4619|3
7121
【GD32F310G-START】USART 不定长接收 [复制链接]
【前言】前面有网友说进不了中断IDLE,这里附上工程,希望对他有帮助:
1、配置usart0:
void usart_config(void)
    /* enable GPIO clock */
    rcu_periph_clock_enable(RCU_GPIOA);
    /* enable USART clock */
    rcu_periph_clock_enable(RCU_USART0);
    /* connect port to USART0 tx */
    gpio_af_set(GPIOA, GPIO_AF_1, GPIO_PIN_9);
    /* connect port to USART0 rx */
    gpio_af_set(GPIOA, GPIO_AF_1, GPIO_PIN_10);
    /* configure USART tx as alternate function push-pull */
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_9);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, GPIO_PIN_9);
    /* configure USART rx as alternate function push-pull */
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_10);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, GPIO_PIN_10);
    /* configure USART */
    usart_deinit(USART0);
    usart_baudrate_set(USART0, 115200U);
    usart_receive_config(USART0, USART_RECEIVE_ENABLE);
    usart_transmit_config(USART0, USART_TRANSMIT_ENABLE);
    usart_dma_receive_config(USART0, USART_DENR_ENABLE);
    usart_dma_transmit_config(USART0, USART_DENT_ENABLE);
    usart_enable(USART0);
2、开启中断:
    \brief      configure NVIC
    \param[in]  none
    \param[out] none
    \retval     none
void nvic_config(void)
    nvic_irq_enable(USART0_IRQn, 0, 0);
3、配置DMA
void dma_config(void)
    dma_parameter_struct dma_init_struct;
    rcu_periph_clock_enable(RCU_DMA);
    /* deinitialize DMA channel2 (USART0 rx) */
    dma_deinit(DMA_CH2);
    dma_struct_para_init(&dma_init_struct);
    dma_init_struct.direction = DMA_PERIPHERAL_TO_MEMORY;
    dma_init_struct.memory_addr = (uint32_t)rxbuffer;
    dma_init_struct.memory_inc = DMA_MEMORY_INCREASE_ENABLE;
    dma_init_struct.memory_width = DMA_MEMORY_WIDTH_8BIT;
    dma_init_struct.number = 256;
    dma_init_struct.periph_addr = (uint32_t)&USART_RDATA(USART0);
    dma_init_struct.periph_inc = DMA_PERIPH_INCREASE_DISABLE;
    dma_init_struct.periph_width = DMA_PERIPHERAL_WIDTH_8BIT;
    dma_init_struct.priority = DMA_PRIORITY_ULTRA_HIGH;
    dma_init(DMA_CH2, &dma_init_struct);
    /* configure DMA mode */
    dma_circulation_disable(DMA_CH2);
    /* enable DMA channel2 */
    dma_channel_enable(DMA_CH2);
4、书写中断接收函数:
    \brief      this function handles USART RBNE interrupt request and TBE interrupt request
    \param[in]  none
    \param[out] none
    \retval     none
void USART0_IRQHandler(void)
    if(RESET != usart_interrupt_flag_get(USART0, USART_INT_FLAG_IDLE)) {
        /* clear IDLE flag */
        usart_interrupt_flag_clear(USART0, USART_INT_FLAG_IDLE);
        /* toggle the LED2 */
        gd_eval_led_toggle();
        /* number of data received */
        rx_count = 256 - (dma_transfer_number_get(DMA_CH2));
        receive_flag = 1;
        /* disable DMA and reconfigure */
        dma_channel_disable(DMA_CH2);
        dma_transfer_number_config(DMA_CH2, 256);
5、main函数:
int main(void)
    gd_eval_led_init();
    gd_eval_led_on();
    nvic_config();
    /* initialize DMA */
    dma_config();
    /* initialize USART */
    usart_config();
    /* wait IDLEF set and clear it */
    while(RESET == usart_flag_get(USART0, USART_FLAG_IDLE));
    usart_flag_clear(USART0, USART_FLAG_IDLE);
    usart_interrupt_enable(USART0, USART_INT_IDLE);
    /* wait the data is received and send to the hyperterminal */
    while(1) {
        if(1 == receive_flag) {
            for(tx_count = 0; tx_count < rx_count; tx_count++) {
                while(RESET == usart_flag_get(USART0, USART_FLAG_TBE));
                usart_data_transmit(USART0, rxbuffer[tx_count]);
            receive_flag = 0;
6、实验效果:
此帖出自GD32 MCU论坛
串口配置里面 IDIE没使能,这条语句能实现吗?if(RESET != usart_interrupt_flag_get(USART0, USART_INT_FLAG_IDLE))   详情 回复 发表于 2024-6-18 14:53
点赞(1) 关注
2853
管理员
谢谢分享,很用心呀
此帖出自GD32 MCU论坛
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
感谢呀,非常感谢检查!  详情 回复 发表于 2022-6-17 07:13
个人签名玩板看这里:
7121
okhxyyo 发表于 2022-6-16 22:37 谢谢分享,很用心呀
感谢呀,非常感谢检查!
此帖出自GD32 MCU论坛
此帖出自GD32 MCU论坛
