【花雕动手做】有趣好玩的音乐可视化项目(11)---WS2812幻彩LED灯带
实验程序四:MegunoLink音乐反应式24颗LED灯带
#include<FastLED.h>
#include<MegunoLink.h>
#include<Filter.h>
// define necessary parameters
#define N_PIXELS 24
#define MIC_PIN A0
#define LED_PIN D6 // labeled "D6" on the board
// the following parameters can be tweaked according to your audio levels
#define NOISE 50
#define TOP (N_PIXELS+2) // allow the max level to be slightly off scale
#define LED_TYPE WS2811
#define BRIGHTNESS 18 // a little dim for recording purposes
#define COLOR_ORDER GRB
// declare the LED array
CRGB leds[N_PIXELS];
// define the variables needed for the audio levels
int lvl = 0, minLvl = 0, maxLvl = 600; // tweak the min and max as needed
// instantiate the filter class for smoothing the raw audio signal
ExponentialFilter<long> ADCFilter(5,0);
void setup() {
// put your setup code here, to run once:
Serial.begin(115200);
// initialize the LED object
FastLED.addLeds<LED_TYPE,LED_PIN,COLOR_ORDER>(leds,N_PIXELS).setCorrection(TypicalLEDStrip);
FastLED.setBrightness(BRIGHTNESS);
void loop() {
// put your main code here, to run repeatedly:
// read the audio signal and filter it
int n, height;
n = analogRead(MIC_PIN);
// remove the MX9614 bias of 1.25VDC
n = abs(1023 - n);
// hard limit noise/hum
n = (n <= NOISE) ? 0 : abs(n - NOISE);
// apply the exponential filter to smooth the raw signal
ADCFilter.Filter(n);
lvl = ADCFilter.Current();
// // plot the raw versus filtered signals
// Serial.print(n);
// Serial.print(" ");
// Serial.println(lvl);
// calculate the number of pixels as a percentage of the range
// TO-DO: can be done dynamically by using a running average of min/max audio levels
height = TOP * (lvl - minLvl) / (long)(maxLvl - minLvl);
if(height < 0L) height = 0;
else if(height > TOP) height = TOP;
// turn the LEDs corresponding to the level on/off
for(uint8_t i = 0; i < N_PIXELS; i++) {
// turn off LEDs above the current level
if(i >= height) leds[i] = CRGB(0,0,0);
// otherwise, turn them on!
else leds[i] = Wheel( map( i, 0, N_PIXELS-1, 30, 150 ) );
FastLED.show();
CRGB Wheel(byte WheelPos) {
// return a color value based on an input value between 0 and 255
if(WheelPos < 85)
return CRGB(WheelPos * 3, 255 - WheelPos * 3, 0);
else if(WheelPos < 170) {
WheelPos -= 85;
return CRGB(255 - WheelPos * 3, 0, WheelPos * 3);
} else {
WheelPos -= 170;
return CRGB(0, WheelPos * 3, 255 - WheelPos * 3);
