-17 09:42
帮顶
75
帮顶
64
顶,新手
