301|0
65
wallys//IPQ6018 OPENWRT QCN9074 QCN9072 4G&5G 2.5Gbps Ethernet Port SFP [复制链接]
Support:QUECTEL RM500Q-GL&Support:QCN9074 WiFi 6E Card,802.11ax,IPQ6010 Support OpenWRT 2x2 2.4G&5G 2.5Gbps Ethernet Port SFP
Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook. welcome to consult.
EMAIL:sales@wallystech.com
Qualcomm-Atheros IPQ6010
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
CPU
CPU Frequency
Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory
1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
SFP Port 1x SFP port
NGFF Slot
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
SD Card Slot
1x SD Card Slot
USB /header
1x USB 2.0 Port
POE
24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack
24V power supply
LED header
FFC/FPC Connector
Serial Port
1x Serial Port 4 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
Bluetooth CSR8811 BLE 4.2
Nor Flash
32MB
Nand Flash
256MB
DDR
256MB~512MB
Dimension
185mm x 116mm
立即报名 | 2025 瑞萨电子工业以太网技术日即将开启!
预报从速,好礼等您拿~
