2786|7
565
【N32L43x评测】6、软硬件I2C驱动0.96吋OLED [复制链接]
本文使用软硬件I2C驱动0.96吋OLED,先上一张图:
1、关于N32L43x的I2C接口
 两路i2c,本文使用i2c1。
2、开发板上I2C的引脚
 3、通用引脚复用为I2C
4、代码实现
(1)硬件i2c
void I2cInit(void)
    I2C_InitType i2c1_master;
    GPIO_InitType i2c1_gpio;
    RCC_EnableAPB1PeriphClk(RCC_APB1_PERIPH_I2C1, ENABLE);
    RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_AFIO, ENABLE);
    RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOB, ENABLE);
    /*PB8 -- SCL; PB9 -- SDA*/
    GPIO_InitStruct(&i2c1_gpio);
    i2c1_gpio.Pin               = GPIO_PIN_8 | GPIO_PIN_9;
    i2c1_gpio.GPIO_Slew_Rate    = GPIO_Slew_Rate_High;
    i2c1_gpio.GPIO_Mode         = GPIO_Mode_AF_OD;
    i2c1_gpio.GPIO_Alternate    = GPIO_AF4_I2C1;
    i2c1_gpio.GPIO_Pull         = GPIO_Pull_Up;
    GPIO_InitPeripheral(GPIOB, &i2c1_gpio);
    I2C_DeInit(I2C1);
    i2c1_master.BusMode     = I2C_BUSMODE_I2C;
    i2c1_master.FmDutyCycle = I2C_FMDUTYCYCLE_2;
    i2c1_master.OwnAddr1    = I2C_OWN_ADDRESS7;
    i2c1_master.AckEnable   = I2C_ACKEN;
    i2c1_master.AddrMode    = I2C_ADDR_MODE_7BIT;
    i2c1_master.ClkSpeed    = 100000; // 100K
    I2C_Init(I2C1, &i2c1_master);
    I2C_Enable(I2C1, ENABLE);
void OledWriteCmd(uint8_t var)
    while (I2C_GetFlag(I2C1, I2C_FLAG_BUSY));
    I2C_GenerateStart(I2C1, ENABLE);
	while (!I2C_CheckEvent(I2C1, I2C_EVT_MASTER_MODE_FLAG)); // EV5
    I2C_SendAddr7bit(I2C1, I2C_SLAVE_ADDRESS7, I2C_DIRECTION_SEND);
    while (!I2C_CheckEvent(I2C1, I2C_EVT_MASTER_TXMODE_FLAG));// EV6
    I2C_SendData(I2C1, 0x00);
	while (!I2C_CheckEvent(I2C1, I2C_EVT_MASTER_DATA_SENDING)); // EV8
	I2C_SendData(I2C1, var);
	while (!I2C_CheckEvent(I2C1, I2C_EVT_MASTER_DATA_SENDED));// EV8-2
	I2C_GenerateStop(I2C1, ENABLE);
void OledWriteData(uint8_t var)
    I2C_SendData(I2C1, 0x40);
(2)软件i2c
#define _SCL_PORT  GPIOB
#define _SCL_PIN   GPIO_PIN_8
#define _SDA_PORT  GPIOB
#define _SDA_PIN   GPIO_PIN_9
void _I2C_Init(void)
	//PB8:SCL  PB9:SDA
	i2c1_gpio.GPIO_Current      = GPIO_DC_12mA;
    i2c1_gpio.GPIO_Mode         = GPIO_Mode_Out_PP;
void _SDA_IN(void)
    i2c1_gpio.Pin               = GPIO_PIN_9;
    i2c1_gpio.GPIO_Mode         = GPIO_Mode_Input;
void _SDA_OUT(void)
void _I2C_Start(void)
	_SDA_OUT();
	GPIO_SetBits(_SDA_PORT,_SDA_PIN);  //SDA=1
	DelayUs(10);
	GPIO_SetBits(_SCL_PORT,_SCL_PIN);  //SCL=1
	DelayUs(10);
	GPIO_ResetBits(_SDA_PORT,_SDA_PIN);//SDA=0
	DelayUs(10);
	GPIO_ResetBits(_SCL_PORT,_SCL_PIN);//SCL=0
	DelayUs(10);
void _I2C_Stop(void)
	_SDA_OUT();
	DelayUs(10);
	DelayUs(10);
	DelayUs(10);
void _I2C_Ack(void)
	_SDA_OUT();
	DelayUs(5);
	DelayUs(5);
	GPIO_ResetBits(_SCL_PORT,_SCL_PIN); //SCL=0
void _I2C_NAck(void)
    DelayUs(10);
    DelayUs(10);
	DelayUs(10);
uint8_t _I2C_Wait_Ack(void)
	uint8_t ucErrTime=0;
#if 0
	SDA_IN();
	 GPIO_SetBits(_SDA_PORT,_SDA_PIN);  //释放总线
#else
	 _SDA_IN();
#endif
	DelayUs(5);
	DelayUs(5);
	while(GPIO_ReadInputDataBit(_SDA_PORT,_SDA_PIN))
		ucErrTime++;
		if(ucErrTime>250)
			_I2C_Stop();
			return 1;
	DelayUs(5);
	return 0;
uint8_t _I2C_Read_Byte(uint8_t ack)
	uint8_t i,rxdata=0;
#if 0
	_SDA_IN();
#else
	_SDA_IN();
#endif
	for(i=0;i<8;i++ )
		DelayUs(5);
		DelayUs(5);
		rxdata<<=1;
		if(GPIO_ReadInputDataBit(_SDA_PORT,_SDA_PIN))
			rxdata|=0x01;
		DelayUs(5);
    if (!ack)
		_I2C_NAck();//nACK
    else
		_I2C_Ack(); //ACK
    return rxdata;
void _I2C_Send_Byte(uint8_t txd)
	uint8_t i;
	_SDA_OUT();
	for(i=0;i<8;i++)
		if((txd&0x80)==0x80)
		else
		txd<<=1;
		DelayUs(5);
		DelayUs(5);
		DelayUs(5);
void _SSD1306_WriteCmd(uint8_t var)
	_I2C_Start();
	_I2C_Send_Byte(I2C_SLAVE_ADDRESS7); //write addr
	_I2C_Wait_Ack();
	_I2C_Send_Byte(0x00);
	_I2C_Wait_Ack();
	_I2C_Send_Byte(var);
	_I2C_Wait_Ack();
	_I2C_Stop();
void _SSD1306_WriteData(uint8_t var)
	_I2C_Start();
	_I2C_Wait_Ack();
	_I2C_Send_Byte(0x40);
	_I2C_Wait_Ack();
	_I2C_Wait_Ack();
	_I2C_Stop();
(3)OLED驱动相关
//SSD1306初始化
void OledInit(void)
  DelayMs(300);
  DelayMs(300);
  //SSD1306复位之后,默认的是页寻址方式
  SSD1306_WriteCmd(0xAE);//--display off
  SSD1306_WriteCmd(0x00);//--set low column address
  SSD1306_WriteCmd(0x10);//--set high column address
  SSD1306_WriteCmd(0x40);//--set start line address
  SSD1306_WriteCmd(0xB0);//--set page address
  SSD1306_WriteCmd(0x81);// contract control
  SSD1306_WriteCmd(0xFF);//--128
  SSD1306_WriteCmd(0xA1);//set segment re-map  0 to 127
  SSD1306_WriteCmd(0xA6);//set normal  display
  SSD1306_WriteCmd(0xA8);//set multiplex ratio(1 to 64)
  SSD1306_WriteCmd(0x3F);//--1/32 duty
  SSD1306_WriteCmd(0xC8);//Com scan direction
  SSD1306_WriteCmd(0xD3);//set display offset
  SSD1306_WriteCmd(0x00);//no offset
  SSD1306_WriteCmd(0xD5);//set display clock divide ratio/oscillator frequency
  SSD1306_WriteCmd(0x80);//
  SSD1306_WriteCmd(0xD8);//set area color mode off
  SSD1306_WriteCmd(0x05);//
  SSD1306_WriteCmd(0xD9);//Set Pre-Charge Period
  SSD1306_WriteCmd(0xF1);//
  SSD1306_WriteCmd(0xDA);//set com pin  hardware configuartion
  SSD1306_WriteCmd(0x12);//
  SSD1306_WriteCmd(0xDB);//set Vcomh
  SSD1306_WriteCmd(0x30);//0x20,0.77xVcc
  SSD1306_WriteCmd(0x8D);//set charge pump enable
  SSD1306_WriteCmd(0x14);//
  SSD1306_WriteCmd(0xAF);//--turn on Oled panel
//坐标设置:也就是在哪里显示
void OledSetPos(uint8_t x, uint8_t y)
  //以下3个寄存器只在页寻址的模式下有效
  SSD1306_WriteCmd(0xb0+y);             //页地址设置     0xb0~0xb7
  SSD1306_WriteCmd(((x&0xf0)>>4)|0x10); //列高位地址设置
  SSD1306_WriteCmd((x&0x0f));           //列低位地址设置
//开启Oled显示
void OledDisplayOn(void)
  SSD1306_WriteCmd(0X8D);  //SET DCDC命令
  SSD1306_WriteCmd(0X14);  //DCDC ON
  SSD1306_WriteCmd(0XAF);  //DISPLAY ON
//关闭Oled显示
void OledDisplayOff(void)
  SSD1306_WriteCmd(0X10);  //DCDC OFF
  SSD1306_WriteCmd(0XAE);  //DISPLAY OFF
//清屏函数,清完屏,整个屏幕是黑色的!和没点亮一样
void OledClear(void)
  uint8_t i,n;
  for(i=0;i<8;i++)
    SSD1306_WriteCmd (0xb0+i);    //设置页地址(0~7)
    SSD1306_WriteCmd (0x00);      //设置显示位置—列低地址
    SSD1306_WriteCmd (0x10);      //设置显示位置—列高地址
    for(n=0;n<128;n++)
      SSD1306_WriteData(0);
  } //更新显示
//在指定位置显示一个字符,包括部分字符
//x:0~127,y:0~7
//Char_Size:选择字体 16/12
////8*16的点阵,取模方式:阴码、逆向、列行式
void OledShowChar(uint8_t x,uint8_t y,uint8_t chr,uint8_t Char_Size)
  uint8_t c=0,i=0;
  c=chr-' ';//得到偏移后的值
  if(x>MAX_COLUMN-1)
    x=0;
    y=y+2;
  if(Char_Size ==16)
    for(i=0;i<8;i++)
	  OledSetPos(x+i,y);
      SSD1306_WriteData(Ascii_8x16[c]);//先写上半部分
    for(i=0;i<8;i++)
	  OledSetPos(x+i,y+1);
      SSD1306_WriteData(Ascii_8x16[c][i+8]);//后写下半部分
  else
    OledSetPos(x,y);
    for(i=0;i<6;i++)
      SSD1306_WriteData(Ascii_6x12[c]);
//显示一个字符串
void OledShowString(uint8_t x,uint8_t y,char *str,uint8_t Char_Size)
  unsigned char j=0;
  while (str[j]!='\0')
    OledShowChar(x,y,str[j],Char_Size);
    x+=8;
    if(x>120)
      x=0;
      y+=2;
    j++;//移动一次就是一个page,取值0-7
//显示汉字
//由于汉字是16*16大小的,所以最多显示4行汉字
//index:在汉字取模中的索引
void OledShowCN(uint8_t x,uint8_t y,uint8_t index)
  uint8_t t;
  OledSetPos(x,y);
  for(t=0;t<16;t++)
    SSD1306_WriteData(Hzk[index][t]);
  OledSetPos(x,y+1);
  for(t=0;t<16;t++)
    SSD1306_WriteData(Hzk[index][t+16]);
(4)OLED显示测试
void OledDisplayTest(void)
#if SOFT_I2C
	_I2C_Init();
#else
	I2cInit();
#endif
	OledInit();
	OledClear();
	OledShowString(40,2,(char *)("Nation"),16);
	OledShowString(40,4,(char *)("N32L43x"),16);
	OledShowCN(24,6,0);
	OledShowCN(40,6,1);
	OledShowCN(56,6,2);
	OledShowCN(72,6,3);
5、现象
请问官方的示例程序是在什么地方下的   详情 回复 发表于 2024-7-15 15:40
点赞 关注(1)
个人签名stm32/LoRa物联网:304350312
565
上传完整代码和字库
oled.c (11.02 KB, 下载次数: 12)
fontlib.h (410.04 KB, 下载次数: 6)
6562
是否有遇到ST的IIC通信卡死现象?国民科技的IIC过程是循环等待标志位的策略吗?
应该需要加入等超时的参数,楼主这里可能没有加进这个参数。  详情 回复 发表于 2022-9-6 16:13
测试的时候是没有卡死的  详情 回复 发表于 2022-7-14 10:17
565
秦天qintian0303 发表于 2022-7-14 09:33 是否有遇到ST的IIC通信卡死现象?国民科技的IIC过程是循环等待标志位的策略吗?
测试的时候是没有卡死的
明天参考楼主的程序测试一下,今天对照官方示例程序,I2C不稳定,会有卡住的情况;后面还专门给I2C引脚焊接了上拉电阻,也没有改善;同样的功能,使用其它MCU的硬件I2C就完全没有问题;问题还是在底层I2C这一块,上  详情 回复 发表于 2022-7-28 22:44
208
freeelectron 发表于 2022-7-14 10:17 测试的时候是没有卡死的
明天参考楼主的程序测试一下,今天对照官方示例程序,I2C不稳定,会有卡住的情况;后面还专门给I2C引脚焊接了上拉电阻,也没有改善;同样的功能,使用其它MCU的硬件I2C就完全没有问题;问题还是在底层I2C这一块,上层的配置,应用没问题……
个人签名We are a team and we work as a team !
7063
IIC的速度不开,感觉确实没有模拟IIC方便,细节修改会直观一点  详情 回复 发表于 2022-9-6 17:16
6562
lugl4313820 发表于 2022-9-6 16:13 应该需要加入等超时的参数,楼主这里可能没有加进这个参数。
在爱好的道路上不断前进,在生活的迷雾中播撒光引
xld0932 发表于 2022-7-28 22:44 明天参考楼主的程序测试一下,今天对照官方示例程序,I2C不稳定,会有卡住的情况;后面还专门给I2C引脚焊 ...
请问官方的示例程序是在什么地方下的
