4065|2
VXWORKS 编译时出现的问题 [复制链接]
 can't find compiler component.
This is typically caused by the compiler not being able to find the
configuration file, ...\VERS\conf\dtools.conf file.
Reinstalling the tools might help.
make: *** [sysALib.o] Error 0x1
请重新安装下您的操作系统  详情 回复 发表于 2010-1-25 14:39
90
帮顶下。
请重新安装下您的操作系统
