今天在开发板上移植了dm9000的kitl碰到的奇怪的问题
移植了dm9000到kitl当镜像下载完以后我看到了调试的画面,上面有detach device 和reset device 我喜欢了reset device 后想再attach device 就不行了 出来一个下载镜像的画面 但是在我的印象中这不应该啊 如果我每次调试都要下载镜像的话那和用串口调试有什么区别呢
还有就是我明明设置了dm9000在kitl时的mac地址可是重启后且没有地址了 以下是我的调试信息。我现在就是想确定一点我的kitl移植成功了吗
Microsoft Windows CE Ethernet Bootloader Common Library Version 1.1 Built Jun 25 2009 16:34:53
Microsoft Windows CE Bootloader for the Samsung SMDK2440 Version 2.4 Built Jun 16 2009
NOW IN InitDisplay
clkval_calc = 9
BP_Init
FMD::FMD_Init
FMD::FMD_Init - pBSPArgs->nfsblk = 0x0
FMD::FMD_Init - READ_REGISTER_BYTE(pNFSBLK) = 0x0
FMD::FMD_Init IPL .....
FMD::FMD_Init Done
MID = 0xec, DID = 0x76 4th Cycle : 0xa5
NUMBLOCKS : 512(0x200), SECTORSPERBLOCK = 256(0x100), BYTESPERSECTOR = 512(0x200)
wNUM_BLOCKS : 512(0x200)
Press [ENTER] to launch image stored on boot media, or [SPACE] to enter boot monitor.
Initiating image launch in 5 seconds. 4 seconds. 3 seconds. 2 seconds. 1 seconds. 0 seconds.
Launching image from boot media ...
OEMPlatformInit: IMAGE_TYPE_RAMIMAGE
IsValidMBR: MBR sector = 0x400
OpenPartition: Partition Exists=0x1 for part 0x21.
BP_SetDataPointer at 0x0
ReadData: Start = 0x0, Length = 0xf7d600.
Log2Phys: Logical 0x500 -> Physical 0x900
System ready!
Preparing for download...
OEMPreDownload
INFO: *** Device Name 'SMDK24400' ***
INFO: Using static IP address 12181.1.
INFO: Using subnet mask 25000.1.
waitforconnect
INFO: OEMLaunch: Jumping to Physical Address 0x30201000h (Virtual Address 0x80201000h)...
醀indows CE Kernel for ARM (Thumb Enabled) Built on Feb 8 2007 at 23:36:51
ProcessorType=0920 Revision=0
sp_abt=ffff5000 sp_irq=ffff2800 sp_undef=ffffc800 OEMAddressTable = 802010e8
TEST FOR EVER IN OEMINIT
DCache: 8 sets, 64 ways, 32 line size, 16384 size
ICache: 8 sets, 64 ways, 32 line size, 16384 size
TEST FOR IN BSPINTRINIT
BSPIntrEnableIrq NUMBER=2
BSPIntrEnableIrq NUMBER=14
IS IN KERNEL OAL INITDISPLAY
OALKitlStart : ETHERNET
INFO: Probe: DM9000 is detected.
DM9000: MAC Address: 0:0:0:0:0:0
KITL: *** Device Name SMDK24400 ***
WARN: KITL can't obtain IRQ for KITL device
WARN: KITL will run in polling mode
VBridge:: built on [Jul 3 2009] time [21:57:52]
)...TX = [16384] bytes -- Rx = [16384] bytes
NK add MAC: [0-0-0-0-0-0]
