183|0
65
wallys//IPQ6018,IPQ4019,IPQ4029,802.11ax,802.11ac Outdoor AP Plastic [复制链接]
DR-AP6018-S(Outdoor) is a 2x2 2.4G&5G high power Radio AP Router which including 1x DR6018-S Board;1 x  Onmi Antenna; 1 x POE Adapter(24V^1A~48V^0.6A);1 x Enclosure.
Planar Antenna
■  2 x 5G Antenna
■  5G: 16dbi
DRA25 Antenna
ElectricalProperties :
Frequency Range:2.4~2.5&5.15~5.85GHz
Impedance:50Ω
VSWR:2.0 Max (≤2.0)
Gain(peak):6±0.5dBi
Polarization:Linear; Vertical
Physical Properties :
Cable:RG-141 Cable
Connector:N-type PLUG
Antenna CAP:ABS
OperatingTemp:-40℃~+65℃
Storage Temp:-40℃~+75℃
CableTemp:<+250℃
Enclosure
■  Dimension: 275x140x48mm
■  UV Protected and Durable ABS Radome
■  IP67 Waterproof Level
■  Support Wallys’DR6018-S
CPU
Qualcomm-Atheros IPQ6010
CPU Frequency
Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory
1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
NGFF Slot
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
SD Card Slot
1x SD Card Slot(Option)
USB /header
1x USB 3.0 Port(Option)
POE
24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack
24V~48V power supply
LED header
2.0 pitch pin header
Serial Port
1x Serial Port 4 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
Nor Flash
8MB
Nand Flash
256MB
DDR
256MB~512MB
Dimension
125mm x 105mm x 20mm
